[ 0.307747] pci 0000:00:02.2: bridge window [mem 0xfd500000-0xfd5fffff]
[ 0.307820] pci 0000:03:00.0: [10ec:8852] type 00 class 0x028000
[ 0.307838] pci 0000:03:00.0: reg 0x10: [io 0x2000-0x20ff]
[ 0.307861] pci 0000:03:00.0: reg 0x18: [mem 0xfd400000-0xfd4fffff 64bit]
[ 0.307973] pci 0000:03:00.0: supports D1 D2
[ 0.307974] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.308112] pci 0000:00:02.3: PCI bridge to [bus 03]
[ 0.308114] pci 0000:00:02.3: bridge window [io 0x2000-0x2fff]
[ 0.308116] pci 0000:00:02.3: bridge window [mem 0xfd400000-0xfd4fffff]
[ 0.308182] pci 0000:04:00.0: [1002:164c] type 00 class 0x030000
[ 0.308192] pci 0000:04:00.0: reg 0x10: [mem 0x460000000-0x46fffffff 64bit pref]
[ 0.308199] pci 0000:04:00.0: reg 0x18: [mem 0x470000000-0x4701fffff 64bit pref]
[ 0.308203] pci 0000:04:00.0: reg 0x20: [io 0x1000-0x10ff]
[ 0.308208] pci 0000:04:00.0: reg 0x24: [mem 0xfd300000-0xfd37ffff]
[ 0.308216] pci 0000:04:00.0: enabling Extended Tags
[ 0.308226] pci 0000:04:00.0: BAR 0: assigned to efifb
[ 0.308261] pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.308292] pci 0000:04:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.308343] pci 0000:04:00.1: [1002:1637] type 00 class 0x040300
[ 0.308350] pci 0000:04:00.1: reg 0x10: [mem 0xfd3c8000-0xfd3cbfff]
[ 0.308369] pci 0000:04:00.1: enabling Extended Tags
[ 0.308395] pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.308450] pci 0000:04:00.2: [1022:15df] type 00 class 0x108000
[ 0.308462] pci 0000:04:00.2: reg 0x18: [mem 0xfd200000-0xfd2fffff]
[ 0.308471] pci 0000:04:00.2: reg 0x24: [mem 0xfd3cc000-0xfd3cdfff]
[ 0.308477] pci 0000:04:00.2: enabling Extended Tags
[ 0.308558] pci 0000:04:00.3: [1022:1639] type 00 class 0x0c0330
[ 0.308567] pci 0000:04:00.3: reg 0x10: [mem 0xfd000000-0xfd0fffff 64bit]
[ 0.308589] pci 0000:04:00.3: enabling Extended Tags
[ 0.308616] pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
[ 0.308670] pci 0000:04:00.4: [1022:1639] type 00 class 0x0c0330
[ 0.308680] pci 0000:04:00.4: reg 0x10: [mem 0xfd100000-0xfd1fffff 64bit]
[ 0.308702] pci 0000:04:00.4: enabling Extended Tags
[ 0.308729] pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
[ 0.308784] pci 0000:04:00.5: [1022:15e2] type 00 class 0x048000
[ 0.308791] pci 0000:04:00.5: reg 0x10: [mem 0xfd380000-0xfd3bffff]
[ 0.308810] pci 0000:04:00.5: enabling Extended Tags
[ 0.308835] pci 0000:04:00.5: PME# supported from D0 D3hot D3cold
[ 0.308888] pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300
[ 0.308895] pci 0000:04:00.6: reg 0x10: [mem 0xfd3c0000-0xfd3c7fff]
[ 0.308914] pci 0000:04:00.6: enabling Extended Tags
[ 0.308939] pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
[ 0.308994] pci 0000:00:08.1: PCI bridge to [bus 04]
[ 0.308997] pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
[ 0.308998] pci 0000:00:08.1: bridge window [mem 0xfd000000-0xfd3fffff]
[ 0.309001] pci 0000:00:08.1: bridge window [mem 0x460000000-0x4701fffff 64bit pref]
[ 0.309108] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.309163] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.309199] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.309249] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.309294] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.309328] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.309362] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.309397] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.309940] ACPI: EC: interrupt unblocked
[ 0.309941] ACPI: EC: event unblocked
[ 0.309946] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.309947] ACPI: EC: GPE=0x3
[ 0.309948] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
[ 0.309949] ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
[ 0.309986] iommu: Default domain type: Translated
[ 0.309987] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.309996] pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.309996] pci 0000:04:00.0: vgaarb: bridge control possible
[ 0.309996] pci 0000:04:00.0: vgaarb: setting as boot device
[ 0.309996] vgaarb: loaded
[ 0.309996] SCSI subsystem initialized
[ 0.309996] libata version 3.00 loaded.
[ 0.309996] ACPI: bus type USB registered
[ 0.309996] usbcore: registered new interface driver usbfs
[ 0.309996] usbcore: registered new interface driver hub
[ 0.309996] usbcore: registered new device driver usb
[ 0.309996] pps_core: LinuxPPS API ver. 1 registered
[ 0.309996] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.309996] PTP clock support registered
[ 0.309996] EDAC MC: Ver: 3.0.0
[ 0.309996] Registered efivars operations
[ 0.309996] NetLabel: Initializing
[ 0.309996] NetLabel: domain hash size = 128
[ 0.309996] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.309996] NetLabel: unlabeled traffic allowed by default
[ 0.309996] PCI: Using ACPI for IRQ routing
[ 0.312839] PCI: pci_cache_line_size set to 64 bytes
[ 0.313041] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.313042] e820: reserve RAM buffer [mem 0x09c00000-0x0bffffff]
[ 0.313043] e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
[ 0.313044] e820: reserve RAM buffer [mem 0xc0cd5000-0xc3ffffff]
[ 0.313045] e820: reserve RAM buffer [mem 0xc3235000-0xc3ffffff]
[ 0.313045] e820: reserve RAM buffer [mem 0xc4b7e000-0xc7ffffff]
[ 0.313046] e820: reserve RAM buffer [mem 0xce000000-0xcfffffff]
[ 0.313047] e820: reserve RAM buffer [mem 0x3ee300000-0x3efffffff]
[ 0.313076] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.313076] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.314598] clocksource: Switched to clocksource tsc-early
[ 0.318164] VFS: Disk quotas dquot_6.6.0
[ 0.318179] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.318266] AppArmor: AppArmor Filesystem Enabled
[ 0.318305] pnp: PnP ACPI init
[ 0.318494] system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
[ 0.318499] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.318500] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.318674] system 00:02: [io 0x0400-0x04cf] has been reserved
