I don’t see in the PKGBUILD of AUR (en) - emby-server-beta that they depend on the actual version. But they compile their own ffmpeg which would fail if you update the dependent library.
Remove emby-server-beta, update your system, and then rebuild the package.
In the future, please do not post about AUR packages in Announcement threads as they are not related to Manjaro updates. I’ve merged all the posts into one thread.
Excuse me? No, pamac is both. I only use pamac and I hardly use the GUI. pacman is only CLI, AFAIK.
I always recommen pamac because it’s deevelopeed for Manjaro by Manjaro. While pacman, as awesome as it is, is developed for Arch. And since Manjaro is a fork of Arch, it works. But it doesn’t have all the Manjaro customisations that pamac has.
In the future watch the tone. All you needed to say is that I didn’t know all the features of Pamac. I myself use the Pamac GUI to look for a package and install it with Pacman or Yay and do ALL updates with Topgrade.
There was nothing wrong with my tone. I simply highlighted a couple of word to make them stand out more, be clearer, because I know how easy it is to confuse pacman and pamac.
I didn’t mean to offend and if that’s the way you’re taking this, well, then I really don’t think there’s anything I could say that’ll convince you differently.
But, I’m sorry if my attitude offended anyone. That wasn’t my intention.
You did, actually. I split 7 posts from the Testing Update thread to your duplicate thread before I realized you already had this thread about the same thing, then merged that thread here.
The fist post in Testing was in the right place. it was there to inform of the issue and point to the thread I created about the issue in case others had the same issue and came looking for a solution, so there actually was no need for you post here about not posting in announcements. The fact that others responded to my post their is on them.
