Dear Team,
Looking to virtualize Win10 with GPU passthrough.
Could I dedicate an SSD to either or both VMs? Or would I be better off with a qcow file on a separate SSD, so that I could do snapshots to a NAS for example? I guess with the latter I would not need to pass through any other device to the VMs like a SATA controller to gain speed or something…
Tryin to find out which USB ports, or controllers to pass through, so that I could switch between VM and the Host with a simple re-plug of keyboard or mouse. I think I could end up with being unable to control the host
Manjaro would only be used as a subsystem to Windows VM, could I then uninstall gui stuff and just run the VMs ‘headless’ via terminal?
To what extent can I declutter the Manjaro system, is there a default minimal text install perhaps? Not as if the testing Win10 VM was sluggish, despite of my HW being quite outdated
Thanks in advance for any suggestions / considerations
