Yes. Redirect it to a file.
Here the differences between Liquorix 6.7.1 and Manjaro 6.7.0:
--- /home/rondo/liquorix.txt 2024-01-21 17:12:13.624771814 +0100
+++ /home/rondo/Manjaro_6.7.0.txt 2024-01-21 17:18:06.977033269 +0100
@@ -1,6 +1,6 @@
# Automatically generated file; DO NOT EDIT.
-# Linux/x86 6.7.1-lqx1 Kernel Configuration
+# Linux/x86 6.7.0-2 Kernel Configuration
CONFIG_CC_VERSION_TEXT="gcc (GCC) 13.2.1 20230801"
CONFIG_CC_IS_GCC=y
@@ -26,11 +26,10 @@
# General setup
-CONFIG_ZEN_INTERACTIVE=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
# CONFIG_WERROR is not set
-CONFIG_LOCALVERSION=""
+CONFIG_LOCALVERSION="-MANJARO"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
@@ -48,7 +47,7 @@
# CONFIG_KERNEL_LZ4 is not set
CONFIG_KERNEL_ZSTD=y
CONFIG_DEFAULT_INIT=""
-CONFIG_DEFAULT_HOSTNAME="(none)"
+CONFIG_DEFAULT_HOSTNAME="archlinux"
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_SYSVIPC_COMPAT=y
@@ -69,6 +68,7 @@
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_GENERIC_PENDING_IRQ=y
CONFIG_GENERIC_IRQ_MIGRATION=y
+CONFIG_GENERIC_IRQ_INJECTION=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
@@ -102,9 +102,11 @@
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
-CONFIG_NO_HZ_IDLE=y
-# CONFIG_NO_HZ_FULL is not set
-# CONFIG_NO_HZ is not set
+# CONFIG_NO_HZ_IDLE is not set
+CONFIG_NO_HZ_FULL=y
+CONFIG_CONTEXT_TRACKING_USER=y
+# CONFIG_CONTEXT_TRACKING_USER_FORCE is not set
+CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_CLOCKSOURCE_WATCHDOG_MAX_SKEW_US=100
# end of Timers subsystem
@@ -121,7 +123,6 @@
CONFIG_BPF_JIT_ALWAYS_ON=y
CONFIG_BPF_JIT_DEFAULT_ON=y
CONFIG_BPF_UNPRIV_DEFAULT_OFF=y
-CONFIG_USERMODE_DRIVER=y
# CONFIG_BPF_PRELOAD is not set
CONFIG_BPF_LSM=y
# end of BPF subsystem
@@ -132,20 +133,24 @@
CONFIG_PREEMPT=y
CONFIG_PREEMPT_COUNT=y
CONFIG_PREEMPTION=y
-# CONFIG_PREEMPT_DYNAMIC is not set
+CONFIG_PREEMPT_DYNAMIC=y
+CONFIG_SCHED_CORE=y
# CPU/Task time and stats accounting
-CONFIG_TICK_CPU_ACCOUNTING=y
-# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
-# CONFIG_IRQ_TIME_ACCOUNTING is not set
+CONFIG_VIRT_CPU_ACCOUNTING=y
+CONFIG_VIRT_CPU_ACCOUNTING_GEN=y
+CONFIG_IRQ_TIME_ACCOUNTING=y
+CONFIG_HAVE_SCHED_AVG_IRQ=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
+CONFIG_PSI=y
+# CONFIG_PSI_DEFAULT_DISABLED is not set
# end of CPU/Task time and stats accounting
CONFIG_CPU_ISOLATION=y
@@ -169,13 +174,13 @@
CONFIG_RCU_FANOUT=64
CONFIG_RCU_FANOUT_LEAF=16
CONFIG_RCU_BOOST=y
-CONFIG_RCU_BOOST_DELAY=97
-CONFIG_RCU_EXP_KTHREAD=y
+CONFIG_RCU_BOOST_DELAY=500
+# CONFIG_RCU_EXP_KTHREAD is not set
CONFIG_RCU_NOCB_CPU=y
# CONFIG_RCU_NOCB_CPU_DEFAULT_ALL is not set
-CONFIG_RCU_NOCB_CPU_CB_BOOST=y
+# CONFIG_RCU_NOCB_CPU_CB_BOOST is not set
# CONFIG_TASKS_TRACE_RCU_READ_MB is not set
-# CONFIG_RCU_LAZY is not set
+CONFIG_RCU_LAZY=y
CONFIG_RCU_DOUBLE_CHECK_CB_TIME=y
# end of RCU Subsystem
@@ -184,15 +189,14 @@
CONFIG_IKHEADERS=m
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
-# CONFIG_PRINTK_INDEX is not set
+CONFIG_PRINTK_INDEX=y
CONFIG_HAVE_UNSTABLE_SCHED_CLOCK=y
# Scheduler features
-CONFIG_SCHED_ALT=y
-# CONFIG_SCHED_BMQ is not set
-CONFIG_SCHED_PDS=y
+CONFIG_UCLAMP_TASK=y
+CONFIG_UCLAMP_BUCKETS_COUNT=5
# end of Scheduler features
CONFIG_ARCH_SUPPORTS_NUMA_BALANCING=y
@@ -202,16 +206,21 @@
CONFIG_GCC11_NO_ARRAY_BOUNDS=y
CONFIG_CC_NO_ARRAY_BOUNDS=y
CONFIG_ARCH_SUPPORTS_INT128=y
+CONFIG_NUMA_BALANCING=y
+CONFIG_NUMA_BALANCING_DEFAULT_ENABLED=y
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
-CONFIG_CGROUP_FAVOR_DYNMODS=y
+# CONFIG_CGROUP_FAVOR_DYNMODS is not set
CONFIG_MEMCG=y
CONFIG_MEMCG_KMEM=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
+CONFIG_CFS_BANDWIDTH=y
+# CONFIG_RT_GROUP_SCHED is not set
CONFIG_SCHED_MM_CID=y
+CONFIG_UCLAMP_TASK_GROUP=y
CONFIG_CGROUP_PIDS=y
CONFIG_CGROUP_RDMA=y
CONFIG_CGROUP_FREEZER=y
@@ -234,6 +243,7 @@
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_CHECKPOINT_RESTORE=y
+CONFIG_SCHED_AUTOGROUP=y
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
@@ -248,8 +258,7 @@
# CONFIG_BOOT_CONFIG_FORCE is not set
# CONFIG_BOOT_CONFIG_EMBED is not set
CONFIG_INITRAMFS_PRESERVE_MTIME=y
-# CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE is not set
-CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE_O3=y
+CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_LD_ORPHAN_WARN=y
CONFIG_LD_ORPHAN_WARN_LEVEL="warn"
@@ -300,7 +309,7 @@
# end of Kernel Performance Events And Counters
CONFIG_SYSTEM_DATA_VERIFICATION=y
-# CONFIG_PROFILING is not set
+CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
@@ -309,9 +318,14 @@
CONFIG_CRASH_CORE=y
CONFIG_KEXEC_CORE=y
CONFIG_KEXEC=y
-# CONFIG_KEXEC_FILE is not set
+CONFIG_KEXEC_FILE=y
+CONFIG_KEXEC_SIG=y
+# CONFIG_KEXEC_SIG_FORCE is not set
+CONFIG_KEXEC_BZIMAGE_VERIFY_SIG=y
CONFIG_KEXEC_JUMP=y
-# CONFIG_CRASH_DUMP is not set
+CONFIG_CRASH_DUMP=y
+CONFIG_CRASH_HOTPLUG=y
+CONFIG_CRASH_MAX_MEMORY_RANGES=8192
# end of Kexec and crash features
# end of General setup
@@ -341,7 +355,7 @@
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_DYNAMIC_PHYSICAL_MASK=y
-CONFIG_PGTABLE_LEVELS=4
+CONFIG_PGTABLE_LEVELS=5
CONFIG_CC_HAS_SANE_STACKPROTECTOR=y
@@ -381,56 +395,16 @@
CONFIG_KVM_GUEST=y
CONFIG_ARCH_CPUIDLE_HALTPOLL=y
CONFIG_PVH=y
-# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
+CONFIG_PARAVIRT_TIME_ACCOUNTING=y
CONFIG_PARAVIRT_CLOCK=y
CONFIG_JAILHOUSE_GUEST=y
CONFIG_ACRN_GUEST=y
CONFIG_INTEL_TDX_GUEST=y
# CONFIG_MK8 is not set
-# CONFIG_MK8SSE3 is not set
-# CONFIG_MK10 is not set
-# CONFIG_MBARCELONA is not set
-# CONFIG_MBOBCAT is not set
-# CONFIG_MJAGUAR is not set
-# CONFIG_MBULLDOZER is not set
-# CONFIG_MPILEDRIVER is not set
-# CONFIG_MSTEAMROLLER is not set
-# CONFIG_MEXCAVATOR is not set
-# CONFIG_MZEN is not set
-# CONFIG_MZEN2 is not set
-# CONFIG_MZEN3 is not set
-# CONFIG_MZEN4 is not set
# CONFIG_MPSC is not set
# CONFIG_MCORE2 is not set
# CONFIG_MATOM is not set
-# CONFIG_MNEHALEM is not set
-# CONFIG_MWESTMERE is not set
-# CONFIG_MSILVERMONT is not set
-# CONFIG_MGOLDMONT is not set
-# CONFIG_MGOLDMONTPLUS is not set
-# CONFIG_MSANDYBRIDGE is not set
-# CONFIG_MIVYBRIDGE is not set
-# CONFIG_MHASWELL is not set
-# CONFIG_MBROADWELL is not set
-# CONFIG_MSKYLAKE is not set
-# CONFIG_MSKYLAKEX is not set
-# CONFIG_MCANNONLAKE is not set
-# CONFIG_MICELAKE is not set
-# CONFIG_MCASCADELAKE is not set
-# CONFIG_MCOOPERLAKE is not set
-# CONFIG_MTIGERLAKE is not set
-# CONFIG_MSAPPHIRERAPIDS is not set
-# CONFIG_MROCKETLAKE is not set
-# CONFIG_MALDERLAKE is not set
-# CONFIG_MRAPTORLAKE is not set
-# CONFIG_MMETEORLAKE is not set
-# CONFIG_MEMERALDRAPIDS is not set
CONFIG_GENERIC_CPU=y
-# CONFIG_GENERIC_CPU2 is not set
-# CONFIG_GENERIC_CPU3 is not set
-# CONFIG_GENERIC_CPU4 is not set
-# CONFIG_MNATIVE_INTEL is not set
-# CONFIG_MNATIVE_AMD is not set
CONFIG_X86_INTERNODE_CACHE_SHIFT=6
CONFIG_X86_L1_CACHE_SHIFT=6
CONFIG_X86_TSC=y
@@ -454,8 +428,8 @@
CONFIG_NR_CPUS_RANGE_BEGIN=2
CONFIG_NR_CPUS_RANGE_END=512
CONFIG_NR_CPUS_DEFAULT=64
-CONFIG_NR_CPUS=128
-# CONFIG_SCHED_CLUSTER is not set
+CONFIG_NR_CPUS=320
+CONFIG_SCHED_CLUSTER=y
CONFIG_SCHED_SMT=y
CONFIG_SCHED_MC=y
CONFIG_SCHED_MC_PRIO=y
@@ -467,14 +441,14 @@
CONFIG_X86_MCE_INTEL=y
CONFIG_X86_MCE_AMD=y
CONFIG_X86_MCE_THRESHOLD=y
-# CONFIG_X86_MCE_INJECT is not set
+CONFIG_X86_MCE_INJECT=m
# Performance monitoring
-CONFIG_PERF_EVENTS_INTEL_UNCORE=y
-CONFIG_PERF_EVENTS_INTEL_RAPL=y
-CONFIG_PERF_EVENTS_INTEL_CSTATE=y
+CONFIG_PERF_EVENTS_INTEL_UNCORE=m
+CONFIG_PERF_EVENTS_INTEL_RAPL=m
+CONFIG_PERF_EVENTS_INTEL_CSTATE=m
CONFIG_PERF_EVENTS_AMD_POWER=m
CONFIG_PERF_EVENTS_AMD_UNCORE=m
CONFIG_PERF_EVENTS_AMD_BRS=y
@@ -486,22 +460,28 @@
CONFIG_X86_IOPL_IOPERM=y
CONFIG_MICROCODE=y
# CONFIG_MICROCODE_LATE_LOADING is not set
-CONFIG_X86_MSR=m
-CONFIG_X86_CPUID=m
-# CONFIG_X86_5LEVEL is not set
+CONFIG_X86_MSR=y
+CONFIG_X86_CPUID=y
+CONFIG_X86_5LEVEL=y
CONFIG_X86_DIRECT_GBPAGES=y
-# CONFIG_X86_CPA_STATISTICS is not set
+CONFIG_X86_CPA_STATISTICS=y
CONFIG_X86_MEM_ENCRYPT=y
CONFIG_AMD_MEM_ENCRYPT=y
# CONFIG_AMD_MEM_ENCRYPT_ACTIVE_BY_DEFAULT is not set
-# CONFIG_NUMA is not set
+CONFIG_NUMA=y
+CONFIG_AMD_NUMA=y
+CONFIG_X86_64_ACPI_NUMA=y
+# CONFIG_NUMA_EMU is not set
