Hi,
I had a manjaro XFCE running system. Recently I installed Windows 10 on one the partition, i am this was not Manjaro installation that I used to install Windows.
After windows installation, I checked that I have manjaro deepin edition (2-3 years old version) iso file. So just gave it a try to rescue. I created live USB using manjaro deepin iso. It booted well. When I tried to find my manjaro installation partition, I could not.
It didn’t appear in fdisk -l or lsblk -f output.
Also sudo manjaro-chroot -a showing error.
Swap partition do appear, all other partitions are appearing, not Manjaro installation.
Manjaro was installed in legacy mode, and so is Windows.
Meanwhile I have downloaded XFCE version and will give it a try to rescue Tomorrow.
/usr/bin/inxi: illegal option – -
Error 7: One of the options you entered in your script parameters: --admin
is not supported.The option may require extra arguments to work.
For supported options (and their arguments), check the help menu: inxi -h
Was Manjaro installed on a logical partition inside of the extended partition? It look like it was the first logical partition in the extended partition betwee ~471 GB and 496 GB, so 25 GB large, right?
It looks really like Windows has overwritten the manjaro installation somehow. If Windows is needed, it is always recommend to install it first and then a linux distro, or install it in another drive and unplug the the linux one. Windows love the behavior to be the only one in the cave.
