Dear Manjaro Support Team,
I installed the newest Community maintained Manjaro with cinnamon Desktop yesterday to my 15" Macbook Pro, mid-2010, using this .iso file: (https://download.manjaro.org/cinnamon/21.3.7/manjaro-cinnamon-21.3.7-220826-linux515.iso)
Everything seems to be running well except when the lid of the MacBook Pro is closed to suspend and reopen it. Nothing happens until I press the power button shortly. Then I hear a short sound (some beep sound), then my desktopβs background image appears frozen, and thatβs it. I have to reboot by pressing the power button for more than 3 seconds.
It is interesting when I set the βWhen the power button is pressed == Suspendβ on the Power Management panel, the system suspends and wakes up for another button press without any issues.
I checked a read all posts on this subject (Search results for 'macbook pro suspend' - Manjaro Linux Forum), but I couldnβt solve the issue.
If anyone of you could help me out I would very much appreciate it. Manjaro is my superb experience with Linux, and I like it much better than EndeavourOS.
System Information:
[b...s@mbp ~]$ neofetch
ββββββββββββββββββ ββββββββ b...s@mbp
ββββββββββββββββββ ββββββββ ----------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: MacBookPro6,2 1.0
ββββββββ ββββββββ Kernel: 5.15.81-1-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 1 hour, 3 mins
ββββββββ ββββββββ ββββββββ Packages: 1115 (pacman)
ββββββββ ββββββββ ββββββββ Shell: bash 5.1.16
ββββββββ ββββββββ ββββββββ Resolution: 1440x900, 1440x900
ββββββββ ββββββββ ββββββββ DE: Cinnamon 5.6.4
ββββββββ ββββββββ ββββββββ WM: Mutter (Muffin)
ββββββββ ββββββββ ββββββββ WM Theme: Mint-Y-Dark-Teal (Mint-Y)
ββββββββ ββββββββ ββββββββ Theme: Mint-Y-Dark-Teal [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: Papirus-Adapta-Nokto-Maia [GTK2/3]
Terminal: gnome-terminal
CPU: Intel i7 M 620 (4) @ 2.661GHz
GPU: NVIDIA GeForce GT 330M
GPU: Intel Core Processor
Memory: 1556MiB / 7874MiB
I am not using a SWAP partition as I have 8GB RAM installed.
β in detailed:
[b...s@mbp ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=193c9617-ea40-45b6-a493-c4e8551626aa rw quiet apparmor=1
Desktop: Cinnamon v: 5.6.4 tk: GTK v: 3.24.35 vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Apple product: MacBookPro6,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-F22586C8
Mobo: Apple model: Mac-F22586C8 v: MacBookPro6,2
serial: <superuser required> UEFI: Apple v: 99.0.0.0.0 date: 06/13/2019
ID-1: BAT0 charge: 76.3 Wh (100.0%) condition: 76.3/76.3 Wh (100.0%)
volts: 12.5 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 3
RAM: total: 7.69 GiB used: 2.97 GiB (38.6%)
Info: model: Intel Core i7 M 620 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1415 high: 1463 min/max: 1197/2661 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1463 2: 1309
3: 1463 4: 1428 bogomips: 21289
Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdtscp sep smx ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel
arch: Gen-5.75 process: Intel 45nm built: 2010 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0046
class-ID: 0300
Device-2: NVIDIA GT216M [GeForce GT 330M] vendor: Apple driver: nouveau
v: kernel non-free: series: 340.xx status: legacy (EOL) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-13 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: LVDS-2
empty: DP-2 bus-ID: 01:00.0 chip-ID: 10de:0a29 class-ID: 0300 temp: 56.0 C
Device-3: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 2-1.1:3
chip-ID: 05ac:8507 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: nouveau,crocus gpu: i915,nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 2880x900 s-dpi: 96 s-size: 762x238mm (30.00x9.37")
s-diag: 798mm (31.43")
Monitor-1: LVDS-1 mapped: LVDS-1-1 pos: right model: Apple Color LCD
built: 2009 res: 1440x900 hz: 60 dpi: 111 gamma: 1.2
size: 331x207mm (13.03x8.15") diag: 390mm (15.4") ratio: 16:10
modes: 1440x900
Monitor-2: LVDS-2 pos: primary,left model: Apple Color LCD built: 2009
res: 1440x900 hz: 60 dpi: 111 gamma: 1.2 size: 331x207mm (13.03x8.15")
diag: 390mm (15.4") ratio: 16:10 modes: max: 1440x900 min: 640x350
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Device-2: NVIDIA GT216 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0be2
class-ID: 0403
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:1684 class-ID: 0200
Device-2: Broadcom BCM43224 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4353 class-ID: 0280
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:8 chip-ID: 05ac:8218 class-ID: fe01
Local Storage: total: 715.41 GiB used: 10.47 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Verbatim model: Vi550 S3
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 916a scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZ7TY256HDHP-000L7
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 4L6Q scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 10.47 GiB (2.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 193c9617-ea40-45b6-a493-c4e8551626aa
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: F7BE-F9F5
ID-1: /dev/sdb1 maj-min: 8:17 size: 238.47 GiB fs: ext4 label: Data
uuid: 05e1ec54-7f40-4d8e-b874-9b2957d4444d
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
Hub-3: 1-1.1:3 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500
Device-1: 1-1.1.3:8 info: Apple Bluetooth Host Controller type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8218
class-ID: fe01
Device-2: 1-1.2:4 info: Apple Internal Keyboard/Trackpad (ISO)
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0237 class-ID: 0301
Device-3: 1-1.3:5 info: Apple Internal Memory Card Reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05ac:8403 class-ID: 0806 serial: <filter>
Hub-4: 2-0:1 info: Full speed or root hub ports: 8 rev: 2.0 speed: 480 Mb/s
Hub-5: 2-1:2 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 3 rev: 2.0
Device-1: 2-1.1:3 info: Apple Built-in iSight type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05ac:8507
Device-2: 2-1.2:4 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
System Temperatures: cpu: 62.0 C mobo: N/A gpu: nouveau temp: 56.0 C
Processes: 218 Uptime: 7h 36m wakeups: 20 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1115 libs: 299 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.23
