Reset Gnome's Accessibility/Display Settings to default?
Hello there,
I need some help regarding the Accessibility settings in Manjaro. I was playing around the screen magnification settings, because i connected to a TV screen and sometimes I could not read things on the screen. I set it up do follow the mouse cursor and then the screen froze. It send me back to the login screen. And now when I login it starts the zoom setting again. And then it freezes and sends me back to the login screen. So I am stuck and have no chance to change the setting via the GUI.
I have access to the terminal however and I was looking around for settings files in which this setting is stored. However I could not find it and I am out of ideas where to look, because I don’t know the application which is doing the zoom.
Can someone point me to a config file or give me some info on how the zoom works, so I can help myself. I basically need some info, so I can reset the setting.
If there is any other information needed let me know.
Thanks
  Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=8d863701-ac77-4439-b64d-84676694cdcc rw quiet splash apparmor=1
  security=apparmor resume=UUID=fb65c45f-5cfc-4936-98ac-211ad42c2936
  udev.log_priority=3
  Console: tty 4 DM: GDM 40.1 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 20FXS06200 v: ThinkPad T460p
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20FXS06200 v: SDK0J40705 WIN serial: <filter>
  UEFI-[Legacy]: LENOVO v: R07ET84W (2.24 ) date: 06/05/2018
  ID-1: BAT0 charge: 37.5 Wh (91.2%) condition: 41.1/47.5 Wh (86.6%)
  volts: 12.4 min: 10.8 model: SMP 45N1736 type: Li-ion serial: <filter>
  status: Charging
  RAM: total: 30.67 GiB used: 3.07 GiB (10.0%)
  Info: Quad Core model: Intel Core i7-6820HQ bits: 64 type: MT MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
  L2: 8 MiB bogomips: 43214
  Speed: 806 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 806 2: 837 3: 848
  4: 839 5: 839 6: 845 7: 848 8: 898
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
  xsaves xtopology xtpr
  Type: l1tf
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 530 vendor: Lenovo driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940MX] driver: N/A
  alternate: nouveau, nvidia_drm, nvidia bus-ID: 02:00.0 chip-ID: 10de:134d
  class-ID: 0302
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:7
  chip-ID: 04f2:b541 class-ID: 0e02 serial: <filter>
  Display: server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: modesetting unloaded: intel alternate: fbdev,vesa tty: 240x67
  Message: Advanced graphics data unavailable in console. Try -G --display
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
  class-ID: 0403
  Device-2: Logitech G933 Wireless Headset Dongle type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.4.3:8
  chip-ID: 046d:0a5b class-ID: 0300
  Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0
  bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
  bus-ID: 1-7:5 chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 238.47 GiB used: 155.56 GiB (65.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
  lanes: 2 type: SSD serial: <filter> rev: 510457LA temp: 26.9 C scheme: MBR
  ID-1: / raw-size: 204.72 GiB size: 200.51 GiB (97.94%)
  used: 155.56 GiB (77.6%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: 8d863701-ac77-4439-b64d-84676694cdcc
  ID-1: swap-1 type: partition size: 33.74 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  uuid: fb65c45f-5cfc-4936-98ac-211ad42c2936
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-3:2 info: Lenovo ThinkPad Ultra Dock Hub ports: 4 rev: 2.1
  speed: 480 Mb/s chip-ID: 17ef:1010 class-ID: 0900
  Device-1: 1-3.1:4 info: Razer USA DeathAdder 3.5G type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 1532:0016 class-ID: 0301
  Hub-3: 1-3.4:6 info: Lenovo ThinkPad Ultra Dock Hub ports: 3 rev: 2.0
  speed: 480 Mb/s power: 2mA chip-ID: 17ef:100f class-ID: 0900
  Device-1: 1-3.4.3:8 info: Logitech G933 Wireless Headset Dongle
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
  rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 046d:0a5b class-ID: 0300
  Device-2: 1-6:3 info: Validity Sensors VFS7500 Touch Fingerprint Sensor
  type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 138a:0090 class-ID: ff00 serial: <filter>
  Device-3: 1-7:5 info: Intel Bluetooth wireless interface type: Bluetooth
  Device-4: 1-8:7 info: Chicony Integrated Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b541
  Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
  Hub-5: 2-4:2 info: Lenovo ThinkPad Ultra Dock Hub ports: 4 rev: 3.0
  speed: 5 Gb/s chip-ID: 17ef:1010 class-ID: 0900
  System Temperatures: cpu: 35.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 263 Uptime: 7m wakeups: 2 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1428 lib: 405
  flatpak: 0 Shell: Zsh (login) v: 5.8 running-in: tty 4 inxi: 3.3.06
Heya, welcome to the forum :wave:
I’ve never had to do this but if I had to fix this I would log into the console (Press Ctrl+Alt+F2 and switch to TTY2. You can also try Ctrl+Alt+F3 for TTY3 if required.)
Use gsettings to reset the value you changed. See a example how to approach this issue here
$ gsettings list-recursively org.gnome.desktop.a11y.applications
lists these values:
org.gnome.desktop.a11y.applications screen-keyboard-enabled false
org.gnome.desktop.a11y.applications screen-magnifier-enabled false
org.gnome.desktop.a11y.applications screen-reader-enabled false
$ gsettings get org.gnome.desktop.a11y.applications screen-magnifier-enabled should output false or true
Turn on magnification:
$ gsettings set org.gnome.desktop.a11y.applications screen-magnifier-enabled true
Turn off magnification:
$ gsettings set org.gnome.desktop.a11y.applications screen-magnifier-enabled false
A easy way to find values is with dconf with is a visual tool with a search option. If you have a install medium you can play around with it in a live session to see what works for you and your hardware without braking your system next time :slight_smile:
Hope this helps, if you have more questions or issues don’t hesitate to follow up on this.
