Removing nvidia drivers?
Hi,
I am using manjaro settings manager to remove nvidia drivers but it fails with
: removing nvidia-utils breaks dependency 'nvidia-utils=570.133.07' required by linux66-nvidia
Is it save for me to remove linux66-nvidia using pacman?
Hi @pietet,
I’d recommend using mhwd CLI. It’s what I’d have done.
The wiki gives a good explanation:
TL;DR
sudo mhwd -r pci video-nvidia
Note:
Be sure to have some kind of backup driver installed, else you won’t have a GUI, only a text-based interface.
Thanks, I tried that but it gives the same error.
mhwd -r pci video-hybrid-intel-nvidia-prime
> Removing video-hybrid-intel-nvidia-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-hybrid-intel-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
checking dependencies...
:: removing nvidia-utils breaks dependency 'nvidia-utils=570.133.07' required by linux66-nvidia
Error: pacman failed!
Error: script failed!
Hmmm, OK. This would probably have saved us some time if I had this info from the beginning, but please provide the output of:
inxi --filter --verbosity=8
…as well as:
pamac search --installed nvidia
And:
mhwd --listinstalled
Here is the output,
sudo inxi --filter --verbosity=8         ✔  7s 
  Kernel: 6.6.84-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=7a65b73b-744c-4be3-ae0c-ee22ef6ea6bc rw quiet splash apparmor=1
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: LENOVO product: 82JD v: Legion 5 Pro 16ITH6H
    serial: <filter> Chassis: type: 10 v: Legion 5 Pro 16ITH6H serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN serial: <filter>
    part-nu: LENOVO_MT_82JD_BU_idea_FM_Legion 5 Pro 16ITH6H
    uuid: 0225b14f-57f1-11ec-80f0-84a938fd2656 UEFI: LENOVO v: H1CN45WW
    date: 11/26/2021
  ID-1: BAT0 charge: 74.3 Wh (100.0%) condition: 74.3/80.0 Wh (92.8%)
    volts: 16.6 min: 15.4 model: Sunwoda L20D4PC1 type: Li-poly serial: <filter>
    status: full cycles: 72
  System RAM: total: 64 GiB available: 62.59 GiB used: 22.31 GiB (35.6%)
    igpu: 60 MiB
  Array-1: capacity: 64 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 32 GiB speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64
    total: 64 manufacturer: A-DATA Technology part-no: N/A serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
  Slot: 1 type: PCIe status: available info: J6C1 length: other
    bus-ID: 00:1c.0
  Slot: 2 type: PCIe status: available info: J6D2 length: other
    bus-ID: 00:1c.1
  Slot: 3 type: PCIe status: available info: J7C1 length: other
    bus-ID: 00:1c.2
  Slot: 4 type: PCIe status: available info: J7D1 length: other
    bus-ID: 00:1c.3
  Slot: 5 type: PCIe status: available info: J8C1 length: other
    bus-ID: 00:1c.4
  Info: model: 11th Gen Intel Core i7-11800H socket: U3E1 bits: 64
    type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x52
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB
    desc: 8x1.2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 base/boost: 2277/4600 scaling:
    driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
    10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 bogomips: 73744
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Xe process: Intel 10nm built: 2020-21 ports: active: none
    off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: none off: HDMI-A-2 empty: DP-6,DP-7,eDP-2 bus-ID: 01:00.0
    chip-ID: 10de:2560 class-ID: 0300
  Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 04f2:b67d
    class-ID: 0e02
  Display: unspecified server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris
    gpu: i915,nvidia,nvidia-nvswitch display-ID: :0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-2 model: Dell U2723QE serial: <filter> built: 2023
    res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green:
    x: 0.267 y: 0.678 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 3840x2160, 2560x1440, 2048x1280, 2048x1152, 1920x1200, 2048x1080,
    1920x1080, 1600x1200, 1680x1050, 1280x1024, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93
  Monitor-2: eDP-1 model-id: CSO 0x1606 built: 2020 res: 2560x1600 dpi: 188
    gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue:
    x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 345x215mm (13.58x8.46")
    diag: 407mm (16") ratio: 16:10 modes: 2560x1600
  EDID-Warnings: 1: parse_edid: unknown tag 112
    drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 25.0.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
    device-ID: 8086:9a60 memory: 30.56 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop
  Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:228e class-ID: 0403
  Device-3: Samson Meteor condenser microphone
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 17a0:0310 class-ID: 0300
  API: ALSA v: k6.6.84-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: n/a (root, process) with:
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 5c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp92s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  Info: services: NetworkManager, nginx, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:8 chip-ID: 8087:0026
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 706.19 GiB (75.8%)
    model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 234110WD temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 706.17 GiB (77.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 7a65b73b-744c-4be3-ae0c-ee22ef6ea6bc
    used: 16.3 MiB (5.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 3FA7-FA2E
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 3-1:2 info: Samson Meteor condenser microphone type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-2: 3-4:9 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-3: 3-6:4 info: Chicony Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b67d class-ID: 0e02
  Device-4: 3-7:5 info: Integrated Express ITE Device(8295)
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 048d:c965 class-ID: 0300
  Device-5: 3-9:6 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c101 class-ID: 0301
  Device-6: 3-10:7 info: N/A type: keyboard,HID driver: hid-generic,usbhid
    interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 026d:0002 class-ID: 0300
  Device-7: 3-14:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-4: 4-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1838 pm: pacman pkgs: 1809 libs: 415 tools: gnome-software,pamac
    pm: flatpak pkgs: 29
    1: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    2: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    3: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    5: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    7: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    8: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    9: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    10: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    11: https://linorg.usp.br/manjaro/stable/$repo/$arch
    12: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    13: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    14: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    15: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    16: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    18: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    19: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    20: https://mirror.23m.com/manjaro/stable/$repo/$arch
