Recovering from Unbootable System after Mid-update Crash
Please excuse me if there is an easy answer to this out there, I’ve been running between different threads and tutorials and have decided I’ve either done as much as I can or have done enough damage already. Last night my laptop randomly froze mid-update (will make separate thread on this semi-frequent freezing), breaking both my kernels (linux61 & 67) as well as pacman, yay, and pamac (returns immediately to command prompt in chroot). I was able to fix the first two package managers by force (meaning --overwrite "*") reinstalling from chroot, however when attempting to force reinstall the kernels (not through mhwd-kernel, as it returns “no targets specified”) I get various errors regarding failed symbol loading and dkms building.
[manjaro /]# pacman -S --overwrite "*" linux61 linux67
warning: linux61-6.1.82-1 is up to date -- reinstalling
warning: linux67-6.7.10-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) linux61-6.1.82-1  linux67-6.7.10-1
Total Installed Size:  280.81 MiB
Net Upgrade Size:        0.00 MiB
:: Proceed with installation? [Y/n] Y
(2/2) checking keys in keyring                                     [------------------------------------] 100%
(2/2) checking package integrity                                   [------------------------------------] 100%
(2/2) loading package files                                        [------------------------------------] 100%
(2/2) checking for file conflicts                                  [------------------------------------] 100%
(2/2) checking available disk space                                [------------------------------------] 100%
(1/2) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Remove upgraded DKMS modules
(1/2) reinstalling linux61                                         [------------------------------------] 100%
(2/2) reinstalling linux67                                         [------------------------------------] 100%
ldconfig: File /usr/lib/libpamac.so.11 is empty, not checked.
ldconfig: File /usr/lib/libKF5Sane.so.6 is empty, not checked.
ldconfig: File /usr/lib/libpamac-flatpak.so.11 is empty, not checked.
ldconfig: File /usr/lib/libpamac-flatpak.so is empty, not checked.
ldconfig: File /usr/lib/libpackagekit-glib2.so.18.1.3 is empty, not checked.
ldconfig: File /usr/lib/libpamac.so.11.6 is empty, not checked.
ldconfig: File /usr/lib/libpamac-appstream.so.11.6 is empty, not checked.
ldconfig: File /usr/lib/libpamac-flatpak.so.11.6 is empty, not checked.
ldconfig: File /usr/lib/libpackagekit-glib2.so.18 is empty, not checked.
ldconfig: File /usr/lib/libpamac-aur.so is empty, not checked.
ldconfig: File /usr/lib/libpamac-snap.so is empty, not checked.
ldconfig: File /usr/lib/libpamac-snap.so.11.6 is empty, not checked.
ldconfig: File /usr/lib/libpamac-aur.so.11 is empty, not checked.
ldconfig: File /usr/lib/libpamac.so is empty, not checked.
ldconfig: File /usr/lib/libpamac-snap.so.11 is empty, not checked.
ldconfig: File /usr/lib/libpackagekit-glib2.so is empty, not checked.
ldconfig: File /usr/lib/libKSaneWidgets6.so is empty, not checked.
ldconfig: File /usr/lib/libKSaneWidgets6.so.6 is empty, not checked.
ldconfig: File /usr/lib/libpamac-appstream.so is empty, not checked.
ldconfig: File /usr/lib/libpamac-aur.so.11.6 is empty, not checked.
ldconfig: File /usr/lib/libKF5Sane.so is empty, not checked.
ldconfig: File /usr/lib/libKSaneWidgets6.so.24.02.0 is empty, not checked.
ldconfig: File /usr/lib/libpamac-appstream.so.11 is empty, not checked.
ldconfig: File /usr/lib/libpacutils.so is empty, not checked.
ldconfig: File /usr/lib/libappstream-glib.so.8.0.10 is empty, not checked.
ldconfig: File /usr/lib/libappstream-glib.so.8 is empty, not checked.
ldconfig: File /usr/lib/libappstream-glib.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Sane.so.24.02.0 is empty, not checked.
