after the latest big update a few days ago usbguard has started blocking my fingerprint device after my device goes to sleep. I’m not sure if this is a problem with usbguard or some other component. All I really know is that it doesn’t seem to actually be the rules.
[manjaro ~]# usbguard list-devices --blocked
16: block id 06cb:00bd serial "3dbf48c08b66" name "" hash "iq1yyUJDvugX9sY3qYn2wxZjiQH49W5KXUG8HCEL/ss=" parent-hash "jEP/6WzviqdJ5VSeTUY8PatCNBKeaREvo2OqdplND/o=" via-port "1-9" with-interface ff:00:00 with-connect-type "not used"
[manjaro ~]# systemctl restart usbguard
[manjaro ~]#
I added the last rule myself after this problem started ~1week ago, hasn’t helped
allow id 1d6b:0002 serial "0000:00:14.0" name "xHCI Host Controller" hash "jEP/6WzviqdJ5VSeTUY8PatCNBKeaREvo2OqdplND/o=" parent-hash "rV9bfLq7c2eA4tYjVjwO4bxhm+y6GgZpl9J60L0fBkY=" with-interface 09:00:00 with-connect-type ""
allow id 1d6b:0003 serial "0000:00:14.0" name "xHCI Host Controller" hash "prM+Jby/bFHCn2lNjQdAMbgc6tse3xVx+hZwjOPHSdQ=" parent-hash "rV9bfLq7c2eA4tYjVjwO4bxhm+y6GgZpl9J60L0fBkY=" with-interface 09:00:00 with-connect-type ""
allow id 1d6b:0002 serial "0000:2d:00.0" name "xHCI Host Controller" hash "OzehKojXcQLCH4FszThLsJSc8ts0wDSspV66FQd8fVs=" parent-hash "/DQ5Pjp6Q5DvYDEC7zhQ5PnPVdd2IWXqzHWqm7Zks4k=" with-interface 09:00:00 with-connect-type ""
allow id 1d6b:0003 serial "0000:2d:00.0" name "xHCI Host Controller" hash "AJeR6ysQt4WetYa4b2CgmeU1pKA6wIod0IHvmin49tY=" parent-hash "/DQ5Pjp6Q5DvYDEC7zhQ5PnPVdd2IWXqzHWqm7Zks4k=" with-interface 09:00:00 with-connect-type ""
allow id 13d3:5405 serial "0000" name "Integrated Camera" hash "bydJoG7rnIcnXvSbdv7V/MF+kDfgfj+a6QdVdMmC6Rk=" parent-hash "jEP/6WzviqdJ5VSeTUY8PatCNBKeaREvo2OqdplND/o=" with-interface { 0e:01:00 0e:02:00 0e:02:00 0e:02:00 0e:02:00 0e:02:00 0e:02:00 0e:02:00 0e:02:00 0e:01:01 0e:02:01 0e:02:01 0e:02:01 0e:02:01 0e:02:01 0e:02:01 0e:02:01 0e:02:01 fe:01:01 } with-connect-type "not used"
allow id 06cb:00bd serial "3dbf48c08b66" name "" hash "iq1yyUJDvugX9sY3qYn2wxZjiQH49W5KXUG8HCEL/ss=" parent-hash "jEP/6WzviqdJ5VSeTUY8PatCNBKeaREvo2OqdplND/o=" with-interface ff:00:00 with-connect-type "not used"
allow id 8087:0026 serial "" name "" hash "Z5csNGxiUukPPZwSHPyUqpVCNagsfOSSNL2CfXhw4IY=" parent-hash "jEP/6WzviqdJ5VSeTUY8PatCNBKeaREvo2OqdplND/o=" via-port "1-10" with-interface { e0:01:01 e0:01:01 e0:01:01 e0:01:01 e0:01:01 e0:01:01 e0:01:01 e0:01:01 } with-connect-type "not used"
allow id 06cb:00bd serial "3dbf48c08b66" name "" hash "iq1yyUJDvugX9sY3qYn2wxZjiQH49W5KXUG8HCEL/ss=" parent-hash "jEP/6WzviqdJ5VSeTUY8PatCNBKeaREvo2OqdplND/o=" via-port "1-9" with-interface ff:00:00 with-connect-type "not used"
I’ve tried regenerating the rules too, that didn’t help. If anyone knows a workaround that’d be great (obviously I could disable usbguard), but I also believe this warrants further investigation as to why this has started.
