Dacobi
September 23, 2020, 6:16pm
1
Hi
I lost my boot sector so I need to reinstall grub.
I got my install booting by installing another instance of Manjaro on another disk which found the old install so I can boot directly into to old Manjaro.
I tried sudo grub-install /dev/sdc
this gave this error:
Installing for i386-pc platform.
grub-install: warning: this GPT partition label contains no BIOS Boot Partition; embedding won’t be possible.
grub-install: warning: Embedding is not possible. GRUB can only be installed in this setup by using blocklists. However, blocklists are UNRELIABLE and their use is discouraged…
grub-install: error: will not proceed with blocklists.
Now my system is x86_64-efi so I tried
sudo grub-install /dev/sdc --target x86_64-efi
which gave this error:
Installing for x86_64-efi platform.
EFI variables are not supported on this system.
grub-install: error: efibootmgr failed to register the boot entry: No such file or directory.
What am I missing?
can you boot on USB iso manjaro
open a terminal and a browser on this topic
and returns
inxi -Fza
sudo parted -l
sudo lsblk -fs
sudo efibootmgr -v
test -d /sys/firmware/efi && echo efi || echo bios
sudo manjaro-chroot -a ( type 1 if only one line 0 )
cat /etc/fstab
exit ( quit chroot )
Dacobi
September 23, 2020, 6:52pm
3
What do you mean: boot on USB iso manjaro?
I can boot my Manjaro install fine, just not from its own grub install.
Dacobi
September 23, 2020, 7:18pm
4
~ >>> inxi -Fza [130]
Host: manjaro-gnome Kernel: 5.6.15-1-MANJARO x86_64 bits: 64
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
misobasedir=manjaro misolabel=MANJARO_GNOME_2003 quiet
systemd.show_status=1 apparmor=1 security=apparmor
Desktop: Gnome 3.36.2 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME Z370-A v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 0408
date: 08/31/2017
Topology: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
family: 6 model-id: 9E (158) stepping: A (10) microcode: CA
L2 cache: 12.0 MiB
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 801 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] driver: nouveau v: kernel
Display: x11 server: X.org 1.20.8 driver: nouveau
resolution: <xdpyinfo missing>
OpenGL: renderer: NV132 v: 4.3 Mesa 20.0.7
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP102 HDMI Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.6.15-1-MANJARO
Device-1: Intel Ethernet I219-V driver: e1000e
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5.75 TiB used: 120.5 MiB (0.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B
ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-3: /dev/sdb vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B
ID-4: /dev/sdc vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
ID-5: /dev/sdd vendor: Seagate model: ST4000DM000-1F2168 size: 3.64 TiB
ID-6: /dev/sde type: USB vendor: SanDisk model: Ultra size: 58.28 GiB
Device-1: md125 type: mdraid status: active raid: mirror report: 4/1 ___U
Components: online: sdd1~c3
Device-2: md127 type: mdraid status: active raid: mirror report: 2/1 _U
Components: online: sdd3~c1
ID-1: / raw size: N/A size: 11.67 GiB used: 120.5 MiB (1.0%) fs: overlay
source: ERR-102
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nouveau temp: 29 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 399
Processes: 298 Uptime: 1m Memory: 15.56 GiB used: 1.35 GiB (8.7%)
Shell: zsh inxi: 3.0.37
~ >>> sudo parted -l
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 500GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 482GB 482GB primary ext4 boot
2 482GB 500GB 18.4GB primary linux-swap(v1)
Model: ATA ST1000DM003-1ER1 (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
1 1049kB 524GB 524GB primary ntfs boot
Disk /dev/sdc: 256GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 boot, esp
2 538MB 239GB 238GB ext4
3 239GB 256GB 17.1GB linux-swap(v1) swap
Model: ATA ST4000DM000-1F21 (scsi)
Disk /dev/sdd: 4001GB
Disk Flags:
1 32.8kB 4295MB 4295MB raid
2 4295MB 4832MB 537MB raid
3 4832MB 4001GB 3996GB raid
Model: SanDisk Ultra (scsi)
Disk /dev/sde: 62.6GB
Disk Flags:
2 2773MB 2777MB 4194kB primary esp
Model: Samsung SSD 960 EVO 500GB (nvme)
Disk /dev/nvme0n1: 500GB
Disk Flags:
1 1049kB 473MB 472MB ntfs Basic data partition hidden, diag
