I did the update using: sudo pacman -Syuw
, which only downloads the updated packages - no problem.
Then I went to tty and did: sudo pacman -Su
, which is supposed to install the downloaded packages - problem:
Total Installed Size: 5595.98 MiB
Net Upgrade Size: 160.00 MiB
(256/256) checking keys in keyring [##################################] 100%
downloading required keys...
:: Import PGP key F9F9FA97A403F63E, "lilac (on behalf of winstonwu91) <winstonwu91@gmail.com>"? [Y/n]
error: key "F9F9FA97A403F63E" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
I followed the procedure described in the manjaro wiki regarding ‘Errors about Keys’ at Pacman troubleshooting - Manjaro but to no avail, the problem persists. Now I do not know if this key really do not exist, or if the remote lookup process is faulty, or which packages are affected, or why I am the only one so far with this problem (maybe the 3 Enlightenment related updates?).
Edit1: I installed the Enlightenment related updates directly using pacman -U ...
from /var/cache/pacman/pkg
and the problem persists.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
