Remmina doesn’t start after GNOME 43 update
libsoup-ERROR **: libsoup2 symbols detected. Using libsoup2 and libsoup3 in the same process is not supported.
This bug report indicates it is a problem with the spice plugin. Since spice-gtk
is already using libsoup3
and I didn’t want to remove spice-gtk
, I simply reinstalled Remmina without the spice plugin.
The spice plugin is installed to /usr/lib/remmina/plugins/remmina-plugin-spice.so
. Since it is a single file it can be removed or better added to NoExtract
so it will not be installed with pacman.
Seems that Merge request Multiple changes to build and run with libsoup 3.0 (!2431) · Merge requests · Remmina / Remmina · GitLab needs to been backported to the current stable version of Remmina @Yochanan
remmina
1:1.4.27-4 is now available in the unstable branch that should fix the issue.
