Removing python2-dbus breaks dependency 'python2-dbus' required by key-mon
Apparently there was another update now or at least a ton of packages were updated. Now the package “key-mon” is broken:
:: Replace hunspell-en_GB with extra/hunspell-en_gb? [Y/n]
:: Replace hunspell-en_US with extra/hunspell-en_us? [Y/n]
:: Replace python-dbus with extra/dbus-python? [Y/n]
:: Replace python-dbus-common with extra/dbus-python? [Y/n]
resolving dependencies...
:: dbus-python and python2-dbus are in conflict. Remove python2-dbus? [y/N] y
:: removing python2-dbus breaks dependency 'python2-dbus' required by key-mon
And when I try to install it again:
-> Could not find all required packages:
        python2-dbus (Wanted by: key-mon)
Seems like that Python package change was done without checking the programs that depend on it. Is this a packaging bug? If yes, how do I report that? Or is that considered a bug in key-mon itself?
Key-mon is an AUR package, it would be best to report it there. Though it hasn’t been updated since 2016.
https://aur.archlinux.org/packages/key-mon
