Restarting after update...and UEFI
After this update my computer is self-restarting for some reason occasionally ( when screen is locked ) and can’t put finger on it, what’s causing this.
Also getting those messages in journald now every reboot with kernel 6.12.4:
dets  28 12:06:45 Zen kernel: [Hardware Error]: System Fatal error.
dets  28 12:06:45 Zen kernel: [Hardware Error]: CPU:7 (19:21:0) MC5_STATUS[-|UE|MiscV|-|PCC|TCC|SyndV|-|-|-]: 0xbaa0000000010150
dets  28 12:06:45 Zen kernel: [Hardware Error]: IPID: 0x000500b000000000, Syndrome: 0x000000004d000040
dets  28 12:06:45 Zen kernel: [Hardware Error]: Execution Unit Ext. Error Code: 1
dets  28 12:06:45 Zen kernel: [Hardware Error]: cache level: RESV, tx: INSN, mem-tx: IRD
or
dets  30 05:27:00 Zen kernel: [Hardware Error]: System Fatal error.
dets  30 05:27:00 Zen kernel: [Hardware Error]: CPU:23 (19:21:0) MC5_STATUS[-|UE|MiscV|-|PCC|TCC|SyndV|-|-|-]: 0xbaa0000000010150
dets  30 05:27:00 Zen kernel: [Hardware Error]: IPID: 0x000500b000000000, Syndrome: 0x000000004d000040
dets  30 05:27:00 Zen kernel: [Hardware Error]: Execution Unit Ext. Error Code: 1
dets  30 05:27:00 Zen kernel: [Hardware Error]: cache level: RESV, tx: INSN, mem-tx: IRD
but when I turned to kernel 6.6, those errors don’t appear. (and I think didn’t come with kernel 6.12.1 either.)
If you can’t put a finger on it, and you have much more info than we do, how are we supposed to know? Please provide the output of the following:
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • the --no-pager formats the output nicely for use here, on the forum; and
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth. Please ensure this parameter is set to the last boot when this occurred.
On a standard Kernel, not the Zen kernel, is this still occurring?
some log...
journalctl --priority=warning..0 --no-pager --boot=-2
dets  28 12:06:45 Zen kernel: ata3.00: Model 'CT2000BX500SSD1', rev 'M6CR030', applying quirks: nolpm
dets  28 12:06:45 Zen kernel: ata3.00: LPM support broken, forcing max_power
dets  28 12:06:45 Zen kernel: usb: port power management may be unreliable
dets  28 12:06:45 Zen kernel: zswap: zpool z3fold not available, using default zsmalloc
dets  28 12:06:45 Zen kernel: blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
dets  28 12:06:45 Zen kernel: blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
dets  28 12:06:45 Zen kernel: blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
dets  28 12:06:45 Zen kernel: blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
dets  28 12:06:45 Zen kernel: blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
dets  28 12:06:45 Zen kernel: blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
dets  28 12:06:45 Zen kernel: hid-generic 0003:31E3:1102.0003: offset (0) exceeds report_count (0)
dets  28 12:06:45 Zen kernel: hid-generic 0003:31E3:1102.0003: No inputs registered, leaving
dets  28 12:06:45 Zen kernel: zenpower: loading out-of-tree module taints kernel.
dets  28 12:06:45 Zen (udev-worker)[841]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
dets  28 12:06:46 Zen kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
dets  28 12:06:48 Zen systemd-tmpfiles[1078]: "/var/log/jellyfin" already exists and is not a directory.
