USB random disconnects. Can i discover the cause?
Hello, when there are USB disconnects like this, can i discover any way to fix this or verify that this is random hardware failure?
5.8.18-1-MANJARO
The port to which the drive is connected is one of the two USB 2.0 ports. The other of the two is used by the 4 port USB hub. One more port is USB 3.0.
The disconnects happen, currently it is numerous time in a few hours without physical touch to the cable.
So if i know this is hardware failure, i would sold the computer as such (i guess no easy/cheap repair).
A post was merged into an existing topic: Manjaro ignored my USB hub - usb 2-5.1: device descriptor read/64, error -110 & Timeout while waiting for setup device command