[ 0.318675] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.318676] system 00:02: [io 0x04d6] has been reserved
[ 0.318677] system 00:02: [io 0x0c00-0x0c01] has been reserved
[ 0.318678] system 00:02: [io 0x0c14] has been reserved
[ 0.318678] system 00:02: [io 0x0c50-0x0c52] has been reserved
[ 0.318679] system 00:02: [io 0x0c6c] has been reserved
[ 0.318680] system 00:02: [io 0x0c6f] has been reserved
[ 0.318681] system 00:02: [io 0x0cd0-0x0cdb] has been reserved
[ 0.318730] system 00:03: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.318731] system 00:03: [mem 0x00000000-0x01ffffff] could not be reserved
[ 0.318733] system 00:03: [mem 0xfec10000-0xfec1001f] has been reserved
[ 0.318734] system 00:03: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.318735] system 00:03: [mem 0xfed61000-0xfed613ff] has been reserved
[ 0.318736] system 00:03: [mem 0xfed80000-0xfed80fff] has been reserved
[ 0.318979] pnp: PnP ACPI: found 6 devices
[ 0.326330] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.326445] NET: Registered PF_INET protocol family
[ 0.326714] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.329064] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.329199] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.329394] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.329456] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.329563] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.329610] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.329654] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.329744] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.329750] NET: Registered PF_XDP protocol family
[ 0.329765] pci 0000:00:02.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.329789] pci 0000:00:02.3: BAR 15: assigned [mem 0x430000000-0x4301fffff 64bit pref]
[ 0.329793] pci 0000:00:02.1: PCI bridge to [bus 01]
[ 0.329797] pci 0000:00:02.1: bridge window [mem 0xfd600000-0xfd6fffff]
[ 0.329801] pci 0000:00:02.2: PCI bridge to [bus 02]
[ 0.329802] pci 0000:00:02.2: bridge window [io 0x3000-0x3fff]
[ 0.329805] pci 0000:00:02.2: bridge window [mem 0xfd500000-0xfd5fffff]
[ 0.329809] pci 0000:00:02.3: PCI bridge to [bus 03]
[ 0.329810] pci 0000:00:02.3: bridge window [io 0x2000-0x2fff]
[ 0.329812] pci 0000:00:02.3: bridge window [mem 0xfd400000-0xfd4fffff]
[ 0.329814] pci 0000:00:02.3: bridge window [mem 0x430000000-0x4301fffff 64bit pref]
[ 0.329828] pci 0000:00:08.1: PCI bridge to [bus 04]
[ 0.329829] pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
[ 0.329831] pci 0000:00:08.1: bridge window [mem 0xfd000000-0xfd3fffff]
[ 0.329833] pci 0000:00:08.1: bridge window [mem 0x460000000-0x4701fffff 64bit pref]
[ 0.329837] pci_bus 0000:00: resource 4 [mem 0x000a0000-0x000bffff window]
[ 0.329838] pci_bus 0000:00: resource 5 [mem 0x000c0000-0x000c1fff window]
[ 0.329839] pci_bus 0000:00: resource 6 [mem 0x000c2000-0x000c3fff window]
[ 0.329839] pci_bus 0000:00: resource 7 [mem 0x000c4000-0x000c5fff window]
[ 0.329840] pci_bus 0000:00: resource 8 [mem 0x000c6000-0x000c7fff window]
[ 0.329841] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000c9fff window]
[ 0.329842] pci_bus 0000:00: resource 10 [mem 0x000ca000-0x000cbfff window]
[ 0.329843] pci_bus 0000:00: resource 11 [mem 0x000cc000-0x000cdfff window]
[ 0.329843] pci_bus 0000:00: resource 12 [mem 0x000ce000-0x000cffff window]
[ 0.329844] pci_bus 0000:00: resource 13 [mem 0x000d0000-0x000d1fff window]
[ 0.329845] pci_bus 0000:00: resource 14 [mem 0x000d2000-0x000d3fff window]
[ 0.329846] pci_bus 0000:00: resource 15 [mem 0x000d4000-0x000d5fff window]
[ 0.329847] pci_bus 0000:00: resource 16 [mem 0x000d6000-0x000d7fff window]
[ 0.329847] pci_bus 0000:00: resource 17 [mem 0x000d8000-0x000d9fff window]
[ 0.329848] pci_bus 0000:00: resource 18 [mem 0x000da000-0x000dbfff window]
[ 0.329849] pci_bus 0000:00: resource 19 [mem 0x000dc000-0x000ddfff window]
[ 0.329850] pci_bus 0000:00: resource 20 [mem 0x000de000-0x000dffff window]
[ 0.329851] pci_bus 0000:00: resource 21 [mem 0x000e0000-0x000e1fff window]
[ 0.329852] pci_bus 0000:00: resource 22 [mem 0x000e2000-0x000e3fff window]
[ 0.329853] pci_bus 0000:00: resource 23 [mem 0x000e4000-0x000e5fff window]
[ 0.329853] pci_bus 0000:00: resource 24 [mem 0x000e6000-0x000e7fff window]
[ 0.329854] pci_bus 0000:00: resource 25 [mem 0x000e8000-0x000e9fff window]
[ 0.329855] pci_bus 0000:00: resource 26 [mem 0x000ea000-0x000ebfff window]
[ 0.329856] pci_bus 0000:00: resource 27 [mem 0x000ec000-0x000edfff window]
[ 0.329857] pci_bus 0000:00: resource 28 [mem 0x000ee000-0x000effff window]
[ 0.329858] pci_bus 0000:00: resource 29 [mem 0xd0000000-0xf7ffffff window]
[ 0.329859] pci_bus 0000:00: resource 30 [mem 0xfc000000-0xfdffffff window]
[ 0.329860] pci_bus 0000:00: resource 31 [mem 0x430000000-0xffffffffff window]
[ 0.329861] pci_bus 0000:00: resource 32 [io 0x0000-0x0cf7 window]
[ 0.329861] pci_bus 0000:00: resource 33 [io 0x0d00-0xffff window]
[ 0.329863] pci_bus 0000:01: resource 1 [mem 0xfd600000-0xfd6fffff]
[ 0.329864] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ 0.329865] pci_bus 0000:02: resource 1 [mem 0xfd500000-0xfd5fffff]
[ 0.329866] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.329867] pci_bus 0000:03: resource 1 [mem 0xfd400000-0xfd4fffff]
[ 0.329867] pci_bus 0000:03: resource 2 [mem 0x430000000-0x4301fffff 64bit pref]
[ 0.329869] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.329869] pci_bus 0000:04: resource 1 [mem 0xfd000000-0xfd3fffff]
[ 0.329870] pci_bus 0000:04: resource 2 [mem 0x460000000-0x4701fffff 64bit pref]
[ 0.330162] pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
[ 0.330191] pci 0000:04:00.3: extending delay after power-on from D3hot to 20 msec
[ 0.330412] pci 0000:04:00.4: extending delay after power-on from D3hot to 20 msec
[ 0.330484] PCI: CLS 32 bytes, default 64
[ 0.330495] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.330557] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.330558] pci 0000:00:00.2: PCI INT A: not connected
[ 0.330571] pci 0000:00:01.0: Adding to iommu group 0
[ 0.330576] Trying to unpack rootfs image as initramfs...