Version : 1.0.0-5
It only seems to be impacting my fingerprint device, though I haven’t tried bluetooth.
Fabby
10 September 2021 13:12
2
Instead of:
Have you tried:
If that doesn’t work,
Post an inxi --admin --verbosity=7 --filter --no-host --width
as that would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Reboot
log in
Execute:
systemctl hibernate
bring back from hibernation
post the output of:
journalctl --system --boot=0 --priority=err
I’ll give this a go, but this is still a change in behavior, not sure if I should be reporting this to arch.
Fabby
12 September 2021 18:35
4
Please feel free to file a bug upstream, but include as much information as you can and be super-professional about it because the average Arch user is hostile towards the average Manjaro user.
ok, it’s not entirely a problem of usbguard, seems gnome thinks it’s a new device every time too. btw, that solution didn’t work, so I’ve disabled usbguard for now.
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: initrd=\intel-ucode.img initrd=\initramfs-5.10-x86_64.img
root=UUID=8e129ee4-9e55-4558-b4ea-33eb08f6b95e rw rootflags=subvol=/@
cryptdevice=UUID=d14ab16d-26ae-4dc1-933c-fa516232997c:cryptroot
luks.name=d14ab16d-26ae-4dc1-933c-fa516232997c=cryptroot elevator=kyber
rootflags=subvol=@ quiet splash apparmor=1 security=apparmor
udev.log_priority=3 threadirqs
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 20U9CTO1WW v: ThinkPad X1 Carbon Gen 8
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20U9CTO1WW serial: <filter> UEFI: LENOVO
v: N2WET28W (1.18 ) date: 04/16/2021
ID-1: BAT0 charge: 47.7 Wh (95.2%) condition: 50.1/51.0 Wh (98.2%)
volts: 16.8 min: 15.4 model: SMP 5B10W13931 type: Li-poly serial: <filter>
status: Discharging cycles: 92
RAM: total: 15.39 GiB used: 9.01 GiB (58.6%)
Info: Quad Core model: Intel Core i7-10610U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 8 MiB bogomips: 36812
Speed: 600 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 600 2: 600 3: 600
4: 600 5: 600 6: 600 7: 600 8: 600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:2 chip-ID: 13d3:5405 class-ID: fe01 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
port: 3000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:0d4e class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Device-1: cryptroot maj-min: 254:0 type: LUKS dm: dm-0 size: 665.34 GiB
Components:
p-1: nvme0n1p7 maj-min: 259:7 size: 665.36 GiB
Local Storage: total: 953.87 GiB used: 39.2 GiB (4.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TDE9X081N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41710C20 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 665.34 GiB size: 665.34 GiB (100.00%)
used: 39.12 GiB (5.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: cryptroot label: N/A uuid: N/A
ID-2: /boot raw-size: 202 MiB size: 96 MiB (47.52%) used: 89.6 MiB (93.3%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 6CEB-F417
ID-3: /home raw-size: 665.34 GiB size: 665.34 GiB (100.00%)
ID-4: /var/cache raw-size: 665.34 GiB size: 665.34 GiB (100.00%)
ID-5: /var/log raw-size: 665.34 GiB size: 665.34 GiB (100.00%)
ID-6: /var/tmp raw-size: 665.34 GiB size: 665.34 GiB (100.00%)
ID-1: swap-1 type: partition size: 32.23 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: swap
uuid: f6b821d3-1edd-4551-8fe5-936ab77a7863
ID-2: swap-2 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
ID-3: swap-3 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 101
dev: /dev/zram1
ID-4: swap-4 type: zram size: 4 GiB used: 0 KiB (0.0%) priority: 102
dev: /dev/zram2
ID-5: swap-5 type: zram size: 4 GiB used: 175.2 MiB (4.3%) priority: 103
dev: /dev/zram3
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 199.91 GiB fs: ntfs label: N/A
uuid: 8016FB6116FB569E
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509.9 MiB fs: ntfs label: N/A
uuid: CA343C30343C223D
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 5.86 GiB fs: f2fs label: N/A
uuid: beb0bd83-51f5-4701-ba96-a824ecc512ee
ID-5: /dev/nvme0n1p8 maj-min: 259:8 size: 48.83 GiB fs: btrfs label: spare
uuid: e36f60a7-a98c-408d-9784-63a08d942046
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-8:2 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-9:14 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-3: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 442 Uptime: 6d 18h 22m wakeups: 210 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1446 pacman: 1441 lib: 426
flatpak: 0 snap: 5 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
I don’t actually have hibernation enabled… it’s sleep
Sep 14 07:48:49 manjaro systemd[1]: Failed to start pkgfile database update.
