Hi,
Is it necessary to resize file system after flashing manjaro? If so, can someone help with the steps?
It is done automatically at the end of the first boot setup before it re-boots.
I plan on booting the RPI through USB. If its not necessary to expand filesystem then that is great. One less thing to worry about.