(1/7) Arming ConditionNeedsUpdate...
(2/7) Updating module dependencies...
depmod: ERROR: failed to load symbols from /lib/modules/6.1.82-1-MANJARO/extramodules/vboxnetflt.ko.zst: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/6.1.82-1-MANJARO/extramodules/vboxnetadp.ko.zst: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/6.1.82-1-MANJARO/extramodules/vboxdrv.ko.zst: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/6.7.10-1-MANJARO/extramodules/vboxnetflt.ko.zst: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/6.7.10-1-MANJARO/extramodules/vboxnetadp.ko.zst: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/6.7.10-1-MANJARO/extramodules/vboxdrv.ko.zst: Invalid argument
(3/7) Install DKMS modules
==> dkms install --no-depmod v4l2loopback/0.12.7 -k 6.7.10-1-MANJARO
readelf: Error: /usr/lib/modules/6.7.10-1-MANJARO/build/vmlinux: Failed to read file's magic number
Error! The /var/lib/dkms/v4l2loopback/0.12.7/6.7.10-1-MANJARO/x86_64/dkms.conf for module v4l2loopback includes a BUILD_EXCLUSIVE directive which does not match this kernel/arch/config.
This indicates that it should not be built.
==> WARNING: `dkms install --no-depmod v4l2loopback/0.12.7 -k 6.7.10-1-MANJARO' exited 77
==> dkms install --no-depmod openrazer-driver/3.7.0 -k 6.7.10-1-MANJARO
Error! Bad return status for module build on kernel: 6.7.10-1-MANJARO (x86_64)
Consult /var/lib/dkms/openrazer-driver/3.7.0/build/make.log for more information.
==> WARNING: `dkms install --no-depmod openrazer-driver/3.7.0 -k 6.7.10-1-MANJARO' exited 10
==> dkms install --no-depmod openrazer-driver/3.7.0 -k 6.1.82-1-MANJARO
readelf: Error: /usr/lib/modules/6.1.82-1-MANJARO/build/vmlinux: Failed to read file's magic number
Error! Bad return status for module build on kernel: 6.1.82-1-MANJARO (x86_64)
==> WARNING: `dkms install --no-depmod openrazer-driver/3.7.0 -k 6.1.82-1-MANJARO' exited 10
==> dkms install --no-depmod v4l2loopback/0.12.7 -k 6.1.82-1-MANJARO
Error! The /var/lib/dkms/v4l2loopback/0.12.7/6.1.82-1-MANJARO/x86_64/dkms.conf for module v4l2loopback includes a BUILD_EXCLUSIVE directive which does not match this kernel/arch/config.
==> WARNING: `dkms install --no-depmod v4l2loopback/0.12.7 -k 6.1.82-1-MANJARO' exited 77
==> dkms install --no-depmod hid-xpadneo/v0.9.6 -k 6.7.10-1-MANJARO
Error! The /var/lib/dkms/hid-xpadneo/v0.9.6/6.7.10-1-MANJARO/x86_64/dkms.conf for module hid-xpadneo includes a BUILD_EXCLUSIVE directive which does not match this kernel/arch/config.
==> WARNING: `dkms install --no-depmod hid-xpadneo/v0.9.6 -k 6.7.10-1-MANJARO' exited 77
==> dkms install --no-depmod hid-xpadneo/v0.9.6 -k 6.1.82-1-MANJARO
Error! The /var/lib/dkms/hid-xpadneo/v0.9.6/6.1.82-1-MANJARO/x86_64/dkms.conf for module hid-xpadneo includes a BUILD_EXCLUSIVE directive which does not match this kernel/arch/config.
==> WARNING: `dkms install --no-depmod hid-xpadneo/v0.9.6 -k 6.1.82-1-MANJARO' exited 77
(4/7) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: '6.1.82-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
  -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux67.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
==> WARNING: Deprecated option 'ALL_microcode' found. Update '/etc/mkinitcpio.d/linux67.preset' to use the 'microcode' hook instead.
