Stuck in Emergency Mode after update
Hi all,
After the latest updatem I keep getting booted into emergency mode. This happebed after the last time the Kernal updated, but it somehow fixed itself, or I did something without realizing it. However now I can’t seem to sort it.
I have two installs of Manjaro, one on an SSD, which is the one I am using now and boots fine, and another on an nvme PCI, which is the one I use and is the one which is stuck. The problem seems to be that on the grub it claims to be Kernal 5.21 (or whatever), but on the ‘E’ selection still shows 5.15.
I have booted into the root of the nvme (using manjaro-chroot -a) and tried Syyuu and updating the grub, but this doesn’t seem to have done anything, and attempts to use Syu or a variant seem to run into a time out failure during the ‘commnity’ section. This might not be being helped by my internet which seems to be a bit dodgy tonight.
The update error message is:
core 169.1 KiB 445 KiB/s 00:00 [#########################################################] 100%
extra 1854.2 KiB 323 KiB/s 00:06 [#########################################################] 100%
community 6.9 MiB 111 KiB/s 01:03 [#########################################################] 100%
multilib 182.0 KiB 719 KiB/s 00:00 [#########################################################] 100%
error: failed retrieving file ‘core.db’ from manjaro.mirrors.uk2.net : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file ‘extra.db’ from manjaro.mirrors.uk2.net : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file ‘community.db’ from manjaro.mirrors.uk2.net : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
warning: too many errors from manjaro.mirrors.uk2.net, skipping for the remainder of this transaction
:: Starting full system upgrade…
there is nothing to do
I have a feeling a lot of this is being caused by having two manjaro’s installed, and a motherboard that’s a bit too old to boot directly to a pci slot (the grub is on the SDD), so maybe when my install of manjaro updates, it doesn’t update the grub? PErhaps if I update the SDD manjaro it will fix itself, but I a reluctant to do that at the moment as it will mean I have nothing to boot to!
Any advice is much appreciated. Thanks!
A
Try looking for errors: [HowTo] Find error logs
So, it comes up with this:
journalctl --boot=-1 --priority=3 --catalog
Apr 29 20:56:12 andriko kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Apr 29 20:56:12 andriko kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Apr 29 20:56:12 andriko systemd[1]: Failed to start Load Kernel Modules.
Apr 29 20:56:12 andriko systemd-modules-load[246]: Failed to look up module alias 'crypto_user': Function not implemented
Apr 29 20:56:12 andriko systemd-modules-load[246]: Failed to look up module alias 'sg': Function not implemented
Apr 29 20:56:12 andriko systemd-modules-load[246]: Failed to look up module alias 'ipmi-devintf': Function not implemented
Apr 29 20:56:12 andriko systemd-modules-load[246]: Failed to look up module alias 'nvidia': Function not implemented
Apr 29 20:56:12 andriko systemd-modules-load[246]: Failed to look up module alias 'nvidia-drm': Function not implemented
Apr 29 20:56:12 andriko systemd-modules-load[246]: Failed to look up module alias 'nvidia-uvm': Function not implemented
Apr 29 20:56:12 andriko systemd-modules-load[246]: Failed to look up module alias 'uinput': Function not implemented
Apr 29 20:56:12 andriko systemd[1]: Failed to start CLI Netfilter Manager.
-- Subject: A start job for unit ufw.service has failed
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- A start job for unit ufw.service has finished with a failure.
-- The job identifier is 110 and the job result is failed.
Apr 29 20:56:13 andriko systemd[1]: Failed to mount /boot/efi.
-- Subject: A start job for unit boot-efi.mount has failed
-- A start job for unit boot-efi.mount has finished with a failure.
-- The job identifier is 27 and the job result is failed.
Apr 29 20:56:19 andriko systemd[1]: Failed to mount /boot/efi.
-- The job identifier is 205 and the job result is failed.
Apr 29 20:56:19 andriko systemd-modules-load[407]: Failed to look up module alias 'crypto_user': Function not implemented
Apr 29 20:56:19 andriko systemd-modules-load[407]: Failed to look up module alias 'sg': Function not implemented
Apr 29 20:56:19 andriko systemd-modules-load[407]: Failed to look up module alias 'ipmi-devintf': Function not implemented
Apr 29 20:56:19 andriko systemd-modules-load[407]: Failed to look up module alias 'nvidia': Function not implemented
Apr 29 20:56:19 andriko systemd-modules-load[407]: Failed to look up module alias 'nvidia-drm': Function not implemented
Apr 29 20:56:19 andriko systemd-modules-load[407]: Failed to look up module alias 'nvidia-uvm': Function not implemented
Apr 29 20:56:19 andriko systemd-modules-load[407]: Failed to look up module alias 'uinput': Function not implemented
Apr 29 20:56:19 andriko systemd[1]: Failed to start Load Kernel Modules.
-- Subject: A start job for unit systemd-modules-load.service has failed
-- A start job for unit systemd-modules-load.service has finished with a failure.
-- The job identifier is 203 and the job result is failed.
Apr 29 20:56:19 andriko systemd[1]: Failed to start CLI Netfilter Manager.
-- The job identifier is 287 and the job result is failed.
Please use preformatting: [HowTo] Use preformatting in a forum post
Thanks, it looks much more readable now! I still don’t understand it ofcourse!
I don’t know is the modules failed to be looked up are relevant or not, but that one is very likely problematic:
Since that service is enabled, your system should boot in EFI mode, and thus requires an EFI partition. That error would indicate your system fails to locate that partition.
We’d need to know your partitioning scheme:
lsblk -fa
cat /etc/fstab
lsblk -fa
NAME        FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
loop1
loop2
loop3
loop4
loop5
loop6
loop7
sda
`-sda1
sdb
|-sdb1
`-sdb2                                38.6G    61% /etc/resolv.conf
sr0
nvme0n1
|-nvme0n1p1                          299.1M     0% /boot/efi
`-nvme0n1p2                          820.6G     5% /
and then
cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=05A3-F0E7                            /boot/efi      vfat    umask=0077 0 2
UUID=66c976f4-de6f-474f-a37b-54eb615d2a84 /              ext4    defaults,noatime 0 1
If I entered them correctly!
This might also be worth mentioning, but when I do load Manjaro on the nvme, it comes up with a screen saying ‘unable to find 66c9… etc. press any key’. Usually, pressing any key goes to the log in screen and all works fine. I’ve always assumed this is because my motherboard doesn’t ‘see’ the nvme in the PCIe slot, but would it also be involved in causing he current problem?
UUIDs don’t show, weird… Plan B:
sudo parted -l
This seems wrong, but we’ll skip that for now…
sudo parted -l
Model: ATA ST1000DM003-1CH1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      1049kB  1000GB  1000GB  primary  ntfs
Model: ATA SanDisk SDSSDP12 (scsi)
Disk /dev/sdb: 126GB
Partition Table: gpt
Disk Flags:
Number  Start   End    Size   File system  Name  Flags
 1      2097kB  317MB  315MB  fat32              boot, esp
 2      317MB   126GB  126GB  ext4         root
Model: WDC WDS100T2B0C-00PXH0 (nvme)
Disk /dev/nvme0n1: 1000GB
Disk Flags:
 2      317MB   1000GB  1000GB  ext4         root
I think the way I have things set up is that the grub loads on the SSD (sdb), and I use that to boot the nvme.
The sdb2 might possibley be a timeshift I made as a back up a while ago.
Still no luck. Plan C:
sudo blkid
sudo blkid
/dev/nvme0n1p1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="05A3-F0E7" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="eb284ccd-b258-2743-beca-bdf2c072ab55"
/dev/nvme0n1p2: UUID="66c976f4-de6f-474f-a37b-54eb615d2a84" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="4e8cfdf1-23ae-f44f-80e9-1b42e8d12c4d"
/dev/sdb2: UUID="3e763b26-7f1e-4640-add1-80a070764657" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="b7233cf6-ddd4-a246-b259-fb3f320d395d"
/dev/sdb1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="2A86-1F6F" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="6bfe43ea-18cb-2e40-b91a-92f0c2120398"
/dev/sda1: BLOCK_SIZE="512" UUID="C6A0FADEA0FAD441" TYPE="ntfs" PARTUUID="a98dd33d-01"
Thanks for all the help, I didn’t realise I had made it so complicated!
No worries, it’s not your fault. :slight_smile:
So with this, we can confirm the UUIDs recorded /etc/fstab are the right ones, which is the first place for errors in mounting.
