Can anyone help me?
First i could not update bottles-git because of this message
removing python-vfs breaks dependency 'python-vfs' required by bottles-git
Now i tried to remove it (sudo pacman -R pyhton-vfs
) → Same message
Can anyone help me?
) → Same message
Well … That AUR package will be renamed because has to be FVS and not VFS AUR (en) - python-vfs see the comment and see the source GitHub - mirkobrombin/FVS: File Versioning System with hash comparison, deduplication and data storage to create unlinked states that can be deleted
@Lolix - might take a look at it soon.
Remove bottles-git
first, then remove python-vfs
. Then install them both again.
I think that would be best, also i think the deps for it changed and the python-vfs
or python-fvs
might not be required at all.
And if it is required, then reinstalling bottles-git
should normally pull it in as a dependency anyway.
