Redshift disables when I connect to VPN (VPN to Japan)
Good day. I have been using redshift for a few weeks now and it is great. My problem is, everytime I connect to VPN (from PH to JP), it turns off…Any idea how to fix this? Thanks in advance
inxi -Fazy
  Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=3e711149-8ebe-45af-8e9a-78a1cdacff3f rw quiet apparmor=1
  security=apparmor resume=UUID=d27dc7f4-ce4f-48b8-ba69-9971d9cc4ca0
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: Aspire A514-53 v: V1.16 serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: IL model: Sneezy_IL v: V1.16 serial: <filter> UEFI: Insyde v: 1.16
  date: 01/18/2021
  ID-1: BAT0 charge: 32.1 Wh (97.9%) condition: 32.8/53.0 Wh (62.0%)
  volts: 16.7 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
  serial: <filter> status: Charging cycles: 386
  Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
  arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
  L2: 4 MiB
  bogomips: 9524
  Speed: 3401 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3401 2: 3400
  3: 3384 4: 3400
  Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
  Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:4
  chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
  diag: 354mm (13.9")
  OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.2
  direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
  bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
  Device-2: C-Media USB PnP Sound Device type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 0d8c:013a
  class-ID: 0300
  Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.37 running: yes
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 4000 bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
  bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  IF-ID-3: virbr0 state: down mac: <filter>
  bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
  hardware: no software: no address: see --recommends
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
  Device-1: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 2136 chunk-size: N/A
  Components: Online: N/A Spare:
  0: nvme0n1 maj-min: 259:0 size: 476.94 GiB state: S
  Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 2944 chunk-size: N/A
  0: nvme1n1 maj-min: 259:5 size: 27.25 GiB state: S
  Local Storage: total: 1.4 TiB used: 207.34 GiB (14.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
  size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
  lanes: 2 type: SSD serial: <filter> rev: G002 temp: 27.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: HBRPEKNX0202AO
  size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
  lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 34.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
  type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
  ID-1: / raw-size: 400 GiB size: 392.65 GiB (98.16%) used: 90.47 GiB (23.0%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2
  used: 308 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 53.0 C mobo: N/A
  Processes: 208 Uptime: 15m wakeups: 1 Memory: 7.45 GiB used: 2.6 GiB (35.0%)
  Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: apt: 0
  pacman: 1504 lib: 422 flatpak: 0 Shell: Zsh v: 5.8 running-in: konsole
  inxi: 3.3.06
neofetch
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   soumi@Hori
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   ----------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   OS: Manjaro Linux x86_64
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Host: Aspire A514-53 V1.16
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Kernel: 5.14.7-2-MANJARO
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Uptime: 15 mins
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Packages: 1504 (pacman)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Shell: zsh 5.8
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Resolution: 1366x768
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   DE: Plasma 5.22.5
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   WM: KWin
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Theme: Breeze Light [Plasma], Breeze [GTK2/3]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Icons: breeze [Plasma], breeze [GTK2/3]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ   Terminal: konsole
                               CPU: Intel i3-1005G1 (4) @ 3.400GHz
                               GPU: Intel Iris Plus Graphics G1
                               Memory: 2390MiB / 7630MiB
It sounds like it’s using your IP address for location. You can specify a location manually, see the documentation:
http://jonls.dk/redshift/
Thanks for this. Will check this out
