Recommend me a external wireless adapter that works great with Manjaro
OK then do as I said initially, give the output of commands to see what is going on:
Additionally to be sure you can build packages, install the dev tools
pamac install base-devel git
It should be enough, nothing more to do.
Heckyeah so I did each step things look promising except this one issue. I hope its an non issue.
==> ERROR: Missing 5.15.2-1-rt19-MANJARO kernel modules tree for module rtl8814au/5.8.5.1.r125.g6d49275.
Refreshing PackageKit...        [3/3]
It said successful, but it also said error for a kernel I’m not even using nor have installed.
I don’t know then, this is weird. Does the driver work now? Do you have WIFI? You probably need to reboot.
Thank you omano for your dedication to see this through I happy to announce that Ive got the 70 dollar device working and am posting using it to connect to my wifi.
Hooo mama… :money_with_wings: :moneybag: :money_with_wings:
As I suggested you could have for around 5 dollars shipped (10 dollars for the fancy ones) one working directly :rofl: but you needed some time to check for the compatibility, and you would have wait time for shipping.
Good if you’re OK with the result :+1:
