Hi,
By default, the headphone jack does not work. Everything is streamed through HDMI cord. However through the audio volume control, headphone appears to be an option but doesn’t work. I have tried various configuration on the audio settings changing stereo inputs and outputs and still can’t find the solution. Anyone know a solution to this?
I figured it out. In terminal type:
sudo alsamixer
Select rockchip sound device
Tap right key all the way till you see left headphone and right headphone. There will be a square above with label MM. Click on it with mouse and u should see 00. Do that for each of them. Then scroll back right and raise DAC to 100%. Then exit terminal. Select headphone jack in audio volume controller and everything should work.
I did notice that after a reboot, alsamixer configuration gets reset. Is there a way to save the alsamixer configuration after alteration?
Yes do this after making the changes in alsamixer
sudo alsactl store
Good Luck.
Thank you very much!
