When Cyberpunk 2077 came out, I installed the mesa-git drivers - these were the ones in the official repos, not the AUR ones that were previously there. I think it was @philm that added these ones. Anyway, I did this via Pamac as suggested and I made a note of everything previously installed with ‘mesa’ in the name before doing so (All these things were installed by default).
Today, I’ve decided to revert back to the stable mesa drivers so in Pamac, I selected mesa 20.3.3-1 & lib32-mesa 20.3.3-1. Pamac informed me it would remove the git versions and replace them with the stable versions so I accepted. After a reboot I checked my list of previously installed mesa libraries and found that only some of them had been reinstalled. I’m now confused as to whether something has gone wrong and I should install them manually, or if they’re not needed anymore?
Here’s the list:
Things that did get reinstalled:
mesa
lib32-mesa
mesa-demos
lib32-mesa-demos
Things that did not get reinstalled:
mesa-vdpau
lib32-mesa-vdpau
libva-mesa-driver
lib32-libva-mesa-driver
vulkan-intel
lib32-vulkan-intel
vulkan-radeon
lib32-vulkan-radeon
What should I do?
By the way, I’m using a Ryzen 2700x & an RX 5700 on Manjaro stable - KDE Plasma.
Thanks for the help