[ 0.330581] pci 0000:00:02.0: Adding to iommu group 1
[ 0.330587] pci 0000:00:02.1: Adding to iommu group 2
[ 0.330594] pci 0000:00:02.2: Adding to iommu group 3
[ 0.330600] pci 0000:00:02.3: Adding to iommu group 4
[ 0.330611] pci 0000:00:08.0: Adding to iommu group 5
[ 0.330615] pci 0000:00:08.1: Adding to iommu group 5
[ 0.330624] pci 0000:00:14.0: Adding to iommu group 6
[ 0.330629] pci 0000:00:14.3: Adding to iommu group 6
[ 0.330647] pci 0000:00:18.0: Adding to iommu group 7
[ 0.330652] pci 0000:00:18.1: Adding to iommu group 7
[ 0.330657] pci 0000:00:18.2: Adding to iommu group 7
[ 0.330664] pci 0000:00:18.3: Adding to iommu group 7
[ 0.330668] pci 0000:00:18.4: Adding to iommu group 7
[ 0.330674] pci 0000:00:18.5: Adding to iommu group 7
[ 0.330678] pci 0000:00:18.6: Adding to iommu group 7
[ 0.330683] pci 0000:00:18.7: Adding to iommu group 7
[ 0.330693] pci 0000:01:00.0: Adding to iommu group 8
[ 0.330699] pci 0000:02:00.0: Adding to iommu group 9
[ 0.330705] pci 0000:03:00.0: Adding to iommu group 10
[ 0.330716] pci 0000:04:00.0: Adding to iommu group 5
[ 0.330719] pci 0000:04:00.1: Adding to iommu group 5
[ 0.330722] pci 0000:04:00.2: Adding to iommu group 5
[ 0.330725] pci 0000:04:00.3: Adding to iommu group 5
[ 0.330728] pci 0000:04:00.4: Adding to iommu group 5
[ 0.330730] pci 0000:04:00.5: Adding to iommu group 5
[ 0.330734] pci 0000:04:00.6: Adding to iommu group 5
[ 0.332050] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.332055] AMD-Vi: Extended features (0x206d73ef22254ade): PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.332059] AMD-Vi: Interrupt remapping enabled
[ 0.332060] AMD-Vi: Virtual APIC enabled
[ 0.332060] AMD-Vi: X2APIC enabled
[ 0.332246] software IO TLB: tearing down default memory pool
[ 0.332918] LVT offset 0 assigned for vector 0x400
[ 0.341904] perf: AMD IBS detected (0x000003ff)
[ 0.341914] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.344560] Initialise system trusted keyrings
[ 0.344572] Key type blacklist registered
[ 0.344625] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.345256] zbud: loaded
[ 0.347897] Key type asymmetric registered
[ 0.347898] Asymmetric key parser 'x509' registered
[ 0.347912] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.347980] io scheduler mq-deadline registered
[ 0.347982] io scheduler kyber registered
[ 0.348005] io scheduler bfq registered
[ 0.348564] pcieport 0000:00:02.1: PME: Signaling with IRQ 26
[ 0.348656] pcieport 0000:00:02.2: PME: Signaling with IRQ 27
[ 0.348736] pcieport 0000:00:02.3: PME: Signaling with IRQ 28
[ 0.348749] pcieport 0000:00:02.3: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.348935] pcieport 0000:00:08.1: PME: Signaling with IRQ 29
[ 0.349001] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.351095] ACPI: AC: AC Adapter [AC] (off-line)
[ 0.351124] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.351137] ACPI: button: Power Button [PWRB]
[ 0.351155] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.356203] ACPI: button: Lid Switch [LID]
[ 0.356284] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.356427] ACPI: button: Sleep Button [SLPB]
[ 0.356505] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.356620] ACPI: button: Power Button [PWRF]
[ 0.356861] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1755
[ 0.356892] Monitor-Mwait will be used to enter C-1 state
[ 0.356902] ACPI: \_SB_.PLTF.C000: Found 3 idle states
[ 0.357106] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[ 0.357261] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[ 0.357412] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[ 0.357669] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[ 0.357975] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[ 0.358238] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[ 0.358578] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[ 0.358788] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[ 0.359025] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[ 0.359216] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[ 0.359501] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[ 0.359768] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[ 0.359924] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[ 0.360184] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[ 0.360459] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[ 0.360953] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.361421] ACPI: battery: Slot [BAT0] (battery present)
[ 0.362006] Non-volatile memory driver v1.3
[ 0.362009] Linux agpgart interface v0.103
[ 0.362113] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 0.363650] nvme 0000:01:00.0: platform quirk: setting simple suspend
[ 0.363684] nvme nvme0: pci function 0000:01:00.0
[ 0.363725] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.363730] ehci-pci: EHCI PCI platform driver
[ 0.363737] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.363739] ohci-pci: OHCI PCI platform driver
[ 0.363743] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.363765] usbcore: registered new interface driver usbserial_generic
[ 0.363767] usbserial: USB Serial support registered for generic
[ 0.363969] rtc_cmos 00:01: RTC can wake from S4
[ 0.364186] rtc_cmos 00:01: registered as rtc0
[ 0.364216] rtc_cmos 00:01: setting system clock to 2022-06-03T21:25:24 UTC (1654291524)
[ 0.364225] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.364866] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.365016] efifb: probing for efifb
[ 0.365028] efifb: showing boot graphics
[ 0.366309] efifb: framebuffer at 0x460000000, using 8128k, total 8128k
[ 0.366313] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.366314] efifb: scrolling: redraw
[ 0.366314] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.366385] fbcon: Deferring console take-over
[ 0.366387] fb0: EFI VGA frame buffer device
[ 0.366423] hid: raw HID events driver (C) Jiri Kosina
[ 0.366513] ashmem: initialized
[ 0.366600] drop_monitor: Initializing network drop monitor service
[ 0.366647] Initializing XFRM netlink socket
[ 0.366697] NET: Registered PF_INET6 protocol family
[ 0.408458] Freeing initrd memory: 8552K
[ 0.415883] Segment Routing with IPv6
[ 0.415888] RPL Segment Routing with IPv6
[ 0.415922] In-situ OAM (IOAM) with IPv6
[ 0.415972] NET: Registered PF_PACKET protocol family
[ 0.418503] microcode: CPU0: patch_level=0x08608103
[ 0.418520] microcode: CPU1: patch_level=0x08608103
[ 0.418551] microcode: CPU2: patch_level=0x08608103
[ 0.418563] microcode: CPU3: patch_level=0x08608103
[ 0.418593] microcode: CPU4: patch_level=0x08608103
[ 0.418608] microcode: CPU5: patch_level=0x08608103
[ 0.418638] microcode: CPU6: patch_level=0x08608103
[ 0.418655] microcode: CPU7: patch_level=0x08608103
[ 0.418675] microcode: CPU8: patch_level=0x08608103
[ 0.418692] microcode: CPU9: patch_level=0x08608103
[ 0.418696] microcode: CPU10: patch_level=0x08608103
[ 0.418706] microcode: CPU11: patch_level=0x08608103
[ 0.418733] microcode: CPU12: patch_level=0x08608103
[ 0.418756] microcode: CPU13: patch_level=0x08608103
[ 0.418783] microcode: CPU14: patch_level=0x08608103
[ 0.418796] microcode: CPU15: patch_level=0x08608103
[ 0.418809] microcode: Microcode Update Driver: v2.2.
[ 0.419431] resctrl: L3 allocation detected
[ 0.419435] resctrl: MB allocation detected
[ 0.419435] resctrl: L3 monitoring detected
[ 0.419441] IPI shorthand broadcast: enabled
[ 0.419453] sched_clock: Marking stable (418982934, 423028)->(424912286, -5506324)
[ 0.419941] registered taskstats version 1
[ 0.420762] Loading compiled-in X.509 certificates
[ 0.422872] Loaded X.509 cert 'Build time autogenerated kernel key: 44e1c42abf17943da1f3658949e0d628601db193'
[ 0.426459] zswap: loaded using pool zstd/z3fold
[ 0.427983] Key type ._fscrypt registered
[ 0.427986] Key type .fscrypt registered
[ 0.427987] Key type fscrypt-provisioning registered
[ 0.428032] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.428250] PM: Magic number: 10:826:448
[ 0.428526] RAS: Correctable Errors collector initialized.
