GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR=“Manjaro”
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash i915.enable_psr=0”
GRUB_CMDLINE_LINUX=“i915.enable_psr=0”
Hello @Terminator and welcome
Did you run sudo update-grub
after editing?
Btw… I edit the title to reflect your topic better. I guess you don’t want to disable the GPU driver…
Um, the title of the thread makes no sense at all. What’s a “panel self-refresh”, and what does it have to do with GRUB?
The OP also did not post any question — merely a snippet from their /etc/default/grub
file.
Um, I feel you wanna kid me?
Let Me DuckDuckGo That For You - LMDDGTFY
However, yes the OP did not ask any question… so just ignore it?
Cute.
Either way, the OP should not expect us to do their research for them. Their post should be clear and concise, with a well-defined question or summary of the problem.
It’s ok. Gotcha. For me it was self-explaining what the OP was trying to do.