+CONFIG_NODES_SHIFT=5
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_DEFAULT=y
+# CONFIG_ARCH_MEMORY_PROBE is not set
CONFIG_ARCH_PROC_KCORE_TEXT=y
CONFIG_ILLEGAL_POINTER_VALUE=0xdead000000000000
CONFIG_X86_PMEM_LEGACY_DEVICE=y
-CONFIG_X86_PMEM_LEGACY=y
-# CONFIG_X86_CHECK_BIOS_CORRUPTION is not set
+CONFIG_X86_PMEM_LEGACY=m
+CONFIG_X86_CHECK_BIOS_CORRUPTION=y
+CONFIG_X86_BOOTPARAM_MEMORY_CORRUPTION_CHECK=y
CONFIG_MTRR=y
CONFIG_MTRR_SANITIZER=y
CONFIG_MTRR_SANITIZER_ENABLE_DEFAULT=1
@@ -511,7 +491,7 @@
CONFIG_X86_UMIP=y
CONFIG_CC_HAS_IBT=y
CONFIG_X86_CET=y
-# CONFIG_X86_KERNEL_IBT is not set
+CONFIG_X86_KERNEL_IBT=y
CONFIG_X86_INTEL_MEMORY_PROTECTION_KEYS=y
# CONFIG_X86_INTEL_TSX_MODE_OFF is not set
# CONFIG_X86_INTEL_TSX_MODE_ON is not set
@@ -527,12 +507,13 @@
CONFIG_EFI_RUNTIME_MAP=y
# CONFIG_HZ_100 is not set
# CONFIG_HZ_250 is not set
-# CONFIG_HZ_300 is not set
-CONFIG_HZ_1000=y
-CONFIG_HZ=1000
+CONFIG_HZ_300=y
+# CONFIG_HZ_1000 is not set
+CONFIG_HZ=300
CONFIG_SCHED_HRTICK=y
CONFIG_ARCH_SUPPORTS_KEXEC=y
CONFIG_ARCH_SUPPORTS_KEXEC_FILE=y
+CONFIG_ARCH_SELECTS_KEXEC_FILE=y
CONFIG_ARCH_SUPPORTS_KEXEC_PURGATORY=y
CONFIG_ARCH_SUPPORTS_KEXEC_SIG=y
CONFIG_ARCH_SUPPORTS_KEXEC_SIG_FORCE=y
@@ -543,16 +524,18 @@
CONFIG_ARCH_HAS_GENERIC_CRASHKERNEL_RESERVATION=y
CONFIG_PHYSICAL_START=0x1000000
CONFIG_RELOCATABLE=y
-# CONFIG_RANDOMIZE_BASE is not set
-CONFIG_PHYSICAL_ALIGN=0x1000000
+CONFIG_RANDOMIZE_BASE=y
+CONFIG_X86_NEED_RELOCS=y
+CONFIG_PHYSICAL_ALIGN=0x200000
+CONFIG_DYNAMIC_MEMORY_LAYOUT=y
+CONFIG_RANDOMIZE_MEMORY=y
+CONFIG_RANDOMIZE_MEMORY_PHYSICAL_PADDING=0xa
CONFIG_ADDRESS_MASKING=y
CONFIG_HOTPLUG_CPU=y
# CONFIG_COMPAT_VDSO is not set
CONFIG_LEGACY_VSYSCALL_XONLY=y
# CONFIG_LEGACY_VSYSCALL_NONE is not set
-CONFIG_CMDLINE_BOOL=y
-CONFIG_CMDLINE="audit=0 intel_pstate=disable rcupdate.rcu_expedited=1 "
-# CONFIG_CMDLINE_OVERRIDE is not set
+# CONFIG_CMDLINE_BOOL is not set
CONFIG_MODIFY_LDT_SYSCALL=y
# CONFIG_STRICT_SIGALTSTACK_SIZE is not set
CONFIG_HAVE_LIVEPATCH=y
@@ -578,7 +561,7 @@
CONFIG_CPU_IBPB_ENTRY=y
CONFIG_CPU_IBRS_ENTRY=y
CONFIG_CPU_SRSO=y
-# CONFIG_SLS is not set
+CONFIG_SLS=y
# CONFIG_GDS_FORCE_MITIGATION is not set
CONFIG_ARCH_HAS_ADD_PAGES=y
@@ -602,7 +585,8 @@
# CONFIG_PM_ADVANCED_DEBUG is not set
# CONFIG_PM_TEST_SUSPEND is not set
CONFIG_PM_SLEEP_DEBUG=y
-# CONFIG_PM_TRACE_RTC is not set
+CONFIG_PM_TRACE=y
+CONFIG_PM_TRACE_RTC=y
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
@@ -640,9 +624,10 @@
CONFIG_ACPI_PLATFORM_PROFILE=m
CONFIG_ARCH_HAS_ACPI_TABLE_UPGRADE=y
CONFIG_ACPI_TABLE_UPGRADE=y
-# CONFIG_ACPI_DEBUG is not set
+CONFIG_ACPI_DEBUG=y
CONFIG_ACPI_PCI_SLOT=y
CONFIG_ACPI_CONTAINER=y
+CONFIG_ACPI_HOTPLUG_MEMORY=y
CONFIG_ACPI_HOTPLUG_IOAPIC=y
CONFIG_ACPI_SBS=m
CONFIG_ACPI_HED=y
@@ -650,6 +635,8 @@
CONFIG_ACPI_BGRT=y
CONFIG_ACPI_NFIT=m
# CONFIG_NFIT_SECURITY_DEBUG is not set
+CONFIG_ACPI_NUMA=y
+CONFIG_ACPI_HMAT=y
CONFIG_HAVE_ACPI_APEI=y
CONFIG_HAVE_ACPI_APEI_NMI=y
CONFIG_ACPI_APEI=y
@@ -657,7 +644,7 @@
CONFIG_ACPI_APEI_PCIEAER=y
CONFIG_ACPI_APEI_MEMORY_FAILURE=y
CONFIG_ACPI_APEI_EINJ=m
-# CONFIG_ACPI_APEI_ERST_DEBUG is not set
+CONFIG_ACPI_APEI_ERST_DEBUG=m
CONFIG_ACPI_DPTF=y
CONFIG_DPTF_POWER=m
CONFIG_DPTF_PCH_FIVR=m
@@ -669,8 +656,12 @@
CONFIG_ACPI_PCC=y
CONFIG_ACPI_FFH=y
CONFIG_PMIC_OPREGION=y
+CONFIG_BYTCRC_PMIC_OPREGION=y
+CONFIG_CHTCRC_PMIC_OPREGION=y
CONFIG_XPOWER_PMIC_OPREGION=y
CONFIG_BXT_WC_PMIC_OPREGION=y
+CONFIG_CHT_WC_PMIC_OPREGION=y
+CONFIG_CHT_DC_TI_PMIC_OPREGION=y
CONFIG_TPS68470_PMIC_OPREGION=y
CONFIG_ACPI_VIOT=y
CONFIG_ACPI_PRMT=y
@@ -682,17 +673,17 @@
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
-# CONFIG_CPU_FREQ_STAT is not set
-CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
+CONFIG_CPU_FREQ_STAT=y
+# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
-# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
+CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
-# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
+CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
-# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
-# CONFIG_CPU_FREQ_GOV_SCHEDUTIL is not set
+CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
+CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
@@ -745,7 +736,7 @@
CONFIG_IA32_EMULATION=y
# CONFIG_IA32_EMULATION_DEFAULT_DISABLED is not set
-CONFIG_X86_X32_ABI=y
+# CONFIG_X86_X32_ABI is not set
CONFIG_COMPAT_32=y
CONFIG_COMPAT=y
CONFIG_COMPAT_FOR_U64_ALIGNMENT=y
@@ -805,6 +796,7 @@
# CONFIG_STATIC_CALL_SELFTEST is not set
CONFIG_OPTPROBES=y
CONFIG_KPROBES_ON_FTRACE=y
+CONFIG_UPROBES=y
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_KRETPROBES=y
@@ -911,14 +903,14 @@
CONFIG_VMAP_STACK=y
CONFIG_HAVE_ARCH_RANDOMIZE_KSTACK_OFFSET=y
CONFIG_RANDOMIZE_KSTACK_OFFSET=y
-# CONFIG_RANDOMIZE_KSTACK_OFFSET_DEFAULT is not set
+CONFIG_RANDOMIZE_KSTACK_OFFSET_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_HAVE_ARCH_PREL32_RELOCATIONS=y
CONFIG_ARCH_USE_MEMREMAP_PROT=y
-# CONFIG_LOCK_EVENT_COUNTS is not set
+CONFIG_LOCK_EVENT_COUNTS=y
CONFIG_ARCH_HAS_MEM_ENCRYPT=y
CONFIG_ARCH_HAS_CC_PLATFORM=y
CONFIG_HAVE_STATIC_CALL=y
@@ -943,7 +935,7 @@
CONFIG_HAVE_GCC_PLUGINS=y
CONFIG_GCC_PLUGINS=y
-CONFIG_GCC_PLUGIN_LATENT_ENTROPY=y
+# CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
CONFIG_FUNCTION_ALIGNMENT_4B=y
CONFIG_FUNCTION_ALIGNMENT_16B=y
CONFIG_FUNCTION_ALIGNMENT=16
@@ -951,15 +943,26 @@
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
+CONFIG_MODULE_SIG_FORMAT=y
CONFIG_MODULES=y
+CONFIG_MODULE_DEBUGFS=y
# CONFIG_MODULE_DEBUG is not set
CONFIG_MODULE_FORCE_LOAD=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
-# CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set
+CONFIG_MODULE_UNLOAD_TAINT_TRACKING=y
# CONFIG_MODVERSIONS is not set
CONFIG_MODULE_SRCVERSION_ALL=y
-# CONFIG_MODULE_SIG is not set
+CONFIG_MODULE_SIG=y
+# CONFIG_MODULE_SIG_FORCE is not set
+CONFIG_MODULE_SIG_ALL=y
+# CONFIG_MODULE_SIG_SHA256 is not set
+# CONFIG_MODULE_SIG_SHA384 is not set
+CONFIG_MODULE_SIG_SHA512=y
+# CONFIG_MODULE_SIG_SHA3_256 is not set
+# CONFIG_MODULE_SIG_SHA3_384 is not set
+# CONFIG_MODULE_SIG_SHA3_512 is not set
+CONFIG_MODULE_SIG_HASH="sha512"
# CONFIG_MODULE_COMPRESS_NONE is not set
# CONFIG_MODULE_COMPRESS_GZIP is not set
# CONFIG_MODULE_COMPRESS_XZ is not set
@@ -984,10 +987,11 @@
CONFIG_BLK_WBT=y
CONFIG_BLK_WBT_MQ=y
CONFIG_BLK_CGROUP_IOLATENCY=y
-# CONFIG_BLK_CGROUP_FC_APPID is not set
+CONFIG_BLK_CGROUP_FC_APPID=y
CONFIG_BLK_CGROUP_IOCOST=y
CONFIG_BLK_CGROUP_IOPRIO=y
-# CONFIG_BLK_DEBUG_FS is not set
+CONFIG_BLK_DEBUG_FS=y
+CONFIG_BLK_DEBUG_FS_ZONED=y
CONFIG_BLK_SED_OPAL=y
CONFIG_BLK_INLINE_ENCRYPTION=y
CONFIG_BLK_INLINE_ENCRYPTION_FALLBACK=y
@@ -996,32 +1000,26 @@
# Partition Types
CONFIG_PARTITION_ADVANCED=y
-CONFIG_ACORN_PARTITION=y
-CONFIG_ACORN_PARTITION_CUMANA=y
-CONFIG_ACORN_PARTITION_EESOX=y
-CONFIG_ACORN_PARTITION_ICS=y
-CONFIG_ACORN_PARTITION_ADFS=y
-CONFIG_ACORN_PARTITION_POWERTEC=y
-CONFIG_ACORN_PARTITION_RISCIX=y
+# CONFIG_ACORN_PARTITION is not set
CONFIG_AIX_PARTITION=y
-CONFIG_OSF_PARTITION=y
-CONFIG_AMIGA_PARTITION=y
-CONFIG_ATARI_PARTITION=y
+# CONFIG_OSF_PARTITION is not set
+# CONFIG_AMIGA_PARTITION is not set
+# CONFIG_ATARI_PARTITION is not set
CONFIG_MAC_PARTITION=y
CONFIG_MSDOS_PARTITION=y
CONFIG_BSD_DISKLABEL=y
CONFIG_MINIX_SUBPARTITION=y
CONFIG_SOLARIS_X86_PARTITION=y
-CONFIG_UNIXWARE_DISKLABEL=y
+# CONFIG_UNIXWARE_DISKLABEL is not set
CONFIG_LDM_PARTITION=y
# CONFIG_LDM_DEBUG is not set
-CONFIG_SGI_PARTITION=y
-CONFIG_ULTRIX_PARTITION=y
-CONFIG_SUN_PARTITION=y
+# CONFIG_SGI_PARTITION is not set
+# CONFIG_ULTRIX_PARTITION is not set
+# CONFIG_SUN_PARTITION is not set
CONFIG_KARMA_PARTITION=y
CONFIG_EFI_PARTITION=y
-CONFIG_SYSV68_PARTITION=y
-CONFIG_CMDLINE_PARTITION=y
+# CONFIG_SYSV68_PARTITION is not set
+# CONFIG_CMDLINE_PARTITION is not set
# end of Partition Types
CONFIG_BLK_MQ_PCI=y
@@ -1080,18 +1078,18 @@
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_DEFLATE is not set
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_LZO is not set
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_842 is not set
-CONFIG_ZSWAP_COMPRESSOR_DEFAULT_LZ4=y
+# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_LZ4 is not set
