Hello,
How would I remove an old kernel that on my computer says it’s no longer installed?
Unable to install module steamos-xpad/20190810 for kernel 4.14.221-1-MANJARO: Missing kernel modules tree.
Please help, thank you!
Hello,
Hello,
Open up Manjaro Settings Manager > Kernels and you can remove it from there, or check if is installed. Otherwise from Terminal:
sudo mhwd-kernel -r linux414
Is all documented in the Manjaro Kernels - Manjaro wiki …
First install another kernel, for example from the terminal:
sudo mhwd-kerneel -i linux54
Or
sudo mhwd-kernel -i linux510
(5.4 is the current LTS and 5.10 is set to be the next LTS.)
If successful, you can then remove 4.14:
sudo mhwd-kernel -r 414
Hold your thumbs and reboot.
If all went well, then you’re good to go!
I am already running linux 510 which is the odd part about this.
When I ran
I got
[sudo] password for wired:
Error: Please enter a valid kernel name.
Currently running: 5.10.15-1-MANJARO (linux510)
* linux510
Packages (1) steamos-xpad-dkms-20190810-1
Total Installed Size: 0.06 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [################################################] 100%
(1/1) checking package integrity [################################################] 100%
(1/1) loading package files [################################################] 100%
(1/1) checking for file conflicts [################################################] 100%
(1/1) checking available disk space [################################################] 100%
(1/1) Remove upgraded DKMS modules
==> dkms remove --no-depmod -m steamos-xpad -v 20190810 -k 5.10.15-1-MANJARO
==> Unable to remove module steamos-xpad/20190810 for kernel 4.14.221-1-MANJARO: Not found in dkms status output.
Error! The module/version combo: steamos-xpad-20190810
is not located in the DKMS tree.
error: command failed to execute correctly
(1/1) reinstalling steamos-xpad-dkms [################################################] 100%
Creating symlink /var/lib/dkms/steamos-xpad/20190810/source ->
/usr/src/steamos-xpad-20190810
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j16 KERNELRELEASE=5.10.15-1-MANJARO KVERSION=5.10.15-1-MANJARO...
Kernel cleanup unnecessary for this kernel. Skipping...
DKMS: build completed.
steamos-xpad.ko.xz:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /usr/lib/modules/5.10.15-1-MANJARO/kernel/drivers/input/joystick/
depmod....
DKMS: install completed.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Install DKMS modules
==> dkms install --no-depmod -m steamos-xpad -v 20190810 -k 5.10.15-1-MANJARO
==> depmod 5.10.15-1-MANJARO
==> Unable to install module steamos-xpad/20190810 for kernel 4.14.221-1-MANJARO: Missing kernel modules tree.
[wired@BigBertha ~]$ sudo mhwd-kernel -r linux414
Error: Kernel not installed.
* linux510
It doesn’t show up as being installed.
Hi @Squitwert ,
Please, take a look at this forum post in order to see whether is useful for you.
‘How to remove a "ghost-kernel"? - #7 by stephane’
Hope it help, regards,
Hey thanks that was!