Now let’s dig further in the journal.
journalctl --boot=-1 --unit=boot-efi.mount
Thank you!
Apr 29 20:56:13 andriko systemd[1]: Mounting /boot/efi...
Apr 29 20:56:13 andriko mount[373]: mount: /boot/efi: unknown filesystem type 'vfat'.
Apr 29 20:56:13 andriko mount[373]:        dmesg(1) may have more information after failed mount system call.
Apr 29 20:56:13 andriko systemd[1]: boot-efi.mount: Mount process exited, code=exited, status=32/n/a
Apr 29 20:56:13 andriko systemd[1]: boot-efi.mount: Failed with result 'exit-code'.
Apr 29 20:56:19 andriko systemd[1]: Mounting /boot/efi...
Apr 29 20:56:19 andriko mount[402]: mount: /boot/efi: unknown filesystem type 'vfat'.
Apr 29 20:56:19 andriko mount[402]:        dmesg(1) may have more information after failed mount system call.
Apr 29 20:56:19 andriko systemd[1]: boot-efi.mount: Mount process exited, code=exited, status=32/n/a
Apr 29 20:56:19 andriko systemd[1]: boot-efi.mount: Failed with result 'exit-code'.
Let’s follow the suggestion.
sudo dmesg
It’s pretty huge, in fact I can’t even scroll back far enough to the command line where I entered the prompt.
[    0.024359] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.024361] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.024363] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.024365] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.024367] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.024379] e820: update [mem 0xce8d0000-0xceb10fff] usable ==> reserved
[    0.024388] TSC deadline timer available
[    0.024389] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.024418] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.024420] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.024422] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.024423] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.024425] PM: hibernation: Registered nosave memory: [mem 0xcba1b000-0xcba21fff]
[    0.024427] PM: hibernation: Registered nosave memory: [mem 0xcbe65000-0xcc3f5fff]
[    0.024428] PM: hibernation: Registered nosave memory: [mem 0xce8d0000-0xceb10fff]
[    0.024430] PM: hibernation: Registered nosave memory: [mem 0xdddad000-0xdde42fff]
[    0.024432] PM: hibernation: Registered nosave memory: [mem 0xdde93000-0xddfc7fff]
[    0.024433] PM: hibernation: Registered nosave memory: [mem 0xddfc8000-0xdef80fff]
[    0.024433] PM: hibernation: Registered nosave memory: [mem 0xdef81000-0xdeffefff]
[    0.024435] PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xf7ffffff]
[    0.024436] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.024436] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.024437] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.024438] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.024438] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.024439] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.024439] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.024440] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.024441] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.024441] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.024442] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.024443] [mem 0xdf000000-0xf7ffffff] available for PCI devices
[    0.024445] Booting paravirtualized kernel on bare hardware
[    0.024447] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.028350] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.028507] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
[    0.028514] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
[    0.028516] pcpu-alloc: [0] 0 1 2 3
[    0.028539] Built 1 zonelists, mobility grouping on.  Total pages: 2050116
[    0.028540] Policy zone: Normal
[    0.028541] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=3e763b26-7f1e-4640-add1-80a070764657 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    0.028603] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
[    0.028956] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.029168] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.029313] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[    0.060869] Memory: 7835244K/8331276K available (14344K kernel code, 2097K rwdata, 10880K rodata, 1864K init, 3776K bss, 495772K reserved, 0K cma-reserved)
[    0.060875] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[    0.060993] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.061003] Kernel/User page tables isolation: enabled
[    0.061020] ftrace: allocating 44461 entries in 174 pages
[    0.073106] ftrace: allocated 174 pages with 5 groups
[    0.073188] rcu: Preemptible hierarchical RCU implementation.
[    0.073189] rcu:     RCU dyntick-idle grace-period acceleration is enabled.
[    0.073189] rcu:     RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.073190] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.073191]  Trampoline variant of Tasks RCU enabled.
[    0.073191]  Rude variant of Tasks RCU enabled.
[    0.073192]  Tracing variant of Tasks RCU enabled.
[    0.073192] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.073193] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.076166] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[    0.076414] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.076508] Console: colour dummy device 80x25
[    0.076519] printk: console [tty0] enabled
[    0.076535] ACPI: Core revision 20210730
[    0.076626] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.076639] APIC: Switch to symmetric I/O mode setup
[    0.076954] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[    0.093304] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x31031c012fe, max_idle_ns: 440795310641 ns
[    0.093307] Calibrating delay loop (skipped), value calculated using timer frequency.. 6803.78 BogoMIPS (lpj=11334056)
[    0.093309] pid_max: default: 32768 minimum: 301
[    0.098532] LSM: Security Framework initializing
[    0.098539] landlock: Up and running.
[    0.098539] Yama: becoming mindful.
[    0.098558] AppArmor: AppArmor initialized
[    0.098582] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.098598] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.098799] CPU0: Thermal monitoring enabled (TM1)
[    0.098829] process: using mwait in idle threads
[    0.098831] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[    0.098832] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[    0.098835] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.098837] Spectre V2 : Mitigation: Retpolines
[    0.098837] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.098838] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.098839] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.098841] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.098843] SRBDS: Mitigation: Microcode
[    0.098844] MDS: Mitigation: Clear CPU buffers
[    0.101019] Freeing SMP alternatives memory: 36K
[    0.103365] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1084
[    0.103371] smpboot: CPU0: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[    0.103484] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.103507] ... version:                3
[    0.103507] ... bit width:              48
[    0.103508] ... generic registers:      8
[    0.103508] ... value mask:             0000ffffffffffff
[    0.103509] ... max period:             00007fffffffffff
[    0.103510] ... fixed-purpose events:   3
[    0.103510] ... event mask:             00000007000000ff
[    0.103601] rcu: Hierarchical SRCU implementation.
[    0.104107] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.104145] smp: Bringing up secondary CPUs ...
[    0.104224] x86: Booting SMP configuration:
[    0.104225] .... node  #0, CPUs:      #1 #2 #3
[    0.108102] smp: Brought up 1 node, 4 CPUs
[    0.108102] smpboot: Max logical packages: 1
[    0.108102] smpboot: Total of 4 processors activated (27212.14 BogoMIPS)
[    0.110214] devtmpfs: initialized
[    0.110214] x86/mm: Memory block size: 128MB
[    0.110390] ACPI: PM: Registering ACPI NVS region [mem 0xcba1b000-0xcba21fff] (28672 bytes)
[    0.110390] ACPI: PM: Registering ACPI NVS region [mem 0xdde93000-0xddfc7fff] (1265664 bytes)
[    0.110390] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.110390] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.110390] pinctrl core: initialized pinctrl subsystem
[    0.110390] PM: RTC time: 10:56:13, date: 2022-04-30
[    0.110390] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.110390] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.110422] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.110472] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.110479] audit: initializing netlink subsys (disabled)
[    0.110484] audit: type=2000 audit(1651316173.033:1): state=initialized audit_enabled=0 res=1
[    0.110484] thermal_sys: Registered thermal governor 'fair_share'
[    0.110484] thermal_sys: Registered thermal governor 'bang_bang'
[    0.110484] thermal_sys: Registered thermal governor 'step_wise'
[    0.110484] thermal_sys: Registered thermal governor 'user_space'
[    0.110484] thermal_sys: Registered thermal governor 'power_allocator'
[    0.110484] cpuidle: using governor ladder
[    0.110484] cpuidle: using governor menu
[    0.110484] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[    0.110484] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.110484] ACPI: bus type PCI registered
[    0.110484] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.110484] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.110484] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.110484] PCI: Using configuration type 1 for base access
[    0.110484] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.111185] Kprobes globally optimized