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_LZ4HC is not set
-# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_ZSTD is not set
-CONFIG_ZSWAP_COMPRESSOR_DEFAULT="lz4"
+CONFIG_ZSWAP_COMPRESSOR_DEFAULT_ZSTD=y
+CONFIG_ZSWAP_COMPRESSOR_DEFAULT="zstd"
# CONFIG_ZSWAP_ZPOOL_DEFAULT_ZBUD is not set
-CONFIG_ZSWAP_ZPOOL_DEFAULT_Z3FOLD=y
-# CONFIG_ZSWAP_ZPOOL_DEFAULT_ZSMALLOC is not set
-CONFIG_ZSWAP_ZPOOL_DEFAULT="z3fold"
+# CONFIG_ZSWAP_ZPOOL_DEFAULT_Z3FOLD is not set
+CONFIG_ZSWAP_ZPOOL_DEFAULT_ZSMALLOC=y
+CONFIG_ZSWAP_ZPOOL_DEFAULT="zsmalloc"
CONFIG_ZBUD=y
CONFIG_Z3FOLD=y
CONFIG_ZSMALLOC=y
-# CONFIG_ZSMALLOC_STAT is not set
+CONFIG_ZSMALLOC_STAT=y
CONFIG_ZSMALLOC_CHAIN_SIZE=8
@@ -1101,9 +1099,9 @@
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
CONFIG_SLAB_FREELIST_RANDOM=y
-# CONFIG_SLAB_FREELIST_HARDENED is not set
+CONFIG_SLAB_FREELIST_HARDENED=y
# CONFIG_SLUB_STATS is not set
-# CONFIG_SLUB_CPU_PARTIAL is not set
+CONFIG_SLUB_CPU_PARTIAL=y
# CONFIG_RANDOM_KMALLOC_CACHES is not set
# end of SLAB allocator options
@@ -1116,19 +1114,26 @@
CONFIG_ARCH_WANT_OPTIMIZE_DAX_VMEMMAP=y
CONFIG_ARCH_WANT_OPTIMIZE_HUGETLB_VMEMMAP=y
CONFIG_HAVE_FAST_GUP=y
+CONFIG_NUMA_KEEP_MEMINFO=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_EXCLUSIVE_SYSTEM_RAM=y
+CONFIG_HAVE_BOOTMEM_INFO_NODE=y
CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
-# CONFIG_MEMORY_HOTPLUG is not set
+CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y
+CONFIG_MEMORY_HOTPLUG=y
+CONFIG_MEMORY_HOTPLUG_DEFAULT_ONLINE=y
+CONFIG_MEMORY_HOTREMOVE=y
+CONFIG_MHP_MEMMAP_ON_MEMORY=y
CONFIG_ARCH_MHP_MEMMAP_ON_MEMORY_ENABLE=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_ARCH_ENABLE_SPLIT_PMD_PTLOCK=y
CONFIG_MEMORY_BALLOON=y
CONFIG_BALLOON_COMPACTION=y
CONFIG_COMPACTION=y
-CONFIG_COMPACT_UNEVICTABLE_DEFAULT=0
+CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1
CONFIG_PAGE_REPORTING=y
CONFIG_MIGRATION=y
+CONFIG_DEVICE_MIGRATION=y
CONFIG_ARCH_ENABLE_HUGEPAGE_MIGRATION=y
CONFIG_ARCH_ENABLE_THP_MIGRATION=y
CONFIG_CONTIG_ALLOC=y
@@ -1139,40 +1144,44 @@
CONFIG_DEFAULT_MMAP_MIN_ADDR=65536
CONFIG_ARCH_SUPPORTS_MEMORY_FAILURE=y
CONFIG_MEMORY_FAILURE=y
-# CONFIG_HWPOISON_INJECT is not set
+CONFIG_HWPOISON_INJECT=m
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_ARCH_WANTS_THP_SWAP=y
CONFIG_TRANSPARENT_HUGEPAGE=y
-# CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS is not set
-CONFIG_TRANSPARENT_HUGEPAGE_MADVISE=y
+CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y
+# CONFIG_TRANSPARENT_HUGEPAGE_MADVISE is not set
CONFIG_THP_SWAP=y
CONFIG_READ_ONLY_THP_FOR_FS=y
CONFIG_NEED_PER_CPU_EMBED_FIRST_CHUNK=y
CONFIG_NEED_PER_CPU_PAGE_FIRST_CHUNK=y
+CONFIG_USE_PERCPU_NUMA_NODE_ID=y
CONFIG_HAVE_SETUP_PER_CPU_AREA=y
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
-# CONFIG_CMA_DEBUGFS is not set
+CONFIG_CMA_DEBUGFS=y
CONFIG_CMA_SYSFS=y
CONFIG_CMA_AREAS=7
CONFIG_MEM_SOFT_DIRTY=y
CONFIG_GENERIC_EARLY_IOREMAP=y
-CONFIG_DEFERRED_STRUCT_PAGE_INIT=y
-# CONFIG_IDLE_PAGE_TRACKING is not set
+# CONFIG_DEFERRED_STRUCT_PAGE_INIT is not set
+CONFIG_PAGE_IDLE_FLAG=y
+CONFIG_IDLE_PAGE_TRACKING=y
CONFIG_ARCH_HAS_CACHE_LINE_SIZE=y
CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y
CONFIG_ARCH_HAS_PTE_DEVMAP=y
CONFIG_ZONE_DMA=y
CONFIG_ZONE_DMA32=y
+CONFIG_ZONE_DEVICE=y
CONFIG_HMM_MIRROR=y
CONFIG_GET_FREE_REGION=y
+CONFIG_DEVICE_PRIVATE=y
CONFIG_VMAP_PFN=y
CONFIG_ARCH_USES_HIGH_VMA_FLAGS=y
CONFIG_ARCH_HAS_PKEYS=y
CONFIG_VM_EVENT_COUNTERS=y
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_TEST is not set
-CONFIG_DMAPOOL_TEST=m
+# CONFIG_DMAPOOL_TEST is not set
CONFIG_ARCH_HAS_PTE_SPECIAL=y
CONFIG_MAPPING_DIRTY_HELPERS=y
CONFIG_MEMFD_CREATE=y
@@ -1192,12 +1201,17 @@
# Data Access Monitoring
-# CONFIG_DAMON is not set
+CONFIG_DAMON=y
+CONFIG_DAMON_VADDR=y
+CONFIG_DAMON_PADDR=y
+CONFIG_DAMON_SYSFS=y
+CONFIG_DAMON_DBGFS=y
+CONFIG_DAMON_RECLAIM=y
+CONFIG_DAMON_LRU_SORT=y
# end of Data Access Monitoring
# end of Memory Management options
CONFIG_NET=y
-CONFIG_WANT_COMPAT_NETLINK_MESSAGES=y
CONFIG_COMPAT_NETLINK_MESSAGES=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
@@ -1208,7 +1222,7 @@
# Networking options
-CONFIG_PACKET=m
+CONFIG_PACKET=y
CONFIG_PACKET_DIAG=m
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
@@ -1216,16 +1230,16 @@
CONFIG_UNIX_DIAG=m
CONFIG_TLS=m
CONFIG_TLS_DEVICE=y
-CONFIG_TLS_TOE=y
+# CONFIG_TLS_TOE is not set
CONFIG_XFRM=y
CONFIG_XFRM_OFFLOAD=y
-CONFIG_XFRM_ALGO=m
-CONFIG_XFRM_USER=m
-CONFIG_XFRM_USER_COMPAT=m
+CONFIG_XFRM_ALGO=y
+CONFIG_XFRM_USER=y
+# CONFIG_XFRM_USER_COMPAT is not set
CONFIG_XFRM_INTERFACE=m
CONFIG_XFRM_SUB_POLICY=y
CONFIG_XFRM_MIGRATE=y
-# CONFIG_XFRM_STATISTICS is not set
+CONFIG_XFRM_STATISTICS=y
CONFIG_XFRM_AH=m
CONFIG_XFRM_ESP=m
CONFIG_XFRM_IPCOMP=m
@@ -1240,15 +1254,12 @@
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
-# CONFIG_IP_FIB_TRIE_STATS is not set
+CONFIG_IP_FIB_TRIE_STATS=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_CLASSID=y
-CONFIG_IP_PNP=y
-CONFIG_IP_PNP_DHCP=y
-CONFIG_IP_PNP_BOOTP=y
-CONFIG_IP_PNP_RARP=y
+# CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_NET_IP_TUNNEL=m
@@ -1278,33 +1289,25 @@
CONFIG_INET_RAW_DIAG=m
CONFIG_INET_DIAG_DESTROY=y
CONFIG_TCP_CONG_ADVANCED=y
-CONFIG_TCP_CONG_BIC=y
+CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
-CONFIG_TCP_CONG_WESTWOOD=y
-CONFIG_TCP_CONG_HTCP=y
-CONFIG_TCP_CONG_HSTCP=y
-CONFIG_TCP_CONG_HYBLA=y
-CONFIG_TCP_CONG_VEGAS=y
+CONFIG_TCP_CONG_WESTWOOD=m
+CONFIG_TCP_CONG_HTCP=m
+CONFIG_TCP_CONG_HSTCP=m
+CONFIG_TCP_CONG_HYBLA=m
+CONFIG_TCP_CONG_VEGAS=m
CONFIG_TCP_CONG_NV=m
-CONFIG_TCP_CONG_SCALABLE=y
-CONFIG_TCP_CONG_LP=y
-CONFIG_TCP_CONG_VENO=y
-CONFIG_TCP_CONG_YEAH=y
-CONFIG_TCP_CONG_ILLINOIS=y
-CONFIG_TCP_CONG_DCTCP=y
+CONFIG_TCP_CONG_SCALABLE=m
+CONFIG_TCP_CONG_LP=m
+CONFIG_TCP_CONG_VENO=m
+CONFIG_TCP_CONG_YEAH=m
+CONFIG_TCP_CONG_ILLINOIS=m
+CONFIG_TCP_CONG_DCTCP=m
CONFIG_TCP_CONG_CDG=m
-CONFIG_TCP_CONG_BBR=y
-# CONFIG_DEFAULT_BIC is not set
-# CONFIG_DEFAULT_CUBIC is not set
-# CONFIG_DEFAULT_HTCP is not set
-# CONFIG_DEFAULT_HYBLA is not set
-# CONFIG_DEFAULT_VEGAS is not set
-# CONFIG_DEFAULT_VENO is not set
-# CONFIG_DEFAULT_WESTWOOD is not set
-# CONFIG_DEFAULT_DCTCP is not set
-CONFIG_DEFAULT_BBR=y
+CONFIG_TCP_CONG_BBR=m
+CONFIG_DEFAULT_CUBIC=y
# CONFIG_DEFAULT_RENO is not set
-CONFIG_DEFAULT_TCP_CONG="bbr"
+CONFIG_DEFAULT_TCP_CONG="cubic"
CONFIG_TCP_SIGPOOL=y
CONFIG_TCP_AO=y
CONFIG_TCP_MD5SIG=y
@@ -1345,7 +1348,7 @@
CONFIG_MPTCP_IPV6=y
CONFIG_NETWORK_SECMARK=y
CONFIG_NET_PTP_CLASSIFY=y
-# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
+CONFIG_NETWORK_PHY_TIMESTAMPING=y
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
@@ -1470,7 +1473,7 @@
CONFIG_NETFILTER_XT_TARGET_NETMAP=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
-# CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set
+CONFIG_NETFILTER_XT_TARGET_NOTRACK=m
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
@@ -1551,9 +1554,9 @@
CONFIG_IP_SET_HASH_NETIFACE=m
CONFIG_IP_SET_LIST_SET=m
CONFIG_IP_VS=m
-# CONFIG_IP_VS_IPV6 is not set
+CONFIG_IP_VS_IPV6=y
# CONFIG_IP_VS_DEBUG is not set
-CONFIG_IP_VS_TAB_BITS=12
+CONFIG_IP_VS_TAB_BITS=15
# IPVS transport protocol load balancing support
@@ -1701,30 +1704,12 @@
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
-CONFIG_BPFILTER=y
-CONFIG_BPFILTER_UMH=m
-CONFIG_IP_DCCP=m
-CONFIG_INET_DCCP_DIAG=m
-# DCCP CCIDs Configuration
-# CONFIG_IP_DCCP_CCID2_DEBUG is not set
-CONFIG_IP_DCCP_CCID3=y
-# CONFIG_IP_DCCP_CCID3_DEBUG is not set
-CONFIG_IP_DCCP_TFRC_LIB=y
-# end of DCCP CCIDs Configuration
-# DCCP Kernel Hacking
-# CONFIG_IP_DCCP_DEBUG is not set
-# end of DCCP Kernel Hacking
+# CONFIG_BPFILTER is not set
+# CONFIG_IP_DCCP is not set
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_OBJCNT is not set
-CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
-# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
+# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5 is not set
+CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1=y
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
CONFIG_SCTP_COOKIE_HMAC_MD5=y
CONFIG_SCTP_COOKIE_HMAC_SHA1=y
@@ -1744,9 +1729,9 @@
CONFIG_ATM_LANE=m
