It is at least a couple of weeks that I have been searching without any luck to solve a weird issue that happened during august full upgrade of Manjaro.
Everytime I connect to a host using Remmina every single command I write has the result of interpreting a simple CRLF with only a LF
a change in libssh - wait until it get’s updated - or get from the manjaro sync pool
And please - don’t post images
sudo pacman -U https://mirror.easyname.at/manjaro/pool/sync/libssh-0.11.1-1-x86_64.pkg.tar.zst
Thank you
I was getting mad
Sorry for asking, why no images ?
because they are not searchable - it takes up a lot of diskspace - it contributes heavily to the service diskusage.
and because it says so in the forum rules
Sorry for that, no intention to break the rules
Next time should i post a link ? is it better?
If you think you can’t describe things without pictures good enough, then yes.
Upload to an image sharing site and post the link to it here.
If the info is in text, as it often is, just post the text and mark it as a code, like this:
(12/24) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux610.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.10-x86_64 -g /boot/initramfs-6.10-x86_64.img
==> Starting build: '6.10.6-10-MANJARO'
