Removing Kernel-Alive (AUR) showed some errors
I just saw today that Kernel-Alive must be removed from official repo’s or something, after i was looking again under Foreign Packages.
I did depency check and it was clear to remove, but after i clicked on pamac apply to remove, i saw some errors in the log.
Preparing...
Checking dependencies...
Running pre-transaction hooks...
Remove systemd service to restore linux kernel modules
Failed to disable unit: Unit file linux-modules-cleanup.service does not exist.
Error: command failed to execute correctly
Removing kernel-alive (0.5.1-1)...
Are this removal error’s normal for this package?
Let us say that if a file has been removed by other means - then pacman will throw a message - in this case I assume has completed succesfully.
Well after a restart i couldn’t see additional errors in journal, so besides the errors in pamac.log, everything is fine. :saluting_face:
