Hi,
My uncle’s 13 year old pc has finally gone “pop”. (Windows 7).
I have bought him a Ras Pi 4 8Gb.
I am going to put Manjaro xfce on it ( I have used that a lot but now use i3 ).
I would like to ask you all for some advice, if you have the time, on the following :
What is the simplest way for me to remote control into his RasPi?
( Has to be very easy at his end, he is 81 and not very good with technology ).
Thanks.
Hi,
For the windows devices I use ultravnc.
For the linux os I use krfb and krdc , both kde software, user friendly, auto start on boot…
No problem to control windows with linux and vice versa.
Thanks @nl.smart , I will go and check out krfb and krdc.
You’re welcome, find below some help
krfb example config (share the desktop)
krdc (view and control the share desktop) example config with krfb
Fabby
4 September 2020 08:47
5
And you’ll also need to set up a VPN to his router to get into his network (unless he lives in the same house as you). (It’s a function the router needs to provide, so off-topic here…)