  -> -k /boot/vmlinuz-6.7-x86_64 -g /boot/initramfs-6.7-x86_64.img
==> Starting build: '6.7.10-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.7-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux67.preset: 'fallback'
  -> -k /boot/vmlinuz-6.7-x86_64 -g /boot/initramfs-6.7-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.7-x86_64-fallback.img'
(5/7) Updating Kernel initcpios for Nvidia-DRM...
(6/7) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.7-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.7-x86_64.img
Found initrd fallback image: /boot/initramfs-6.7-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Warning: version_find_latest() is deprecated. Use version_sort() instead.
Warning: version_test_gt() is deprecated. Use version_sort() instead.
Warning: version_test_numeric() is deprecated. Use version_sort() instead.
done
(7/7) .pacnew notify
error: command failed to execute correctly
I hoped that maybe these were issues I could fix from my installation, but upon restarting after running update-grub, it skipped grub and booted straight to my installation. During this process a few errors displayed, obtained now from journalctl --boot=-1 --priority=3 (the entries from system-logind, avahi-daemon, & bluetoothd did not display during boot, only from systemd, just to be clear):
Mar 16 11:31:15 CreamMachine systemd[1]: Failed to start D-Bus System Message Bus.
Mar 16 11:31:16 CreamMachine systemd-logind[1138]: Failed to connect to system bus: Connection refused
Mar 16 11:31:16 CreamMachine systemd-logind[1138]: Failed to fully start up daemon: Connection refused
Mar 16 11:31:16 CreamMachine systemd[1]: Failed to start User Login Management.
Mar 16 11:31:16 CreamMachine systemd[1]: Failed to start D-Bus System Message Bus.
Mar 16 11:31:16 CreamMachine avahi-daemon[1130]: dbus_bus_get_private(): Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mar 16 11:31:16 CreamMachine systemd[1]: Failed to start Avahi mDNS/DNS-SD Stack.
Mar 16 11:31:16 CreamMachine systemd[1]: Failed to start Authorization Manager.
Mar 16 11:31:16 CreamMachine bluetoothd[1507]: src/main.c:main() Unable to get on D-Bus
Mar 16 11:31:16 CreamMachine systemd[1]: Failed to start Bluetooth service.
One more thing I should probably mention is that originally I had nvidia-dkms installed, but with the DKMS errors part of my attempts so far to return to a system I can login to was repalcing it with linux61-nvidia & linux67-nvidia from chroot. Lastly, some information (all from manjaro-chroot environment, idk what’s up with the 12s):
inxi -v8azy
12System:
  12Kernel 6.6.10-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1
    12clocksource tsc 12avail acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64
    lang=en_US keytable=us tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_2313 quiet systemd.show_status=1 splash
    driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  12Desktop KDE Plasma 12v ERR-101 12tk Qt 12v N/A 12dm N/A 12Distro Manjaro
    12base Arch Linux
12Machine:
  12Type Laptop 12System Alienware 12product Alienware m15 R6 12v N/A 12serial <filter>
    12Chassis 12type 10 12serial <filter>
  12Mobo Alienware 12model 0Y6YVC 12v A02 12serial <filter> 12part-nu 0A73
    12uuid 4c4c4544-0059-4210-804d-b3c04f5a4b33 12UEFI Alienware 12v 1.27.0
    12date 12/13/2023
12Battery:
  12ID-1 BAT0 12charge 59.8 Wh (100.0%) 12condition 59.8/84.3 Wh (70.9%) 12volts 12.6
    12min 11.4 12model BYD DELL M59JH1A 12type Li-poly 12serial <filter> 12status full
12Memory:
  12System RAM 12total 16 GiB 12available 15.36 GiB 12used 5 GiB (32.5%) 12igpu 60 MiB
  12Array-1 12capacity 128 GiB 12note check 12slots 2 12modules 2 12EC None
    12max-module-size 64 GiB 12note est.