[ 0.463726] nvme nvme0: 16/0/0 default/read/poll queues
[ 0.477402] nvme0n1: p1 p2
[ 0.479310] Freeing unused decrypted memory: 2036K
[ 0.479631] Freeing unused kernel image (initmem) memory: 1864K
[ 0.489954] Write protecting the kernel read-only data: 28672k
[ 0.490972] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.491375] Freeing unused kernel image (rodata/data gap) memory: 1396K
[ 0.519724] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.519730] rodata_test: all tests were successful
[ 0.519736] Run /init as init process
[ 0.519737] with arguments:
[ 0.519738] /init
[ 0.519738] with environment:
[ 0.519739] HOME=/
[ 0.519739] TERM=linux
[ 0.519740] BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
[ 0.635590] xhci_hcd 0000:04:00.3: xHCI Host Controller
[ 0.635632] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 1
[ 0.635760] xhci_hcd 0000:04:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 0.636111] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.636113] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.636114] usb usb1: Product: xHCI Host Controller
[ 0.636115] usb usb1: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 0.636116] usb usb1: SerialNumber: 0000:04:00.3
[ 0.636286] hub 1-0:1.0: USB hub found
[ 0.636292] hub 1-0:1.0: 4 ports detected
[ 0.636540] xhci_hcd 0000:04:00.3: xHCI Host Controller
[ 0.636545] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
[ 0.636549] xhci_hcd 0000:04:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.636569] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.636584] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.636586] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.636587] usb usb2: Product: xHCI Host Controller
[ 0.636588] usb usb2: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 0.636589] usb usb2: SerialNumber: 0000:04:00.3
[ 0.636708] hub 2-0:1.0: USB hub found
[ 0.636712] hub 2-0:1.0: 2 ports detected
[ 0.637082] xhci_hcd 0000:04:00.4: xHCI Host Controller
[ 0.637093] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 3
[ 0.637184] xhci_hcd 0000:04:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 0.637569] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.637572] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.637574] usb usb3: Product: xHCI Host Controller
[ 0.637575] usb usb3: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 0.637576] usb usb3: SerialNumber: 0000:04:00.4
[ 0.637814] hub 3-0:1.0: USB hub found
[ 0.637821] hub 3-0:1.0: 4 ports detected
[ 0.638066] xhci_hcd 0000:04:00.4: xHCI Host Controller
[ 0.638072] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
[ 0.638075] xhci_hcd 0000:04:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.638105] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.638119] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.638121] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.638122] usb usb4: Product: xHCI Host Controller
[ 0.638123] usb usb4: Manufacturer: Linux 5.15.41-1-MANJARO xhci-hcd
[ 0.638124] usb usb4: SerialNumber: 0000:04:00.4
[ 0.638244] hub 4-0:1.0: USB hub found
[ 0.638249] hub 4-0:1.0: 2 ports detected
[ 0.639243] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 0.642068] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.642100] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.658925] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.806770] fbcon: Taking over console
[ 0.807002] Console: switching to colour frame buffer device 240x67
[ 0.855789] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 0.888191] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[ 0.888208] usb 3-3: new full-speed USB device number 2 using xhci_hcd
[ 0.932287] random: fast init done
[ 0.948946] systemd[1]: systemd 250.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 0.949167] systemd[1]: Detected architecture x86-64.
[ 0.950853] systemd[1]: Hostname set to <Laptop>.
[ 1.032892] usb 1-3: New USB device found, idVendor=13d3, idProduct=56fb, bcdDevice=20.04
[ 1.032902] usb 1-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.032906] usb 1-3: Product: Integrated Camera
[ 1.032908] usb 1-3: Manufacturer: Azurewave
[ 1.032911] usb 1-3: SerialNumber: 0000
[ 1.063217] usb 3-3: New USB device found, idVendor=04f3, idProduct=0c4b, bcdDevice=27.01
[ 1.063227] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.063231] usb 3-3: Product: ELAN:Fingerprint
[ 1.063234] usb 3-3: Manufacturer: ELAN
[ 1.158759] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.159990] systemd[1]: Created slice Slice /system/getty.
[ 1.160204] systemd[1]: Created slice Slice /system/modprobe.
[ 1.160354] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.160447] systemd[1]: Created slice User and Session Slice.
[ 1.160485] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1.160507] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.160607] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.160629] systemd[1]: Reached target Local Encrypted Volumes.
[ 1.160640] systemd[1]: Reached target Login Prompts.
[ 1.160650] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 1.160666] systemd[1]: Reached target Remote File Systems.
[ 1.160674] systemd[1]: Reached target Slice Units.
[ 1.160690] systemd[1]: Reached target Swaps.
[ 1.160702] systemd[1]: Reached target Local Verity Protected Volumes.
[ 1.160742] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.160897] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.161567] systemd[1]: Listening on Process Core Dump Socket.
[ 1.161643] systemd[1]: Listening on Journal Audit Socket.
[ 1.161689] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.161735] systemd[1]: Listening on Journal Socket.
[ 1.162208] systemd[1]: Listening on udev Control Socket.
[ 1.162248] systemd[1]: Listening on udev Kernel Socket.
[ 1.162751] systemd[1]: Mounting Huge Pages File System...
[ 1.163400] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.163778] systemd[1]: Mounting Kernel Debug File System...
[ 1.164171] systemd[1]: Mounting Kernel Trace File System...
[ 1.164774] systemd[1]: Starting Load AppArmor profiles...
[ 1.165555] systemd[1]: Starting Create List of Static Device Nodes...
[ 1.166757] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 1.167946] systemd[1]: Starting Load Kernel Module configfs...
[ 1.168476] systemd[1]: Starting Load Kernel Module drm...
[ 1.169124] systemd[1]: Starting Load Kernel Module fuse...
[ 1.169241] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 1.170644] systemd[1]: Starting Load Kernel Modules...
[ 1.171224] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.171274] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 1.171890] systemd[1]: Starting Coldplug All udev Devices...
[ 1.173039] systemd[1]: Mounted Huge Pages File System.
[ 1.173109] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.173144] systemd[1]: Mounted Kernel Debug File System.
[ 1.173181] systemd[1]: Mounted Kernel Trace File System.
[ 1.173287] systemd[1]: Finished Create List of Static Device Nodes.
[ 1.173573] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 1.173658] systemd[1]: Finished Load Kernel Module configfs.
[ 1.173875] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 1.173971] systemd[1]: Finished Load Kernel Module drm.
[ 1.174713] systemd[1]: Mounting Kernel Configuration File System...
[ 1.176343] systemd[1]: Mounted Kernel Configuration File System.
[ 1.176950] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null). Quota mode: none.
[ 1.177276] random: lvm: uninitialized urandom read (4 bytes read)
[ 1.178075] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 1.178222] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 1.179709] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 1.180685] systemd[1]: Starting Load/Save Random Seed...
[ 1.180748] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 1.181831] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 1.182522] usb 3-4: new full-speed USB device number 3 using xhci_hcd
[ 1.184023] fuse: init (API version 7.34)
[ 1.184753] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 1.184898] systemd[1]: Finished Load Kernel Module fuse.
[ 1.186036] systemd[1]: Mounting FUSE Control File System...
[ 1.188627] systemd[1]: Mounted FUSE Control File System.