dets  28 12:06:48 Zen (uetoothd)[1100]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
dets  28 12:06:48 Zen (modprobe)[1103]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support bap plugin
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support bass plugin
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support mcp plugin
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support vcp plugin
dets  28 12:06:48 Zen bluetoothd[1100]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support micp plugin
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support ccp plugin
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support csip plugin
dets  28 12:06:48 Zen bluetoothd[1100]: src/plugin.c:init_plugin() System does not support asha plugin
dets  28 12:06:48 Zen bluetoothd[1100]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
dets  28 12:06:48 Zen bluetoothd[1100]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
dets  28 12:06:49 Zen dbus-broker-launch[1096]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
dets  28 12:06:49 Zen dbus-broker-launch[1303]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
dets  28 12:06:49 Zen dbus-broker-launch[1303]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
dets  28 12:06:49 Zen dbus-broker-launch[1303]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
dets  28 12:06:50 Zen pipewire[1328]: pw.context: vm.overrides in context.properties are deprecated, use context.properties.rules instead
dets  28 12:06:50 Zen wireplumber[1329]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
dets  28 12:06:51 Zen dbus-broker-launch[1096]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
dets  28 12:06:51 Zen (jellyfin)[1468]: jellyfin.service: Referenced but unset environment variable evaluates to an empty string: JELLYFIN_NOWEBAPP_OPT, JELLYFIN_SERVICE_OPT
dets  28 12:06:55 Zen rpc.statd[1521]: Flags: TI-RPC
dets  28 15:02:46 Zen sddm-helper[1971]: gkr-pam: unable to locate daemon control file
dets  28 15:02:46 Zen dbus-broker-launch[2028]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
dets  28 15:02:46 Zen dbus-broker-launch[2028]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
dets  28 15:02:46 Zen dbus-broker-launch[2028]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
dets  28 15:02:47 Zen systemd[1977]: /run/user/1000/systemd/generator.late/app-pcloudcc@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
dets  28 15:02:47 Zen xdg-desktop-por[2081]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
dets  28 15:02:47 Zen xdg-desktop-por[2081]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
dets  28 15:02:47 Zen pipewire[2131]: pw.context: vm.overrides in context.properties are deprecated, use context.properties.rules instead
dets  28 15:02:48 Zen wireplumber[2132]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
dets  28 15:02:48 Zen pipewire-pulse[2339]: mod.protocol-pulse: vm.overrides in pulse.properties are deprecated, use pulse.properties.rules instead
dets  28 15:02:48 Zen kernel: block nvme0n1: No UUID available providing old NGUID
dets  28 15:02:49 Zen org_kde_powerdevil[2429]: busno=4, sleep-multiplier =  2.00. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
dets  28 15:02:50 Zen backlighthelper[2774]: org.kde.powerdevil: no kernel backlight interface found
dets  28 15:02:50 Zen (pcscd)[2954]: pcscd.service: Referenced but unset environment variable evaluates to an empty string: PCSCD_ARGS
dets  28 15:03:47 Zen systemd[1977]: dbus-:1.2-org.kde.KSplash@0.service: Failed with result 'exit-code'.
dets  28 15:15:59 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) graph xrun not-triggered (0 suppressed)
dets  28 15:15:59 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) xrun state:0x753f1c563008 pending:1/1 s:10609344067759 a:10609344072659 f:10609344101240 waiting:4900 process:28581 status:triggered
dets  28 15:32:48 Zen systemd[1977]: drkonqi-coredump-pickup.service: Service reached runtime time limit. Stopping.
dets  28 15:32:48 Zen systemd[1977]: drkonqi-coredump-pickup.service: Failed with result 'timeout'.