[    0.111189] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[    0.111189] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.111189] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.113378] ACPI: Added _OSI(Module Device)
[    0.113379] ACPI: Added _OSI(Processor Device)
[    0.113380] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.113381] ACPI: Added _OSI(Processor Aggregator Device)
[    0.113382] ACPI: Added _OSI(Linux-Dell-Video)
[    0.113382] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.113383] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.123097] ACPI: 6 ACPI AML tables successfully acquired and loaded
[    0.124133] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.125070] ACPI: Dynamic OEM Table Load:
[    0.125075] ACPI: SSDT 0xFFFFA02440272800 0003D3 (v01 PmRef  Cpu0Cst  00003001 INTL 20120711)
[    0.125834] ACPI: Dynamic OEM Table Load:
[    0.125838] ACPI: SSDT 0xFFFFA02440B7B800 0005AA (v01 PmRef  ApIst    00003000 INTL 20120711)
[    0.126688] ACPI: Dynamic OEM Table Load:
[    0.126692] ACPI: SSDT 0xFFFFA02440217E00 000119 (v01 PmRef  ApCst    00003000 INTL 20120711)
[    0.128158] ACPI: Interpreter enabled
[    0.128181] ACPI: PM: (supports S0 S3 S4 S5)
[    0.128182] ACPI: Using IOAPIC for interrupt routing
[    0.128204] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.128529] ACPI: Enabled 7 GPEs in block 00 to 3F
[    0.136740] ACPI: PM: Power Resource [FN00]
[    0.136797] ACPI: PM: Power Resource [FN01]
[    0.136852] ACPI: PM: Power Resource [FN02]
[    0.136905] ACPI: PM: Power Resource [FN03]
[    0.136958] ACPI: PM: Power Resource [FN04]
[    0.137626] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.137631] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.137878] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.138031] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    0.138033] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.138466] PCI host bridge to bus 0000:00
[    0.138467] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.138469] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.138470] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.138471] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.138472] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.138473] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.138474] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.138475] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[    0.138477] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.138512] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.138639] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[    0.138669] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.139040] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[    0.139055] pci 0000:00:14.0: reg 0x10: [mem 0xf7400000-0xf740ffff 64bit]
[    0.139107] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.139191] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[    0.139206] pci 0000:00:16.0: reg 0x10: [mem 0xf741a000-0xf741a00f 64bit]
[    0.139259] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.139383] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[    0.139396] pci 0000:00:1a.0: reg 0x10: [mem 0xf7418000-0xf74183ff]
[    0.139468] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.139579] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[    0.139592] pci 0000:00:1b.0: reg 0x10: [mem 0xf7410000-0xf7413fff 64bit]
[    0.139645] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.139754] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[    0.139819] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.140158] pci 0000:00:1c.5: [8086:8c1a] type 01 class 0x060400
[    0.140223] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.140553] pci 0000:00:1c.6: [8086:244e] type 01 class 0x060401
[    0.140618] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    0.140946] pci 0000:00:1c.7: [8086:8c1e] type 01 class 0x060400
[    0.141010] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[    0.141347] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[    0.141361] pci 0000:00:1d.0: reg 0x10: [mem 0xf7417000-0xf74173ff]
[    0.141434] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.141547] pci 0000:00:1f.0: [8086:8c44] type 00 class 0x060100
[    0.141736] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[    0.141747] pci 0000:00:1f.2: reg 0x10: [io  0xf070-0xf077]
[    0.141753] pci 0000:00:1f.2: reg 0x14: [io  0xf060-0xf063]
[    0.141759] pci 0000:00:1f.2: reg 0x18: [io  0xf050-0xf057]
[    0.141765] pci 0000:00:1f.2: reg 0x1c: [io  0xf040-0xf043]
[    0.141771] pci 0000:00:1f.2: reg 0x20: [io  0xf020-0xf03f]
[    0.141777] pci 0000:00:1f.2: reg 0x24: [mem 0xf7416000-0xf74167ff]
[    0.141806] pci 0000:00:1f.2: PME# supported from D3hot
[    0.141907] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[    0.141921] pci 0000:00:1f.3: reg 0x10: [mem 0xf7415000-0xf74150ff 64bit]
[    0.141938] pci 0000:00:1f.3: reg 0x20: [io  0xf000-0xf01f]
[    0.142027] pci 0000:01:00.0: [10de:11c0] type 00 class 0x030000
[    0.142037] pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[    0.142046] pci 0000:01:00.0: reg 0x14: [mem 0xe8000000-0xefffffff 64bit pref]
[    0.142055] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[    0.142061] pci 0000:01:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.142067] pci 0000:01:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[    0.142081] pci 0000:01:00.0: BAR 3: assigned to efifb
[    0.142085] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.142138] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.142191] pci 0000:01:00.1: [10de:0e0b] type 00 class 0x040300
[    0.142201] pci 0000:01:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[    0.142306] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.142308] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.142309] pci 0000:00:01.0:   bridge window [mem 0xf6000000-0xf70fffff]
[    0.142312] pci 0000:00:01.0:   bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[    0.142381] pci 0000:02:00.0: [15b7:5009] type 00 class 0x010802
[    0.142404] pci 0000:02:00.0: reg 0x10: [mem 0xf7300000-0xf7303fff 64bit]
[    0.142436] pci 0000:02:00.0: reg 0x20: [mem 0xf7304000-0xf73040ff 64bit]
[    0.142575] pci 0000:02:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:1c.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    0.142637] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.142641] pci 0000:00:1c.0:   bridge window [mem 0xf7300000-0xf73fffff]
[    0.142713] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[    0.142732] pci 0000:03:00.0: reg 0x10: [io  0xd000-0xd0ff]
[    0.142759] pci 0000:03:00.0: reg 0x18: [mem 0xf7200000-0xf7200fff 64bit]
[    0.142775] pci 0000:03:00.0: reg 0x20: [mem 0xf2100000-0xf2103fff 64bit pref]
[    0.142874] pci 0000:03:00.0: supports D1 D2
[    0.142875] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.142996] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.142998] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.143001] pci 0000:00:1c.5:   bridge window [mem 0xf7200000-0xf72fffff]
[    0.143006] pci 0000:00:1c.5:   bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[    0.143074] pci 0000:04:00.0: [1b21:1080] type 01 class 0x060400
[    0.143214] pci 0000:04:00.0: supports D1 D2
[    0.143215] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.149985] pci 0000:00:1c.6: PCI bridge to [bus 04-05] (subtractive decode)
[    0.149992] pci 0000:00:1c.6:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.149994] pci 0000:00:1c.6:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.149995] pci 0000:00:1c.6:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.149996] pci 0000:00:1c.6:   bridge window [mem 0x000d0000-0x000d3fff window] (subtractive decode)
[    0.149997] pci 0000:00:1c.6:   bridge window [mem 0x000d4000-0x000d7fff window] (subtractive decode)
[    0.149998] pci 0000:00:1c.6:   bridge window [mem 0x000d8000-0x000dbfff window] (subtractive decode)
[    0.149999] pci 0000:00:1c.6:   bridge window [mem 0x000dc000-0x000dffff window] (subtractive decode)
[    0.150000] pci 0000:00:1c.6:   bridge window [mem 0xe0000000-0xfeafffff window] (subtractive decode)
[    0.150048] pci_bus 0000:05: extended config space not accessible
[    0.150115] pci 0000:04:00.0: PCI bridge to [bus 05]
[    0.150208] pci 0000:06:00.0: [168c:0034] type 00 class 0x028000
[    0.150229] pci 0000:06:00.0: reg 0x10: [mem 0xf7100000-0xf717ffff 64bit]
[    0.150264] pci 0000:06:00.0: reg 0x30: [mem 0xf7180000-0xf718ffff pref]
[    0.150339] pci 0000:06:00.0: supports D1 D2
[    0.150340] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.150443] pci 0000:00:1c.7: PCI bridge to [bus 06]
[    0.150448] pci 0000:00:1c.7:   bridge window [mem 0xf7100000-0xf71fffff]
[    0.151232] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[    0.151283] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    0.151331] ACPI: PCI: Interrupt link LNKC configured for IRQ 10
[    0.151381] ACPI: PCI: Interrupt link LNKD configured for IRQ 3
[    0.151428] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.151429] ACPI: PCI: Interrupt link LNKE disabled
[    0.151476] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.151477] ACPI: PCI: Interrupt link LNKF disabled
[    0.151525] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[    0.151573] ACPI: PCI: Interrupt link LNKH configured for IRQ 3
[    0.151937] iommu: Default domain type: Translated
[    0.151938] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.151948] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.151948] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.151948] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.151948] vgaarb: loaded
[    0.151948] SCSI subsystem initialized
[    0.151948] libata version 3.00 loaded.