[ 1.195560] IPMI message handler: version 39.2
[ 1.196737] audit: type=1400 audit(1654291525.329:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=357 comm="apparmor_parser"
[ 1.196746] audit: type=1400 audit(1654291525.329:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=357 comm="apparmor_parser"
[ 1.200803] ipmi device interface
[ 1.201906] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 1.201992] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 1.203709] systemd[1]: Starting Journal Service...
[ 1.205359] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 1.207635] systemd[1]: Finished Load Kernel Modules.
[ 1.208930] systemd[1]: Starting Apply Kernel Variables...
[ 1.215254] systemd[1]: Finished Apply Kernel Variables.
[ 1.231643] systemd[1]: Finished Coldplug All udev Devices.
[ 1.231707] audit: type=1130 audit(1654291525.363:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.242573] audit: type=1400 audit(1654291525.373:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=353 comm="apparmor_parser"
[ 1.243298] audit: type=1400 audit(1654291525.376:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=353 comm="apparmor_parser"
[ 1.243962] audit: type=1400 audit(1654291525.376:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=352 comm="apparmor_parser"
[ 1.247358] systemd[1]: Started Journal Service.
[ 1.247460] audit: type=1130 audit(1654291525.379:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.252250] audit: type=1130 audit(1654291525.383:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.252793] systemd-journald[361]: Received client request to flush runtime journal.
[ 1.268005] audit: type=1130 audit(1654291525.399:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.312996] acpi_cpufreq: overriding BIOS provided _PSD data
[ 1.341319] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.344724] acpi device:0b: registered as cooling_device16
[ 1.345146] usb 3-4: New USB device found, idVendor=0bda, idProduct=4852, bcdDevice= 0.00
[ 1.345151] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.345152] usb 3-4: Product: Bluetooth Radio
[ 1.345154] usb 3-4: Manufacturer: Realtek
[ 1.345155] usb 3-4: SerialNumber: 00e04c000001
[ 1.345903] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0a/LNXVIDEO:00/input/input6
[ 1.348935] tpm_tis NTC0702:00: 2.0 TPM (device-id 0xFC, rev-id 1)
[ 1.355831] tsc: Refined TSC clocksource calibration: 1810.456 MHz
[ 1.355843] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1a18bf2831c, max_idle_ns: 440795293610 ns
[ 1.355880] clocksource: Switched to clocksource tsc
[ 1.365055] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.365132] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.365176] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.365217] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.367443] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.413097] r8168: loading out-of-tree module taints kernel.
[ 1.440855] r8168: module verification failed: signature and/or required key missing - tainting kernel
[ 1.441033] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 1.441679] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 1.441684] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 1.441809] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 1.442942] mc: Linux media interface: v0.10
[ 1.443324] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 1.443328] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 1.444100] ccp 0000:04:00.2: enabling device (0000 -> 0002)
[ 1.444270] ccp 0000:04:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[ 1.444881] snd_rn_pci_acp3x 0000:04:00.5: enabling device (0000 -> 0002)
[ 1.454452] ccp 0000:04:00.2: tee enabled
[ 1.454479] ccp 0000:04:00.2: psp enabled
[ 1.471816] r8168 Gigabit Ethernet driver 8.049.02-NAPI loaded
[ 1.477805] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 1.477930] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 1.478021] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 1.478873] cryptd: max_cpu_qlen set to 1000
[ 1.490260] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.502967] r8168 Copyright (C) 2021 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.548697] AVX2 version of gcm_enc/dec engaged.
[ 1.548748] AES CTR mode by8 optimization enabled
[ 1.550117] videodev: Linux video capture interface: v2.00
[ 1.586885] r8168 0000:02:00.0 enp2s0: renamed from eth0
[ 1.589822] thinkpad_acpi: ThinkPad ACPI Extras v0.26
[ 1.589827] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 1.589829] thinkpad_acpi: ThinkPad BIOS R1OET28W (1.07 ), EC R1OHT28W
[ 1.589831] thinkpad_acpi: Lenovo ThinkPad E14 Gen 3, model 20Y7003XGE
[ 1.593319] thinkpad_acpi: radio switch found; radios are enabled
[ 1.593336] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
[ 1.593337] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[ 1.597670] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[ 1.679830] snd_hda_intel 0000:04:00.1: enabling device (0000 -> 0002)
[ 1.689627] ACPI Error: No handler for Region [ECSI] (00000000478193e1) [EmbeddedControl] (20210730/evregion-130)
[ 1.689637] ACPI Error: Region EmbeddedControl (ID=3) has no handler (20210730/exfldio-261)
[ 1.689651] ACPI Error: Aborting method \_SB.UBTC.ECRD due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
[ 1.690038] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[ 1.690248] snd_hda_intel 0000:04:00.6: enabling device (0000 -> 0002)
[ 1.690572] ACPI Error: Aborting method \_SB.UBTC._DSM due to previous error (AE_NOT_EXIST) (20210730/psparse-529)
[ 1.691643] ACPI: \_SB_.UBTC: failed to evaluate _DSM (0x6)
[ 1.691648] ucsi_acpi USBC000:00: ucsi_acpi_dsm: failed to evaluate _DSM 2
[ 1.714237] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input10
[ 1.714290] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input11
[ 1.714328] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input12
[ 1.729215] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[ 1.818760] Bluetooth: Core ver 2.22
[ 1.818799] NET: Registered PF_BLUETOOTH protocol family
[ 1.818801] Bluetooth: HCI device and connection manager initialized
[ 1.818805] Bluetooth: HCI socket layer initialized
[ 1.818808] Bluetooth: L2CAP socket layer initialized
[ 1.818811] Bluetooth: SCO socket layer initialized
[ 1.822244] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 1.822250] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 1.822252] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 1.822254] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 1.822255] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 1.822256] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 1.822257] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 1.833493] usb 1-3: Found UVC 1.10 device Integrated Camera (13d3:56fb)
[ 1.844208] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.0/input/input13
[ 1.845707] usb 1-3: Found UVC 1.50 device Integrated Camera (13d3:56fb)
[ 1.849042] input: Integrated Camera: Integrated I as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3/1-3:1.2/input/input14
[ 1.849566] usbcore: registered new interface driver uvcvideo
[ 1.852025] thinkpad_acpi: battery 1 registered (start 90, stop 95)
[ 1.852037] ACPI: battery: new extension: ThinkPad Battery Extension
[ 1.855035] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input9
[ 1.865707] kvm: Nested Virtualization enabled
[ 1.865711] SVM: kvm: Nested Paging enabled
[ 1.865722] SVM: Virtual VMLOAD VMSAVE supported
[ 1.865723] SVM: Virtual GIF supported
[ 1.903685] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input15
[ 1.903760] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input16
[ 1.936986] MCE: In-kernel MCE decoding enabled.
[ 1.971273] usbcore: registered new interface driver btusb
[ 1.971435] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=dbb7 lmp_ver=0b lmp_subver=c1d9
[ 1.971443] Bluetooth: hci0: RTL: unknown IC info, lmp subver c1d9, hci rev dbb7, hci ver 000b
[ 1.971445] Bluetooth: hci0: RTL: assuming no firmware upload needed
[ 2.028813] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x5f3001)
[ 2.041720] psmouse serio1: elantech: Synaptics capabilities query result 0x90, 0x18, 0x0d.
[ 2.055315] psmouse serio1: elantech: Elan sample query result 00, 0d, a7
[ 2.068411] psmouse serio1: elantech: Elan ic body: 0x11, current fw version: 0x4
[ 2.080318] [drm] amdgpu kernel modesetting enabled.
