RockPro64 dies after update
Hello :slight_smile:
I'm happy Manjaro has embraced the RockPro64!
Sadly, it stops working whenever i install all the updates.
No ethernet, no wifi, no display output.
These are the steps leading to the problem:
  • install KDE preview 1 (screen works, network works)
  • fix the mirror path /$arch/$repo -> /$repo/$arch
  • perform update
  • install the uboot-update
# dd if=/boot/idbloader.img of=/dev/mmcblkX seek=64 conv=notrunc
# dd if=/boot/u-boot.itb of=/dev/mmcblkX seek=16384 conv=notrunc
  • reboot
Then there's nothing..
Anybody else experiencing the same problem?
Install the new image (20.02.1).
Then do updates. It should work.
for anyone viewing this thread:
i'm waiting for a new SD card to arrive for testing because my 8GB SanDisk stopped working:
dd: error writing '/dev/mmcblk0': No space left on device
983028+0 records in
983027+0 records out
4026478592 bytes (4.0 GB, 3.7 GiB) copied, 92.1248 s, 43.7 MB/s
i've bought 2 new 16gb cards from pine64:
£ dd if=Manjaro-ARM-kde-plasma-rockpro64-20.02.1.img of=/dev/mmcblk0 bs=4096
[sudo] password for root:
983028+0 records in
4026478592 bytes (4.0 GB, 3.7 GiB) copied, 28.1669 s, 143 MB/s
£ dd if=Manjaro-ARM-kde-plasma-rockpro64-20.02.1.img of=/dev/mmcblk0 seek=983027 skip=983
027 bs=4096
1+0 records in
0+0 records out
0 bytes copied, 0.0239988 s, 0.0 kB/s
£ la -h /dev/mmcblk0
-rw-r--r-- 1 root root 3.8G Mar 24 13:54 /dev/mmcblk0
Mar 24 14:25:16 brot kernel: mmc0: new ultra high speed SDR104 SDHC card at address 1388
Mar 24 14:25:16 brot kernel: mmcblk0: mmc0:1388 USD00 14.7 GiB
Mar 24 14:25:16 brot kernel:  mmcblk0: p1
Surely, I must be doing something wrong - they can't both really only be 4Gb...
If anyone knows something i don't, please help me out <3
When they are plugged in, what does lsblk say in the SIZE column?
Thanks for your help? Where do i tip?
mmcblk0     179:0    0  14.7G  0 disk
└─mmcblk0p1 179:1    0  14.7G  0 part
I figured it out..
Sometimes, when the card is attached it doesn't start because of some voltage problems.
Without noticing that, I ran dd and created in file in /dev...
(and i was puzzled as too why the machine was constantly swapping / out of ram...)
with the new image, everything works even after the uboot upgrade!
<3
