i clone firefox theme repo and install that but i don’t like that so i try to uninstall but i unable to do that
can anyone help me how to uninstall that customization
If you look at the install.sh script you just run, then you should know what to do. If is not obvious, just run from terminal from the same cloned github directory:
./install.sh -r
You can always manually remove installed Firefox themes in your home with:
