gcr-viewer can’t import certificates - «/org/gnome/gcr/ui/gcr-pkcs11-import-dialog.ui» doesn’t exist
[android7890@komputator ~]$ sudo gcr-viewer /home/android7890/Рабочий\ стол/sstu-ca.cer
(gcr-viewer:603098): Gcr-WARNING **: 17:27:54.140: couldn't load ui builder file: Ресурс из «/org/gnome/gcr/ui/gcr-pkcs11-import-dialog.ui» не существует
(gcr-viewer:603098): Gtk-CRITICAL **: 17:27:54.140: gtk_entry_set_text: assertion 'GTK_IS_ENTRY (entry)' failed
screenshot: https://ibb.co/QNBvr0x