CONFIG_ATM_MPOA=m
CONFIG_ATM_BR2684=m
-CONFIG_ATM_BR2684_IPFILTER=y
+# CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_L2TP=m
-# CONFIG_L2TP_DEBUGFS is not set
+CONFIG_L2TP_DEBUGFS=m
CONFIG_L2TP_V3=y
CONFIG_L2TP_IP=m
CONFIG_L2TP_ETH=m
@@ -1788,11 +1773,11 @@
CONFIG_LLC=m
CONFIG_LLC2=m
CONFIG_ATALK=m
-CONFIG_X25=m
-CONFIG_LAPB=m
+# CONFIG_X25 is not set
+# CONFIG_LAPB is not set
CONFIG_PHONET=m
CONFIG_6LOWPAN=m
-# CONFIG_6LOWPAN_DEBUGFS is not set
+CONFIG_6LOWPAN_DEBUGFS=y
CONFIG_6LOWPAN_NHC=m
CONFIG_6LOWPAN_NHC_DEST=m
CONFIG_6LOWPAN_NHC_FRAGMENT=m
@@ -1909,7 +1894,7 @@
CONFIG_NET_TC_SKB_EXT=y
CONFIG_NET_SCH_FIFO=y
CONFIG_DCB=y
-CONFIG_DNS_RESOLVER=y
+CONFIG_DNS_RESOLVER=m
CONFIG_BATMAN_ADV=m
CONFIG_BATMAN_ADV_BATMAN_V=y
CONFIG_BATMAN_ADV_BLA=y
@@ -1944,7 +1929,7 @@
CONFIG_QRTR_MHI=m
CONFIG_NET_NCSI=y
CONFIG_NCSI_OEM_CMD_GET_MAC=y
-# CONFIG_NCSI_OEM_CMD_KEEP_PHY is not set
+CONFIG_NCSI_OEM_CMD_KEEP_PHY=y
CONFIG_PCPU_DEV_REFCNT=y
CONFIG_MAX_SKB_FRAGS=17
CONFIG_RPS=y
@@ -1962,7 +1947,7 @@
# Network testing
CONFIG_NET_PKTGEN=m
-# CONFIG_NET_DROP_MONITOR is not set
+CONFIG_NET_DROP_MONITOR=y
# end of Network testing
# end of Networking options
@@ -1979,13 +1964,13 @@
# AX.25 network device drivers
-# CONFIG_MKISS is not set
-# CONFIG_6PACK is not set
-# CONFIG_BPQETHER is not set
-# CONFIG_BAYCOM_SER_FDX is not set
-# CONFIG_BAYCOM_SER_HDX is not set
-# CONFIG_BAYCOM_PAR is not set
-# CONFIG_YAM is not set
+CONFIG_MKISS=m
+CONFIG_6PACK=m
+CONFIG_BPQETHER=m
+CONFIG_BAYCOM_SER_FDX=m
+CONFIG_BAYCOM_SER_HDX=m
+CONFIG_BAYCOM_PAR=m
+CONFIG_YAM=m
# end of AX.25 network device drivers
CONFIG_CAN=m
@@ -2003,16 +1988,15 @@
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_CMTP=m
CONFIG_BT_HIDP=m
-CONFIG_BT_HS=y
+# CONFIG_BT_HS is not set
CONFIG_BT_LE=y
CONFIG_BT_LE_L2CAP_ECRED=y
CONFIG_BT_6LOWPAN=m
CONFIG_BT_LEDS=y
CONFIG_BT_MSFTEXT=y
CONFIG_BT_AOSPEXT=y
-# CONFIG_BT_DEBUGFS is not set
+CONFIG_BT_DEBUGFS=y
# CONFIG_BT_SELFTEST is not set
-# CONFIG_BT_FEATURE_DEBUG is not set
# Bluetooth device drivers
@@ -2038,6 +2022,7 @@
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIUART_3WIRE=y
CONFIG_BT_HCIUART_INTEL=y
+CONFIG_BT_HCIUART_BCM=y
CONFIG_BT_HCIUART_RTL=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_BT_HCIUART_AG6XX=y
@@ -2064,9 +2049,9 @@
CONFIG_AF_RXRPC_IPV6=y
# CONFIG_AF_RXRPC_INJECT_LOSS is not set
# CONFIG_AF_RXRPC_INJECT_RX_DELAY is not set
-# CONFIG_AF_RXRPC_DEBUG is not set
+CONFIG_AF_RXRPC_DEBUG=y
CONFIG_RXKAD=y
-CONFIG_RXPERF=m
+# CONFIG_RXPERF is not set
CONFIG_AF_KCM=m
CONFIG_STREAM_PARSER=y
CONFIG_MCTP=y
@@ -2079,12 +2064,12 @@
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=m
-CONFIG_NL80211_TESTMODE=y
+# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
-# CONFIG_CFG80211_DEBUGFS is not set
+CONFIG_CFG80211_DEBUGFS=y
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
CONFIG_CFG80211_WEXT_EXPORT=y
@@ -2100,6 +2085,7 @@
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
CONFIG_MAC80211_MESH=y
CONFIG_MAC80211_LEDS=y
+CONFIG_MAC80211_DEBUGFS=y
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
@@ -2113,13 +2099,10 @@
CONFIG_NET_9P_XEN=m
CONFIG_NET_9P_RDMA=m
# CONFIG_NET_9P_DEBUG is not set
-CONFIG_CAIF=m
-# CONFIG_CAIF_DEBUG is not set
-CONFIG_CAIF_NETDEV=m
-CONFIG_CAIF_USB=m
+# CONFIG_CAIF is not set
CONFIG_CEPH_LIB=m
-# CONFIG_CEPH_LIB_PRETTYDEBUG is not set
-# CONFIG_CEPH_LIB_USE_DNS_RESOLVER is not set
+CONFIG_CEPH_LIB_PRETTYDEBUG=y
+CONFIG_CEPH_LIB_USE_DNS_RESOLVER=y
CONFIG_NFC=m
CONFIG_NFC_DIGITAL=m
CONFIG_NFC_NCI=m
@@ -2173,7 +2156,7 @@
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
CONFIG_SOCK_VALIDATE_XMIT=y
-CONFIG_NET_SELFTESTS=y
+CONFIG_NET_SELFTESTS=m
CONFIG_NET_SOCK_MSG=y
CONFIG_NET_DEVLINK=y
CONFIG_PAGE_POOL=y
@@ -2192,9 +2175,9 @@
CONFIG_PCIEPORTBUS=y
CONFIG_HOTPLUG_PCI_PCIE=y
CONFIG_PCIEAER=y
-# CONFIG_PCIEAER_INJECT is not set
+CONFIG_PCIEAER_INJECT=m
CONFIG_PCIEAER_CXL=y
-# CONFIG_PCIE_ECRC is not set
+CONFIG_PCIE_ECRC=y
CONFIG_PCIEASPM=y
CONFIG_PCIEASPM_DEFAULT=y
# CONFIG_PCIEASPM_POWERSAVE is not set
@@ -2207,16 +2190,17 @@
CONFIG_PCI_MSI=y
CONFIG_PCI_QUIRKS=y
# CONFIG_PCI_DEBUG is not set
-CONFIG_PCI_REALLOC_ENABLE_AUTO=y
-CONFIG_PCI_STUB=m
+# CONFIG_PCI_REALLOC_ENABLE_AUTO is not set
+CONFIG_PCI_STUB=y
CONFIG_PCI_PF_STUB=m
-CONFIG_XEN_PCIDEV_FRONTEND=y
+CONFIG_XEN_PCIDEV_FRONTEND=m
CONFIG_PCI_ATS=y
CONFIG_PCI_DOE=y
CONFIG_PCI_LOCKLESS_CONFIG=y
CONFIG_PCI_IOV=y
CONFIG_PCI_PRI=y
CONFIG_PCI_PASID=y
+CONFIG_PCI_P2PDMA=y
CONFIG_PCI_LABEL=y
CONFIG_PCI_HYPERV=m
CONFIG_VGA_ARB=y
@@ -2245,11 +2229,9 @@
CONFIG_PCIE_DW=y
CONFIG_PCIE_DW_HOST=y
-CONFIG_PCIE_DW_EP=y
CONFIG_PCI_MESON=y
CONFIG_PCIE_DW_PLAT=y
CONFIG_PCIE_DW_PLAT_HOST=y
-CONFIG_PCIE_DW_PLAT_EP=y
# end of DesignWare-based PCIe controllers
@@ -2261,12 +2243,7 @@
# PCI Endpoint
-CONFIG_PCI_ENDPOINT=y
-CONFIG_PCI_ENDPOINT_CONFIGFS=y
-# CONFIG_PCI_EPF_TEST is not set
-CONFIG_PCI_EPF_NTB=m
-CONFIG_PCI_EPF_VNTB=m
-CONFIG_PCI_EPF_MHI=m
+# CONFIG_PCI_ENDPOINT is not set
# end of PCI Endpoint
@@ -2303,30 +2280,13 @@
CONFIG_PD6729=m
CONFIG_I82092=m
CONFIG_PCCARD_NONSTATIC=y
-CONFIG_RAPIDIO=y
-CONFIG_RAPIDIO_TSI721=y
-CONFIG_RAPIDIO_DISC_TIMEOUT=30
-CONFIG_RAPIDIO_ENABLE_RX_TX_PORTS=y
-CONFIG_RAPIDIO_DMA_ENGINE=y
-# CONFIG_RAPIDIO_DEBUG is not set
-CONFIG_RAPIDIO_ENUM_BASIC=m
-CONFIG_RAPIDIO_CHMAN=m
-CONFIG_RAPIDIO_MPORT_CDEV=m
-# RapidIO Switch drivers
-CONFIG_RAPIDIO_CPS_XX=y
-CONFIG_RAPIDIO_CPS_GEN2=y
-CONFIG_RAPIDIO_RXS_GEN3=m
-# end of RapidIO Switch drivers
+# CONFIG_RAPIDIO is not set
# Generic Driver Options
CONFIG_AUXILIARY_BUS=y
-CONFIG_UEVENT_HELPER=y
-CONFIG_UEVENT_HELPER_PATH=""
+# CONFIG_UEVENT_HELPER is not set
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_DEVTMPFS_SAFE=y
@@ -2337,6 +2297,7 @@
# Firmware loader
CONFIG_FW_LOADER=y
+CONFIG_FW_LOADER_DEBUG=y
CONFIG_FW_LOADER_PAGED_BUF=y
CONFIG_FW_LOADER_SYSFS=y
CONFIG_EXTRA_FIRMWARE=""
@@ -2354,7 +2315,8 @@
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
-CONFIG_TEST_ASYNC_DRIVER_PROBE=m
+CONFIG_HMEM_REPORTING=y
+# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_SYS_HYPERVISOR=y
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_GENERIC_CPU_VULNERABILITIES=y
@@ -2363,14 +2325,12 @@
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SLIMBUS=m
CONFIG_REGMAP_SPI=y
-CONFIG_REGMAP_SPMI=m
CONFIG_REGMAP_W1=m
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_REGMAP_SOUNDWIRE=m
CONFIG_REGMAP_SOUNDWIRE_MBQ=m
CONFIG_REGMAP_SCCB=m
-CONFIG_REGMAP_I3C=m
CONFIG_REGMAP_SPI_AVMM=m
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
@@ -2407,23 +2367,32 @@
# CONFIG_EDD_OFF is not set
CONFIG_FIRMWARE_MEMMAP=y
CONFIG_DMIID=y
-CONFIG_DMI_SYSFS=m
+CONFIG_DMI_SYSFS=y
CONFIG_DMI_SCAN_MACHINE_NON_EFI_FALLBACK=y
CONFIG_ISCSI_IBFT_FIND=y
CONFIG_ISCSI_IBFT=m
CONFIG_FW_CFG_SYSFS=m
-CONFIG_FW_CFG_SYSFS_CMDLINE=y
+# CONFIG_FW_CFG_SYSFS_CMDLINE is not set
CONFIG_SYSFB=y
-# CONFIG_SYSFB_SIMPLEFB is not set
+CONFIG_SYSFB_SIMPLEFB=y
CONFIG_FW_CS_DSP=m
-# CONFIG_GOOGLE_FIRMWARE is not set
+CONFIG_GOOGLE_FIRMWARE=y
+# CONFIG_GOOGLE_SMI is not set
+CONFIG_GOOGLE_CBMEM=m
+CONFIG_GOOGLE_COREBOOT_TABLE=m
+CONFIG_GOOGLE_MEMCONSOLE=m
+# CONFIG_GOOGLE_MEMCONSOLE_X86_LEGACY is not set
+CONFIG_GOOGLE_FRAMEBUFFER_COREBOOT=m
+CONFIG_GOOGLE_MEMCONSOLE_COREBOOT=m
+CONFIG_GOOGLE_VPD=m
# EFI (Extensible Firmware Interface) Support
CONFIG_EFI_ESRT=y
-CONFIG_EFI_VARS_PSTORE=m
+CONFIG_EFI_VARS_PSTORE=y
CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE=y
+CONFIG_EFI_SOFT_RESERVE=y
CONFIG_EFI_DXE_MEM_ATTRIBUTES=y
CONFIG_EFI_RUNTIME_WRAPPERS=y
CONFIG_EFI_BOOTLOADER_CONTROL=m
@@ -2463,16 +2432,13 @@
CONFIG_GNSS_UBX_SERIAL=m
CONFIG_GNSS_USB=m
CONFIG_MTD=m
-CONFIG_MTD_TESTS=m
+# CONFIG_MTD_TESTS is not set
# Partition parsers
# CONFIG_MTD_CMDLINE_PARTS is not set
-CONFIG_MTD_REDBOOT_PARTS=m
-CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1
-# CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
-# CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
+# CONFIG_MTD_REDBOOT_PARTS is not set
# end of Partition parsers
@@ -2480,78 +2446,55 @@
CONFIG_MTD_BLKDEVS=m
CONFIG_MTD_BLOCK=m
-CONFIG_MTD_BLOCK_RO=m
+# CONFIG_MTD_BLOCK_RO is not set
# Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK.