dets  28 17:31:05 Zen kernel: warning: `wine_sechost_se' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
dets  28 17:42:37 Zen org_kde_powerdevil[2429]: dh=Display_Handle[i2c-5: fd=34], Keeping adjusted sleep multiplier 1.60 for SE_POST_WRITE or SE_POST_SAVE_SETTINGS
dets  28 17:42:38 Zen org_kde_powerdevil[2429]: dh=Display_Handle[i2c-5: fd=34], Keeping adjusted sleep multiplier 1.30 for SE_POST_WRITE or SE_POST_SAVE_SETTINGS
dets  28 19:47:15 Zen kernel: amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 100 tries - dcn32_program_compbuf_size line:139
dets  28 21:25:35 Zen kernel: amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 100 tries - dcn32_program_compbuf_size line:139
dets  28 23:21:37 Zen kernel: amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 100 tries - dcn32_program_compbuf_size line:139
dets  29 00:31:00 Zen kernel: playstation 0005:054C:09CC.000C: unknown main item tag 0x0
dets  29 00:31:32 Zen bluetoothd[1100]: profiles/input/device.c:hidp_report_req_timeout() Device 98:B6:E9:B3:93:53 HIDP GET_REPORT request timed out
dets  29 00:31:47 Zen bluetoothd[1100]: profiles/input/device.c:hidp_report_req_timeout() Device 98:B6:E9:B3:93:53 HIDP GET_REPORT request timed out
dets  29 00:49:42 Zen bluetoothd[1100]: profiles/input/device.c:hidp_report_req_timeout() Device 98:B6:E9:B3:93:53 HIDP GET_REPORT request timed out
dets  29 00:50:42 Zen bluetoothd[1100]: profiles/input/device.c:hidp_report_req_timeout() Device 98:B6:E9:B3:93:53 HIDP GET_REPORT request timed out
dets  29 02:12:13 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) graph xrun not-triggered (1 suppressed)
dets  29 02:12:13 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) xrun state:0x753f1c563008 pending:2/2 s:50532028249152 a:50532028252892 f:50532028320363 waiting:3740 process:67471 status:triggered
dets  29 02:31:42 Zen gnome-calculato[71710]: Unknown key gtk-modules in /home/deemon/.config/gtk-4.0/settings.ini
dets  29 02:31:43 Zen gnome-calculato[71710]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
dets  29 02:32:54 Zen gnome-calculato[71710]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
dets  29 02:32:55 Zen gnome-calculato[71710]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
dets  29 03:45:19 Zen kernel: amdgpu 0000:2f:00.0: [drm] REG_WAIT timeout 1us * 100 tries - dcn32_program_compbuf_size line:139
dets  29 16:41:56 Zen systemd[1977]: app-protontricks\x2dlaunch@b8d9e4e0c01546ef8412974072b90fc9.service: Failed with result 'exit-code'.
dets  29 20:21:01 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) graph xrun not-triggered (0 suppressed)
dets  29 20:21:01 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) xrun state:0x753f1c563008 pending:2/2 s:113079888802918 a:113079888805228 f:113079888814658 waiting:2310 process:9430 status:triggered
dets  30 05:10:58 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) graph xrun not-triggered (2 suppressed)
dets  30 05:10:58 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) xrun state:0x753f1c563008 pending:1/3 s:147858550308075 a:147858550337535 f:147858550344096 waiting:29460 process:6561 status:triggered
dets  30 05:11:16 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) graph xrun not-triggered (1 suppressed)
dets  30 05:11:16 Zen pipewire[2131]: pw.node: (alsa_output.pci-0000_31_00.4.analog-surround-51-50) xrun state:0x753f1c563008 pending:1/3 s:147876537381099 a:147876537409989 f:147876537417960 waiting:28890 process:7971 status:triggered
and boot happened at 05:27:00
dets  30 05:27:00 Zen kernel: Linux version 6.12.4-1-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Mon, 09 Dec 2024 11:58:37 +0000
dets  30 05:27:00 Zen kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=5d7a533c-7c16-4026-b28c-1bd1f407e3ff rw apparmor=1 security=apparmor nohibernate amdgpu.noretry=0 amdgpu.lockup_timeout=1000 amdgpu.gpu_recovery=1 amdgpu.deep_color=1 amdgpu.freesync_video=1 amd_iommu=on iommu=pt sysrq_always_enabled=1 pcie_aspm=off cpufreq.off=0 zswap.enabled=1 zswap.compressor=zstd zswap.max_pool_percent=30 zswap.zpool=z3fold
Yes. Those “hardware errors” happen on normal Linux version 6.12.4-1-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.0) #1 SMP PREEMPT_DYNAMIC Mon, 09 Dec 2024 11:58:37 +0000
although regardless of those errors, the computer is stable and works perfectly. until I screenlock it with meta-L and then sometime later after the reboot thing happens. But not sure if the reboot thing is also related to kernel 6.12.4 or something else.