  12Device-1 DIMM A 12type DDR4 12detail synchronous 12size 8 GiB 12speed 3200 MT/s
    12volts 12curr 1.2 12width (bits) 12data 64 12total 64 12manufacturer 80CE000080CE
    12part-no M471A1G44BB0-CWE 12serial <filter>
  12Device-2 DIMM B 12type DDR4 12detail synchronous 12size 8 GiB 12speed 3200 MT/s
12PCI Slots:
  12Slot 0 12type PCIe 12lanes 1 12status available 12length long 12volts 3.3
    12bus-ID 00:1c.0
  12Slot 1 12type PCIe 12lanes 1 12status available 12length long 12volts 3.3
    12bus-ID 00:1c.1
  12Slot 2 12type PCIe 12lanes 1 12status available 12length long 12volts 3.3
    12bus-ID 00:1c.2
  12Slot 3 12type PCIe 12lanes 4 12status available 12length long 12volts 3.3
    12bus-ID 00:1c.3
12CPU:
  12Info 12model 11th Gen Intel Core i7-11800H 12socket U3E1 12bits 64 12type MT MCP
    12arch Tiger Lake 12gen core 11 12level v4 12note check 12built 2020 12process Intel 10nm
    12family 6 12model-id 0x8D (141) 12stepping 1 12microcode 0x4E
  12Topology 12cpus 1x 12cores 8 12tpc 2 12threads 16 12smt enabled 12cache 12L1 640 KiB
    12desc d-8x48 KiB; i-8x32 KiB 12L2 10 MiB 12desc 8x1.2 MiB 12L3 24 MiB 12desc 1x24 MiB
  12Speed (MHz) 12avg 1127 12high 3143 12min/max 800/4600 12base/boost 2277/5000
    12scaling 12driver intel_pstate 12governor powersave 12volts 0.7 V 12ext-clock 100 MHz
    12cores 121 1318 122 800 123 800 124 800 125 800 126 2732 127 3143 128 800 129 1204 1210 800
    1211 843 1212 801 1213 800 1214 800 1215 800 1216 800 12bogomips 73744
  12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
    pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
    sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
  12Vulnerabilities
  12Type gather_data_sampling 12mitigation Microcode
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type mmio_stale_data 12status Not affected
  12Type retbleed 12status Not affected
  12Type spec_rstack_overflow 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 Intel TigerLake-H GT1 [UHD Graphics] 12vendor Dell 12driver i915
    12v kernel 12arch Gen-12.1 12process Intel 10nm 12built 2020-21 12ports 12active eDP-1
    12empty DP-1,DP-2 12bus-ID 00:02.0 12chip-ID 8086:9a60 12class-ID 0300
  12Device-2 NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] 12vendor Dell
    12driver nvidia 12v 545.29.06 12non-free 545.xx+ 12status current (as of 2024-02;
    EOL~2026-12-xx) 12arch Ampere 12code GAxxx 12process TSMC n7 (7nm)
    12built 2020-2023 12pcie 12gen 4 12speed 16 GT/s 12lanes 8 12link-max 12lanes 16
    12bus-ID 01:00.0 12chip-ID 10de:2560 12class-ID 0300
  12Device-3 Sunplus Innovation Integrated_Webcam_HD 12driver uvcvideo 12type USB
    12rev 2.0 12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 3-5:2 12chip-ID 1bcf:2b9e
    12class-ID 0e02 12serial <filter>
  12Display 12server X.org 12v 1.21.1.11 12with Xwayland 12v 23.2.4 12driver 12gpu i915
    12display-ID :0
  12Monitor-1 eDP-1 12model LG Display 0x0690 12built 2020 12res 2560x1440 12dpi 189
    12gamma 1.2 12chroma 12red 12x 0.682 12y 0.322 12green 12x 0.263 12y 0.690 12blue 12x 0.145
    12y 0.059 12white 12x 0.314 12y 0.329 12size 344x194mm (13.54x7.64")
    12diag 395mm (15.5") 12ratio 16:9 12modes 2560x1440
  12EDID-Warnings 121 parse_edid: unknown flag 0 122 parse_edid: unknown tag 112
  12API EGL 12v 1.5 12hw 12drv intel iris 12platforms 12device 0 12drv iris 12device 2
    12drv swrast 12gbm 12drv kms_swrast 12surfaceless 12drv iris
    12inactive wayland,x11,device-1
  12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 24.0.3-manjaro1.1
    12note incomplete (EGL sourced) 12renderer llvmpipe (LLVM 17.0.6 256 bits), Mesa
    Intel UHD Graphics (TGL GT1)
  12API Vulkan 12Message No Vulkan data available.