[    0.151948] ACPI: bus type USB registered
[    0.151948] usbcore: registered new interface driver usbfs
[    0.151948] usbcore: registered new interface driver hub
[    0.151948] usbcore: registered new device driver usb
[    0.151948] pps_core: LinuxPPS API ver. 1 registered
[    0.151948] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.151948] PTP clock support registered
[    0.151948] EDAC MC: Ver: 3.0.0
[    0.151948] Registered efivars operations
[    0.151948] NetLabel: Initializing
[    0.151948] NetLabel:  domain hash size = 128
[    0.151948] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.151948] NetLabel:  unlabeled traffic allowed by default
[    0.151948] PCI: Using ACPI for IRQ routing
[    0.153529] PCI: pci_cache_line_size set to 64 bytes
[    0.153577] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.153579] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.153579] e820: reserve RAM buffer [mem 0xcba1b000-0xcbffffff]
[    0.153580] e820: reserve RAM buffer [mem 0xcbe65000-0xcbffffff]
[    0.153581] e820: reserve RAM buffer [mem 0xce8d0000-0xcfffffff]
[    0.153582] e820: reserve RAM buffer [mem 0xdddad000-0xdfffffff]
[    0.153583] e820: reserve RAM buffer [mem 0xdde93000-0xdfffffff]
[    0.153584] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[    0.153585] e820: reserve RAM buffer [mem 0x21f000000-0x21fffffff]
[    0.153952] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.153958] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.156007] clocksource: Switched to clocksource tsc-early
[    0.159921] VFS: Disk quotas dquot_6.6.0
[    0.159934] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.160030] AppArmor: AppArmor Filesystem Enabled
[    0.160061] pnp: PnP ACPI init
[    0.160162] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.160354] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.160356] system 00:01: [io  0xffff] has been reserved
[    0.160357] system 00:01: [io  0xffff] has been reserved
[    0.160358] system 00:01: [io  0xffff] has been reserved
[    0.160360] system 00:01: [io  0x1c00-0x1cfe] has been reserved
[    0.160361] system 00:01: [io  0x1d00-0x1dfe] has been reserved
[    0.160362] system 00:01: [io  0x1e00-0x1efe] has been reserved
[    0.160363] system 00:01: [io  0x1f00-0x1ffe] has been reserved
[    0.160364] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.160365] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.160423] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.160527] system 00:04: [io  0x0a00-0x0a0f] has been reserved
[    0.160529] system 00:04: [io  0x0a10-0x0a1f] has been reserved
[    0.160678] pnp 00:05: [dma 0 disabled]
[    0.160936] pnp 00:06: [dma 0 disabled]
[    0.161048] system 00:07: [io  0x04d0-0x04d1] has been reserved
[    0.161467] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.161469] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.161471] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.161473] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.161474] system 00:08: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.161476] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.161477] system 00:08: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.161479] system 00:08: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.161480] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[    0.161483] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.161484] system 00:08: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[    0.161486] system 00:08: [mem 0xf7fe0000-0xf7feffff] has been reserved
[    0.161712] pnp: PnP ACPI: found 9 devices
[    0.167048] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.167094] NET: Registered PF_INET protocol family
[    0.167168] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.168121] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.168157] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.168256] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.168369] TCP: Hash tables configured (established 65536 bind 65536)
[    0.168412] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    0.168447] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.168466] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.168499] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.168504] NET: Registered PF_XDP protocol family
[    0.168513] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.168516] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.168518] pci 0000:00:01.0:   bridge window [mem 0xf6000000-0xf70fffff]
[    0.168520] pci 0000:00:01.0:   bridge window [mem 0xe8000000-0xf1ffffff 64bit pref]
[    0.168523] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.168527] pci 0000:00:1c.0:   bridge window [mem 0xf7300000-0xf73fffff]
[    0.168533] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.168535] pci 0000:00:1c.5:   bridge window [io  0xd000-0xdfff]
[    0.168539] pci 0000:00:1c.5:   bridge window [mem 0xf7200000-0xf72fffff]
[    0.168542] pci 0000:00:1c.5:   bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
[    0.168546] pci 0000:04:00.0: PCI bridge to [bus 05]
[    0.168562] pci 0000:00:1c.6: PCI bridge to [bus 04-05]
[    0.168570] pci 0000:00:1c.7: PCI bridge to [bus 06]
[    0.168574] pci 0000:00:1c.7:   bridge window [mem 0xf7100000-0xf71fffff]
[    0.168581] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.168582] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.168583] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.168584] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.168585] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.168586] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.168587] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.168588] pci_bus 0000:00: resource 11 [mem 0xe0000000-0xfeafffff window]
[    0.168590] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.168591] pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
[    0.168592] pci_bus 0000:01: resource 2 [mem 0xe8000000-0xf1ffffff 64bit pref]
[    0.168593] pci_bus 0000:02: resource 1 [mem 0xf7300000-0xf73fffff]
[    0.168594] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[    0.168595] pci_bus 0000:03: resource 1 [mem 0xf7200000-0xf72fffff]
[    0.168596] pci_bus 0000:03: resource 2 [mem 0xf2100000-0xf21fffff 64bit pref]
[    0.168597] pci_bus 0000:04: resource 4 [io  0x0000-0x0cf7 window]
[    0.168598] pci_bus 0000:04: resource 5 [io  0x0d00-0xffff window]
[    0.168599] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.168600] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.168601] pci_bus 0000:04: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.168602] pci_bus 0000:04: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.168603] pci_bus 0000:04: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.168604] pci_bus 0000:04: resource 11 [mem 0xe0000000-0xfeafffff window]
[    0.168606] pci_bus 0000:06: resource 1 [mem 0xf7100000-0xf71fffff]
[    0.169088] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.169098] pci 0000:04:00.0: Disabling ASPM L0s/L1
[    0.169100] pci 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[    0.169105] PCI: CLS 64 bytes, default 64
[    0.169109] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.169110] software IO TLB: mapped [mem 0x00000000c7a1b000-0x00000000cba1b000] (64MB)
[    0.169144] Trying to unpack rootfs image as initramfs...
[    0.177004] Initialise system trusted keyrings
[    0.177013] Key type blacklist registered
[    0.177050] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[    0.177946] zbud: loaded
[    0.186405] Key type asymmetric registered
[    0.186406] Asymmetric key parser 'x509' registered
[    0.186419] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.186442] io scheduler mq-deadline registered
[    0.186443] io scheduler kyber registered
[    0.186469] io scheduler bfq registered
[    0.187149] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.187385] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.187444] ACPI: button: Power Button [PWRB]
[    0.187474] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.187493] ACPI: button: Power Button [PWRF]
[    0.187967] thermal LNXTHERM:00: registered as thermal_zone0
[    0.187969] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    0.188186] thermal LNXTHERM:01: registered as thermal_zone1
[    0.188187] ACPI: thermal: Thermal Zone [TZ01] (30 C)
[    0.188293] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.188425] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.189694] Non-volatile memory driver v1.3
[    0.189695] Linux agpgart interface v0.103
[    0.189696] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    0.190062] nvme nvme0: pci function 0000:02:00.0
[    0.190084] ahci 0000:00:1f.2: version 3.0
[    0.190274] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x13 impl SATA mode
[    0.190277] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[    0.203257] nvme nvme0: allocated 32 MiB host memory buffer.