Sep 14 07:48:49 manjaro kernel: usb 1-9: Device is not authorized for usage
Sep 14 07:48:50 manjaro wpa_supplicant[1160]: nl80211: kernel reports: Attribute failed policy validation
Sep 14 07:48:50 manjaro wpa_supplicant[1160]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Sep 14 07:48:50 manjaro wpa_supplicant[1160]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Fabby
14 September 2021 12:29
6
I won’t be able to help you any further, so I’d say: file a bug…
I mean, afaik this is kind of a bug, I haven’t seen an appropriate way to file a bug with manjaro, and if it’s a problem in a manjaro package, arch will be pissed it may not be a problem in usbguard. I’m not even sure usbguard updated recently.
Fabby
14 September 2021 12:49
8
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Especially the What’s this Upstream / Downstream business and then file a bug upstream, because it’s definitely not a bug in one of the Manjaro tools…
[quote="[HowTo] become a Manjaro power user when you’re a wizard at Windows but a N00b at Manjaro / Linux, post:1, topic:13646"]
[/quote]
I’ve been using Linux since 2003, admittedly I haven’t been using it full time since 2014 (I was using it as my primary desktop before then, but then I was mostly on work Mac as a Java Developer) until march of this year, but still. So forgive me if I find this a little patronizing.
Also, Manjaro does change packages from arch, it builds some differently, it changes the PKGBUILD’s for all I know this is caused by some tweak to the kernel that’s being made. I haven’t dug through every library updated ~2 weeks ago.
❯ cat /var/log/pacman.log| grep usbguard
[2021-08-02T02:42:20-0400] [ALPM] installed usbguard (1.0.0-5)
now since usbguard hasn’t been updated since early august, and this happened in early september, do you have any suggestions on which package is causing this? see this is a problem with manjaro over arch, it’s a lot harder to tell which package has been updated.
[2021-09-06T10:28:23-0400] [ALPM] transaction started
[2021-09-06T10:28:24-0400] [ALPM] removed libredefender (0.3.1-1)
[2021-09-06T10:28:24-0400] [ALPM] removed clamav (0.103.3-1)
[2021-09-06T10:28:24-0400] [ALPM] removed libmspack (1:0.10.1alpha-3)
[2021-09-06T10:28:24-0400] [ALPM] transaction completed
[2021-09-06T10:28:24-0400] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-09-06T10:28:25-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T12:22:41-0400] [PAMAC] synchronizing package lists
[2021-09-06T12:23:08-0400] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-09-06T12:23:08-0400] [ALPM] running '71-dkms-remove.hook'...
[2021-09-06T12:23:08-0400] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod -m acpi_call -v 1.2.1 -k 5.10.60-1-MANJARO
[2021-09-06T12:23:08-0400] [ALPM-SCRIPTLET] ==> depmod 5.10.60-1-MANJARO
[2021-09-06T12:23:15-0400] [ALPM] running 'kernel-alive-pre.hook'...
