Hi,
I just flashed https://github.com/manjaro-pinephone/plasma-mobile/releases/download/202106260244/Manjaro-ARM-plasma-mobile-pinephone-20210626.img.xz to my Pinephone v1.2 and have the same problem that I had previously after updates.
The phone just shows the KDE logo and a mouse cursor.
Unfortunately plugging in a USB keyboard doesn’t work via a USB hub, probably due to the USB hardware fault on v1.2?
Am I stuck and forced to roll back (which version?) / wait for the next update?
Thanks.
Edit: https://github.com/manjaro-pinephone/plasma-mobile/releases/download/202106250247/Manjaro-ARM-plasma-mobile-pinephone-20210625.img.xz works fine though I did not dare install updates (unstable), I switched to stable and downgraded
Edit2: after downgrade to current stable branch, no kde-unstable repo, reboots fine and works as normal
