Recommendation for Backup to Proton cloud
Until now, I have been using restic/rclone to create a backup in the Proton Cloud. Unfortunately, due to changes in the Proton API, it no longer works, and there is no maintainer for the interface in rclone.
Therefore, I am looking for a suitable replacement.
These are the solutions I have shortlisted so far:
Borg update - no multithreading
Kopia - AUR
Duplicacy - AUR/non-free licence
I tend to use Borg because it is included in the official repositories.
Are there any experiences or recommendations regarding these three apps?
Are you referring to Proton AG and the Proton Drive?
Proton Drive · GitHub
There is also something called pCloud - another Swiss company?
Yes, its the Proton AG.
Unfortunately, support for Linux is somewhat neglected, every operating system has a drive app except Linux.
With the help from my buddy gemini, i tried to setup Kopia - rclone - proton-drive-bridge (a community project).
The chain itself works (files are created in the cloud).
Unfortunately, kopia still cannot create a repository. This seems to be a known issue between kopia and rclone, which has actually have been fixed.
According to gemini, rclone is necessary because kopia only supports sftp and proton-drive-bridge only provides an ftp interface.
But I will check this by myself.
Update (might be helpful for other Proton Drive users)
Since the solution described above doesn’t work for me, I’ve now opted for a less elegant approach:
kopia (AUR kopia) creates the backup/repository in a local directory.
proton-drive-sync (AUR proton-drive-sync-bin) synchronizes this directory with Proton Drive.
Since I only back up the important files in my home directory, the kopia repository is only about 15 GB in size, which isn’t really a big deal.
Not pretty, but it works.
I have been fiddling with a Proton drive client from scratch but struggled to find documentation
All I have been able to find at Proton is proton-mail-bridge.
What I have found is that the proton-drive API expects some sort of whitelisted app-versions - which is one of the reasons rclone does not work.
yes, the rclone interface was reversed engineered and the maintainer quit.
right now there are two community solutions for proton drive on linux.
I don’t know if proton-mail-bridge can be missused to write to proton drive, but actually there is no official linux app to sync to proton drive.
