Request for inclusion of Zotero
I would like to see zotero included as standard (extra) package, currently available on AUR:
It is the only FOSS software for reference management and WYSIWYG paper citing (the most common commercial ones being EndNote and Mendeley). It can be run completely local (cloud features are optional), integrates (optionally) into LibreOffice and offers browser plugins.
I regard it as essential for any researcher using linux.
thanks for reading and hopefully considering it!
/det
It’s also available as flatpak (but the flatpak is tagged as unverified, meaning that it wasn’t packed on Flathub by the developer team)
The main advantages of Zotero are the no cost and the licencing being compatible with GNU Linux; I recall it being quite useful for a period of my life.
The application obviously has it’s uses in Academia, but whether it might be considered for inclusion by Arch, I can’t say.
It looks like the downloadable Zotero-10.0_linux-x86_64.tar.xz archive contains a portable version, in which case it’s possible to simply extract it somewhere convenient, and run the zotero executable.
Zotero is also available via the AUR; however, I would suggest using the binary zotero-bin which might save having to build it from source.
pamac build zotero-bin
This will (should) also provide a zotero.desktop file which can be used to launch the application.
The package (at version 9.0) is included in the Chaotic-aur repository. IF you add that one then you can install it as a binary as if it were in the standard repos.
Note however, chaotic is unsupported. I would advise against adding it as a repo, unless one knows what one is doing and does not rely on the forum for support. The problem is an inexperienced user can easily install other libraries versions on update and completely bork the system. So better use the flatpak or the portable version.
That said it would be nice to be included in the future in the repos.
If the package gets included into the Arch distribution it will also be in Manjaro. To get packages from the AUR into Arch
There are packages in the Manjaro distribution that aren’t part of the Arch distribution. But then you would need someone from the team, i think, willing to maintain the package (and it isn’t something that is part of defining or distinguishing Manjaro from Arch like pamac for instance)
This sounds as if the Chaotic-aur would be an extension of the Arch distribution? I think this would be a huge misunderstanding – the more so for Manjaro.
Chaotic AUR is a user-created repository with precompiled AUR packages. Technically, you can add it to /etc/pacman.conf as a repository — just like the core and extra repositories (and multilib if you have that one), which are already in there — but this is very dangerous when running Manjaro, and not recommended even if you run a pure Arch, not to mention that we will not offer any support if one screws up their system that way.
@soundofthunder
yes i know it is in AUR - i am using zotero-bin for years and don’t remember ever having a problem with it. this is, however, not the topic here:
  • AUR is officially advised gainst
  • it always surprised me that such a good, essential FOSS package is not part of the official repos
@jofi
didn’t know the AUR votes were of any consequence and never bothered. however, registration of new users is currently not possible.
zotero-bin is on #45 regarding votes, not too bad. behind many packages that i don’t think should ever be part of the official repos.
Mod edit: Consecutive posts merged, @mentions added..
Not really - it is more a “user beware” advice.
The AUR isn’t officially supported by Manjaro, which means that users cannot expect help from the Manjaro team or the forum if an AUR package doesn’t install or work (or breaks something) on their system.
:backhand_index_pointing_up: Nor Arch itself.
@captaindet Especially see the first red warning box on the (apparently recently updated) documentation in the Wiki link posted above.
The problem with including an application in the official repository is maintenance.
Manjaro team does not have enough manpower to take on the maintenance of new applications.
While AUR can be intimidating and insecure for the green rookie - the suggestion to use ChaoticAUR is even worse and outright dangerous, at least in terms of system compatibility.
Most importantly - It is not built for Manjaro but Arch Linux.
When I tell you that ChaoticAUR is an automated build machine (see https://aur.chaotic.cx) which builds any and all scripts without human interference - then you should think of all the attempts to place malware in AUR.
Unless the maintainers of ChaoticAUR has done their due diligence - some or all that malware may now exist on ChaoticAUR as prebuilt packages; package you cannot verify like you can do with the original AUR recipe.
This basically means - using Chaotic will always be a greater risk than cloning a custom recipe, verify the content and build it locally.
