Remove plasma widget without access to plasmashell
I’ve managed to install a widget that crashes plamashell (seg fault) immediately after it starts. How do I remove it without access to the GUI? All the help I can find online is predicated on access to the GUI or outdated.
Thanks
its ~/.config/plasmashellrc … if you cant find it in there … just move or backup/delete the file so it is regenerated with defaults.
This did not fix the issue, but removing the offending widget under .local//share/plasma/plasmoids/ did. I’m not sure why I didn’t think of that sooner!