-CONFIG_FTL=m
-CONFIG_NFTL=m
-CONFIG_NFTL_RW=y
-CONFIG_INFTL=m
-CONFIG_RFD_FTL=m
-CONFIG_SSFDC=m
-CONFIG_SM_FTL=m
-CONFIG_MTD_OOPS=m
-CONFIG_MTD_SWAP=m
-# CONFIG_MTD_PARTITIONED_MASTER is not set
+# CONFIG_FTL is not set
+# CONFIG_NFTL is not set
+# CONFIG_INFTL is not set
+# CONFIG_RFD_FTL is not set
+# CONFIG_SSFDC is not set
+# CONFIG_SM_FTL is not set
+# CONFIG_MTD_OOPS is not set
+CONFIG_MTD_PSTORE=m
+# CONFIG_MTD_SWAP is not set
+CONFIG_MTD_PARTITIONED_MASTER=y
# RAM/ROM/Flash chip drivers
-CONFIG_MTD_CFI=m
-CONFIG_MTD_JEDECPROBE=m
-CONFIG_MTD_GEN_PROBE=m
-# CONFIG_MTD_CFI_ADV_OPTIONS is not set
+# CONFIG_MTD_CFI is not set
+# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
-CONFIG_MTD_CFI_INTELEXT=m
-CONFIG_MTD_CFI_AMDSTD=m
-CONFIG_MTD_CFI_STAA=m
-CONFIG_MTD_CFI_UTIL=m
-CONFIG_MTD_RAM=m
+# CONFIG_MTD_RAM is not set
CONFIG_MTD_ROM=m
-CONFIG_MTD_ABSENT=m
+# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
-CONFIG_MTD_COMPLEX_MAPPINGS=y
-CONFIG_MTD_PHYSMAP=m
-# CONFIG_MTD_PHYSMAP_COMPAT is not set
-CONFIG_MTD_PHYSMAP_GPIO_ADDR=y
-CONFIG_MTD_SBC_GXX=m
-CONFIG_MTD_AMD76XROM=m
-CONFIG_MTD_ICHXROM=m
-CONFIG_MTD_ESB2ROM=m
-CONFIG_MTD_CK804XROM=m
-CONFIG_MTD_SCB2_FLASH=m
-CONFIG_MTD_NETtel=m
-CONFIG_MTD_L440GX=m
-CONFIG_MTD_PCI=m
-CONFIG_MTD_PCMCIA=m
-CONFIG_MTD_PCMCIA_ANONYMOUS=y
-CONFIG_MTD_INTEL_VR_NOR=m
-CONFIG_MTD_PLATRAM=m
+# CONFIG_MTD_COMPLEX_MAPPINGS is not set
+# CONFIG_MTD_PHYSMAP is not set
+# CONFIG_MTD_INTEL_VR_NOR is not set
+# CONFIG_MTD_PLATRAM is not set
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
-CONFIG_MTD_PMC551=m
-# CONFIG_MTD_PMC551_BUGFIX is not set
-# CONFIG_MTD_PMC551_DEBUG is not set
-CONFIG_MTD_DATAFLASH=m
-# CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set
-CONFIG_MTD_DATAFLASH_OTP=y
-CONFIG_MTD_MCHP23K256=m
-CONFIG_MTD_MCHP48L640=m
-CONFIG_MTD_SST25L=m
-CONFIG_MTD_SLRAM=m
+# CONFIG_MTD_PMC551 is not set
+# CONFIG_MTD_DATAFLASH is not set
+# CONFIG_MTD_MCHP23K256 is not set
+# CONFIG_MTD_MCHP48L640 is not set
+# CONFIG_MTD_SST25L is not set
+# CONFIG_MTD_SLRAM is not set
CONFIG_MTD_PHRAM=m
CONFIG_MTD_MTDRAM=m
CONFIG_MTDRAM_TOTAL_SIZE=4096
@@ -2561,51 +2504,40 @@
# Disk-On-Chip Device Drivers
-CONFIG_MTD_DOCG3=m
-CONFIG_BCH_CONST_M=14
-CONFIG_BCH_CONST_T=4
+# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# NAND
CONFIG_MTD_NAND_CORE=m
-CONFIG_MTD_ONENAND=m
-CONFIG_MTD_ONENAND_VERIFY_WRITE=y
-CONFIG_MTD_ONENAND_GENERIC=m
-CONFIG_MTD_ONENAND_OTP=y
-CONFIG_MTD_ONENAND_2X_PROGRAM=y
+# CONFIG_MTD_ONENAND is not set
CONFIG_MTD_RAW_NAND=m
# Raw/parallel NAND flash controllers
-CONFIG_MTD_NAND_DENALI=m
-CONFIG_MTD_NAND_DENALI_PCI=m
-CONFIG_MTD_NAND_CAFE=m
-CONFIG_MTD_NAND_MXIC=m
-CONFIG_MTD_NAND_GPIO=m
-CONFIG_MTD_NAND_PLATFORM=m
-CONFIG_MTD_NAND_ARASAN=m
+# CONFIG_MTD_NAND_DENALI_PCI is not set
+# CONFIG_MTD_NAND_CAFE is not set
+# CONFIG_MTD_NAND_MXIC is not set
+# CONFIG_MTD_NAND_GPIO is not set
+# CONFIG_MTD_NAND_PLATFORM is not set
+# CONFIG_MTD_NAND_ARASAN is not set
# Misc
-CONFIG_MTD_SM_COMMON=m
CONFIG_MTD_NAND_NANDSIM=m
-CONFIG_MTD_NAND_RICOH=m
-CONFIG_MTD_NAND_DISKONCHIP=m
-# CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADVANCED is not set
-CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADDRESS=0
-# CONFIG_MTD_NAND_DISKONCHIP_BBTWRITE is not set
-CONFIG_MTD_SPI_NAND=m
+# CONFIG_MTD_NAND_RICOH is not set
+# CONFIG_MTD_NAND_DISKONCHIP is not set
+# CONFIG_MTD_SPI_NAND is not set
# ECC engine support
CONFIG_MTD_NAND_ECC=y
CONFIG_MTD_NAND_ECC_SW_HAMMING=y
-# CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set
+CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC=y
CONFIG_MTD_NAND_ECC_SW_BCH=y
CONFIG_MTD_NAND_ECC_MXIC=y
# end of ECC engine support
@@ -2614,8 +2546,7 @@
# LPDDR & LPDDR2 PCM memory drivers
-CONFIG_MTD_LPDDR=m
-CONFIG_MTD_QINFO_PROBE=m
+# CONFIG_MTD_LPDDR is not set
# end of LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_SPI_NOR=m
@@ -2626,10 +2557,10 @@
CONFIG_MTD_UBI=m
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
-CONFIG_MTD_UBI_FASTMAP=y
+# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
-CONFIG_MTD_UBI_BLOCK=y
-CONFIG_MTD_HYPERBUS=m
+# CONFIG_MTD_UBI_BLOCK is not set
+# CONFIG_MTD_HYPERBUS is not set
# CONFIG_OF is not set
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
CONFIG_PARPORT=m
@@ -2641,7 +2572,7 @@
CONFIG_PARPORT_1284=y
CONFIG_PARPORT_NOT_PC=y
CONFIG_PNP=y
-# CONFIG_PNP_DEBUG_MESSAGES is not set
+CONFIG_PNP_DEBUG_MESSAGES=y
# Protocols
@@ -2655,28 +2586,28 @@
CONFIG_BLK_DEV_PCIESSD_MTIP32XX=m
CONFIG_ZRAM=m
# CONFIG_ZRAM_DEF_COMP_LZORLE is not set
-# CONFIG_ZRAM_DEF_COMP_ZSTD is not set
-CONFIG_ZRAM_DEF_COMP_LZ4=y
+CONFIG_ZRAM_DEF_COMP_ZSTD=y
+# CONFIG_ZRAM_DEF_COMP_LZ4 is not set
# CONFIG_ZRAM_DEF_COMP_LZO is not set
# CONFIG_ZRAM_DEF_COMP_LZ4HC is not set
# CONFIG_ZRAM_DEF_COMP_842 is not set
-CONFIG_ZRAM_DEF_COMP="lz4"
+CONFIG_ZRAM_DEF_COMP="zstd"
CONFIG_ZRAM_WRITEBACK=y
CONFIG_ZRAM_MEMORY_TRACKING=y
CONFIG_ZRAM_MULTI_COMP=y
CONFIG_BLK_DEV_LOOP=m
-CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
+CONFIG_BLK_DEV_LOOP_MIN_COUNT=0
CONFIG_BLK_DEV_DRBD=m
# CONFIG_DRBD_FAULT_INJECTION is not set
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_RAM=m
CONFIG_BLK_DEV_RAM_COUNT=16
-CONFIG_BLK_DEV_RAM_SIZE=4096
+CONFIG_BLK_DEV_RAM_SIZE=16384
CONFIG_CDROM_PKTCDVD=m
CONFIG_CDROM_PKTCDVD_BUFFERS=8
-CONFIG_CDROM_PKTCDVD_WCACHE=y
+# CONFIG_CDROM_PKTCDVD_WCACHE is not set
CONFIG_ATA_OVER_ETH=m
-CONFIG_XEN_BLKDEV_FRONTEND=y
+CONFIG_XEN_BLKDEV_FRONTEND=m
CONFIG_XEN_BLKDEV_BACKEND=m
CONFIG_VIRTIO_BLK=m
CONFIG_BLK_DEV_RBD=m
@@ -2690,11 +2621,11 @@
# NVME Support
CONFIG_NVME_KEYRING=m
-CONFIG_NVME_AUTH=y
-CONFIG_NVME_CORE=y
-CONFIG_BLK_DEV_NVME=y
+CONFIG_NVME_AUTH=m
+CONFIG_NVME_CORE=m
+CONFIG_BLK_DEV_NVME=m
CONFIG_NVME_MULTIPATH=y
-# CONFIG_NVME_VERBOSE_ERRORS is not set
+CONFIG_NVME_VERBOSE_ERRORS=y
CONFIG_NVME_HWMON=y
CONFIG_NVME_FABRICS=m
CONFIG_NVME_RDMA=m
@@ -2720,7 +2651,7 @@
CONFIG_AD525X_DPOT=m
CONFIG_AD525X_DPOT_I2C=m
CONFIG_AD525X_DPOT_SPI=m
-CONFIG_DUMMY_IRQ=m
+# CONFIG_DUMMY_IRQ is not set
CONFIG_IBM_ASM=m
CONFIG_PHANTOM=m
CONFIG_TIFM_CORE=m
@@ -2754,10 +2685,10 @@
# EEPROM support
CONFIG_EEPROM_AT24=m
