Right click "Run with Nvidia GPU" not working in Cinnamon edition
I installed Bumblebee nvidia 430 drivers. When I try to launch an application by right clicking it in Cinnamon and selecting "Run with Nvidia GPU" the application launches without being used by the GPU. If I want it to run with the GPU I have to run it from the command line using optirun. For example "optirun darktable". Then it works. I don't want to have to run all applications manually from the command line. Does anyone have any idea why its not working from Cinnamon?
Host: Dell-Inspiron Kernel: 5.4.6-2-MANJARO x86_64 bits: 64
Desktop: Cinnamon 4.4.5 Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 7570 v: N/A
serial:
Mobo: Dell model: 0N2FW9 v: A00 serial: UEFI: Dell
v: 1.13.1 date: 12/10/2018
ID-1: BAT0 charge: 17.6 Wh condition: 17.6/42.0 Wh (42%)
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
L2 cache: 6144 KiB
Speed: 1321 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1999 2: 2000
3: 2000 4: 2000 5: 2001 6: 2000 7: 2000 8: 2002
Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: NVIDIA GM108M [GeForce MX130] driver: N/A
Display: x11 server: X.Org 1.20.6 driver: intel resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
v: 4.6 Mesa 19.3.1
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.6-2-MANJARO
driver: r8169
IF: enp2s0 state: down mac: 54:48:10:de:59:26
Device-2: Intel Wireless 7265 driver: iwlwifi
IF: wlp3s0 state: up mac: 34:e1:2d:26:eb:02
Local Storage: total: 1.03 TiB used: 7.82 GiB (0.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
ID-2: /dev/sdb vendor: LITE-ON model: CV8-8E128-11 SATA 128GB
ID-1: / size: 99.92 GiB used: 7.82 GiB (7.8%) fs: ext4 dev: /dev/dm-0
ID-2: swap-1 size: 16.92 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-1
System Temperatures: cpu: 42.0 C mobo: 38.0 C sodimm: 41.0 C
Fan Speeds (RPM): cpu: 0
Processes: 243 Uptime: 6h 52m Memory: 15.39 GiB used: 2.27 GiB (14.8%)
Shell: bash inxi: 3.0.37