    21: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    22: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    23: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    24: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    25: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    26: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    27: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    28: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    29: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    30: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    31: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    32: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    33: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    34: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    35: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    36: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    37: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    38: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    39: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    40: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    41: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    43: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    44: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    45: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    46: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    47: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    48: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    49: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    50: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    51: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    52: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    53: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    54: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    55: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    56: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    57: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    58: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    59: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    60: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    62: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    63: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    65: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    66: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    67: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    68: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    69: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    70: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    71: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    72: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    73: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    74: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    75: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    76: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    78: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    79: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    81: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    82: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    83: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    84: http://manjaro.grena.ge/stable/$repo/$arch
    85: https://mirror.init7.net/manjaro/stable/$repo/$arch
    86: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    87: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    88: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    89: https://manjaro.ynh.ovh/stable/$repo/$arch
    90: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    91: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    92: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    93: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    94: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    95: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    96: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    97: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    98: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    99: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    100: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    101: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    102: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    103: http://manjaro.mirror.ac.za/stable/$repo/$arch
    104: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    105: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    106: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    107: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    108: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    109: https://manjaro.kurdy.org/stable/$repo/$arch
    110: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    111: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    112: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    113: https://mirrors2.manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 493
  1: cpu: 35.1% command: idea pid: 7277 mem: 10590.9 MiB (16.5%)
  2: cpu: 4.0% command: gnome-shell pid: 2042 mem: 659.3 MiB (1.0%)
  3: cpu: 3.3% command: firefox pid: 4714 mem: 682.2 MiB (1.0%)
  4: cpu: 3.0% command: telegram-desktop pid: 2302 mem: 1016.5 MiB (1.5%)
  5: cpu: 2.6% command: exe pid: 13565 mem: 315.8 MiB (0.4%)
  Memory top: 5 of 493
  1: mem: 10590.9 MiB (16.5%) command: idea pid: 7277 cpu: 35.1%
  2: mem: 1016.5 MiB (1.5%) command: telegram-desktop pid: 2302 cpu: 3.0%
  3: mem: 916.3 MiB (1.4%) command: webpack pid: 15156 cpu: 1.3%
  4: mem: 682.2 MiB (1.0%) command: firefox pid: 4714 cpu: 3.3%
  5: mem: 659.3 MiB (1.0%) command: gnome-shell pid: 2042 cpu: 4.0%
  Processes: 493 Power: uptime: 3h 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.02 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Sudo (sudo)
    v: 1.9.16p2 default: Bash v: 5.2.37 running-in: gnome-terminal inxi: 3.3.37
sudo pamac search --installed nvidia         ✔
egl-wayland  4:1.1.18-1        extra
    EGLStream-based Wayland external platform
egl-gbm  1.1.2.1-1        extra
    The GBM EGL external platform library
opencl-nvidia  570.133.07-2        extra
    OpenCL implemention for NVIDIA
mhwd-nvidia-470xx  470.256.02-10        extra
    MHWD module-ids for nvidia 470.256.02
mhwd-nvidia-390xx  390.157-19        extra
    MHWD module-ids for nvidia 390.157
mhwd-nvidia  570.133.07-2        extra
    MHWD module-ids for nvidia 570.133.07
linux66-nvidia  570.133.07-2        extra
    NVIDIA drivers for linux66
libnvidia-container  1.17.5-1        extra
    NVIDIA container runtime library
lib32-nvidia-utils  570.133.07-1        multilib
    NVIDIA drivers utilities (32-bit)
nvidia-utils  570.133.07-2        extra
nvidia-settings  570.133.07-2.2        extra
    Tool for configuring the NVIDIA graphics driver
nvidia-prime  1.0-5        extra
    NVIDIA Prime Render Offload configuration and utilities
nvidia-driver-assistant  0.20.124.06-1        extra
    Detect and install the best NVIDIA driver packages for the system
nvidia-container-toolkit  1.17.5-1        extra
    NVIDIA container toolkit
mhwd --listinstalled         ✔
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
video-hybrid-intel-nvidia-prime            2025.01.13               false            PCI
I manually removed linux66-nvidia then ran mhwd -r pci video-hybrid-intel-nvidia-prime and rebooted and its working.
All this is because after the recent upgrade suspend / restore broke and some apps like teams have screen tear. I wanted to remove nvidia to see if its that.
suspend / restore is working again, however teams still has screen tear.
Thanks
Pieter
Thanks