-CONFIG_EEPROM_AT25=m
+# CONFIG_EEPROM_AT25 is not set
CONFIG_EEPROM_MAX6875=m
CONFIG_EEPROM_93CX6=m
-CONFIG_EEPROM_93XX46=m
+# CONFIG_EEPROM_93XX46 is not set
CONFIG_EEPROM_IDT_89HPESX=m
CONFIG_EEPROM_EE1004=m
# end of EEPROM support
@@ -2774,8 +2705,8 @@
CONFIG_SENSORS_LIS3_I2C=m
CONFIG_ALTERA_STAPL=m
-CONFIG_INTEL_MEI=y
-CONFIG_INTEL_MEI_ME=y
+CONFIG_INTEL_MEI=m
+CONFIG_INTEL_MEI_ME=m
CONFIG_INTEL_MEI_TXE=m
CONFIG_INTEL_MEI_GSC=m
CONFIG_INTEL_MEI_HDCP=m
@@ -2786,7 +2717,7 @@
CONFIG_GENWQE_PLATFORM_ERROR_RECOVERY=0
CONFIG_ECHO=m
CONFIG_BCM_VK=m
-# CONFIG_BCM_VK_TTY is not set
+CONFIG_BCM_VK_TTY=y
CONFIG_MISC_ALCOR_PCI=m
CONFIG_MISC_RTSX_PCI=m
CONFIG_MISC_RTSX_USB=m
@@ -2850,22 +2781,22 @@
CONFIG_SCSI_ACARD=m
CONFIG_SCSI_AACRAID=m
CONFIG_SCSI_AIC7XXX=m
-CONFIG_AIC7XXX_CMDS_PER_DEVICE=8
+CONFIG_AIC7XXX_CMDS_PER_DEVICE=32
CONFIG_AIC7XXX_RESET_DELAY_MS=15000
-# CONFIG_AIC7XXX_DEBUG_ENABLE is not set
+CONFIG_AIC7XXX_DEBUG_ENABLE=y
CONFIG_AIC7XXX_DEBUG_MASK=0
-# CONFIG_AIC7XXX_REG_PRETTY_PRINT is not set
+CONFIG_AIC7XXX_REG_PRETTY_PRINT=y
CONFIG_SCSI_AIC79XX=m
CONFIG_AIC79XX_CMDS_PER_DEVICE=32
CONFIG_AIC79XX_RESET_DELAY_MS=15000
-# CONFIG_AIC79XX_DEBUG_ENABLE is not set
+CONFIG_AIC79XX_DEBUG_ENABLE=y
CONFIG_AIC79XX_DEBUG_MASK=0
-# CONFIG_AIC79XX_REG_PRETTY_PRINT is not set
+CONFIG_AIC79XX_REG_PRETTY_PRINT=y
CONFIG_SCSI_AIC94XX=m
-# CONFIG_AIC94XX_DEBUG is not set
+CONFIG_AIC94XX_DEBUG=y
CONFIG_SCSI_MVSAS=m
-# CONFIG_SCSI_MVSAS_DEBUG is not set
-# CONFIG_SCSI_MVSAS_TASKLET is not set
+CONFIG_SCSI_MVSAS_DEBUG=y
+CONFIG_SCSI_MVSAS_TASKLET=y
CONFIG_SCSI_MVUMI=m
CONFIG_SCSI_ADVANSYS=m
CONFIG_SCSI_ARCMSR=m
@@ -2883,7 +2814,7 @@
CONFIG_SCSI_SMARTPQI=m
CONFIG_SCSI_HPTIOP=m
CONFIG_SCSI_BUSLOGIC=m
-# CONFIG_SCSI_FLASHPOINT is not set
+CONFIG_SCSI_FLASHPOINT=y
CONFIG_SCSI_MYRB=m
CONFIG_SCSI_MYRS=m
CONFIG_VMWARE_PVSCSI=m
@@ -2912,8 +2843,8 @@
CONFIG_SCSI_SYM53C8XX_MAX_TAGS=64
CONFIG_SCSI_SYM53C8XX_MMIO=y
CONFIG_SCSI_IPR=m
-# CONFIG_SCSI_IPR_TRACE is not set
-# CONFIG_SCSI_IPR_DUMP is not set
+CONFIG_SCSI_IPR_TRACE=y
+CONFIG_SCSI_IPR_DUMP=y
CONFIG_SCSI_QLOGIC_1280=m
CONFIG_SCSI_QLA_FC=m
CONFIG_TCM_QLA2XXX=m
@@ -2927,7 +2858,7 @@
CONFIG_SCSI_DC395x=m
CONFIG_SCSI_AM53C974=m
CONFIG_SCSI_WD719X=m
-# CONFIG_SCSI_DEBUG is not set
+CONFIG_SCSI_DEBUG=m
CONFIG_SCSI_PMCRAID=m
CONFIG_SCSI_PM8001=m
CONFIG_SCSI_BFA_FC=m
@@ -2943,7 +2874,6 @@
CONFIG_SCSI_DH_HP_SW=m
CONFIG_SCSI_DH_EMC=m
CONFIG_SCSI_DH_ALUA=m
-CONFIG_VHBA=m
# end of SCSI device support
CONFIG_ATA=y
@@ -2959,7 +2889,7 @@
# Controllers with non-SFF native interface
CONFIG_SATA_AHCI=y
-CONFIG_SATA_MOBILE_LPM_POLICY=0
+CONFIG_SATA_MOBILE_LPM_POLICY=3
CONFIG_SATA_AHCI_PLATFORM=m
CONFIG_AHCI_DWC=m
CONFIG_SATA_INIC162X=m
@@ -2980,7 +2910,7 @@
CONFIG_ATA_PIIX=m
CONFIG_SATA_DWC=m
-CONFIG_SATA_DWC_OLD_DMA=y
+# CONFIG_SATA_DWC_OLD_DMA is not set
CONFIG_SATA_MV=m
CONFIG_SATA_NV=m
CONFIG_SATA_PROMISE=m
@@ -3082,9 +3012,10 @@
CONFIG_BCACHE_ASYNC_REGISTRATION=y
CONFIG_BLK_DEV_DM_BUILTIN=y
CONFIG_BLK_DEV_DM=m
-# CONFIG_DM_DEBUG is not set
+CONFIG_DM_DEBUG=y
CONFIG_DM_BUFIO=m
-# CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set
+CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING=y
+# CONFIG_DM_DEBUG_BLOCK_STACK_TRACING is not set
CONFIG_DM_BIO_PRISON=m
CONFIG_DM_PERSISTENT_DATA=m
CONFIG_DM_UNSTRIPED=m
@@ -3098,7 +3029,7 @@
CONFIG_DM_ERA=m
CONFIG_DM_CLONE=m
CONFIG_DM_MIRROR=m
-# CONFIG_DM_LOG_USERSPACE is not set
+CONFIG_DM_LOG_USERSPACE=m
CONFIG_DM_RAID=m
CONFIG_DM_ZERO=m
CONFIG_DM_MULTIPATH=m
@@ -3112,7 +3043,7 @@
CONFIG_DM_FLAKEY=m
CONFIG_DM_VERITY=m
CONFIG_DM_VERITY_VERIFY_ROOTHASH_SIG=y
-# CONFIG_DM_VERITY_VERIFY_ROOTHASH_SIG_SECONDARY_KEYRING is not set
+CONFIG_DM_VERITY_VERIFY_ROOTHASH_SIG_SECONDARY_KEYRING=y
CONFIG_DM_VERITY_FEC=y
CONFIG_DM_SWITCH=m
CONFIG_DM_LOG_WRITES=m
@@ -3134,7 +3065,7 @@
CONFIG_FUSION_SPI=m
CONFIG_FUSION_FC=m
CONFIG_FUSION_SAS=m
-CONFIG_FUSION_MAX_SGE=40
+CONFIG_FUSION_MAX_SGE=128
CONFIG_FUSION_CTL=m
CONFIG_FUSION_LAN=m
# CONFIG_FUSION_LOGGING is not set
@@ -3150,7 +3081,7 @@
# end of IEEE 1394 (FireWire) support
CONFIG_MACINTOSH_DRIVERS=y
-CONFIG_MAC_EMUMOUSEBTN=y
+CONFIG_MAC_EMUMOUSEBTN=m
CONFIG_NETDEVICES=y
CONFIG_MII=m
CONFIG_NET_CORE=y
@@ -3184,12 +3115,9 @@
CONFIG_NETPOLL=y
CONFIG_NET_POLL_CONTROLLER=y
CONFIG_NTB_NETDEV=m
-CONFIG_RIONET=m
-CONFIG_RIONET_TX_SIZE=128
-CONFIG_RIONET_RX_SIZE=128
CONFIG_TUN=m
CONFIG_TAP=m
-CONFIG_TUN_VNET_CROSS_LE=y
+# CONFIG_TUN_VNET_CROSS_LE is not set
CONFIG_VETH=m
CONFIG_VIRTIO_NET=m
CONFIG_NLMON=m
@@ -3198,27 +3126,17 @@
CONFIG_VSOCKMON=m
CONFIG_MHI_NET=m
CONFIG_SUNGEM_PHY=m
-CONFIG_ARCNET=m
-CONFIG_ARCNET_1201=m
-CONFIG_ARCNET_1051=m
-CONFIG_ARCNET_RAW=m
-CONFIG_ARCNET_CAP=m
-CONFIG_ARCNET_COM90xx=m
-CONFIG_ARCNET_COM90xxIO=m
-CONFIG_ARCNET_RIM_I=m
-CONFIG_ARCNET_COM20020=m
-CONFIG_ARCNET_COM20020_PCI=m
-CONFIG_ARCNET_COM20020_CS=m
+# CONFIG_ARCNET is not set
CONFIG_ATM_DRIVERS=y
-CONFIG_ATM_DUMMY=m
+# CONFIG_ATM_DUMMY is not set
CONFIG_ATM_TCP=m
CONFIG_ATM_LANAI=m
CONFIG_ATM_ENI=m
# CONFIG_ATM_ENI_DEBUG is not set
# CONFIG_ATM_ENI_TUNE_BURST is not set
CONFIG_ATM_NICSTAR=m
-CONFIG_ATM_NICSTAR_USE_SUNI=y
-CONFIG_ATM_NICSTAR_USE_IDT77105=y
+# CONFIG_ATM_NICSTAR_USE_SUNI is not set
+# CONFIG_ATM_NICSTAR_USE_IDT77105 is not set
CONFIG_ATM_IDT77252=m
# CONFIG_ATM_IDT77252_DEBUG is not set
# CONFIG_ATM_IDT77252_RCV_ALL is not set
@@ -3226,15 +3144,12 @@
CONFIG_ATM_IA=m
# CONFIG_ATM_IA_DEBUG is not set
CONFIG_ATM_FORE200E=m
-# CONFIG_ATM_FORE200E_USE_TASKLET is not set
+CONFIG_ATM_FORE200E_USE_TASKLET=y
CONFIG_ATM_FORE200E_TX_RETRY=16
CONFIG_ATM_FORE200E_DEBUG=0
CONFIG_ATM_HE=m
CONFIG_ATM_HE_USE_SUNI=y
CONFIG_ATM_SOLOS=m
-CONFIG_CAIF_DRIVERS=y
-CONFIG_CAIF_TTY=m
-CONFIG_CAIF_VIRTIO=m
# Distributed Switch Architecture drivers
@@ -3248,7 +3163,7 @@
CONFIG_NET_DSA_BCM_SF2=m
CONFIG_NET_DSA_LOOP=m
CONFIG_NET_DSA_HIRSCHMANN_HELLCREEK=m
-CONFIG_NET_DSA_LANTIQ_GSWIP=m
+# CONFIG_NET_DSA_LANTIQ_GSWIP is not set
CONFIG_NET_DSA_MT7530=m
CONFIG_NET_DSA_MT7530_MDIO=m
CONFIG_NET_DSA_MT7530_MMIO=m
@@ -3367,7 +3282,6 @@
CONFIG_CHELSIO_T4VF=m
CONFIG_CHELSIO_LIB=m
CONFIG_CHELSIO_INLINE_CRYPTO=y
-CONFIG_CRYPTO_DEV_CHELSIO_TLS=m
CONFIG_CHELSIO_IPSEC_INLINE=m
CONFIG_CHELSIO_TLS_DEVICE=m