12Audio:
  12Device-1 Intel Tiger Lake-H HD Audio 12vendor Dell
    12driver sof-audio-pci-intel-tgl 12bus-ID 00:1f.3 12chip-ID 8086:43c8 12class-ID 0401
  12Device-2 NVIDIA GA106 High Definition Audio 12driver snd_hda_intel 12v kernel
    12pcie 12gen 4 12speed 16 GT/s 12lanes 8 12link-max 12lanes 16 12bus-ID 01:00.1
    12chip-ID 10de:228e 12class-ID 0403
  12API ALSA 12v k6.6.10-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 PipeWire 12v 1.0.4 12status off 12with 121 pipewire-pulse 12status off
    122 wireplumber 12status off 123 pipewire-alsa 12type plugin 124 pw-jack 12type plugin
    12tools pactl,pw-cat,pw-cli,wpctl
12Network:
  12Device-1 Intel Tiger Lake PCH CNVi WiFi 12vendor Rivet Networks 12driver iwlwifi
    12v kernel 12bus-ID 00:14.3 12chip-ID 8086:43f0 12class-ID 0280
  12IF wlp0s20f3 12state up 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type noprefixroute 12scope link
  12Device-2 Realtek Killer E2600 GbE 12vendor Dell 12driver r8169 12v kernel 12pcie
    12gen 1 12speed 2.5 GT/s 12lanes 1 12port 3000 12bus-ID 2d:00.0 12chip-ID 10ec:2600
    12class-ID 0200
  12IF enp45s0 12state down 12mac <filter>
  12Info 12services No services found.
  12WAN IP <filter>
12Bluetooth:
  12Device-1 Intel AX201 Bluetooth 12driver btusb 12v 0.8 12type USB 12rev 2.0
    12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 3-14:5 12chip-ID 8087:0026 12class-ID e001
  12Report btmgmt 12ID hci0 12rfk-id 0 12state down 12bt-service N/A 12rfk-block
    12hardware no 12software no 12address N/A
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 982.51 GiB 12used 493.2 GiB (50.2%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor SK Hynix 12model PC711 NVMe 1TB
    12size 953.87 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
    12lanes 4 12tech SSD 12serial <filter> 12fw-rev 41001131 12temp 46.9 C
  12SMART yes 12health PASSED 12on 353d 0h 12cycles 2,016
    12read-units 56,729,429 [29.0 TB] 12written-units 67,552,657 [34.5 TB]
  12ID-2 /dev/sda 12maj-min 8:0 12vendor SanDisk 12model USB 3.2Gen1 12size 28.64 GiB
    12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 3.0 12spd 5 Gb/s 12lanes 1
    12mode 3.2 gen-1x1 12tech N/A 12serial <filter> 12fw-rev 1.00
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12Message No optical or floppy data found.
