Replace pacman-mirrors?
Posting this here since Testing update announcement closed:
Transition to manjaro-mirrors was not completely seamless
Updating all packages including AUR with pamac update requested installing AUR/WSL package pacman-mirrors
Updating with pamac update --no-aur worked for installing manjaro-mirrors but system was switched from testing to stable branch
Switched back to testing branch: sudo pacman-mirrors --api --set-branch testing
Testing branch had another update for manjaro-mirrors
To upgrade (1):
  manjaro-mirrors  4.23.2+2+g2f58b3c-2  (4.23.2+2+g2f58b3c-1)  core  152.2 kB
No change of branch after this update
Nice work :+1: - branch at unstable as expected
 $ sudo pacman -Syu
 core                                  160,3 KiB   239 KiB/s 00:01 [------------------------------------] 100%
 extra is up to date
 community is up to date
 multilib is up to date
 sublime-text is up to date
:: Replace manjaro-mirrors with core/pacman-mirrors? [Y/n] y
resolving dependencies...
Packages (2) manjaro-mirrors-4.23.2+2+g2f58b3c-1 [removal]  pacman-mirrors-4.23.2+2+g2f58b3c-3
Total Download Size:   0,17 MiB
Total Installed Size:  0,67 MiB
Net Upgrade Size:      0,00 MiB
:: Retrieving packages...
 pacman-mirrors-4.23.2+2+g2f58b3c...   173,4 KiB   774 KiB/s 00:00 [------------------------------------] 100%
(1/1) checking keys in keyring                                     [------------------------------------] 100%
(1/1) checking package integrity                                   [------------------------------------] 100%
(1/1) loading package files                                        [------------------------------------] 100%
(1/1) checking for file conflicts                                  [------------------------------------] 100%
(2/2) checking available disk space                                [------------------------------------] 100%
(1/1) removing manjaro-mirrors                                     [------------------------------------] 100%
(1/1) installing pacman-mirrors                                    [------------------------------------] 100%
Optional dependencies for pacman-mirrors
    gtk3: for interactive mode (GUI) [installed]
    python-gobject: for interactive mode (GUI) [installed]
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
(3/3) Configuring pacman-mirrors ...
Your current config has been restored.
A new pacman-mirrors.conf is created as /etc/pacman-mirrors-new-20221223.conf
Please verify you're not missing any changes
::INFO => Mirror status: https://repo.manjaro.org/status.json
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
14:36:39 ā—‹ [fh@tiger] ~
 $ pacman-mirrors
Pacman-mirrors version 4.23.2
Local mirror status for unstable branch
Mirror #1   OK  00:07   Austria  https://mirror.easyname.at/manjaro/
With the pacman-mirrors 4.23.2+2+g2f58b3c-3 all should be back to normal actually, but you can still check the /etc/pacman-mirrors.conf if the branch line is commented or switched to stable and you had it set to testing or unstable prior the manjaro-mirrors …
sudo pacman -Syu         1 ✘
[sudo] password for veprovina:
:: Synchronising package databases...
 core is up to date
 extra is up to date
Packages (3) libpamac-11.4.1-3  pacman-6.0.2-6  pacman-mirrors-4.23.2+2+g2f58b3c-3
Total Download Size:    2,14 MiB
Total Installed Size:   9,07 MiB
Net Upgrade Size:      -0,05 MiB
So i’m assuming the conflict was resloved?
my system is trying to switch manjaro-mirrors with core/pacman-mirrors. What should I do? On every post about it the system is trying to switch the other way around.
Im in Stable and want to keep in that way.
Refresh your mirrors and then update your repositories.
If it persists, wait a bit, the mirrors might not reflect the updated state.