CONFIG_NET_VENDOR_CISCO=y
@@ -3427,7 +3341,7 @@
CONFIG_IXGBE_HWMON=y
CONFIG_IXGBE_DCA=y
CONFIG_IXGBE_DCB=y
-CONFIG_IXGBE_IPSEC=y
+# CONFIG_IXGBE_IPSEC is not set
CONFIG_IXGBEVF=m
CONFIG_IXGBEVF_IPSEC=y
CONFIG_I40E=m
@@ -3477,7 +3391,8 @@
CONFIG_MLX5_EN_IPSEC=y
CONFIG_MLX5_EN_TLS=y
CONFIG_MLX5_SW_STEERING=y
-# CONFIG_MLX5_SF is not set
+CONFIG_MLX5_SF=y
+CONFIG_MLX5_SF_MANAGER=y
CONFIG_MLX5_DPLL=m
CONFIG_MLXSW_CORE=m
CONFIG_MLXSW_CORE_HWMON=y
@@ -3612,7 +3527,7 @@
CONFIG_NET_VENDOR_TEHUTI=y
CONFIG_TEHUTI=m
CONFIG_NET_VENDOR_TI=y
-CONFIG_TI_CPSW_PHY_SEL=y
+# CONFIG_TI_CPSW_PHY_SEL is not set
CONFIG_TLAN=m
CONFIG_NET_VENDOR_VERTEXCOM=y
CONFIG_MSE102X=m
@@ -3637,18 +3552,16 @@
CONFIG_XILINX_LL_TEMAC=m
CONFIG_NET_VENDOR_XIRCOM=y
CONFIG_PCMCIA_XIRC2PS=m
-CONFIG_FDDI=y
+CONFIG_FDDI=m
CONFIG_DEFXX=m
CONFIG_SKFP=m
-CONFIG_HIPPI=y
-CONFIG_ROADRUNNER=m
-# CONFIG_ROADRUNNER_LARGE_RINGS is not set
+# CONFIG_HIPPI is not set
CONFIG_NET_SB1000=m
CONFIG_PHYLINK=m
-CONFIG_PHYLIB=y
+CONFIG_PHYLIB=m
CONFIG_SWPHY=y
CONFIG_LED_TRIGGER_PHY=y
-CONFIG_FIXED_PHY=y
+CONFIG_FIXED_PHY=m
CONFIG_SFP=m
@@ -3662,9 +3575,10 @@
CONFIG_BROADCOM_PHY=m
CONFIG_BCM54140_PHY=m
CONFIG_BCM7XXX_PHY=m
-CONFIG_BCM84881_PHY=y
+CONFIG_BCM84881_PHY=m
CONFIG_BCM87XX_PHY=m
CONFIG_BCM_NET_PHYLIB=m
+CONFIG_BCM_NET_PHYPTP=m
CONFIG_CICADA_PHY=m
CONFIG_CORTINA_PHY=m
CONFIG_DAVICOM_PHY=m
@@ -3694,7 +3608,7 @@
CONFIG_QSEMI_PHY=m
CONFIG_REALTEK_PHY=m
CONFIG_RENESAS_PHY=m
-CONFIG_ROCKCHIP_PHY=m
+# CONFIG_ROCKCHIP_PHY is not set
CONFIG_SMSC_PHY=m
CONFIG_STE10XP=m
CONFIG_TERANETICS_PHY=m
@@ -3723,7 +3637,7 @@
CONFIG_CAN_C_CAN_PLATFORM=m
CONFIG_CAN_C_CAN_PCI=m
CONFIG_CAN_CC770=m
-CONFIG_CAN_CC770_ISA=m
+# CONFIG_CAN_CC770_ISA is not set
CONFIG_CAN_CC770_PLATFORM=m
CONFIG_CAN_CTUCANFD=m
CONFIG_CAN_CTUCANFD_PCI=m
@@ -3735,14 +3649,14 @@
CONFIG_CAN_PEAK_PCIEFD=m
CONFIG_CAN_SJA1000=m
CONFIG_CAN_EMS_PCI=m
-CONFIG_CAN_EMS_PCMCIA=m
+# CONFIG_CAN_EMS_PCMCIA is not set
CONFIG_CAN_F81601=m
CONFIG_CAN_KVASER_PCI=m
CONFIG_CAN_PEAK_PCI=m
CONFIG_CAN_PEAK_PCIEC=y
CONFIG_CAN_PEAK_PCMCIA=m
CONFIG_CAN_PLX_PCI=m
-CONFIG_CAN_SJA1000_ISA=m
+# CONFIG_CAN_SJA1000_ISA is not set
CONFIG_CAN_SJA1000_PLATFORM=m
CONFIG_CAN_SOFTING=m
CONFIG_CAN_SOFTING_CS=m
@@ -3778,14 +3692,13 @@
CONFIG_MCTP_SERIAL=m
CONFIG_MCTP_TRANSPORT_I2C=m
-CONFIG_MCTP_TRANSPORT_I3C=m
# end of MCTP Device Drivers
-CONFIG_MDIO_DEVICE=y
-CONFIG_MDIO_BUS=y
-CONFIG_FWNODE_MDIO=y
-CONFIG_ACPI_MDIO=y
-CONFIG_MDIO_DEVRES=y
+CONFIG_MDIO_DEVICE=m
+CONFIG_MDIO_BUS=m
+CONFIG_FWNODE_MDIO=m
+CONFIG_ACPI_MDIO=m
+CONFIG_MDIO_DEVRES=m
CONFIG_MDIO_BITBANG=m
CONFIG_MDIO_BCM_UNIMAC=m
CONFIG_MDIO_CAVIUM=m
@@ -3884,15 +3797,18 @@
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
CONFIG_ATH5K=m
-# CONFIG_ATH5K_DEBUG is not set
-# CONFIG_ATH5K_TRACER is not set
+CONFIG_ATH5K_DEBUG=y
+CONFIG_ATH5K_TRACER=y
CONFIG_ATH5K_PCI=y
CONFIG_ATH9K_HW=m
CONFIG_ATH9K_COMMON=m
+CONFIG_ATH9K_COMMON_DEBUG=y
CONFIG_ATH9K_BTCOEX_SUPPORT=y
CONFIG_ATH9K=m
CONFIG_ATH9K_PCI=y
CONFIG_ATH9K_AHB=y
+CONFIG_ATH9K_DEBUGFS=y
+CONFIG_ATH9K_STATION_STATISTICS=y
CONFIG_ATH9K_DYNACK=y
CONFIG_ATH9K_WOW=y
CONFIG_ATH9K_RFKILL=y
@@ -3900,40 +3816,45 @@
CONFIG_ATH9K_PCOEM=y
CONFIG_ATH9K_PCI_NO_EEPROM=m
CONFIG_ATH9K_HTC=m
-# CONFIG_ATH9K_HTC_DEBUGFS is not set
+CONFIG_ATH9K_HTC_DEBUGFS=y
CONFIG_ATH9K_HWRNG=y
+CONFIG_ATH9K_COMMON_SPECTRAL=y
CONFIG_CARL9170=m
CONFIG_CARL9170_LEDS=y
+CONFIG_CARL9170_DEBUGFS=y
CONFIG_CARL9170_WPC=y
# CONFIG_CARL9170_HWRNG is not set
CONFIG_ATH6KL=m
CONFIG_ATH6KL_SDIO=m
CONFIG_ATH6KL_USB=m
-# CONFIG_ATH6KL_DEBUG is not set
-# CONFIG_ATH6KL_TRACING is not set
+CONFIG_ATH6KL_DEBUG=y
+CONFIG_ATH6KL_TRACING=y
CONFIG_AR5523=m
CONFIG_WIL6210=m
CONFIG_WIL6210_ISR_COR=y
-# CONFIG_WIL6210_TRACING is not set
-# CONFIG_WIL6210_DEBUGFS is not set
+CONFIG_WIL6210_TRACING=y
+CONFIG_WIL6210_DEBUGFS=y
CONFIG_ATH10K=m
CONFIG_ATH10K_CE=y
CONFIG_ATH10K_PCI=m
CONFIG_ATH10K_SDIO=m
CONFIG_ATH10K_USB=m
-# CONFIG_ATH10K_DEBUG is not set
-# CONFIG_ATH10K_DEBUGFS is not set
-# CONFIG_ATH10K_TRACING is not set
+CONFIG_ATH10K_DEBUG=y
+CONFIG_ATH10K_DEBUGFS=y
+CONFIG_ATH10K_SPECTRAL=y
+CONFIG_ATH10K_TRACING=y
CONFIG_WCN36XX=m
-# CONFIG_WCN36XX_DEBUGFS is not set
+CONFIG_WCN36XX_DEBUGFS=y
CONFIG_ATH11K=m
CONFIG_ATH11K_AHB=m
CONFIG_ATH11K_PCI=m
-# CONFIG_ATH11K_DEBUG is not set
+CONFIG_ATH11K_DEBUG=y
+CONFIG_ATH11K_DEBUGFS=y
# CONFIG_ATH11K_TRACING is not set
+CONFIG_ATH11K_SPECTRAL=y
CONFIG_ATH12K=m
-# CONFIG_ATH12K_DEBUG is not set
-# CONFIG_ATH12K_TRACING is not set
+CONFIG_ATH12K_DEBUG=y
+CONFIG_ATH12K_TRACING=y
CONFIG_WLAN_VENDOR_ATMEL=y
CONFIG_ATMEL=m
CONFIG_PCI_ATMEL=m
@@ -3963,7 +3884,7 @@
CONFIG_B43LEGACY_PCICORE_AUTOSELECT=y
CONFIG_B43LEGACY_LEDS=y
CONFIG_B43LEGACY_HWRNG=y
-# CONFIG_B43LEGACY_DEBUG is not set
+CONFIG_B43LEGACY_DEBUG=y
CONFIG_B43LEGACY_DMA=y
CONFIG_B43LEGACY_PIO=y
CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y
@@ -3978,8 +3899,8 @@
CONFIG_BRCMFMAC_SDIO=y
CONFIG_BRCMFMAC_USB=y
CONFIG_BRCMFMAC_PCIE=y
-# CONFIG_BRCM_TRACING is not set
-# CONFIG_BRCMDBG is not set
+CONFIG_BRCM_TRACING=y
+CONFIG_BRCMDBG=y
CONFIG_WLAN_VENDOR_CISCO=y
CONFIG_AIRO=m
CONFIG_AIRO_CS=m
@@ -4002,7 +3923,8 @@
# iwl3945 / iwl4965 Debugging Options
-# CONFIG_IWLEGACY_DEBUG is not set
+CONFIG_IWLEGACY_DEBUG=y
+CONFIG_IWLEGACY_DEBUGFS=y
# end of iwl3945 / iwl4965 Debugging Options
CONFIG_IWLWIFI=m
@@ -4014,8 +3936,9 @@
# Debugging Options
-# CONFIG_IWLWIFI_DEBUG is not set
-# CONFIG_IWLWIFI_DEVICE_TRACING is not set
+CONFIG_IWLWIFI_DEBUG=y
+CONFIG_IWLWIFI_DEBUGFS=y
+CONFIG_IWLWIFI_DEVICE_TRACING=y
# end of Debugging Options
CONFIG_WLAN_VENDOR_INTERSIL=y
@@ -4124,6 +4047,7 @@
CONFIG_RT2X00_LIB_FIRMWARE=y
CONFIG_RT2X00_LIB_CRYPTO=y
CONFIG_RT2X00_LIB_LEDS=y
+CONFIG_RT2X00_LIB_DEBUGFS=y
# CONFIG_RT2X00_DEBUG is not set
CONFIG_WLAN_VENDOR_REALTEK=y
CONFIG_RTL8180=m
@@ -4142,7 +4066,7 @@
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_PCI=m
CONFIG_RTLWIFI_USB=m
-# CONFIG_RTLWIFI_DEBUG is not set
+CONFIG_RTLWIFI_DEBUG=y
CONFIG_RTL8192C_COMMON=m
CONFIG_RTL8723_COMMON=m
CONFIG_RTLBTCOEXIST=m
@@ -4169,8 +4093,8 @@
CONFIG_RTW88_8821CE=m
CONFIG_RTW88_8821CS=m
CONFIG_RTW88_8821CU=m
-# CONFIG_RTW88_DEBUG is not set
