I get output from Pitcairn > Asus (Screen 0) just fine. No output from Navi > Dell, monitor stays asleep.
GPU to monitor, DisplayPort to DisplayPort.
Both cards recognized in BIOS.
Both display controllers appear in Hardware Config.
Dualboot Windows - setup worked out of the box, for what it’s worth.
Both monitors are recognized in Display Configuration but the Dell is disabled. When I enable the Dell, I get one of two results.
- system lock up
- extreme frame loss on Asus, ~5-10 fps, stutter. Dell remains asleep, no reaction.
You guys have an amazing level of patience. Thank you for all you do!
System: Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=b3b8a689-6981-46c1-839b-06d376c3eafc rw
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland vt: 2 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME X399-A v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 1203 date: 10/09/2019
CPU: Info: 16-Core (2-Die) model: AMD Ryzen Threadripper 2950X bits: 64 type: MT MCP MCM arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 239646
Speed: 3743 MHz min/max: 2200/3750 MHz boost: disabled Core speeds (MHz): 1: 3743 2: 2139 3: 2196
4: 2196 5: 2196 6: 2196 7: 2196 8: 2196 9: 3743 10: 2135 11: 2139 12: 2139 13: 2139 14: 2196 15: 2196
16: 2196 17: 2196 18: 2196 19: 2196 20: 2196 21: 2196 22: 2196 23: 2196 24: 2139 25: 2196 26: 2196
27: 2196 28: 2196 29: 2196 30: 2196 31: 2196 32: 2196
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Tul driver: amdgpu v: kernel bus-ID: 0c:00.0 chip-ID: 1002:731f class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Pitcairn XT GL [FirePro W7000] driver: radeon v: kernel
alternate: amdgpu bus-ID: 41:00.0 chip-ID: 1002:6808 class-ID: 0300
Display: wayland server: X.Org 1.21.0.99 compositor: kwin_wayland driver: loaded: amdgpu,ati,radeon
unloaded: modesetting alternate: fbdev,vesa display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: AMD PITCAIRN (DRM 2.50.0 5.10.23-1-MANJARO LLVM 11.1.0) v: 4.5 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0c:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0e:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] driver: snd_hda_intel
v: kernel bus-ID: 41:00.1 chip-ID: 1002:aab0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.17 running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: 2000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wgivpn state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8
bus-ID: 1-10:2 chip-ID: 0a12:0001 class-ID: e001
Drives: Local Storage: total: 6.03 TiB used: 2.98 TiB (49.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T3X0C-00SJG0 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 102000WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7PC128HAFU-000L1 size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 4L1Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A120G size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SDSSDP128G size: 117.38 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 032 scheme: MBR
ID-7: /dev/sdf maj-min: 8:80 vendor: Western Digital model: WD1003FZEX-00MK2A0 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: 1A01 scheme: MBR
ID-8: /dev/sdg maj-min: 8:96 vendor: Western Digital model: WDS200T2B0B size: 1.82 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 90WD scheme: MBR
Partition: ID-1: / raw-size: 931.51 GiB size: 915.89 GiB (98.32%) used: 162.65 GiB (17.8%) fs: ext4
dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.1 MiB (26.1%) fs: vfat dev: /dev/sdc2
maj-min: 8:34
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 32.6 C mobo: N/A
GPU: device: radeon temp: 52.0 C device: amdgpu temp: 40.0 C mem: 40.0 C fan: 0 watts: 9.00
Info: Processes: 587 Uptime: 3m wakeups: 0 Memory: 31.27 GiB used: 4.33 GiB (13.8%) Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1570 pacman: 1563 lib: 459 flatpak: 0
snap: 7 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
xrandr
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
XWAYLAND0 connected 1920x1080+0+0 (0x24) normal (normal left inverted right x axis y axis) 530mm x 300mm
Identifier: 0x21
Timestamp: 25074
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 0.0
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
non-desktop: 0
supported: 0, 1
1920x1080 (0x24) 172.750MHz -HSync +VSync *current +preferred
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.06KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.88Hz
1440x1080 (0x25) 128.750MHz -HSync +VSync
h: width 1440 start 1528 end 1680 total 1920 skew 0 clock 67.06KHz
v: height 1080 start 1083 end 1087 total 1120 clock 59.87Hz
1400x1050 (0x26) 121.500MHz -HSync +VSync
h: width 1400 start 1488 end 1632 total 1864 skew 0 clock 65.18KHz
v: height 1050 start 1053 end 1057 total 1089 clock 59.86Hz
1280x1024 (0x27) 108.750MHz -HSync +VSync
h: width 1280 start 1368 end 1496 total 1712 skew 0 clock 63.52KHz
v: height 1024 start 1027 end 1034 total 1063 clock 59.76Hz
1280x960 (0x28) 101.000MHz -HSync +VSync
h: width 1280 start 1360 end 1488 total 1696 skew 0 clock 59.55KHz
v: height 960 start 963 end 967 total 996 clock 59.79Hz
1152x864 (0x29) 81.500MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.62KHz
v: height 864 start 867 end 871 total 897 clock 59.78Hz
1024x768 (0x2a) 63.250MHz -HSync +VSync
h: width 1024 start 1072 end 1176 total 1328 skew 0 clock 47.63KHz
v: height 768 start 771 end 775 total 798 clock 59.68Hz
800x600 (0x2b) 38.250MHz -HSync +VSync
h: width 800 start 832 end 912 total 1024 skew 0 clock 37.35KHz
v: height 600 start 603 end 607 total 624 clock 59.86Hz
640x480 (0x2c) 23.750MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 29.69KHz
v: height 480 start 483 end 487 total 500 clock 59.38Hz
320x240 (0x2d) 6.000MHz -HSync +VSync
h: width 320 start 336 end 360 total 400 skew 0 clock 15.00KHz
v: height 240 start 243 end 247 total 252 clock 59.52Hz
1680x1050 (0x2e) 146.000MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.18KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.85Hz
1440x900 (0x2f) 106.500MHz -HSync +VSync
h: width 1440 start 1528 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1280x800 (0x30) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
720x480 (0x31) 26.750MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 29.85KHz
v: height 480 start 483 end 493 total 500 clock 59.71Hz
640x400 (0x32) 19.750MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 24.69KHz
v: height 400 start 403 end 409 total 417 clock 59.20Hz
320x200 (0x33) 5.000MHz -HSync +VSync
h: width 320 start 336 end 360 total 400 skew 0 clock 12.50KHz
v: height 200 start 203 end 209 total 212 clock 58.96Hz
1600x900 (0x34) 118.000MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.87KHz
v: height 900 start 903 end 908 total 934 clock 59.82Hz
1368x768 (0x35) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1280x720 (0x36) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1024x576 (0x37) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
864x486 (0x38) 32.250MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.08KHz
v: height 486 start 489 end 494 total 506 clock 59.45Hz
720x400 (0x39) 22.250MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 24.83KHz
v: height 400 start 403 end 413 total 417 clock 59.55Hz
640x350 (0x3a) 17.500MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 21.88KHz
v: height 350 start 353 end 363 total 366 clock 59.77Hz