12Partition:
  12ID-1 / 12raw-size 552.55 GiB 12size 542.81 GiB (98.24%) 12used 493.12 GiB (90.8%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p9 12maj-min 259:8 12label N/A
    12uuid ad936496-7268-4a7f-912e-82c498da5f79
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 296 MiB (98.67%) 12used 85.1 MiB (28.8%)
    12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label ESP
    12uuid 78AD-A0FC
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/nvme0n1p2 12maj-min 259:2 12size 128 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-2 /dev/nvme0n1p3 12maj-min 259:3 12size 374.31 GiB 12fs ntfs 12label OS
    12uuid B892B00A92AFCB68
  12ID-3 /dev/nvme0n1p4 12maj-min 259:4 12size 990 MiB 12fs ntfs 12label N/A
    12uuid 963CC8CF3CC8AB95
  12ID-4 /dev/nvme0n1p5 12maj-min 259:5 12size 16.79 GiB 12fs ntfs 12label Image
    12uuid 444CAC214CAC102A
  12ID-5 /dev/nvme0n1p6 12maj-min 259:6 12size 1.38 GiB 12fs ntfs 12label DELLSUPPORT
    12uuid 083C77B83C779F7E
  12ID-6 /dev/nvme0n1p7 12maj-min 259:7 12size 7.45 GiB 12fs swap 12label N/A
    12uuid dfce739f-67b5-4de2-b5d8-a2c23b2e80d9
  12ID-7 /dev/sda1 12maj-min 8:1 12size 3.65 GiB 12fs N/A 12label N/A 12uuid N/A
  12ID-8 /dev/sda2 12maj-min 8:2 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid B5B6-A7FC
12USB:
  12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 1 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
  12Hub-2 2-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
    12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
  12Hub-3 3-0:1 12info hi-speed hub with single TT 12ports 16 12rev 2.0
  12Device-1 3-4:6 12info Razer USA Naga Pro 12type mouse,keyboard
    12driver hid-generic,usbhid 12interfaces 5 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s)
    12lanes 1 12mode 1.1 12power 100mA 12chip-ID 1532:0090 12class-ID 0300
    12serial <filter>
  12Device-2 3-5:2 12info Sunplus Innovation Integrated_Webcam_HD 12type video
    12driver uvcvideo 12interfaces 4 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
    12mode 2.0 12power 500mA 12chip-ID 1bcf:2b9e 12class-ID 0e02 12serial <filter>
  12Device-3 3-7:3 12info Alienware LED controller 12type HID
    12driver hid-generic,usbhid 12interfaces 1 12rev 2.1 12speed 12 Mb/s (1.4 MiB/s)
    12lanes 1 12mode 1.1 12chip-ID 187c:0550 12class-ID 0300 12serial <filter>
  12Device-4 3-8:4 12info Darfon 12type keyboard 12driver hid-generic,usbhid
    12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 16mA
    12chip-ID 0d62:3740 12class-ID 0301
  12Device-5 3-14:5 12info Intel AX201 Bluetooth 12type bluetooth 12driver btusb
    12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA
  12Hub-4 4-0:1 12info super-speed hub 12ports 8 12rev 3.1 12speed 20 Gb/s (2.33 GiB/s)
    12lanes 2 12mode 3.2 gen-2x2 12chip-ID 1d6b:0003 12class-ID 0900
  12Device-1 4-3:2 12info SanDisk Ultra 12type mass storage 12driver usb-storage
    12interfaces 1 12rev 3.0 12speed 5 Gb/s (596.0 MiB/s) 12lanes 1 12mode 3.2 gen-1x1
    12power 896mA 12chip-ID 0781:5581 12class-ID 0806 12serial <filter>
12Sensors:
  12System Temperatures 12cpu 53.0 C 12mobo 47.0 C
  12Fan Speeds (rpm) 12cpu 442
12Repos:
  12Packages 2183 12pm pacman 12pkgs 2168 12libs 555 12tools pamac,yay 12pm flatpak 12pkgs 15
  12Active pacman repo servers in /etc/pacman.d/mirrorlist
    121 https: //mirrors.ocf.berkeley.edu/manjaro/unstable/$repo/$arch
    122 https: //opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
    123 https: //uvermont.mm.fcix.net/manjaro/unstable/$repo/$arch
    124 https: //mirror.phoepsilonix.love/manjaro/unstable/$repo/$arch
    125 https: //mirror.csclub.uwaterloo.ca/manjaro/unstable/$repo/$arch
    126 http: //free.nchc.org.tw/manjaro/unstable/$repo/$arch
    127 https: //mirrors.ft.uam.es/manjaro/unstable/$repo/$arch
    128 https: //ftp.nluug.nl/pub/os/Linux/distr/manjaro/unstable/$repo/$arch
12Processes:
  12Message No process data available.