2 473MB 577MB 104MB fat32 EFI system partition boot, esp
3 577MB 593MB 16.8MB Microsoft reserved partition msftres
4 593MB 499GB 499GB ntfs Basic data partition msftdata
5 499GB 500GB 857MB ntfs hidden, diag
Model: Linux Software RAID Array (md)
Disk /dev/md127: 3996GB
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 3996GB 3996GB ext4
Disk /dev/md125: 4293MB
Disk Flags:
1 0.00B 4293MB 4293MB ext4
~ >>> sudo lsblk -fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0
squash 4.0 0 100% /run/miso/
loop1
loop2
loop3
sda1 ext4 1.0 7467ca54-be3c-4971-a41a-37fedfe6058d
└─sda
sda2 swap 1 ad59bec3-8dbb-42ca-b818-f4b3ee576ae9
└─sda
sdb1 ntfs Space 3EDC4DF3DC4DA64D
└─sdb
sdc1 vfat FAT32 15C4-EA1A
└─sdc
sdc2 ext4 1.0 3726e907-3d39-4655-ba0b-135bc2c3abe8
└─sdc
sdc3 swap 1 ba70038b-86d0-4aae-b7fa-7f0fdad0f3a9
└─sdc
sde1 iso966 Jolie MANJARO_GNOME_2003
│ 2020-06-06-09-50-25-00 0 100% /run/miso/
└─sde
sde2 vfat FAT12 MISO_EFI
│ 57E8-A8ED
└─sde
md125
│ ext4 1.0 7fffffff:root
│ 08102738-c0c6-4bce-93fd-52f8b606135c
└─sdd1
linux_ 1.2 0e351c44:0
65e7a4e3-aa1f-2270-c3c3-c8c8f8e0782f
└─sdd
md127
│ ext4 1.0 31b68c0a-387e-4ed9-b304-0a9a8e5843af
└─sdd3
linux_ 1.2 0e351c44:data-0
180e7812-ef16-8607-0577-725127351a8f
└─sdd
nvme0n1p1
│ ntfs Recovery
│ E038287E382855B6
└─nvme0n1
nvme0n1p2
│ vfat FAT32 1629-1B80
└─nvme0n1
nvme0n1p3
└─nvme0n1
nvme0n1p4
│ ntfs 42C02DFBC02DF5B7
└─nvme0n1
nvme0n1p5
│ ntfs 082AED242AED100C
└─nvme0n1
~ >>> sudo efibootmgr -v
~ >>> test -d /sys/firmware/efi && echo efi || echo bios [2]
bios
~ >>> sudo manjaro-chroot -a
==> Detected systems:
--> 0) ManjaroLinux
--> 1) ManjaroLinux1
--> 2) Debian
==> Select system to mount [0-2] :
1
==> Mounting (ManjaroLinux1) [/dev/sdc2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
[manjaro-gnome /]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
#UUID=4e3338b7-02ab-4bdb-8e6a-8360d5f51dd5 swap swap defaults,noatime 0 2
UUID=15C4-EA1A /boot/efi vfat defaults,noatime 0 2
UUID=3726e907-3d39-4655-ba0b-135bc2c3abe8 / ext4 defaults,noatime,discard 0 1
UUID=ba70038b-86d0-4aae-b7fa-7f0fdad0f3a9 swap swap defaults,noatime,discard 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
/dev/md127 /mnt/raid1 ext4 defaults,noatime 0 0
qwaler
September 23, 2020, 7:28pm
5
You should install grub on /dev/nvme0n1p2
mount needed partitions and chroot into your installation
# grub-install --target=x86_64-efi --efi-directory=/boot/efi
You have so many different partitions and disks. Can you describe what is your goal?
Dacobi
September 23, 2020, 7:38pm
6
I used to have Win10 on nvme and Manjaro on sdc2.
The boot loader on nvme was wiped during a power out.
So I’m trying to reinstall it.
when booted on sdc2, grub-install /dev/nvme0n1p2 --target=x86_64-efi --efi-directory=/boot/efi
gives this error:
sudo grub-install /dev/nvme0n1p2 --target=x86_64-efi --efi-directory=/boot/efi
qwaler
September 23, 2020, 7:43pm
7
Is your NVMe EFI partition mounted inside /boot/efi?
Show us
# findmnt
you cant restore grub
you have booted UEFI [Legacy] ( not EFI , failback to legacy )
recheck all option in Bios to get only EFI
disable secureboot
disable fastboot
no CSM or Legacy
choose UEFI only or first or others ( not windows )
disks on AHCI
no optane RST
and boot in UEFI only on USB iso
check before with terminal
inxi -Mza
sudo efibootmgr -v
what is exactly md125 & md127 ?
raid 1 & raid 0 ?
/boot/efi is on sdc1 ( also nvme0n1p2 windows )
Dacobi
September 23, 2020, 7:50pm
9
I think I fixed it.
When booting from USB the stick was listed both as EFI and normal/legacy.
So I booted as EFI and chrooted to my old install and now grub-install ran without errors.
Now I can boot the old install from its own grub-menu.
Only thing I’m missing now is a boot entry for Win10
see with windows boot repair
see after for update your bios version
qwaler
September 23, 2020, 8:08pm
11
If you wiped EFI partition, easiest way to fix dual boot is
Fix windows boot entry using their automatic repair
Installation of GRUB
Dacobi
September 23, 2020, 8:09pm
12
The nvme with Win10 installed doesn’t show up at all in the BIOS boot menu.
However I can mount it in Linux.
qwaler
September 23, 2020, 8:16pm
13
Boot windows 10 installer, click repair your system
After this, do same as you did till now.
system
Closed
September 26, 2020, 8:16pm
14
