Hello, I have held off from updating my system for a long time now due to this issue and was hoping the updating now would finally solve the issue but it still persists. I can’t connect to my home wifi with manjaro and only manjaro. Everything else connects just fine.
Here is a picture of what appears in the network manager. (Remove the spaces in the link for it to work)
https:// ibb. co/ v4LkfY4
When trying to connect it disconnects immediately. In the network log it says
config → failed (reason ‘supplicant-failed’, sys-iface-state: ‘managed’)
failure to add network: invalid message format
I did see one solution being to downgrade wpa_supplicant to 2.9 version but apparently to ensure I go insane manjaro has made it only downgrade to 2.10 and no further.
I still have the Manjaro Live USB (which does connect to the wifi fine) to reinstall onto my system again but I’m tired of updating to see if it works now only to then reset my entire system all over again. Please tell me there is a solution to this.
Olli
December 1, 2022, 6:04pm
#2
please post the output of
first. use the preformatted option and insert it there. any pics have no valuable info.
Desktop]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e724ffe8-09b8-47a1-af71-5abe89093fb1 rw quiet
udev.log_priority=3
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: MSI model: B250M PRO-VD (MS-7A74) v: 1.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1.20
date: 12/02/2016
RAM: total: 15.59 GiB used: 1.72 GiB (11.0%)
Info: model: Intel Pentium G4560 bits: 64 type: MT MCP arch: Kaby Lake
level: v2 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28009
Flags: 3dnowprefetch abm acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority flush_l1d fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: v: 21.1.4 compositor: xfwm v: 4.16.1 driver: N/A
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 size: N/A modes: N/A
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor:
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: no
Device-1: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 168c:0030 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
vendor: Micro-Star MSI driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 1.82 TiB used: 140.74 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 140.74 GiB (7.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: e724ffe8-09b8-47a1-af71-5abe89093fb1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: BDA Xbox Series X EnWired Controller Blue inline
type: <vendor specific> driver: xpad interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 20d6:200a class-ID: ff00 serial: <filter>
Device-2: 1-7:3 info: [Maxxter] USB GAMING MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0fc0 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 25 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 188 Uptime: 1h 55m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 946 libs: 289 tools: pamac Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.23
Olli
December 1, 2022, 7:52pm
#4
please check the antenna-connection first and make sure that there is no failure
TriMoon
December 1, 2022, 11:05pm
#5
Hi and welcome to the forum
Also pls perform these commands:
alias xclip='xclip -selection clipboard'
journalctl --no-pager --unit=wpa_supplicant | xclip
Then paste what is copied in your clipboard inside code tags like this:
``` ⇐ are backticks, normally on left of the 1 key.
<your pasted text>
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to f…
No failure there, it’s able to connect to other networks with no issue. It also connects fine when I reinstall manjaro from the live usb. The network drops only when I update and only that specific network.
TriMoon
December 2, 2022, 8:29am
#7
And…thats why you need to provide the logs after you have updated and it drops that connection .
No logs provided means only word-guessing between you and those who spend time to help you…
It might be caused by a driver update or openssl package etc etc etc…
So please install the xclip
package first then perform the commands i posted, that way ppl can see why your supplicant does not connect after that update…
