Recommended NON flat themes and NON flat icons for my Manjaro Cinnamon?
#1
Hi,
Could you share me your preferred NON flat themes and NON flat icons themes you use with your Manjaro Cinnamon ?
I’m tired of seeing that flat themes !!
Thanks
#2
This is entirely subjective and you’ll never get a perfect answer.
Instead, go to https://www.gnome-look.org/ and browse until you find something you like.
Gnome look is where i searched and not found what i am looking for, so i ask here.
I don’t want a perfect answer, i just want some choice or advice…
I don’t think it’s a newbie question but rather to know what people are using as a theme other than flat.
Thanks
#4
If you can’t find something you like on GNOME Look then it probably doesn’t exist. :man_shrugging:
#5
Theme: Adwaita-manjaro
Desktop bar: Cinnamon
Icons: Delft
#6
Thanks @Lolix
I use the Obsidian Icon theme from the same as Delft ! look great
Adwaita-manjaro, great to but i found windows border need more gradient but controles look great !
Cinnamon desktop bar is what i use! good to !
Overall it’s a good combo…
At the moment i use Vertex Maia
But I take all the information possible to find themes that suit me
You can try elementary theme and icons. Faenza icons too.
What about Moka + Faba? They go together as a pair to install. Moka uses some Faba icons.
both are available from AUR
Thanks, but too flat for me …
#10
okay, thought it may be but it’s a 50% flat theme so worth a mention :wink:
the one I used to like is no longer maintained. there was a theme called RAVEfinity Vivacious I used to use with MATE. That wasn’t flat but has been left out to pasture. Instead they recommend Mint users use Mint-Y which near enough resembles it now. I don’t know if a similar package is in AUR but like jonathon said it’s nigh on impossible to recommend something like this
Yes, i know it’s not easy to find! i will look for Mint-y
Thanks again
closed #12
