Recovering grub settings form file thats in use by grub.
Hello,
My problem is that my grub settings are corrupted (probably because i was using grub-customizer) and command update-grub show errors and dont save changes. But my actual grub.cfg file is fine and i want to keep it as it is. Is there any way to dont change actual used settings (grub.cfg file) but make command grub-update working again?
This is a result of update-grub command:
Found theme: /boot/grub/themes/starfield/theme.txt
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Found Windows 10 on /dev/sda1
błąd: syntax error.
błąd: Incorrect command.
błąd: syntax error.
Błąd składni w linii 199
Syntax errors are detected in generated GRUB config file.
Ensure that there are no errors in /etc/default/grub
and /etc/grub.d/* files or please file a bug report with
/boot/grub/grub.cfg.new file attached.
Please have a look at the following solution from @gohlip:
Change sda to adapt to your proper setup.
Thanks, i think it works. Its clear and i lost my settings but thats ok.
Great! Good that it worked out!
All credit goes to @gohlip (非常谢谢)from whom I have been learning a lot (still am) when it comes to Grub, booting, installation etc.
What settings?
Only things like custom theme, background. I was trying to save them but in that way i learned something new by doing this myself manually, so its not a big deal.
If you're saying the 'grub theme' settings is lost, meaning you've lost the nicer grub menu, see this post and change in /etc/default/grub to
GRUB_TERMINAL_OUTPUT=gfxterm
GRUB_GFXMODE=1024x768x32
GRUB_GFXPAYLOAD_LINUX=1024x768x32
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
As in that post, first check there is a directory in /usr/share/grub/themes/manjaro/
Don't forget to 'update-grub' after changes.
But yes, grub thingies should be in /boot/grub/~ not /usr/share/grub/~
We used Fedora way to make things hidden/complicated/messed up.
Luckily, we've not used initrdefi or linux16 in our grub commands.
Or /boot/efi/grub.cfg or /boot/efi/grub2/grub.cfg or... :face_with_thermometer:
I looked into grub file on my pc and I figure out how to import theme by myself but thanks anyway. I will add the rest of this lines just to make it better.