[    0.206760] nvme nvme0: 4/0/0 default/read/poll queues
[    0.213836] scsi host0: ahci
[    0.214019] scsi host1: ahci
[    0.214108] scsi host2: ahci
[    0.214188] scsi host3: ahci
[    0.214241] scsi host4: ahci
[    0.214293] scsi host5: ahci
[    0.214317] ata1: SATA max UDMA/133 abar m2048@0xf7416000 port 0xf7416100 irq 30
[    0.214320] ata2: SATA max UDMA/133 abar m2048@0xf7416000 port 0xf7416180 irq 30
[    0.214321] ata3: DUMMY
[    0.214321] ata4: DUMMY
[    0.214323] ata5: SATA max UDMA/133 abar m2048@0xf7416000 port 0xf7416300 irq 30
[    0.214324] ata6: DUMMY
[    0.214355] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.214359] ehci-pci: EHCI PCI platform driver
[    0.214483] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.214488] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.214498] ehci-pci 0000:00:1a.0: debug port 2
[    0.218407] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7418000
[    0.220879]  nvme0n1: p1 p2
[    0.230009] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.230044] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    0.230046] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.230047] usb usb1: Product: EHCI Host Controller
[    0.230049] usb usb1: Manufacturer: Linux 5.15.28-1-MANJARO ehci_hcd
[    0.230050] usb usb1: SerialNumber: 0000:00:1a.0
[    0.230157] hub 1-0:1.0: USB hub found
[    0.230162] hub 1-0:1.0: 2 ports detected
[    0.230355] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.230360] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    0.230368] ehci-pci 0000:00:1d.0: debug port 2
[    0.234274] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7417000
[    0.246664] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.246695] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    0.246697] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.246698] usb usb2: Product: EHCI Host Controller
[    0.246700] usb usb2: Manufacturer: Linux 5.15.28-1-MANJARO ehci_hcd
[    0.246701] usb usb2: SerialNumber: 0000:00:1d.0
[    0.246806] hub 2-0:1.0: USB hub found
[    0.246811] hub 2-0:1.0: 2 ports detected
[    0.246930] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.246933] ohci-pci: OHCI PCI platform driver
[    0.246940] uhci_hcd: USB Universal Host Controller Interface driver
[    0.246967] usbcore: registered new interface driver usbserial_generic
[    0.246970] usbserial: USB Serial support registered for generic
[    0.247087] rtc_cmos 00:02: RTC can wake from S4
[    0.247304] rtc_cmos 00:02: registered as rtc0
[    0.247336] rtc_cmos 00:02: setting system clock to 2022-04-30T10:56:13 UTC (1651316173)
[    0.247348] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.247461] intel_pstate: Intel P-state driver initializing
[    0.247679] ledtrig-cpu: registered to indicate activity on CPUs
[    0.247856] efifb: probing for efifb
[    0.247868] efifb: showing boot graphics
[    0.249215] efifb: framebuffer at 0xf1000000, using 3072k, total 3072k
[    0.249217] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    0.249218] efifb: scrolling: redraw
[    0.249218] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.249256] fbcon: Deferring console take-over
[    0.249257] fb0: EFI VGA frame buffer device
[    0.249286] hid: raw HID events driver (C) Jiri Kosina
[    0.249356] ashmem: initialized
[    0.249427] drop_monitor: Initializing network drop monitor service
[    0.249473] Initializing XFRM netlink socket
[    0.249533] NET: Registered PF_INET6 protocol family
[    0.260673] Freeing initrd memory: 13144K
[    0.264748] Segment Routing with IPv6
[    0.264749] RPL Segment Routing with IPv6
[    0.264765] In-situ OAM (IOAM) with IPv6
[    0.264781] NET: Registered PF_PACKET protocol family
[    0.265170] microcode: sig=0x306c3, pf=0x2, revision=0x28
[    0.265230] microcode: Microcode Update Driver: v2.2.
[    0.265246] IPI shorthand broadcast: enabled
[    0.265254] sched_clock: Marking stable (264814194, 289061)->(275193733, -10090478)
[    0.265409] registered taskstats version 1
[    0.265558] Loading compiled-in X.509 certificates
[    0.267983] Loaded X.509 cert 'Build time autogenerated kernel key: 43fc9945725818abff4eb549eed62d04b329cee2'
[    0.268510] zswap: loaded using pool zstd/z3fold
[    0.268831] Key type ._fscrypt registered
[    0.268832] Key type .fscrypt registered
[    0.268833] Key type fscrypt-provisioning registered
[    0.268863] AppArmor: AppArmor sha1 policy hashing enabled
[    0.269053] PM:   Magic number: 2:194:933
[    0.269201] RAS: Correctable Errors collector initialized.
[    0.480009] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    0.500007] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    0.526867] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.526883] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.526897] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    0.527534] ata1.00: ATA-9: ST1000DM003-1CH162, CC47, max UDMA/133
[    0.527723] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    0.527785] ata2.00: ATA-9: SanDisk SDSSDP128G, 3.1.0, max UDMA/133
[    0.527798] ata2.00: 246162672 sectors, multi 1: LBA48 NCQ (depth 32)
[    0.528595] ata1.00: configured for UDMA/133
[    0.528674] ata2.00: Features: Dev-Sleep
[    0.528718] scsi 0:0:0:0: Direct-Access     ATA      ST1000DM003-1CH1 CC47 PQ: 0 ANSI: 5
[    0.529146] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    0.529153] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    0.529173] sd 0:0:0:0: [sda] Write Protect is off
[    0.529180] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.529214] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.529594] ata2.00: configured for UDMA/133
[    0.529664] scsi 1:0:0:0: Direct-Access     ATA      SanDisk SDSSDP12 0    PQ: 0 ANSI: 5
[    0.529868] sd 1:0:0:0: [sdb] 246162672 512-byte logical blocks: (126 GB/117 GiB)
[    0.529906] sd 1:0:0:0: [sdb] Write Protect is off
[    0.529908] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    0.529945] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.529953] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
[    0.529959] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.529965] ata5.00: ATAPI: PIONEER BD-ROM  BDC-207D, 1.00, max UDMA/100
[    0.533403] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
[    0.533409] ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    0.533415] ata5.00: configured for UDMA/100
[    0.544161] scsi 4:0:0:0: CD-ROM            PIONEER  BD-ROM  BDC-207D 1.00 PQ: 0 ANSI: 5
[    0.561896]  sda: sda1
[    0.569855]  sdb: sdb1 sdb2
[    0.590300] sd 0:0:0:0: [sda] Attached SCSI disk
[    0.600300] sd 1:0:0:0: [sdb] Attached SCSI disk
[    0.602924] Freeing unused decrypted memory: 2036K
[    0.603453] Freeing unused kernel image (initmem) memory: 1864K
[    0.603516] Write protecting the kernel read-only data: 28672k
[    0.604327] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    0.604785] Freeing unused kernel image (rodata/data gap) memory: 1408K
[    0.627098] usb 1-1: New USB device found, idVendor=8087, idProduct=8008, bcdDevice= 0.04
[    0.627106] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    0.627402] hub 1-1:1.0: USB hub found
[    0.627573] hub 1-1:1.0: 6 ports detected
[    0.647059] usb 2-1: New USB device found, idVendor=8087, idProduct=8000, bcdDevice= 0.04
[    0.647062] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    0.647337] hub 2-1:1.0: USB hub found
[    0.647433] hub 2-1:1.0: 8 ports detected
[    0.672167] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.672170] rodata_test: all tests were successful
[    0.672171] x86/mm: Checking user space page tables
[    0.713004] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.713006] Run /init as init process
[    0.713007]   with arguments:
[    0.713008]     /init
[    0.713009]   with environment:
[    0.713009]     HOME=/
[    0.713010]     TERM=linux
[    0.713010]     BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
[    0.813679] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.813685] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    0.814754] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[    0.814886] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    0.814889] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.814890] usb usb3: Product: xHCI Host Controller
[    0.814891] usb usb3: Manufacturer: Linux 5.15.28-1-MANJARO xhci-hcd
[    0.814892] usb usb3: SerialNumber: 0000:00:14.0
[    0.814982] hub 3-0:1.0: USB hub found
[    0.814997] hub 3-0:1.0: 14 ports detected
[    0.817403] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.817406] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    0.817409] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    0.817435] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    0.817437] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.817438] usb usb4: Product: xHCI Host Controller
[    0.817439] usb usb4: Manufacturer: Linux 5.15.28-1-MANJARO xhci-hcd
[    0.817440] usb usb4: SerialNumber: 0000:00:14.0
[    0.817572] hub 4-0:1.0: USB hub found
[    0.817584] hub 4-0:1.0: 6 ports detected
[    0.853755] sr 4:0:0:0: [sr0] scsi3-mmc drive: 125x/125x writer cd/rw xa/form2 cdda tray
[    0.853768] cdrom: Uniform CD-ROM driver Revision: 3.20
[    0.868158] random: fast init done
[    0.909849] sr 4:0:0:0: Attached scsi CD-ROM sr0
[    1.070005] usb 3-5: new full-speed USB device number 2 using xhci_hcd
[    1.193342] tsc: Refined TSC clocksource calibration: 3399.997 MHz
[    1.193346] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x31024bd20a6, max_idle_ns: 440795346804 ns
[    1.193388] clocksource: Switched to clocksource tsc
[    1.212704] usb 3-5: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
[    1.212717] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.212718] usb 3-5: Product: USB Receiver
[    1.212719] usb 3-5: Manufacturer: Logitech
[    1.232861] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.0/0003:046D:C52B.0001/input/input2
[    1.287327] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-5/input0
[    1.290046] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.1/0003:046D:C52B.0002/input/input3
[    1.290170] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.1/0003:046D:C52B.0002/input/input4
[    1.336709] usb 3-8: new full-speed USB device number 3 using xhci_hcd
[    1.346969] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.1/0003:046D:C52B.0002/input/input5
[    1.347512] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-5/input1
[    1.349537] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-5/input2
[    1.349608] usbcore: registered new interface driver usbhid
[    1.349612] usbhid: USB HID core driver
[    1.478151] usb 3-8: string descriptor 0 read error: -22
[    1.478153] usb 3-8: New USB device found, idVendor=04ca, idProduct=3006, bcdDevice= 0.02
[    1.478155] usb 3-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.540660] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-5/input2
[    1.599978] usb 3-9: new high-speed USB device number 4 using xhci_hcd
[    1.655249] input: Logitech Wireless Device PID:4031 Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.2/0003:046D:C52B.0003/0003:046D:4031.0004/input/input7
[    1.655503] hid-generic 0003:046D:4031.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Device PID:4031] on usb-0000:00:14.0-5/input2:1
[    1.656937] input: Logitech Wireless Device PID:2011 Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.2/0003:046D:C52B.0003/0003:046D:2011.0005/input/input11
[    1.657049] hid-generic 0003:046D:2011.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Device PID:2011] on usb-0000:00:14.0-5/input2:2
[    1.706687] input: Logitech M310/M310t as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.2/0003:046D:C52B.0003/0003:046D:4031.0004/input/input15
[    1.706880] logitech-hidpp-device 0003:046D:4031.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M310/M310t] on usb-0000:00:14.0-5/input2:1
[    1.740797] usb 3-9: New USB device found, idVendor=1397, idProduct=0509, bcdDevice= 1.12
[    1.740809] usb 3-9: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[    1.740814] usb 3-9: Product: UMC404HD 192k
[    1.740818] usb 3-9: Manufacturer: BEHRINGER
[    1.783059] input: Logitech K520 as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.2/0003:046D:C52B.0003/0003:046D:2011.0005/input/input16
[    1.783480] logitech-hidpp-device 0003:046D:2011.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K520] on usb-0000:00:14.0-5/input2:2
[    1.815436] fbcon: Taking over console
[    1.815552] Console: switching to colour frame buffer device 128x48
[    1.880862] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    2.072190] systemd[1]: systemd 250.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    2.086763] systemd[1]: Detected architecture x86-64.