[2021-09-06T12:23:21-0400] [ALPM] transaction started
[2021-09-06T12:23:21-0400] [ALPM] upgraded alsa-card-profiles (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:23:21-0400] [ALPM] upgraded tzdata (2021a-1 -> 2021a-2)
[2021-09-06T12:23:21-0400] [ALPM] upgraded aom (3.1.2-1 -> 3.1.2-2)
[2021-09-06T12:23:22-0400] [ALPM] upgraded archlinux-appstream-data (20210723-1 -> 20210902-1)
[2021-09-06T12:23:22-0400] [ALPM] upgraded libgcrypt (1.9.3-1 -> 1.9.4-1)
[2021-09-06T12:23:22-0400] [ALPM] upgraded avahi (0.8+20+gd1e71b3-1 -> 0.8+22+gfd482a7-1)
[2021-09-06T12:23:22-0400] [ALPM] upgraded nss (3.69-1 -> 3.69.1-1)
[2021-09-06T12:23:22-0400] [ALPM] upgraded re2 (1:20210801-1 -> 1:20210901-1)
[2021-09-06T12:23:22-0400] [ALPM] upgraded freetype2 (2.10.4-1 -> 2.11.0-3)
[2021-09-06T12:23:22-0400] [ALPM] upgraded libssh (0.9.5-1 -> 0.9.6-1)
[2021-09-06T12:23:22-0400] [ALPM] upgraded ca-certificates-mozilla (3.69-1 -> 3.69.1-1)
[2021-09-06T12:23:22-0400] [ALPM] upgraded vulkan-icd-loader (1.2.187-1 -> 1.2.188-1)
[2021-09-06T12:23:23-0400] [ALPM] upgraded iso-codes (4.6.0-1 -> 4.7.0-1)
[2021-09-06T12:23:23-0400] [ALPM] upgraded glib-networking (1:2.68.1-1 -> 1:2.68.2-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded electron11 (11.4.12-1 -> 11.5.0-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded bitwarden (1.28.1-1 -> 1.28.2-3)
[2021-09-06T12:23:24-0400] [ALPM] upgraded bluez (5.60-1 -> 5.61-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded bluez-libs (5.60-1 -> 5.61-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded bluez-utils (5.60-1 -> 5.61-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded cpupower (5.13-1 -> 5.14-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded libx86emu (3.1-1 -> 3.2-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded bmenu (0.16-1 -> 0.17-1)
[2021-09-06T12:23:24-0400] [ALPM] upgraded bubblewrap (0.4.1-2 -> 0.5.0-1)
[2021-09-06T12:23:29-0400] [ALPM] upgraded chromium (92.0.4515.159-1 -> 93.0.4577.63-1)
[2021-09-06T12:23:29-0400] [ALPM] upgraded poppler (21.08.0-1 -> 21.09.0-1)
[2021-09-06T12:23:29-0400] [ALPM] upgraded imagemagick (7.1.0.4-2 -> 7.1.0.5-1)
[2021-09-06T12:23:29-0400] [ALPM] upgraded cups-filters (1.28.9-1 -> 1.28.10-1)
[2021-09-06T12:23:29-0400] [ALPM] upgraded dkms (2.8.4-1 -> 2.8.5-1)
[2021-09-06T12:23:29-0400] [ALPM] upgraded pipewire (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:23:30-0400] [ALPM] upgraded flatpak (1.11.2-1 -> 1.11.3-1)
[2021-09-06T12:23:30-0400] [ALPM] upgraded foomatic-db (3:20210528-1 -> 3:20210828-1)
[2021-09-06T12:23:30-0400] [ALPM] upgraded fprintd (1.92.0-1 -> 1.94.0-1)
[2021-09-06T12:23:30-0400] [ALPM] upgraded upower (0.99.12-2 -> 0.99.13-1)
[2021-09-06T12:23:30-0400] [ALPM] upgraded xorg-xrdb (1.2.0-2 -> 1.2.1-1)
[2021-09-06T12:23:30-0400] [ALPM] upgraded libgdm-plymouth (40.1-1 -> 40.1-2)
[2021-09-06T12:23:30-0400] [ALPM] upgraded pipewire-media-session (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:23:31-0400] [ALPM] upgraded gst-plugin-pipewire (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:23:31-0400] [ALPM] upgraded pipewire-pulse (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:23:31-0400] [ALPM] upgraded libwacom (1.11-1 -> 1.12-1)
[2021-09-06T12:23:31-0400] [ALPM] upgraded pipewire-alsa (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:23:31-0400] [ALPM] upgraded mobile-broadband-provider-info (20201225-1 -> 20210805-1)
[2021-09-06T12:23:31-0400] [ALPM] upgraded gdm-plymouth (40.1-1 -> 40.1-2)
[2021-09-06T12:23:31-0400] [ALPM] upgraded gnome-shell-extension-nightthemeswitcher (51-1 -> 51-2)
[2021-09-06T12:23:45-0400] [ALPM] upgraded go (2:1.17-1 -> 2:1.17-2)
