lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 18.9M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 692.7M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.9G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 643.7M 1 loop /run/miso/sfs/rootfs
**sda 8:0 0 931.5G 0 disk **
**├─sda1 8:1 0 117.3G 0 part **
**├─sda2 8:2 0 117.3G 0 part **
**├─sda3 8:3 0 117.3G 0 part **
**└─sda4 8:4 0 117.3G 0 part**
sdb 8:16 1 14.5G 0 disk
├─sdb1 8:17 1 14.5G 0 part
│ └─ventoy 254:0 0 3.3G 1 dm /run/miso/bootmnt
└─sdb2 8:18 1 32M 0 part
**sdc 8:32 0 2T 0 disk **
**├─sdc1 8:33 0 117.3G 0 part **
**└─sdc2 8:34 0 117.3G 0 part**
nvme1n1 259:0 0 238.5G 0 disk
├─nvme1n1p1 259:1 0 300M 0 part
├─nvme1n1p2 259:2 0 221.2G 0 part
└─nvme1n1p3 259:3 0 17G 0 part
nvme0n1 259:4 0 238.5G 0 disk
├─nvme0n1p1 259:5 0 260M 0 part
├─nvme0n1p2 259:6 0 16M 0 part
├─nvme0n1p3 259:7 0 237.7G 0 part
└─nvme0n1p4 259:8 0 531M 0 part
mount
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=8078744k,nr_inodes=2019686,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/mapper/ventoy on /run/miso/bootmnt type iso9660 (ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=utf8)
cowspace on /run/miso/cowspace type tmpfs (rw,relatime,size=262144k,mode=755,inode64)
overlay_root on /run/miso/overlay_root type tmpfs (rw,relatime,size=12163200k,mode=755,inode64)
/dev/loop0 on /run/miso/sfs/livefs type squashfs (ro,relatime,errors=continue)
/dev/loop1 on /run/miso/sfs/mhwdfs type squashfs (ro,relatime,errors=continue)
/dev/loop2 on /run/miso/sfs/desktopfs type squashfs (ro,relatime,errors=continue)
/dev/loop3 on /run/miso/sfs/rootfs type squashfs (ro,relatime,errors=continue)
overlay on / type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,xino=off)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=20445)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,size=8108800k,nr_inodes=1048576,inode64)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /etc/pacman.d/gnupg type tmpfs (rw,relatime,mode=755,inode64)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1621756k,nr_inodes=405439,mode=700,uid=1000,gid=1000,inode64)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
I intended to make it strong but within <> it just came out as **. This was to point to the 2 drives in play. sda is a HD and that was the one I accidentally GPTed losing the file system journals.
sdc is the SSD which I am trying to copy the 4 seen partitions from sda into and keeps throwing corrupted superblocks when partition manager is finishing up coping the partition. This results in damaged GPT which I can fix temporarily (reboot returns the GPT to damaged state. The manager shows 1 partition that was copied, but unknown state.
Thought this may help:
lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT
NAME FSTYPE SIZE MOUNTPOINT
sda 931.5G
├─sda1 ext4 117.3G
├─sda2 ext4 117.3G
├─sda3 ext4 117.3G
└─sda4 ext4 117.3G
sdc 2T
├─sdc1 117.3G
└─sdc2 117.3G
sda1->sdc1. sda2->sdc2
The 4 sda partitions come from using testdisk.