Can you also provide some System Information for better context:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
  • Is your system set to hibernate?
  • Do you have swap space configured?
  • Does your / partition have enough space available?
inxi
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    zswap.zpool=z3fold
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84) v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 1.90
    date: 03/18/2022
  System RAM: total: 32 GiB available: 31.27 GiB used: 11.23 GiB (35.9%)
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3600C18-8GTZRX serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
    desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2200 min/max: 2200/5083 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
    21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200
    29: 2200 30: 2200 31: 2200 32: 2200 bogomips: 217726
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1, DP-2, DP-3, HDMI-A-1
    empty: none bus-ID: 2f:00.0 chip-ID: 1002:744c class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
    d-rect: 6400x2280 display-ID: 0
  Monitor-1: DP-1 pos: bottom-l res: 2560x1440 size: N/A modes: N/A
  Monitor-2: DP-2 pos: top-center res: 1920x1080 size: N/A modes: N/A
  Monitor-3: DP-3 pos: bottom-r res: 1920x1200 size: N/A modes: N/A
  Monitor-4: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
    navi31 LLVM 18.1.8 DRM 3.54 6.6.65-1-MANJARO) device-ID: 1002:744c
    memory: 23.44 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
    surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 25:00.0
  IF: huginn state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 27:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: muninn state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 5.5 TiB used: 5.35 TiB (97.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T8
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000BX500SSD1
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 030 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: WDC WDS200T2B0B-00YS70
    tech: SSD serial: <filter> fw-rev: 40WD scheme: GPT
  ID-1: / raw-size: 1.86 TiB size: 1.83 TiB (98.37%) used: 1.64 TiB (89.2%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 5d7a533c-7c16-4026-b28c-1bd1f407e3ff
    used: 536 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 49AD-47B9
  ID-3: /home/<filter>/pCloudDrive raw-size: N/A size: 2 TiB
    used: 463.02 GiB (22.6%) fs: fuse source: ERR-102
  ID-4: /media/nas-toshiba raw-size: N/A size: 5.41 TiB
    used: 4.99 TiB (92.3%) fs: nfs remote: nas542.local:/i-data/c65dd9d1/toshiba
  ID-5: /media/nas-wd-red-pro raw-size: N/A size: 14.43 TiB
    used: 11.83 TiB (81.9%) fs: nfs
    remote: nas542.local:/i-data/49d7c167/wd-red-pro
  ID-6: /media/nas-wd-red2 raw-size: N/A size: 5.41 TiB
    used: 5.35 TiB (98.9%) fs: nfs remote: nas542.local:/i-data/f9b5c33b/wd-red2
  ID-7: /mnt/crucial_bx500 raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 1.66 TiB (92.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
    label: crucial_bx500 uuid: 269cde67-0952-41c6-823b-b0f1f1e70424
  ID-8: /mnt/wd-blue raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 1.61 TiB (89.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: wd-blue
    uuid: 9611b50a-3b22-4e27-84c6-754f0bc55c6d
  Kernel: swappiness: 40 (default 60) cache-pressure: 100 (default) zswap: yes
    compressor: zstd max-pool: 30%
  ID-1: swap-1 type: file size: 64 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  Device-1: 1-4:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-2: 1-5:3 info: Razer USA RZ01-0316 Gaming Mouse [Basilisk V2]
    type: mouse,keyboard driver: razermouse,usbhid interfaces: 3 rev: 2.0