[    2.088554] systemd[1]: Hostname set to <andreas-ms7850>.
[    2.443297] systemd[1]: Queued start job for default target Graphical Interface.
[    2.444091] systemd[1]: Created slice Slice /system/getty.
[    2.444288] systemd[1]: Created slice Slice /system/modprobe.
[    2.444472] systemd[1]: Created slice Slice /system/systemd-fsck.
[    2.444614] systemd[1]: Created slice User and Session Slice.
[    2.444663] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.444697] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.444800] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.444823] systemd[1]: Reached target Local Encrypted Volumes.
[    2.444833] systemd[1]: Reached target Login Prompts.
[    2.444843] systemd[1]: Reached target Local Integrity Protected Volumes.
[    2.444858] systemd[1]: Reached target Remote File Systems.
[    2.444866] systemd[1]: Reached target Slice Units.
[    2.444881] systemd[1]: Reached target Swaps.
[    2.444892] systemd[1]: Reached target Local Verity Protected Volumes.
[    2.444942] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.445010] systemd[1]: Listening on LVM2 poll daemon socket.
[    2.445824] systemd[1]: Listening on Process Core Dump Socket.
[    2.445938] systemd[1]: Listening on Journal Audit Socket.
[    2.446014] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.446088] systemd[1]: Listening on Journal Socket.
[    2.448323] systemd[1]: Listening on udev Control Socket.
[    2.448387] systemd[1]: Listening on udev Kernel Socket.
[    2.448909] systemd[1]: Mounting Huge Pages File System...
[    2.449375] systemd[1]: Mounting POSIX Message Queue File System...
[    2.449902] systemd[1]: Mounting Kernel Debug File System...
[    2.450465] systemd[1]: Mounting Kernel Trace File System...
[    2.451085] systemd[1]: Starting Load AppArmor profiles...
[    2.451797] systemd[1]: Starting Create List of Static Device Nodes...
[    2.452378] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    2.453005] systemd[1]: Starting Load Kernel Module configfs...
[    2.453565] systemd[1]: Starting Load Kernel Module drm...
[    2.454128] systemd[1]: Starting Load Kernel Module fuse...
[    2.454190] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[    2.459077] systemd[1]: Starting Load Kernel Modules...
[    2.459600] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.459648] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[    2.460213] systemd[1]: Starting Coldplug All udev Devices...
[    2.461468] systemd[1]: Mounted Huge Pages File System.
[    2.461545] systemd[1]: Mounted POSIX Message Queue File System.
[    2.461604] systemd[1]: Mounted Kernel Debug File System.
[    2.461665] systemd[1]: Mounted Kernel Trace File System.
[    2.461811] systemd[1]: Finished Create List of Static Device Nodes.
[    2.462033] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    2.462117] systemd[1]: Finished Load Kernel Module configfs.
[    2.462293] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    2.462373] systemd[1]: Finished Load Kernel Module drm.
[    2.463250] systemd[1]: Mounting Kernel Configuration File System...
[    2.464189] EXT4-fs (sdb2): re-mounted. Opts: (null). Quota mode: none.
[    2.464917] systemd[1]: Finished Remount Root and Kernel File Systems.
[    2.465025] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[    2.472602] fuse: init (API version 7.34)
[    2.474854] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[    2.475482] systemd[1]: Starting Load/Save Random Seed...
[    2.475535] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[    2.476043] systemd[1]: Starting Create Static Device Nodes in /dev...
[    2.476708] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    2.476917] systemd[1]: Finished Load Kernel Module fuse.
[    2.477083] systemd[1]: Mounted Kernel Configuration File System.
[    2.477665] systemd[1]: Mounting FUSE Control File System...
[    2.480947] systemd[1]: Mounted FUSE Control File System.
[    2.490777] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.490860] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    2.490941] sr 4:0:0:0: Attached scsi generic sg2 type 5
[    2.504259] random: lvm: uninitialized urandom read (4 bytes read)
[    2.504302] IPMI message handler: version 39.2
[    2.509914] ipmi device interface
[    2.530626] systemd[1]: Finished Coldplug All udev Devices.
[    2.547627] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    2.553548] systemd[1]: Finished Create Static Device Nodes in /dev.
[    2.553633] systemd[1]: Reached target Preparation for Local File Systems.
[    2.554903] systemd[1]: Mounting /tmp...
[    2.554938] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[    2.554962] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[    2.555942] systemd[1]: Starting Journal Service...
[    2.556845] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    2.560087] systemd[1]: Mounted /tmp.
[    2.594159] audit: type=1400 audit(1651316175.842:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=262 comm="apparmor_parser"
[    2.594924] audit: type=1400 audit(1651316175.842:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=262 comm="apparmor_parser"
[    2.599153] audit: type=1400 audit(1651316175.846:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=261 comm="apparmor_parser"
[    2.618741] audit: type=1400 audit(1651316175.862:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=270 comm="apparmor_parser"
[    2.618751] audit: type=1400 audit(1651316175.862:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=270 comm="apparmor_parser"
[    2.618766] audit: type=1300 audit(1651316175.862:5): arch=c000003e syscall=1 success=yes exit=85794 a0=7 a1=7f7f18117010 a2=14f22 a3=0 items=0 ppid=257 pid=270 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[    2.618774] audit: type=1327 audit(1651316175.862:5): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
[    2.634542] systemd[1]: Started Journal Service.
[    2.635519] audit: type=1130 audit(1651316175.882:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.642150] audit: type=1400 audit(1651316175.889:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=264 comm="apparmor_parser"
[    2.644078] systemd-journald[267]: Received client request to flush runtime journal.
[    2.920606] logitech-hidpp-device 0003:046D:4031.0004: HID++ 2.0 device connected.
[    2.924611] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20210730/utaddress-204)
[    2.924617] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    2.924620] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
[    2.924622] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    2.924623] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20210730/utaddress-204)
[    2.924625] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
[    2.924627] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    2.924628] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20210730/utaddress-204)
[    2.924630] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20210730/utaddress-204)
[    2.924632] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    2.924632] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    3.027768] parport_pc 00:06: reported by Plug and Play ACPI
[    3.027822] parport0: PC-style at 0x378, irq 5 [PCSPP]
[    3.085992] mousedev: PS/2 mouse device common for all mice
[    3.187094] mc: Linux media interface: v0.10
[    3.215404] Bluetooth: Core ver 2.22
[    3.215461] NET: Registered PF_BLUETOOTH protocol family
[    3.215462] Bluetooth: HCI device and connection manager initialized
[    3.215469] Bluetooth: HCI socket layer initialized
[    3.215472] Bluetooth: L2CAP socket layer initialized
[    3.215480] Bluetooth: SCO socket layer initialized
[    3.215644] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.222253] nvidia: loading out-of-tree module taints kernel.
