I performed a fresh installation of Manjaro 20 Gnome about 3 weeks ago and it’s been running great on my custom built Asus Tuf Gaming desktop.
However, after an update today my system boots to an all black screen.
To get into the system and get the GUI I have to hold down Ctrl + Alt + F2 and login.
Once I log in I have to type startx and than I am able to use my system.
How to I fix it so that I don’t have to keep logging in through tty and run startx?
Most likely it is GDM playing some tricks on you. You can try to use Wayland to be used by GDM. Go to /etc/gdm/custom.conf and edit the file like this:
I’ve been having a similar issue with fresh Manjaro Gnome installs recently on a laptop with a nvidia 1050ti. My temporary solution has been to ctrl + alt + f2 and startx into the gui and then use the hardware configuration tool in Manjaro Settings to Auto-Install Open Source Driver. While I no longer have easy access to the discrete gpu (which isn’t critical to my use case), GDM now works when I first boot up so I can log normally now. From what I’ve gathered from other places on the internet, there is some compatibility issue between recent kernels and the proprietary nvidia drivers.
