Hi, I was running into an issue where when my computer would sleep it would not “wake up” but fans on pc would spin and lights would turn on. I looked into it and someone said it involved something with the kernel so i decided to just switch to an older version. After installing an older version (linux59 i believe) and the progress pop up showing it was completed I removed the version I was using at the moment. Then I reinstalled to see if the changes went through but my grub no longer showed Manjaro.
I tried chrooting into the manjaro partition from a usb and installing the kernel from there but nothing changed. Any help would be appreciated, I finally had my entire dual boot system set up with the things I needed and would rather not go through the hassle of reinstalling/troubleshooting a fresh manjaro install over again.