[    3.222265] nvidia: module license 'NVIDIA' taints kernel.
[    3.222266] Disabling lock debugging due to kernel taint
[    3.228681] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.228728] input: PC Speaker as /devices/platform/pcspkr/input/input17
[    3.232743] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[    3.248883] r8169 0000:03:00.0 eth0: RTL8168g/8111g, d4:3d:7e:df:30:ad, XID 4c0, IRQ 37
[    3.248888] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[    3.257086] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    3.299506] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[    3.300363] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[    3.300386] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    3.300726] i2c i2c-0: 2/4 memory slots populated (from DMI)
[    3.301196] i2c i2c-0: Successfully instantiated SPD at 0x51
[    3.301651] i2c i2c-0: Successfully instantiated SPD at 0x53
[    3.302495] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    3.403757] r8169 0000:03:00.0 enp3s0: renamed from eth0
[    3.410351] iTCO_vendor_support: vendor-support=0
[    3.411689] at24 0-0051: supply vcc not found, using dummy regulator
[    3.412273] at24 0-0051: 256 byte spd EEPROM, read-only
[    3.412294] at24 0-0053: supply vcc not found, using dummy regulator
[    3.412848] at24 0-0053: 256 byte spd EEPROM, read-only
[    3.434544] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[    3.434547] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    3.434547] RAPL PMU: hw unit of domain package 2^-14 Joules
[    3.434548] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    3.434742] ppdev: user-space parallel port driver
[    3.440023] usbcore: registered new interface driver btusb
[    3.446601] usbcore: registered new interface driver ath3k
[    3.454233] cryptd: max_cpu_qlen set to 1000
[    3.462850] iTCO_wdt iTCO_wdt.1.auto: Found a Lynx Point TCO device (Version=2, TCOBASE=0x1860)
[    3.463048] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[    3.463280] snd_hda_intel 0000:01:00.1: Disabling MSI
[    3.463284] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    3.472590] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[    3.487001] intel-spi intel-spi: mx25l6405d (8192 Kbytes)
[    3.488477] AVX2 version of gcm_enc/dec engaged.
[    3.488523] AES CTR mode by8 optimization enabled
[    3.494592] Creating 1 MTD partitions on "intel-spi":
[    3.494597] 0x000000000000-0x000000800000 : "BIOS"
[    3.557040] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input18
[    3.557085] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input19
[    3.557141] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input20
[    3.557197] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input21
[    3.557429] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input22
[    3.557468] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input23
[    3.557493] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input24
[    3.557679] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    3.557683] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.557684] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.557685] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    3.557686] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    3.557687] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[    3.557689] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[    3.557689] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[    3.573694] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input25
[    3.573739] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input26
[    3.573923] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input27
[    3.573958] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input28
[    3.573995] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input29
[    3.618205] ath9k 0000:06:00.0: enabling device (0000 -> 0002)
[    3.627633] ath: EEPROM regdomain: 0x6a
[    3.627634] ath: EEPROM indicates we should expect a direct regpair map
[    3.627636] ath: Country alpha2 being used: 00
[    3.627637] ath: Regpair used: 0x6a
[    3.628098] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    3.628423] ieee80211 phy0: Atheros AR9462 Rev:2 mem=0xffffb38b81780000, irq=19
[    3.641990] ath9k 0000:06:00.0 wlp6s0: renamed from wlan0
[    3.686656] random: crng init done
[    3.901783] intel_rapl_common: Found RAPL domain package
[    3.901786] intel_rapl_common: Found RAPL domain core
[    3.901787] intel_rapl_common: Found RAPL domain dram
[    4.743350] usbcore: registered new interface driver snd-usb-audio
[    4.867962] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.103.01  Thu Jan  6 12:10:04 UTC 2022
[    4.881002] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  470.103.01  Thu Jan  6 12:12:52 UTC 2022
[    4.905977] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    4.905980] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[    5.108658] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[    5.118315] nvidia-uvm: Loaded the UVM driver, major device number 507.
[    5.125983] kauditd_printk_skb: 15 callbacks suppressed
[    5.125985] audit: type=1130 audit(1651316178.372:21): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.130201] audit: type=1130 audit(1651316178.379:22): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.139529] audit: type=1130 audit(1651316178.386:23): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.142980] audit: type=1334 audit(1651316178.389:24): prog-id=9 op=LOAD
[    5.143063] audit: type=1334 audit(1651316178.389:25): prog-id=10 op=LOAD
[    5.143088] audit: type=1334 audit(1651316178.389:26): prog-id=11 op=LOAD
[    5.145041] audit: type=1130 audit(1651316178.392:27): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.347862] audit: type=1130 audit(1651316178.596:28): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.350508] audit: type=1130 audit(1651316178.599:29): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.350591] audit: type=1130 audit(1651316178.599:30): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.358848] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.358851] Bluetooth: BNEP filters: protocol multicast
[    5.358854] Bluetooth: BNEP socket layer initialized
[    5.366014] NET: Registered PF_ALG protocol family
[    5.455617] loop: module loaded
[    5.456031] loop0: detected capacity change from 0 to 8
[    5.478681] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    5.646652] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[    5.677451] NET: Registered PF_QIPCRTR protocol family
[    5.836807] r8169 0000:03:00.0 enp3s0: Link is Down
[    6.083451] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
[    6.083456] caller _nv000722rm+0x1ad/0x200 [nvidia] mapping multiple BARs
[    8.851836] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[    8.851850] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[   15.644702] kauditd_printk_skb: 42 callbacks suppressed
[   15.644710] audit: type=1131 audit(1651316188.892:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   16.086696] logitech-hidpp-device 0003:046D:2011.0005: HID++ 1.0 device connected.