[2021-09-06T12:23:45-0400] [ALPM] upgraded gpm (1.20.7.r38.ge82d1a6-3 -> 1.20.7.r38.ge82d1a6-4)
[2021-09-06T12:23:45-0400] [ALPM] upgraded poppler-glib (21.08.0-1 -> 21.09.0-1)
[2021-09-06T12:23:58-0400] [ALPM] upgraded inkscape (1.1-5 -> 1.1-6)
[2021-09-06T12:23:58-0400] [ALPM] upgraded iproute2 (5.13.0-1 -> 5.14.0-1)
[2021-09-06T12:24:01-0400] [ALPM] upgraded qt5-declarative (5.15.2+kde+r29-1 -> 5.15.2+kde+r30-1)
[2021-09-06T12:24:01-0400] [ALPM] upgraded kdecoration (5.22.4-1 -> 5.22.5-1)
[2021-09-06T12:24:01-0400] [ALPM] upgraded kde-gtk-config (5.22.4-1 -> 5.22.5-1)
[2021-09-06T12:24:02-0400] [ALPM] installed lib32-brotli (1.0.9-1)
[2021-09-06T12:24:02-0400] [ALPM] upgraded lib32-freetype2 (2.10.4-1 -> 2.11.0-3)
[2021-09-06T12:24:02-0400] [ALPM] upgraded lib32-libgcrypt (1.9.3-1 -> 1.9.4-1)
[2021-09-06T12:24:02-0400] [ALPM] upgraded lib32-nss (3.69-1 -> 3.69.1-1)
[2021-09-06T12:24:02-0400] [ALPM] upgraded lib32-openssl (1:1.1.1.k-1 -> 1:1.1.1.l-1)
[2021-09-06T12:24:03-0400] [ALPM] upgraded lib32-pipewire (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:24:03-0400] [ALPM] upgraded lib32-sdl2 (2.0.14-1 -> 2.0.16-1)
[2021-09-06T12:24:04-0400] [ALPM] warning: directory permissions differ on /boot/
[2021-09-06T12:24:09-0400] [ALPM] upgraded linux510 (5.10.60-1 -> 5.10.61-1)
[2021-09-06T12:24:18-0400] [ALPM] upgraded linux510-headers (5.10.60-1 -> 5.10.61-1)
[2021-09-06T12:24:18-0400] [ALPM] upgraded python-cairo (1.20.0-3 -> 1.20.1-1)
[2021-09-06T12:24:18-0400] [ALPM] upgraded lollypop (1.4.22-1 -> 1.4.23-1)
[2021-09-06T12:24:19-0400] [ALPM] upgraded man-pages (5.12-2 -> 5.13-1)
[2021-09-06T12:24:19-0400] [ALPM] upgraded manjaro-release (21.1.1-1 -> 21.1.2-1)
[2021-09-06T12:24:20-0400] [ALPM] upgraded npm (7.21.0-1 -> 7.21.1-1)
[2021-09-06T12:24:44-0400] [ALPM] upgraded opera (78.0.4093.147-1 -> 78.0.4093.184-1)
[2021-09-06T12:24:44-0400] [ALPM] upgraded opera-ffmpeg-codecs (92.0.4515.131-1 -> 92.0.4515.159-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded papirus-icon-theme (20210802-2 -> 20210901-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded pipewire-jack (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded pipewire-zeroconf (1:0.3.33-1 -> 1:0.3.34-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded python-cryptography (3.4.7-1 -> 3.4.8-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded python-google-api-python-client (2.17.0-1 -> 2.18.0-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded python-tldextract (3.1.0-1 -> 3.1.2-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded run-parts (5.3-1 -> 5.4-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded telegram-desktop (2.9.3-1 -> 3.0.0-1)
[2021-09-06T12:25:03-0400] [ALPM] upgraded timeshift (20.11.1.r28.gefed117-2 -> 20.11.1+28+gefed117-1)
[2021-09-06T12:25:03-0400] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Attempting to enable Cronie services...e[1;0mCreated symlink /etc/systemd/system/multi-user.target.wants/cronie.service → /usr/lib/systemd/system/cronie.service.
[2021-09-06T12:25:04-0400] [ALPM-SCRIPTLET]
[2021-09-06T12:25:04-0400] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Cronie services should now be enabled.e[1;0me[1;1me[1;32m==>e[1;0me[1;1m Reboot your system, so changes will take affect.e[1;0m
[2021-09-06T12:25:04-0400] [ALPM] upgraded vulkan-headers (1:1.2.187-1 -> 1:1.2.188-1)
[2021-09-06T12:25:04-0400] [ALPM] transaction completed
[2021-09-06T12:25:09-0400] [ALPM] running '20-systemd-sysusers.hook'...
[2021-09-06T12:25:10-0400] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-09-06T12:25:10-0400] [ALPM] running '30-systemd-hwdb.hook'...
