Refind, what file to edit
Still locked folder.
Try changing the permissions on the mountpoint (directory) itself… :backhand_index_pointing_down:
sudo chmod 755 /boot/efi
Nope, still locked.
Well then just boot from live usb and mount it from there. Guaranteed to work.
Um… I don’t quite understand why you’re going to all that trouble fiddling with the permissions?
A simple sudo ls -alp /boot/efi/ should be enough to take a quick look, and then you can just follow it up with sudo nano /boot/efi/EFI/refind/refind.conf.
Don’t be afraid of the terminal—it’s not rocket science.
Why be so modest and settle for just a wallpaper… when there are such cool themes out there?
Thanks. I was thinking this way too but i couldn’t remember the exact path to the file.
Now, if you had only scrolled up. :wink:
From Post#13:
sudo nano /boot/efi/efi/refind/refind.conf