[   17.903696] audit: type=1100 audit(1651316191.152:68): pid=601 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="andreas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   17.903861] audit: type=1101 audit(1651316191.152:69): pid=601 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="andreas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   17.904198] audit: type=1103 audit(1651316191.152:70): pid=601 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="andreas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   17.904321] audit: type=1006 audit(1651316191.152:71): pid=601 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   17.904335] audit: type=1300 audit(1651316191.152:71): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffe75ba08e0 a2=4 a3=0 items=0 ppid=511 pid=601 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
[   17.904343] audit: type=1327 audit(1651316191.152:71): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746839326630396466382D336332382D346161392D626563622D653636343139316637323433002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[   17.920225] audit: type=1130 audit(1651316191.169:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.925459] audit: type=1101 audit(1651316191.172:73): pid=603 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="andreas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.925497] audit: type=1103 audit(1651316191.172:74): pid=603 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="andreas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   19.863354] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
[   19.882985] ntfs3: Max link count 4000
[   19.882988] ntfs3: Enabled Linux POSIX ACLs support
[   19.882989] ntfs3: Read-only LZX/Xpress compression included
[   19.888492] ntfs3: Unknown parameter 'windows_names'
[   20.019989] Bluetooth: RFCOMM TTY layer initialized
[   20.019996] Bluetooth: RFCOMM socket layer initialized
[   20.020001] Bluetooth: RFCOMM ver 1.11
[   20.995713] retire_capture_urb: 13 callbacks suppressed
[   28.299627] audit: type=1131 audit(1651316201.546:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   28.306204] audit: type=1131 audit(1651316201.552:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@962 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   28.963194] audit: type=1130 audit(1651316202.209:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   35.508659] audit: type=1131 audit(1651316208.756:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   35.589761] audit: type=1334 audit(1651316208.839:88): prog-id=0 op=UNLOAD
[   35.589767] audit: type=1334 audit(1651316208.839:89): prog-id=0 op=UNLOAD
[   35.589769] audit: type=1334 audit(1651316208.839:90): prog-id=0 op=UNLOAD
[   35.658545] audit: type=1131 audit(1651316208.906:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   35.676772] audit: type=1334 audit(1651316208.926:92): prog-id=0 op=UNLOAD
[   35.676775] audit: type=1334 audit(1651316208.926:93): prog-id=0 op=UNLOAD
[   35.676777] audit: type=1334 audit(1651316208.926:94): prog-id=0 op=UNLOAD
[   37.749885] audit: type=1111 audit(1651316210.996:95): pid=475 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp3s0" ifindex=2 args=2000 pid=704 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   38.975580] audit: type=1131 audit(1651316212.222:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.882501] audit: type=1111 audit(1651316226.129:97): pid=475 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp3s0" ifindex=2 args=0 pid=704 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[   80.615032] audit: type=1131 audit(1651316253.862:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   88.377284] r8169 0000:03:00.0 enp3s0: Link is Down
[   94.436862] audit: type=1334 audit(1651316267.686:99): prog-id=0 op=UNLOAD
[   94.437574] audit: type=1130 audit(1651316267.686:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  102.411227] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  104.439308] audit: type=1131 audit(1651316277.686:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  134.765590] r8169 0000:03:00.0 enp3s0: Link is Down
[  137.736678] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  148.035590] audit: type=1130 audit(1651316321.282:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  158.045644] audit: type=1131 audit(1651316331.292:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  172.085935] r8169 0000:03:00.0 enp3s0: Link is Down
[  175.131917] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  193.033388] audit: type=1130 audit(1651316366.282:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  203.042289] audit: type=1131 audit(1651316376.289:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  211.092687] audit: type=1334 audit(1651316384.339:106): prog-id=23 op=LOAD
[  211.092693] audit: type=1300 audit(1651316384.339:106): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff8ece9720 a2=80 a3=7fff8ece9720 items=0 ppid=1 pid=475 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
[  211.092695] audit: type=1327 audit(1651316384.339:106): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[  211.099416] audit: type=1130 audit(1651316384.346:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  221.108020] audit: type=1131 audit(1651316394.356:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  253.374258] audit: type=1111 audit(1651316426.622:109): pid=475 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp3s0" ifindex=2 args=2000 pid=704 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[  254.341113] r8169 0000:03:00.0 enp3s0: Link is Down
[  260.382887] audit: type=1130 audit(1651316433.629:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  260.386659] audit: type=1334 audit(1651316433.636:111): prog-id=0 op=UNLOAD
[  267.797315] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  270.385647] audit: type=1131 audit(1651316443.632:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  277.611309] audit: type=1334 audit(1651316450.859:113): prog-id=24 op=LOAD
[  277.611314] audit: type=1300 audit(1651316450.859:113): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fff8ece9720 a2=80 a3=7fff8ece9720 items=0 ppid=1 pid=475 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
[  277.611316] audit: type=1327 audit(1651316450.859:113): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[  277.617929] audit: type=1130 audit(1651316450.866:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  287.628066] audit: type=1131 audit(1651316460.876:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  308.716929] audit: type=1130 audit(1651316481.966:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  314.587178] r8169 0000:03:00.0 enp3s0: Link is Down
[  318.728581] audit: type=1131 audit(1651316491.976:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  320.646144] audit: type=1130 audit(1651316493.892:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  320.649937] audit: type=1334 audit(1651316493.899:119): prog-id=0 op=UNLOAD
[  328.988079] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  329.164289] audit: type=1334 audit(1651316502.409:120): prog-id=25 op=LOAD
[  329.164295] audit: type=1300 audit(1651316502.409:120): arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7fff8ece9720 a2=80 a3=7fff8ece9720 items=0 ppid=1 pid=475 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
[  329.164297] audit: type=1327 audit(1651316502.409:120): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
[  330.648545] audit: type=1131 audit(1651316503.896:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  359.452111] audit: type=1100 audit(1651316532.699:122): pid=1948 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="andreas" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  359.452342] audit: type=1101 audit(1651316532.699:123): pid=1948 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="andreas" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  359.453056] audit: type=1110 audit(1651316532.699:124): pid=1948 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  359.453555] audit: type=1105 audit(1651316532.702:125): pid=1948 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  359.605157] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[  359.621686] JFS: nTxBlock = 8192, nTxLock = 65536
[  359.679154] raid6: skip pq benchmark and using algorithm avx2x4
[  359.679156] raid6: using avx2x2 recovery algorithm
[  359.682623] xor: automatically using best checksumming function   avx
[  359.768630] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[  360.258498] device-mapper: uevent: version 1.0.3
[  360.258602] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[  366.874818] audit: type=1101 audit(1651316540.122:126): pid=2453 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  366.875416] audit: type=1110 audit(1651316540.122:127): pid=2453 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  366.876199] audit: type=1105 audit(1651316540.122:128): pid=2453 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
There is one big red area though:
I was hoping to find more details there, but i don’t see anything related…
I found some results suggesting the issue may come from init parameters, pointing to the wrong partition. I would retry booting, and paying attention to the messages (possibly checking again the logs at that time) for anything related:
https://bbs.archlinux.org/viewtopic.php?id=202726
Ok, so from the grub I select the nvme Manjaro (listed as 5.21 or something), go to the drive so and so doesn’t exists, press any key then get:
FAILED: Failed to start Load KErnal Module
FAILED: Failed to start CLI Netfliter Manager
FAILED: Failed to mount /boot/efi
DEPEND: Dependecy failed for Local File Systems.
Then the blurb about being in emergency mode, where it won’t let me type anything (I press the keys and nothing happens). Pressing ‘Control-D’ just brings up the same prompt.
The log says:
journalctl --boot=-1 --unit=<service_name>
bash: syntax error near unexpected token `newline'
[andreas-ms7850 /]# journalctl --boot=-1 --priority=3 --catalog
Apr 29 21:15:06 andriko kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20210730/psargs-330)
Apr 29 21:15:06 andriko kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Apr 29 21:15:06 andriko systemd[1]: Failed to start Load Kernel Modules.
Apr 29 21:15:06 andriko systemd-modules-load[247]: Failed to look up module alias 'crypto_user': Function not implemented
Apr 29 21:15:06 andriko systemd-modules-load[247]: Failed to look up module alias 'sg': Function not implemented
Apr 29 21:15:06 andriko systemd-modules-load[247]: Failed to look up module alias 'ipmi-devintf': Function not implemented
Apr 29 21:15:06 andriko systemd-modules-load[247]: Failed to look up module alias 'nvidia': Function not implemented
Apr 29 21:15:06 andriko systemd-modules-load[247]: Failed to look up module alias 'nvidia-drm': Function not implemented
Apr 29 21:15:06 andriko systemd-modules-load[247]: Failed to look up module alias 'nvidia-uvm': Function not implemented
Apr 29 21:15:06 andriko systemd-modules-load[247]: Failed to look up module alias 'uinput': Function not implemented
Apr 29 21:15:06 andriko systemd[1]: Failed to start CLI Netfilter Manager.
-- Subject: A start job for unit ufw.service has failed
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- A start job for unit ufw.service has finished with a failure.
-- The job identifier is 86 and the job result is failed.
Apr 29 21:15:06 andriko systemd[1]: Failed to mount /boot/efi.
-- Subject: A start job for unit boot-efi.mount has failed
-- A start job for unit boot-efi.mount has finished with a failure.
-- The job identifier is 215 and the job result is failed.
Apr 29 21:15:13 andriko systemd-modules-load[404]: Failed to look up module alias 'crypto_user': Function not implemented
Apr 29 21:15:13 andriko systemd-modules-load[404]: Failed to look up module alias 'sg': Function not implemented
Apr 29 21:15:13 andriko systemd-modules-load[404]: Failed to look up module alias 'ipmi-devintf': Function not implemented
Apr 29 21:15:13 andriko systemd-modules-load[404]: Failed to look up module alias 'nvidia': Function not implemented
Apr 29 21:15:13 andriko systemd-modules-load[404]: Failed to look up module alias 'nvidia-drm': Function not implemented
Apr 29 21:15:13 andriko systemd-modules-load[404]: Failed to look up module alias 'nvidia-uvm': Function not implemented
Apr 29 21:15:13 andriko systemd-modules-load[404]: Failed to look up module alias 'uinput': Function not implemented
Apr 29 21:15:13 andriko systemd[1]: Failed to start Load Kernel Modules.
-- Subject: A start job for unit systemd-modules-load.service has failed
-- A start job for unit systemd-modules-load.service has finished with a failure.
-- The job identifier is 187 and the job result is failed.
Apr 29 21:15:13 andriko systemd[1]: Failed to start CLI Netfilter Manager.
-- The job identifier is 279 and the job result is failed.
For what it’s worth, we could check the details of the service failed before the mount.
journalctl --boot=-1 --unit=ufw.service
