Restart after sleep
Hi
I used manjaro for a few years on gnome and the sleep function worked well. Recently I install kde and now my PC restarts every day after sleep. Not always, but about once a day. A few sleeps can go ok, I resume where I left off, but then on the next one the PC just restarts.
Do you know where to look for a problem? How to debug it?
Is it a mobile computer (laptop, notebook)?
Go to system settings within Desktop session (/usr/bin/systemsettings) > system > click power management
There you’ll find several suspend session options.
Also, check the Activities settings for the current Activity, even if you only have one. It too contains settings regarding sleep, et al.
This is a miniPc with
KDE Plasma Version: 6.5.5
KDE Frameworks Version: 6.22.0
Qt Version: 6.10.1
Kernel Version: 6.18.8-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 16 Ă— AMD Ryzen 9 7940HS w/ Radeon 780M Graphics
Memory: 64 GiB of RAM (54,6 GiB usable)
Graphics Processor: AMD Radeon 780M Graphics
Manufacturer: Micro Computer (HK) Tech Limited
Product Name: Venus series
I have only Default activity in settings, it has “Automatically shutting down or sleeping” on. Didn’t touch these settings.
I looked at power management settings but I don’t see anything that seems off. Mostly these are default settings
Hmm - one could speculate if that sleep is hibernate and thus the swap space required is not enough, thereby triggering a restart instead.
 # cat /sys/power/mem_sleep
[s2idle] deep
That’s not enough info, please provide
$ inxi -zv8
I don’t have swap at all and I don’t want it. 64GB is enough for most of the tasks
Output of inxi -zv8
  Kernel: 6.18.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=cf86f33a-f89e-47cf-b6bf-878e1ea1800a rw quiet splash apparmor=1
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
  Type: Mini-pc System: Micro (HK) Tech product: Venus series v: N/A
    serial: <superuser required>
  Mobo: Shenzhen Meigao Equipment model: F7BSC serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: 1.07 date: 09/01/2023
  System RAM: total: 64 GiB available: 54.64 GiB used: 20.11 GiB (36.8%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF556S40-32 serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
    microcode: 0xA704108
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 403 min/max: 403/4001 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 403 2: 403 3: 403
    4: 403 5: 403 6: 403 7: 403 8: 403 9: 403 10: 403 11: 403 12: 403 13: 403
    14: 403 15: 403 16: 403 bogomips: 127773
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
    cmov cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
    x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 driver: amdgpu v: kernel
    arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-1, DP-2, DP-3,
    DP-4, DP-5, DP-6, DP-7, HDMI-A-1, Writeback-1 bus-ID: c4:00.0
    chip-ID: 1002:15bf class-ID: 0300 temp: 26.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-2 model: Dell U2722DE serial: <filter> built: 2022 res:
    mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 2560x1440, 2048x1080, 1920x1080, 1600x1200, 1600x900,
    1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
    phoenix LLVM 21.1.6 DRM 3.64 6.18.8-1-MANJARO) device-ID: 1002:15bf
    memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon 780M Graphics (RADV PHOENIX) driver: mesa radv v: 25.3.4-arch1.1
    device-ID: 1002:15bf surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    bus-ID: c4:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: c4:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
    bus-ID: c4:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.8-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak]
    vendor: Rivet Networks Killer driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2.1.3:11
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: eth0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 1.04 TiB (57.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 34.9 C
    scheme: GPT
  ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 70.57 GiB (36.0%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: Root
    uuid: cf86f33a-f89e-47cf-b6bf-878e1ea1800a
    used: 31.4 MiB (10.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: EFI uuid: 970B-82C0
  ID-3: /home raw-size: 1.05 TiB size: 1.03 TiB (98.33%)
    used: 991.81 GiB (93.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Home uuid: 008e6f90-e835-4684-9e16-b330cbe6419c
  ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 588.02 GiB fs: ntfs label: N/A
    uuid: 32F8D0FCF8D0BF73
  ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 966 MiB fs: ntfs label: N/A
    uuid: CCAA8262AA8248C2
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Hub-2: 1-1:2 info: VIA Labs USB2.0 Hub ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
  Hub-3: 1-2:3 info: VIA Labs USB2.0 Hub ports: 2 rev: 2.1
  Hub-4: 1-2.2:13 info: Realtek 4-Port USB 2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5483
  Hub-5: 1-2.2.1:14 info: Realtek 4-Port USB 2.0 Hub ports: 4 rev: 2.1
  Device-1: 1-2.2.2:15 info: Logitech M500s Optical Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c093 class-ID: 0300
    serial: <filter>
  Device-2: 1-2.2.3:16 info: Monterey Keyboard type: keyboard,HID
    chip-ID: 0566:3002 class-ID: 0300
  Device-3: 1-2.2.5:17 info: Realtek USB2.0 HID type: HID
    chip-ID: 0bda:1100 class-ID: 0300
  Device-4: 1-5:4 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-6: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 2-1:2 info: VIA Labs USB3.1 Hub ports: 2 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 2109:0822
  Hub-8: 2-2:3 info: VIA Labs USB3.1 Hub ports: 2 rev: 3.2
  Hub-9: 2-2.2:8 info: Realtek 4-Port USB 3.0 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 0bda:0483
  Hub-10: 2-2.2.1:9 info: Realtek 4-Port USB 3.0 Hub ports: 3 rev: 3.2
  Device-1: 2-2.2.1.3:11 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 256mA
  Hub-11: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-12: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-13: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-14: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-15: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-16: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 28.5 C mobo: N/A gpu: amdgpu temp: 26.0 C
  Fan Speeds (rpm): N/A
  Packages: 2363 pm: pacman pkgs: 2339 libs: 463 tools: gnome-software,
    octopi, pamac, yay pm: flatpak pkgs: 24
    1: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    3: https://manjaro.ynh.ovh/stable/$repo/$arch
    4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 554
  1: cpu: 13.0% command: localsearch-extractor-3 pid: 82596
    mem: 47.1 MiB (0.0%)
  2: cpu: 7.3% command: rustrover pid: 33757 mem: 3425.8 MiB (6.1%)
  3: cpu: 3.2% command: chrome pid: 82407 mem: 223.1 MiB (0.3%)
  4: cpu: 2.8% command: ksgrd_network_helper pid: 2079 mem: 7.04 MiB (0.0%)
  5: cpu: 2.6% command: firefox pid: 3657 mem: 952.3 MiB (1.7%)
  Memory top: 5 of 554
  1: mem: 3425.8 MiB (6.1%) command: rustrover pid: 33757 cpu: 7.3%
  2: mem: 1601.2 MiB (2.8%) command: chrome pid: 6089 cpu: 0.0%
  3: mem: 952.3 MiB (1.7%) command: firefox pid: 3657 cpu: 2.6%
  4: mem: 728.3 MiB (1.3%) command: firefox pid: 16280 cpu: 0.6%
  5: mem: 581.1 MiB (1.0%) command: firefox pid: 8886 cpu: 0.5%
  Processes: 554 Power: uptime: 20h 3m states: freeze,mem,disk suspend: s2idle
    wakeups: 10 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 21.84 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
[s2idle]
How are you hibernating without swap? Or do you mean suspend to RAM? In second case, maybe RAM is full when you set the PC to sleep.
Your /home is already packed, it would be recommendable to free some space.
I believe I suspend to RAM, I click “Sleep” button in start menu. Yes, the SSD is almost full now but it was the same when I had 200GB free. The RAM should be enough when I do the sleep. I didn’t pay attention to it though but at the same time if I suspend to RAM, then I presume there no much pressure for RAM anyway since all the data that is already there stay there and maybe there is a few more MBs of additional data to support resumption, some tech data but it shouldn’t be GBs, and I definitely have enough free GBs. Also when I was in gnome, I sometimes suspended the PC when more than 95% of RAM was used and it still worked without problems.
The problem correlates with my move to KDE. Maybe something didn’t install correctly or maybe KDE has some background services that interfere with the normal sleep or resume functions.
Most likely not related to the problem at hand - I’ll mention it anyway:
Are you aware that ext4 reserves 5% of the space for root?
This does not really make sense for the /home partition - and it amounts to ~50 GB of usable storage space “wasted”.
sudo tune2fs -m 0 /dev/The_Home_Partition
Similar for / - but there I’d indeed leave some room to make sure root can always write if need be:
sudo tune2fs -m 1 /dev/The_Root_Partition
I didn’t know about it, thanks for sharing :+1:
The issue has disappeared after updating to the latest kernel and the latest versions of the rest of the packages