12Info:
  12Processes 0 12Power 12uptime 29m 12states freeze,mem,disk 12suspend s2idle 12wakeups 0
    12hibernate platform 12avail shutdown, reboot, suspend, test_resume
    12image 6.12 GiB 12Init systemd 12v 255 12default graphical 12tool systemctl
  12Compilers 12clang 17.0.6 12gcc 13.2.1 12alt 11/12 12Client systemd 12inxi 3.3.33
Apologies if this is not enough information or presented in a terrible way, I tried to follow the basic guidelines I could find, but a lot of peoples’ advice and wants are conflicting.
at this point just reinstall it… there may be some still some issues because of your nvidia tinkering, but we will see…
from chroot run this:
pacman -Qqn | pacman --overwrite=* -S -
when done, exit chroot, and reboot
Got this after checking package integrity:
error: iana-etc: signature from "Jelle van der Waa <jelle@vdwaa.nl>" is invalid
:: File /var/cache/pacman/pkg/iana-etc-20240222-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] Y
error: libksane: signature from "Antonio Rojas <arojas@archlinux.org>" is invalid
:: File /var/cache/pacman/pkg/libksane-24.02.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libksane5: signature from "Antonio Rojas <arojas@archlinux.org>" is invalid
:: File /var/cache/pacman/pkg/libksane5-24.02.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpackagekit-glib: signature from "Mark Wagie <mark@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/libpackagekit-glib-1.2.8-7-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac-flatpak-plugin: signature from "Mark Wagie <mark@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/libpamac-flatpak-plugin-11.6.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac-snap-plugin: signature from "Mark Wagie <mark@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/libpamac-snap-plugin-11.6.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux67-virtualbox-host-modules: signature from "Manjaro Build Server <build@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/linux67-virtualbox-host-modules-7.0.14-12-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pamac-cli: signature from "Mark Wagie <mark@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/pamac-cli-11.6.0-4-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: packagekit: signature from "Mark Wagie <mark@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/packagekit-1.2.8-7-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pacutils: signature from "Mark Wagie <mark@manjaro.org>" is invalid
:: File /var/cache/pacman/pkg/pacutils-0.11.1-3-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
I am probably quite stupid for answering yes to all those without completely understanding.
did you run the exact command? because it skips security checks, so there should not be any of those signature errors…
Reinstall arch- and manjaro-keyring first.
I did run the exact command. Running it again though I was able to reinstall everything, although with the same errors produced for the kernel installations. I am now able to boot and login though with the GRUB menu also showing up. I was also able to reinstall the kernels once again but without any of the errors from before. Pamac has also started working again. Thank you for you help!
NEVER overwrite globally. The --overwrite flag should only be used with the directories containing the files that need to be overwritten.
❯ man pacman | grep overwrite
       --overwrite <glob>
           Bypass file conflict checks and overwrite conflicting files. If the package that is about to be installed contains files that are already installed and match glob, this
           option will cause all those files to be overwritten. Using --overwrite will not allow overwriting a directory with a file or installing packages with conflicting files and
           All three files are the same, so overwrites are not an issue. Install the new file.