[ 2.113119] intel_rapl_common: Found RAPL domain package
[ 2.113126] intel_rapl_common: Found RAPL domain core
[ 2.129421] clocksource: timekeeping watchdog on CPU3: Marking clocksource 'tsc' as unstable because the skew is too large:
[ 2.129430] clocksource: 'hpet' wd_nsec: 510596877 wd_now: 1bba8ea wd_last: 14c1b08 mask: ffffffff
[ 2.129434] clocksource: 'tsc' cs_nsec: 506696151 cs_now: 5da3121e8 cs_last: 5a3837708 mask: ffffffffffffffff
[ 2.129437] clocksource: 'tsc' is current clocksource.
[ 2.129445] tsc: Marking TSC unstable due to clocksource watchdog
[ 2.129460] TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
[ 2.129462] sched_clock: Marking unstable (2129037025, 423007)<-(2134966184, -5506324)
[ 2.129789] clocksource: Checking clocksource tsc synchronization from CPU 3 to CPUs 0,4,7,10,14-15.
[ 2.129988] clocksource: Switched to clocksource hpet
[ 2.140723] psmouse serio1: elantech: Trying to set up SMBus access
[ 2.140770] psmouse serio1: elantech: SMbus companion is not ready yet
[ 2.169680] input: ETPS/2 Elantech TrackPoint as /devices/platform/i8042/serio1/input/input17
[ 2.186411] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input8
[ 2.187698] random: avahi-daemon: uninitialized urandom read (4 bytes read)
[ 2.190498] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 2.206402] random: polkitd: uninitialized urandom read (8 bytes read)
[ 2.222735] mousedev: PS/2 mouse device common for all mice
[ 2.228165] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.228169] Bluetooth: BNEP filters: protocol multicast
[ 2.228173] Bluetooth: BNEP socket layer initialized
[ 2.263618] NET: Registered PF_ALG protocol family
[ 2.309566] enp2s0: 0xffffa37ec0339000, 90:2e:16:2f:85:7c, IRQ 69
[ 2.312250] amdgpu: Virtual CRAT table created for CPU
[ 2.312267] amdgpu: Topology: Add CPU node
[ 2.312353] checking generic (460000000 7f0000) vs hw (460000000 10000000)
[ 2.312356] checking generic (460000000 7f0000) vs hw (460000000 10000000)
[ 2.312357] fb0: switching to amdgpu from EFI VGA
[ 2.312510] Console: switching to colour dummy device 80x25
[ 2.312595] amdgpu 0000:04:00.0: vgaarb: deactivate vga console
[ 2.312658] amdgpu 0000:04:00.0: enabling device (0006 -> 0007)
[ 2.313371] [drm] initializing kernel modesetting (RENOIR 0x1002:0x164C 0x17AA:0x5097 0xC1).
[ 2.313378] amdgpu 0000:04:00.0: amdgpu: Trusted Memory Zone (TMZ) feature enabled
[ 2.314363] [drm] register mmio base: 0xFD300000
[ 2.314369] [drm] register mmio size: 524288
[ 2.314372] [drm] PCIE atomic ops is not supported
[ 2.315474] [drm] add ip block number 0 <soc15_common>
[ 2.315479] [drm] add ip block number 1 <gmc_v9_0>
[ 2.315480] [drm] add ip block number 2 <vega10_ih>
[ 2.315481] [drm] add ip block number 3 <psp>
[ 2.315482] [drm] add ip block number 4 <smu>
[ 2.315483] [drm] add ip block number 5 <gfx_v9_0>
[ 2.315484] [drm] add ip block number 6 <sdma_v4_0>
[ 2.315485] [drm] add ip block number 7 <dm>
[ 2.315486] [drm] add ip block number 8 <vcn_v2_0>
[ 2.315487] [drm] add ip block number 9 <jpeg_v2_0>
[ 2.315505] amdgpu 0000:04:00.0: amdgpu: Fetched VBIOS from VFCT
[ 2.315508] amdgpu: ATOM BIOS: 113-LUCIENNE-016
[ 2.315928] [drm] VCN decode is enabled in VM mode
[ 2.315931] [drm] VCN encode is enabled in VM mode
[ 2.315931] [drm] JPEG decode is enabled in VM mode
[ 2.315970] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 2.315976] amdgpu 0000:04:00.0: amdgpu: VRAM: 1024M 0x000000F400000000 - 0x000000F43FFFFFFF (1024M used)
[ 2.315979] amdgpu 0000:04:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 2.315980] amdgpu 0000:04:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 2.315985] [drm] Detected VRAM RAM=1024M, BAR=1024M
[ 2.315985] [drm] RAM width 128bits DDR4
[ 2.316031] [drm] amdgpu: 1024M of VRAM memory ready
[ 2.316032] [drm] amdgpu: 3072M of GTT memory ready.
[ 2.316037] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.316156] [drm] PCIE GART of 1024M enabled.
[ 2.316157] [drm] PTB located at 0x000000F400900000
[ 2.317302] amdgpu 0000:04:00.0: amdgpu: PSP runtime database doesn't exist
[ 2.322182] [drm] Loading DMUB firmware via PSP: version=0x0101001F
[ 2.322863] [drm] Found VCN firmware Version ENC: 1.17 DEC: 5 VEP: 0 Revision: 2
[ 2.322877] amdgpu 0000:04:00.0: amdgpu: Will use PSP to load VCN firmware
[ 2.417568] loop: module loaded
[ 2.418297] loop0: detected capacity change from 0 to 8
[ 2.419049] NET: Registered PF_QIPCRTR protocol family
[ 2.425627] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.822943] ucsi_acpi: probe of USBC000:00 failed with error -5
[ 3.083923] [drm] reserve 0x400000 from 0xf43f800000 for PSP TMR
[ 3.109151] random: crng init done
[ 3.109154] random: 6 urandom warning(s) missed due to ratelimiting
[ 3.173602] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 3.183185] amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 3.183192] amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 3.183736] amdgpu 0000:04:00.0: amdgpu: SMU is initialized successfully!
[ 3.185077] [drm] kiq ring mec 2 pipe 1 q 0
[ 3.186192] [drm] Display Core initialized with v3.2.149!
[ 3.186719] [drm] DMUB hardware initialized: version=0x0101001F
[ 3.207839] snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 3.389654] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 3.389675] [drm] JPEG decode initialized successfully.