[2021-09-06T12:25:11-0400] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-09-06T12:25:11-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T12:25:11-0400] [ALPM] running '40-update-ca-trust.hook'...
[2021-09-06T12:25:12-0400] [ALPM] running '60-depmod.hook'...
[2021-09-06T12:25:25-0400] [ALPM] running '70-dkms-install.hook'...
[2021-09-06T12:25:25-0400] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m acpi_call -v 1.2.1 -k 5.10.61-1-MANJARO
[2021-09-06T12:25:28-0400] [ALPM-SCRIPTLET] ==> depmod 5.10.61-1-MANJARO
[2021-09-06T12:25:34-0400] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-09-06T12:25:34-0400] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-09-06T12:25:34-0400] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-09-06T12:25:34-0400] [ALPM-SCRIPTLET] ==> Starting build: 5.10.61-1-MANJARO
[2021-09-06T12:25:34-0400] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-09-06T12:25:34-0400] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-09-06T12:25:35-0400] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-09-06T12:25:35-0400] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-09-06T12:25:36-0400] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-09-06T12:25:36-0400] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-09-06T12:25:36-0400] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-09-06T12:25:36-0400] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-09-06T12:25:37-0400] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-09-06T12:25:38-0400] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-09-06T12:25:38-0400] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-09-06T12:25:38-0400] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-09-06T12:25:39-0400] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-09-06T12:25:39-0400] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-09-06T12:25:39-0400] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-09-06T12:25:39-0400] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-09-06T12:25:39-0400] [ALPM-SCRIPTLET] ==> Starting build: 5.10.61-1-MANJARO
[2021-09-06T12:25:39-0400] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-09-06T12:25:39-0400] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-09-06T12:25:40-0400] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-09-06T12:25:40-0400] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-09-06T12:25:41-0400] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-09-06T12:25:41-0400] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-09-06T12:25:41-0400] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-09-06T12:25:44-0400] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-09-06T12:25:45-0400] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-09-06T12:25:45-0400] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-09-06T12:25:47-0400] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-09-06T12:25:47-0400] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-09-06T12:25:47-0400] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-09-06T12:25:47-0400] [ALPM] running 'dbus-reload.hook'...
[2021-09-06T12:25:47-0400] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-09-06T12:25:47-0400] [ALPM] running 'gio-querymodules.hook'...
[2021-09-06T12:25:47-0400] [ALPM] running 'glib-compile-schemas.hook'...
[2021-09-06T12:25:47-0400] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-09-06T12:25:54-0400] [ALPM] running 'kernel-alive-post.hook'...
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET]
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Warning:
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET] -> at next boot.
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET] e[1;0m
[2021-09-06T12:25:59-0400] [ALPM] running 'manjaro-extensions.hook'...
[2021-09-06T12:25:59-0400] [ALPM-SCRIPTLET] No schema files found: doing nothing.
[2021-09-06T12:25:59-0400] [ALPM] running 'sdboot-kernel-update.hook'...
[2021-09-06T12:25:59-0400] [ALPM] running 'texinfo-install.hook'...
[2021-09-06T12:26:01-0400] [ALPM] running 'update-desktop-database.hook'...
[2021-09-06T12:26:01-0400] [ALPM] running 'update-mime-database.hook'...
[2021-09-06T12:26:08-0400] [ALPM] transaction started
[2021-09-06T12:26:08-0400] [ALPM] upgraded em-keyboard (1.0.0-1 -> 2.0.0-1)
[2021-09-06T12:26:08-0400] [ALPM] transaction completed
[2021-09-06T12:26:08-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T13:05:06-0400] [ALPM] transaction started
[2021-09-06T13:05:06-0400] [ALPM] installed libzip (1.7.3-2)
[2021-09-06T13:05:06-0400] [ALPM] installed php (8.0.10-1)
[2021-09-06T13:05:07-0400] [ALPM] transaction completed
[2021-09-06T13:05:07-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T13:05:21-0400] [ALPM] transaction started
[2021-09-06T13:05:22-0400] [ALPM] installed phoronix-test-suite (10.4.0-1)
[2021-09-06T13:05:22-0400] [ALPM] transaction completed
[2021-09-06T13:05:22-0400] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-09-06T13:05:22-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T13:05:22-0400] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-09-06T13:05:22-0400] [ALPM] running 'update-desktop-database.hook'...
