Hi, I had installed Manjaro KDE 21.1.1 on a 250 GB SSD and updated till I broke the system (due to my fault). So I installed Manjaro again, but to my surprise, I found that the installation size is much more in today’s install. How can that be possible? (I installed almost the same set of software) Am I getting something very wrong?
Previous:
Btrfs is COW (copy on write) , So when you create snapshot , it creates a separate instance at that time, and not stores data twice. Whenever anything new is added it is added “over” the previous instance.
What you see in Size is , size of snapshot, not how much size of data that was had to be stored on disk for that snapshot, that is shown in unshared portion, which you can clearly see is merely 13.7mb + 344.1kb.
You can also verify this by mounting the drive in the folder , and doing
Something like this can help you crosscheck , in case you have doubts for each particular snapshot.
This is an interesting question, most popular tools usually don’t report correct due to btrfs COW feature and they might think data has been copied twice while it’s not
btrfs-progs which is already installed provides utilities to manage that,
in order to check usage of any folder use
sudo btrfs filesystem du --mbytes -s <Folder_Path>
du = disk usage
–mbytes = report it in mb
-s = don’t tell me usage of every file , rather summarize it
You can also check how much disk is free/or check total usage by simply using
This is not as easy as it looks, because btrfs may have compressed some files. Some may be linked together. There may be snapshots …
This will show the real size and space of btrfs fast
sudo btrfs filesystem show /
Label: none uuid: 3487ba3d-1cba-4cdc-a043-c420ebca2aca
Total devices 2 FS bytes used 418.94GiB
devid 1 size 900.00GiB used 470.03GiB path /dev/sda2
devid 3 size 900.00GiB used 470.03GiB path /dev/nvme0n1p3
If you want btrfs to count all the beans this will take a while
