Hi, I am new to Linux. Yesterday I saw my bandwidth usage for the day was disproportionately high. I know I clicked Refresh Databases on Pamac, so my question is could refreshing databases consume 13 GB of data?
Thank you for your advice.
Hello @newtolinux and welcome
No, if you force refresh the database, then it downloads the whole database which is about ~70MB.
You can check this folder (it is a terminal command):
du -hs /var/tmp/pamac/dbs/sync
The rest must be an enormous big update of your system. Usually it is about 1 or 2GB monthly. But it depends on what you have installed with pamac.
Thank you, megavolt.
So it was 55MB.
I appreciate you taking the time to help me.
And that’s it? You opened a thread because of mysteriously consumed 13GB of data, and you’re done now you know updating packages database doesn’t consume much bandwidth?
On a side note watching videos online consume A LOT of data, it goes fast. For sure 13GB of data is not small so if you’re not using your connection, maybe someone else is, I would investigate a little at least.