[2021-09-06T14:02:14-0400] [ALPM] transaction started
[2021-09-06T14:02:15-0400] [ALPM] removed timeshift (20.11.1+28+gefed117-1)
[2021-09-06T14:02:15-0400] [ALPM] transaction completed
[2021-09-06T14:02:15-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T14:02:15-0400] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-09-06T14:02:15-0400] [ALPM] running 'update-desktop-database.hook'...
[2021-09-06T23:27:11-0400] [ALPM] transaction started
[2021-09-06T23:27:11-0400] [ALPM] removed evolution-spamassassin (3.40.4-1)
[2021-09-06T23:27:11-0400] [ALPM] transaction completed
[2021-09-06T23:27:11-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T23:27:25-0400] [ALPM] transaction started
[2021-09-06T23:27:25-0400] [ALPM] removed spamassassin (3.4.6-2)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-mail-spf (2.9.0-8)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-netaddr-ip (4.079-11)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-crypt-ssleay (0.73_04-15)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-path-class (0.37-7)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-bytes-random-secure (0.29-9)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-math-random-isaac (1.004-8)
[2021-09-06T23:27:25-0400] [ALPM] removed re2c (2.2-1)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-crypt-random-seed (0.03-6)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-crypt-random-tesha2 (0.01-7)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-mail-dkim (1.20200907-2)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-mail-authenticationresults (2.20210112-2)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-json (4.03-1)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-crypt-openssl-rsa (0.31-6)
[2021-09-06T23:27:25-0400] [ALPM] removed perl-crypt-openssl-random (0.15-7)
[2021-09-06T23:27:25-0400] [ALPM] transaction completed
[2021-09-06T23:27:25-0400] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-09-06T23:27:25-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T23:28:02-0400] [PAMAC] synchronizing package lists
[2021-09-06T23:28:09-0400] [ALPM] transaction started
[2021-09-06T23:28:09-0400] [ALPM] upgraded bmenu (0.17-1 -> 0.17-2)
[2021-09-06T23:28:09-0400] [ALPM] installed libmspack (1:0.10.1alpha-3)
[2021-09-06T23:28:09-0400] [ALPM] installed clamav (0.103.3-1)
[2021-09-06T23:28:09-0400] [ALPM] installed libredefender (0.3.1-1)
[2021-09-06T23:28:10-0400] [ALPM] transaction completed
[2021-09-06T23:28:10-0400] [ALPM] running '20-systemd-sysusers.hook'...
[2021-09-06T23:28:10-0400] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-09-06T23:28:10-0400] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-09-06T23:28:10-0400] [ALPM] running '30-systemd-update.hook'...
[2021-09-06T23:28:10-0400] [ALPM] running 'update-desktop-database.hook'...
[2021-09-06T23:28:23-0400] [PAMAC] synchronizing package lists
Fabby
16 September 2021 18:43
10
My apologies, it’s just a boilerplate answer that:
you’re running this package, I’m not, so I can’t help you any further and hence:
P.S. You’re also the first veteran to be offended by being sent to the N00b page in 3 years. Most veterans respond with
And which package is that? for since usbguard hasn’t been updated, I’d say it stands to reason it might be the Linux kernel or libfprint (which is no end of issues for me). I really don’t know which package. I suppose I’ll go report it to arch to see if they have any idea how to debug it. They’re likely to tell me to F* off if I mention the manjaro anything though.
I’m in a really bad mood these days, lot’s of personal drama. I’m so tired of having to run around and badger people to do their shit. Lawyer’s need to do their stuff, ISP and Phone Company should do theirs, My moving company needs to get me my stuff, it’s been 3 months… dev’s need to fix their bugs.
Fabby
16 September 2021 20:21
12
usbguard
: you might be running a newer kernel / newer libs than the devs themselves: Manjaro is at the cutting edge…
If they know about them…
As to the mood, the only thing I can to for you is to… please bear with me until the end… refer you back to the N00b guide : Even if you’re a veteran, it’s a pretty funny read and I’d like your input on how to improve it!
well, I’ve uninstalled usbguard, and rebooted after yesterdays update. I just went to log in an fingerprint wasn’t available at log in, but it was after. I think it’s somewhere else. Maybe libfprint… I suppose I can go find my previous, recent, libfprint, bug and remind myself how to enable the debugger for that. I’m hoping it’s not the kernel but who knows.
