3080Ti high idle power consumption and temp after put Xorg service on iGPU
so i use the xorg.conf to put the xorg service on the iGPU, after that, the 3080Ti stays high temp while idle.
(base) [dijin@dijin-ms7d16 ~]$ nvidia-smi
Thu Nov 18 23:20:31 2021
| NVIDIA-SMI 470.74       Driver Version: 470.74       CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 Off |                  N/A |
| 42%   57C    P0   102W / 350W |      0MiB / 12053MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