[ 3.391434] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 3.429224] memmap_init_zone_device initialised 262144 pages in 4ms
[ 3.429262] amdgpu: HMM registered 1024MB device memory
[ 3.429392] amdgpu: SRAT table not found
[ 3.429396] amdgpu: Virtual CRAT table created for GPU
[ 3.429566] amdgpu: Topology: Add dGPU node [0x164c:0x1002]
[ 3.429570] kfd kfd: amdgpu: added device 1002:164c
[ 3.429604] amdgpu 0000:04:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 8, active_cu_number 8
[ 3.432285] [drm] fb mappable at 0x3F0CD3000
[ 3.432289] [drm] vram apper at 0x3F0000000
[ 3.432290] [drm] size 8294400
[ 3.432291] [drm] fb depth is 24
[ 3.432291] [drm] pitch is 7680
[ 3.432640] fbcon: amdgpudrmfb (fb0) is primary device
[ 3.491580] Console: switching to colour frame buffer device 240x67
[ 3.510701] amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 3.523867] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 3.523875] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 3.523878] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 3.523880] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 3.523882] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 3.523884] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 3.523885] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 3.523887] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 3.523889] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 3.523891] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 3.523894] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 3.523896] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 3.523898] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 3.523900] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 3.523902] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 3.526909] [drm] Initialized amdgpu 3.42.0 20150101 for 0000:04:00.0 on minor 0
[ 4.399371] r8168: enp2s0: link up
[ 4.405889] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 5.271813] kauditd_printk_skb: 60 callbacks suppressed
[ 5.271821] audit: type=1130 audit(1654291529.402:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.276632] audit: type=1334 audit(1654291529.409:66): prog-id=20 op=LOAD
[ 5.276918] audit: type=1334 audit(1654291529.409:67): prog-id=21 op=LOAD
[ 5.335020] audit: type=1130 audit(1654291529.465:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.982268] audit: type=1131 audit(1654291531.115:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.333598] audit: type=1131 audit(1654291536.465:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.458404] audit: type=1131 audit(1654291541.589:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.935018] audit: type=1100 audit(1654291547.065:72): pid=737 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="jakob" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 22.935210] audit: type=1101 audit(1654291547.065:73): pid=737 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="jakob" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 22.936113] audit: type=1103 audit(1654291547.068:74): pid=737 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="jakob" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 22.936282] audit: type=1006 audit(1654291547.068:75): pid=737 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 22.936291] audit: type=1300 audit(1654291547.068:75): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffe67c48510 a2=4 a3=7ffe67c48224 items=0 ppid=569 pid=737 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
[ 22.936295] audit: type=1327 audit(1654291547.068:75): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746839393631346339392D376533392D346132382D626436662D373130306466316337636135002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 22.966611] audit: type=1130 audit(1654291547.098:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.975409] audit: type=1101 audit(1654291547.105:77): pid=739 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="jakob" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.975417] audit: type=1103 audit(1654291547.105:78): pid=739 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="jakob" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 22.975473] audit: type=1006 audit(1654291547.105:79): pid=739 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 24.956812] Bluetooth: RFCOMM TTY layer initialized
[ 24.956836] Bluetooth: RFCOMM socket layer initialized
[ 24.956847] Bluetooth: RFCOMM ver 1.11
[ 32.464933] kauditd_printk_skb: 12 callbacks suppressed
[ 32.464937] audit: type=1131 audit(1654291556.595:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.504607] audit: type=1131 audit(1654291556.635:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.529623] audit: type=1334 audit(1654291556.662:90): prog-id=0 op=UNLOAD
[ 32.529636] audit: type=1334 audit(1654291556.662:91): prog-id=0 op=UNLOAD
[ 32.529639] audit: type=1334 audit(1654291556.662:92): prog-id=0 op=UNLOAD
[ 32.552700] audit: type=1334 audit(1654291556.685:93): prog-id=0 op=UNLOAD
[ 32.552709] audit: type=1334 audit(1654291556.685:94): prog-id=0 op=UNLOAD
[ 32.552712] audit: type=1334 audit(1654291556.685:95): prog-id=0 op=UNLOAD
[ 33.340956] audit: type=1131 audit(1654291557.472:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 33.349957] audit: type=1131 audit(1654291557.482:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.328775] kauditd_printk_skb: 1 callbacks suppressed
[ 38.328782] audit: type=1111 audit(1654291562.458:99): pid=546 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp2s0" ifindex=2 args=0 pid=895 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 62.084393] audit: type=1111 audit(1654291586.215:100): pid=546 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp2s0" ifindex=2 args=2000 pid=895 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 63.346754] audit: type=1111 audit(1654291587.478:101): pid=546 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp2s0" ifindex=2 args=0 pid=895 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 642.087512] [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[ 936.843081] audit: type=1130 audit(1654292460.977:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 936.843095] audit: type=1131 audit(1654292460.977:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 941.834842] PM: suspend entry (deep)
[ 941.837834] Filesystems sync: 0.002 seconds
[ 941.838251] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 941.840385] OOM killer disabled.
[ 941.840386] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 941.841955] printk: Suspending console(s) (use no_console_suspend to debug)
[ 941.975390] [drm] free PSP TMR buffer
[ 942.334768] ACPI: EC: interrupt blocked
[ 942.349422] amdgpu 0000:04:00.0: amdgpu: MODE2 reset
[ 942.366229] ACPI: PM: Preparing to enter system sleep state S3
[ 942.367562] ACPI: EC: event blocked
[ 942.367564] ACPI: EC: EC stopped
[ 942.367565] ACPI: PM: Saving platform NVS memory
[ 942.367902] Disabling non-boot CPUs ...
[ 942.371628] smpboot: CPU 1 is now offline
[ 942.375388] smpboot: CPU 2 is now offline
[ 942.379109] smpboot: CPU 3 is now offline
[ 942.382676] smpboot: CPU 4 is now offline
[ 942.385842] smpboot: CPU 5 is now offline
[ 942.389222] smpboot: CPU 6 is now offline
[ 942.392185] smpboot: CPU 7 is now offline
[ 942.396104] smpboot: CPU 8 is now offline
[ 942.399225] smpboot: CPU 9 is now offline
[ 942.402157] smpboot: CPU 10 is now offline
[ 942.405057] smpboot: CPU 11 is now offline
[ 942.407697] smpboot: CPU 12 is now offline
[ 942.410404] smpboot: CPU 13 is now offline
[ 942.413980] smpboot: CPU 14 is now offline
[ 942.416315] smpboot: CPU 15 is now offline
[ 942.416508] ACPI: PM: Low-level resume complete
[ 942.416508] ACPI: EC: EC started
[ 942.416508] ACPI: PM: Restoring platform NVS memory
[ 942.416508] LVT offset 0 assigned for vector 0x400
[ 942.416508] Enabling non-boot CPUs ...
