remap the caps key
Hi,
I am trying to remap the caps key in the bsmwp dist of manjaro. Sorry I am newbie so struggling to find the right way to do this.
Thanks,
Murtaza
I have tried setxkbmap -option caps:ctrl and setxkbmap -option caps:swapctrl but that doesnt work.
#!/bin/bash
setxkbmap -option caps:none
setxkbmap -option ctrl:nocaps
setxkbmap -option "shift:both_capslock"
xcape -e "Control_L=Super_L|w" &
This remaps caps and uses xcape to assign super+w.
I can't check rn but, I think super+w is already mapped. Maybe to hide/show windows features in manjaro-bspwm. So it may conflict or needs to be commented out in sxhkdrc. Also nice quick work!
@murtaza52 double check sxhkdrc for conflicting keys and change 'w' to another key if needed.
Just an example :smiley:
@xircon thanks for the reply.
I am trying to pull it apart to better understand -
Does this map ctrl to caps?
What does this do ?
`setxkbmap -option "shift:both_capslock"
Why do the remapping for super+w, what am I missing here ?
Also where should I include the above settings, so that they effect for all my apps - emacs, terminal etc - xinitrc, .zshenv etc - This is a newbie question !
Just an example.
setxkbmap -option ctrl:nocaps I am an emacs user, it makes caps a control.
I use caps by pressing both shifts.
Why super+w - I use super+w to launch browser by tapping caps. Long press is a control (left).
It is a standalone script, source it from your bspwmrc. e.g.:
source ~/.config/bspwm/mybspwm.sh&
As the last line.
@xircon thanks appreciate your answers.
One last question on super+w.
  1. What do you mean by long press is a control ? Long press of super is a control ? Or long press of super + w is control ? How is that used / useful (sincere question) ?
  2. I use super+w to launch browser by tapping caps Hos does caps become super+w ?
Thanks,
Murtaza
1 long press = hold
2 xcape maps the tap of the key to super+w.
Try it. Install xcape, run the script. In your sxhkdrc add:
Replace "w" with an unused key in sxhkdrc and the script:
super + w
	alacritty -e tmux
Replace the second line with a program you use, restart sxhkd:
pkill -USR1 -x sxhkd
Tap the capslock, program should open.
Open a terminal, press (hold) capslock + c - should generate a control+c.
Another trick I have - turn the space bar into a Hyper modifier, when held.
This gives you a whole new set of keyboard shortcuts. sxhkd accepts hyper as a modifier so it can also be used in other desktops like plasma.
If you are interested, I can share my xmodmap config and talk you through it.
@xircon thanks for sharing the above tricks with me. The long press key trick is cool !
What is a hyper modifier ? Also the above pkill command did not bring the new keybindings into effect. I have to restart the machine for this. Is there a better way ?
Yes I would be thrilled to walk through your xmodmap config file !
Thanks,
Murtaza
Hyper is a modifier like super and alt. Not many (if any) keyboards have it.
Stage 1:
! Unmap capslock
clear Lock
!Make Alt-gr & menu into Home and end
! This is easier on my laptop.
keycode 135 = End
keycode 108 = Home
! Leave mod4 as windows key _only_
clear mod3
clear mod4
add mod3 = Hyper_L
add mod4 = Super_L Super_R
keycode 65 = Hyper_L
keycode any = space
Save to ~/.Xmodmap.
xmodmap ~/.Xmodmap
loads the file. Space bar (when held) is now a modifier - Hyper.
But it no longer works as a spacebar.........
xcape -e Hyper_L=space
Fixes this.
sxhkdrc:
hyper+w
	firefox
Press and hold space + w = launches firefox.
Put it all together:
#!/bin/bash
xmodmap ~/.Xmodmap
xcape -e Hyper_L=space &
So now tapping space is a space (defined by xcape), holding is hyper (a new modifier).
Hyper key combos can also be defined in emacs as well:
(global-set-key (kbd "H-p")'package-list-packages)
Pulls up the package manager. sxhkd overides emacs, so if defined in sxhkd, emacs will not see it.
@xircon thanks for the detailed replies, it was a great help !