    chip-ID: 1532:0085 class-ID: 0301
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c84 class-ID: 0300
    serial: <filter>
  Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-6.2:4 info: Corsair Lighting Node CORE type: HID
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 1b1c:0c1a class-ID: 0300
    serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Wooting WootingOne type: HID,keyboard
    driver: hid-generic,usbhid interfaces: 6 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 31e3:1102 class-ID: 0300
    serial: <filter>
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 65.9 C mobo: 51.0 C gpu: amdgpu temp: 70.0 C
    mem: 78.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 1130 fan-3: 962 fan-4: 0 fan-5: 957
    fan-6: 0 fan-7: 1771 gpu: amdgpu fan: 855
  Packages: 1874 pm: pacman pkgs: 1868 libs: 504 tools: pamac,yay pm: flatpak
    pkgs: 6
  Active pacman repo servers in: /etc/pacman.conf
    1: file:///localrepo
    1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    2: https://mirror.zetup.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 534
  1: cpu: 100% command: ps pid: 8965 mem: 3.75 MiB (0.0%)
  2: cpu: 12.6% command: firefox pid: 3348 mem: 1176.0 MiB (3.6%)
  3: cpu: 6.1% command: firefox pid: 4351 mem: 393.0 MiB (1.2%)
  4: cpu: 6.0% command: firefox pid: 4363 mem: 455.4 MiB (1.4%)
  5: cpu: 4.5% command: firefox pid: 3892 mem: 648.4 MiB (2.0%)
  Memory top: 5 of 534
  1: mem: 1419.9 MiB (4.4%) command: clamd pid: 1054 cpu: 1.4%
  2: mem: 1176.0 MiB (3.6%) command: firefox pid: 3348 cpu: 12.6%
  3: mem: 648.4 MiB (2.0%) command: firefox pid: 3892 cpu: 4.5%
  4: mem: 483.3 MiB (1.5%) command: plasmashell pid: 1981 cpu: 0.5%
  5: mem: 464.3 MiB (1.4%) command: firefox pid: 3730 cpu: 0.9%
  Processes: 534 Power: uptime: 29m states: freeze,mem suspend: deep
    avail: s2idle wakeups: 0 hibernate: disabled image: 12.5 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 256
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.36
Worth testing version 6.6, then.
System seems to be running hot.
I’d guess overheating might be an issue here.
looks pretty normal to me…
Around 50/60 is pretty normal for me. :smile_cat:
well, the cpu and gpu thermal and fan control are done by respective parties by themselves… I have done 0 interference or adjustments there… so must be ok?
except I turned off any kernel power management there for more stability… nohibernate pcie_aspm=off cpufreq.off=0
Mine is:
System Temperatures: cpu: 41.0 C mobo: 35.0 C gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 69%
Still seems a bit high to me.
Showoff. :stuck_out_tongue_winking_eye:
Yes, I know, mine could probably be better too. :wink:
Anyway for right now I let it run with kernel 6.6 and report back the behavior if there is anything to report.
Yup. I know. But, well…
:man_shrugging:
Kernel 6.6.65 has worked perfectly those 2 days now. No random weird reboots, no weird hardware error messages … so far so good.
Well, 6.6 is an LTS version. Maybe not the latest but greatest is highly subjective.
Looks suspicious! Cleann out the fan vents. And check fan connections.
no it’s not. no I don’t. However I removed the pcie_aspm=off from kernel commands and somewhat later now I have:
  System Temperatures: cpu: 50.0 C mobo: 39.0 C gpu: amdgpu temp: 55.0 C
    mem: 64.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 766 fan-3: 969 fan-4: 0 fan-5: 943
    fan-6: 0 fan-7: 0 gpu: amdgpu fan: 724
as expected. Also don’t forget, it’s desktop pc, not some laptop. And AMD cpu and gpu.
I believe that is the greatest contributor. I don’t know 'bout the graphics card, but as far as I know AMD CPUs run hotter than Intel due to their build.