[ 942.416508] x86: Booting SMP configuration:
[ 942.416508] smpboot: Booting Node 0 Processor 1 APIC 0x1
[ 942.371430] microcode: CPU1: patch_level=0x08608103
[ 942.417554] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[ 942.417991] CPU1 is up
[ 942.418150] smpboot: Booting Node 0 Processor 2 APIC 0x2
[ 942.417406] microcode: CPU2: patch_level=0x08608103
[ 942.418675] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[ 942.419159] CPU2 is up
[ 942.419398] smpboot: Booting Node 0 Processor 3 APIC 0x3
[ 942.418394] microcode: CPU3: patch_level=0x08608103
[ 942.420142] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[ 942.420622] CPU3 is up
[ 942.420852] smpboot: Booting Node 0 Processor 4 APIC 0x4
[ 942.419768] microcode: CPU4: patch_level=0x08608103
[ 942.421905] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[ 942.422562] CPU4 is up
[ 942.422769] smpboot: Booting Node 0 Processor 5 APIC 0x5
[ 942.385816] microcode: CPU5: patch_level=0x08608103
[ 942.423379] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[ 942.423924] CPU5 is up
[ 942.424102] smpboot: Booting Node 0 Processor 6 APIC 0x6
[ 942.389064] microcode: CPU6: patch_level=0x08608103
[ 942.424863] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[ 942.425765] CPU6 is up
[ 942.425942] smpboot: Booting Node 0 Processor 7 APIC 0x7
[ 942.424433] microcode: CPU7: patch_level=0x08608103
[ 942.426410] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[ 942.427023] CPU7 is up
[ 942.427189] smpboot: Booting Node 0 Processor 8 APIC 0x8
[ 942.396098] microcode: CPU8: patch_level=0x08608103
[ 942.428287] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[ 942.429548] CPU8 is up
[ 942.429740] smpboot: Booting Node 0 Processor 9 APIC 0x9
[ 942.427782] microcode: CPU9: patch_level=0x08608103
[ 942.430401] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[ 942.431256] CPU9 is up
[ 942.431418] smpboot: Booting Node 0 Processor 10 APIC 0xa
[ 942.430055] microcode: CPU10: patch_level=0x08608103
[ 942.432288] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[ 942.433469] CPU10 is up
[ 942.433618] smpboot: Booting Node 0 Processor 11 APIC 0xb
[ 942.431884] microcode: CPU11: patch_level=0x08608103
[ 942.434169] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[ 942.435116] CPU11 is up
[ 942.435278] smpboot: Booting Node 0 Processor 12 APIC 0xc
[ 942.433867] microcode: CPU12: patch_level=0x08608103
[ 942.436294] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[ 942.437320] CPU12 is up
[ 942.437480] smpboot: Booting Node 0 Processor 13 APIC 0xd
[ 942.435824] microcode: CPU13: patch_level=0x08608103
[ 942.437954] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[ 942.438910] CPU13 is up
[ 942.439214] smpboot: Booting Node 0 Processor 14 APIC 0xe
[ 942.437782] microcode: CPU14: patch_level=0x08608103
[ 942.440159] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[ 942.441415] CPU14 is up
[ 942.441562] smpboot: Booting Node 0 Processor 15 APIC 0xf
[ 942.439704] microcode: CPU15: patch_level=0x08608103
[ 942.442008] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[ 942.443183] CPU15 is up
[ 942.444418] ACPI: PM: Waking up from system sleep state S3
[ 942.468515] ACPI: EC: interrupt unblocked
[ 942.500278] ACPI: EC: event unblocked
[ 942.500754] [drm] PCIE GART of 1024M enabled.
[ 942.500761] [drm] PTB located at 0x000000F400900000
[ 942.500776] [drm] PSP is resuming...
[ 942.501154] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 942.501163] pci 0000:00:00.2: PCI INT A: no GSI
[ 942.521039] [drm] reserve 0x400000 from 0xf43f800000 for PSP TMR
[ 942.632459] nvme nvme0: 16/0/0 default/read/poll queues
[ 942.637958] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 942.648941] amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 942.648943] amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 942.648946] amdgpu 0000:04:00.0: amdgpu: SMU is resuming...
[ 942.649098] amdgpu 0000:04:00.0: amdgpu: dpm has been disabled
[ 942.650142] amdgpu 0000:04:00.0: amdgpu: SMU is resumed successfully!
[ 942.651423] [drm] kiq ring mec 2 pipe 1 q 0
[ 942.652564] [drm] DMUB hardware initialized: version=0x0101001F
[ 942.655004] [drm] REG_WAIT timeout 1us * 1000 tries - dcn20_dsc_pg_control line:363
[ 942.657242] [drm] REG_WAIT timeout 1us * 1000 tries - dcn20_dsc_pg_control line:371
[ 942.659478] [drm] REG_WAIT timeout 1us * 1000 tries - dcn20_dsc_pg_control line:379
[ 942.749762] usb 1-3: reset high-speed USB device number 2 using xhci_hcd
[ 942.761915] usb 3-4: reset full-speed USB device number 3 using xhci_hcd
[ 942.775431] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 942.775483] [drm] JPEG decode initialized successfully.
[ 942.775683] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 942.775685] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 942.775709] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 942.775710] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 942.775711] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 942.775711] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 942.775712] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 942.775713] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 942.775713] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 942.775714] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 942.775716] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 942.775717] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 942.775717] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 942.775718] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 942.775719] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 942.918987] OOM killer enabled.
[ 942.918990] Restarting tasks ...
[ 942.919845] usb 3-3: USB disconnect, device number 2
[ 942.920058] pci_bus 0000:01: Allocating resources
[ 942.920071] pcieport 0000:00:02.1: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 942.920081] pcieport 0000:00:02.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 942.920095] pci_bus 0000:02: Allocating resources
[ 942.920106] done.
[ 942.920433] pcieport 0000:00:02.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 942.920444] pci_bus 0000:03: Allocating resources
[ 942.920488] pcieport 0000:00:02.1: BAR 15: assigned [mem 0x430200000-0x4303fffff 64bit pref]
[ 942.920513] pcieport 0000:00:02.2: BAR 15: assigned [mem 0x430400000-0x4305fffff 64bit pref]
[ 942.920525] pcieport 0000:00:02.1: BAR 13: assigned [io 0x4000-0x4fff]
[ 942.921612] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=000a lmp_ver=0b lmp_subver=8852
[ 942.921962] PM: suspend exit
[ 942.922160] pci_bus 0000:04: Allocating resources
[ 942.923692] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 942.923701] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852au_fw.bin
[ 942.925356] audit: type=1130 audit(1654292966.503:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 942.925364] audit: type=1131 audit(1654292966.503:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 942.926197] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852au_config.bin
[ 942.926472] Bluetooth: hci0: RTL: cfg_sz 6, total sz 46379
[ 943.022470] audit: type=1334 audit(1654292966.603:106): prog-id=0 op=UNLOAD
[ 943.042384] usb 3-3: new full-speed USB device number 4 using xhci_hcd
[ 943.064204] enp2s0: 0xffffa37ec0339000, 90:2e:16:2f:85:7c, IRQ 69
[ 943.075535] audit: type=1130 audit(1654292966.653:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 943.199690] usb 3-3: New USB device found, idVendor=04f3, idProduct=0c4b, bcdDevice=27.01
[ 943.199701] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 943.199705] usb 3-3: Product: ELAN:Fingerprint
[ 943.199708] usb 3-3: Manufacturer: ELAN
[ 943.233478] audit: type=1130 audit(1654292966.813:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 943.318687] Bluetooth: hci0: RTL: fw version 0xdbb7c1d9
[ 945.149121] r8168: enp2s0: link up
[ 945.149121] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[ 945.225017] audit: type=1334 audit(1654292968.803:109): prog-id=23 op=LOAD
[ 945.225034] audit: type=1300 audit(1654292968.803:109): arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7ffdd664ec90 a2=90 a3=16 items=0 ppid=1 pid=546 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
[ 945.225040] audit: type=1327 audit(1654292968.803:109): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[ 946.646463] audit: type=1100 audit(1654292970.226:110): pid=1847 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="jakob" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ 948.239089] audit: type=1131 audit(1654292971.816:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 953.086149] audit: type=1131 audit(1654292976.666:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 965.675471] audit: type=1100 audit(1654292989.253:113): pid=1937 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="jakob" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 965.675501] audit: type=1101 audit(1654292989.253:114): pid=1937 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="jakob" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 965.677089] audit: type=1110 audit(1654292989.256:115): pid=1937 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 965.679054] audit: type=1105 audit(1654292989.256:116): pid=1937 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 965.695109] audit: type=1106 audit(1654292989.273:117): pid=1937 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 965.695184] audit: type=1104 audit(1654292989.273:118): pid=1937 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 983.897044] audit: type=1101 audit(1654293007.476:119): pid=1971 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="jakob" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 983.898116] audit: type=1110 audit(1654293007.476:120): pid=1971 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 983.901302] audit: type=1105 audit(1654293007.479:121): pid=1971 uid=1000 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