-# CONFIG_RTW88_DEBUGFS is not set
+CONFIG_RTW88_DEBUG=y
+CONFIG_RTW88_DEBUGFS=y
CONFIG_RTW89=m
CONFIG_RTW89_CORE=m
CONFIG_RTW89_PCI=m
@@ -4182,11 +4106,12 @@
CONFIG_RTW89_8852AE=m
CONFIG_RTW89_8852BE=m
CONFIG_RTW89_8852CE=m
-# CONFIG_RTW89_DEBUGMSG is not set
-# CONFIG_RTW89_DEBUGFS is not set
+CONFIG_RTW89_DEBUG=y
+CONFIG_RTW89_DEBUGMSG=y
+CONFIG_RTW89_DEBUGFS=y
CONFIG_WLAN_VENDOR_RSI=y
CONFIG_RSI_91X=m
-# CONFIG_RSI_DEBUGFS is not set
+CONFIG_RSI_DEBUGFS=y
CONFIG_RSI_SDIO=m
CONFIG_RSI_USB=m
CONFIG_RSI_COEX=y
@@ -4232,7 +4157,7 @@
# Wireless WAN
-CONFIG_WWAN=m
+CONFIG_WWAN=y
CONFIG_WWAN_DEBUGFS=y
CONFIG_WWAN_HWSIM=m
CONFIG_MHI_WWAN_CTRL=m
@@ -4242,7 +4167,7 @@
CONFIG_MTK_T7XX=m
# end of Wireless WAN
-CONFIG_XEN_NETDEV_FRONTEND=y
+CONFIG_XEN_NETDEV_FRONTEND=m
CONFIG_XEN_NETDEV_BACKEND=m
CONFIG_VMXNET3=m
CONFIG_FUJITSU_ES=m
@@ -4281,7 +4206,7 @@
CONFIG_INPUT_FF_MEMLESS=m
CONFIG_INPUT_SPARSEKMAP=m
CONFIG_INPUT_MATRIXKMAP=m
-CONFIG_INPUT_VIVALDIFMAP=y
+CONFIG_INPUT_VIVALDIFMAP=m
# Userland interfaces
@@ -4303,7 +4228,7 @@
CONFIG_KEYBOARD_ADP5588=m
CONFIG_KEYBOARD_ADP5589=m
CONFIG_KEYBOARD_APPLESPI=m
-CONFIG_KEYBOARD_ATKBD=y
+CONFIG_KEYBOARD_ATKBD=m
CONFIG_KEYBOARD_QT1050=m
CONFIG_KEYBOARD_QT1070=m
CONFIG_KEYBOARD_QT2160=m
@@ -4597,14 +4522,14 @@
# Hardware I/O ports
-CONFIG_SERIO=y
+CONFIG_SERIO=m
CONFIG_ARCH_MIGHT_HAVE_PC_SERIO=y
-CONFIG_SERIO_I8042=y
+CONFIG_SERIO_I8042=m
CONFIG_SERIO_SERPORT=m
CONFIG_SERIO_CT82C710=m
CONFIG_SERIO_PARKBD=m
CONFIG_SERIO_PCIPS2=m
-CONFIG_SERIO_LIBPS2=y
+CONFIG_SERIO_LIBPS2=m
CONFIG_SERIO_RAW=m
CONFIG_SERIO_ALTERA_PS2=m
CONFIG_SERIO_PS2MULT=m
@@ -4630,7 +4555,7 @@
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
# CONFIG_LEGACY_PTYS is not set
-CONFIG_LEGACY_TIOCSTI=y
+# CONFIG_LEGACY_TIOCSTI is not set
CONFIG_LDISC_AUTOLOAD=y
@@ -4640,7 +4565,7 @@
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set
CONFIG_SERIAL_8250_PNP=y
-CONFIG_SERIAL_8250_16550A_VARIANTS=y
+# CONFIG_SERIAL_8250_16550A_VARIANTS is not set
CONFIG_SERIAL_8250_FINTEK=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
@@ -4650,7 +4575,7 @@
CONFIG_SERIAL_8250_CS=m
CONFIG_SERIAL_8250_MEN_MCB=m
CONFIG_SERIAL_8250_NR_UARTS=32
-CONFIG_SERIAL_8250_RUNTIME_UARTS=4
+CONFIG_SERIAL_8250_RUNTIME_UARTS=32
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_PCI1XXXX=m
@@ -4663,19 +4588,19 @@
CONFIG_SERIAL_8250_RT288X=y
CONFIG_SERIAL_8250_LPSS=y
CONFIG_SERIAL_8250_MID=y
-CONFIG_SERIAL_8250_PERICOM=m
+CONFIG_SERIAL_8250_PERICOM=y
# Non-8250 serial port support
CONFIG_SERIAL_MAX3100=m
-CONFIG_SERIAL_MAX310X=y
+CONFIG_SERIAL_MAX310X=m
CONFIG_SERIAL_UARTLITE=m
CONFIG_SERIAL_UARTLITE_NR_UARTS=1
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_JSM=m
-CONFIG_SERIAL_LANTIQ=m
+# CONFIG_SERIAL_LANTIQ is not set
CONFIG_SERIAL_SCCNXP=m
CONFIG_SERIAL_SC16IS7XX_CORE=m
CONFIG_SERIAL_SC16IS7XX=m
@@ -4709,7 +4634,8 @@
CONFIG_HVC_XEN=y
CONFIG_HVC_XEN_FRONTEND=y
CONFIG_RPMSG_TTY=m
-CONFIG_SERIAL_DEV_BUS=m
+CONFIG_SERIAL_DEV_BUS=y
+CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
CONFIG_PRINTER=m
CONFIG_LP_CONSOLE=y
CONFIG_PPDEV=m
@@ -4726,7 +4652,7 @@
CONFIG_IPMI_POWEROFF=m
CONFIG_SSIF_IPMI_BMC=m
CONFIG_IPMB_DEVICE_INTERFACE=m
-CONFIG_HW_RANDOM=m
+CONFIG_HW_RANDOM=y
CONFIG_HW_RANDOM_TIMERIOMEM=m
CONFIG_HW_RANDOM_INTEL=m
CONFIG_HW_RANDOM_AMD=m
@@ -4737,15 +4663,15 @@
CONFIG_APPLICOM=m
CONFIG_MWAVE=m
CONFIG_DEVMEM=y
-CONFIG_NVRAM=m
+CONFIG_NVRAM=y
CONFIG_DEVPORT=y
CONFIG_HPET=y
# CONFIG_HPET_MMAP is not set
CONFIG_HANGCHECK_TIMER=m
-CONFIG_TCG_TPM=m
+CONFIG_TCG_TPM=y
CONFIG_HW_RANDOM_TPM=y
-CONFIG_TCG_TIS_CORE=m
-CONFIG_TCG_TIS=m
+CONFIG_TCG_TIS_CORE=y
+CONFIG_TCG_TIS=y
CONFIG_TCG_TIS_SPI=m
CONFIG_TCG_TIS_SPI_CR50=y
CONFIG_TCG_TIS_I2C=m
@@ -4757,7 +4683,7 @@
CONFIG_TCG_ATMEL=m
CONFIG_TCG_INFINEON=m
CONFIG_TCG_XEN=m
-CONFIG_TCG_CRB=m
+CONFIG_TCG_CRB=y
CONFIG_TCG_VTPM_PROXY=m
CONFIG_TCG_TIS_ST33ZP24=m
CONFIG_TCG_TIS_ST33ZP24_I2C=m
@@ -4802,7 +4728,7 @@
# PC SMBus host controller drivers
-CONFIG_I2C_CCGX_UCSI=m
+CONFIG_I2C_CCGX_UCSI=y
CONFIG_I2C_ALI1535=m
CONFIG_I2C_ALI1563=m
CONFIG_I2C_ALI15X3=m
@@ -4814,7 +4740,7 @@
CONFIG_I2C_ISCH=m
CONFIG_I2C_ISMT=m
CONFIG_I2C_PIIX4=m
-CONFIG_I2C_NCT6775=m
+CONFIG_I2C_CHT_WC=m
CONFIG_I2C_NFORCE2=m
CONFIG_I2C_NFORCE2_S4985=m
CONFIG_I2C_NVIDIA_GPU=m
@@ -4833,12 +4759,11 @@
# I2C system bus drivers (mostly embedded / system-on-chip)
CONFIG_I2C_CBUS_GPIO=m
-CONFIG_I2C_DESIGNWARE_CORE=m
+CONFIG_I2C_DESIGNWARE_CORE=y
CONFIG_I2C_DESIGNWARE_SLAVE=y
-CONFIG_I2C_DESIGNWARE_PLATFORM=m
-CONFIG_I2C_DESIGNWARE_AMDPSP=y
+CONFIG_I2C_DESIGNWARE_PLATFORM=y
CONFIG_I2C_DESIGNWARE_BAYTRAIL=y
-CONFIG_I2C_DESIGNWARE_PCI=m
+CONFIG_I2C_DESIGNWARE_PCI=y
CONFIG_I2C_EMEV2=m
CONFIG_I2C_GPIO=m
# CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
@@ -4879,11 +4804,7 @@
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
-CONFIG_I3C=m
-CONFIG_CDNS_I3C_MASTER=m
-CONFIG_DW_I3C_MASTER=m
-CONFIG_SVC_I3C_MASTER=m
-CONFIG_MIPI_I3C_HCI=m
+# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
@@ -4900,7 +4821,7 @@
CONFIG_SPI_BUTTERFLY=m
CONFIG_SPI_CADENCE=m
CONFIG_SPI_CS42L43=m
-CONFIG_SPI_DESIGNWARE=y
+CONFIG_SPI_DESIGNWARE=m
CONFIG_SPI_DW_DMA=y
CONFIG_SPI_DW_PCI=m
CONFIG_SPI_DW_MMIO=m
@@ -4913,7 +4834,7 @@
CONFIG_SPI_LJCA=m
CONFIG_SPI_MICROCHIP_CORE=m
CONFIG_SPI_MICROCHIP_CORE_QSPI=m
-CONFIG_SPI_LANTIQ_SSC=m
+# CONFIG_SPI_LANTIQ_SSC is not set
CONFIG_SPI_OC_TINY=m
CONFIG_SPI_PCI1XXXX=m
CONFIG_SPI_PXA2XX=m
@@ -4941,27 +4862,16 @@
CONFIG_SPI_SLAVE_TIME=m
CONFIG_SPI_SLAVE_SYSTEM_CONTROL=m
CONFIG_SPI_DYNAMIC=y
-CONFIG_SPMI=m
-CONFIG_SPMI_HISI3670=m
-CONFIG_HSI=m
-CONFIG_HSI_BOARDINFO=y
-# HSI controllers
-# HSI clients
-CONFIG_HSI_CHAR=m
+# CONFIG_SPMI is not set
+# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
-# CONFIG_PPS_CLIENT_KTIMER is not set
-# CONFIG_PPS_CLIENT_LDISC is not set
+CONFIG_PPS_CLIENT_KTIMER=m
+CONFIG_PPS_CLIENT_LDISC=m
CONFIG_PPS_CLIENT_PARPORT=m
CONFIG_PPS_CLIENT_GPIO=m
@@ -4974,10 +4884,8 @@
CONFIG_PTP_1588_CLOCK=y
CONFIG_PTP_1588_CLOCK_OPTIONAL=y
-# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
+CONFIG_DP83640_PHY=m
+CONFIG_PTP_1588_CLOCK_INES=m
CONFIG_PTP_1588_CLOCK_KVM=m
CONFIG_PTP_1588_CLOCK_IDT82P33=m
CONFIG_PTP_1588_CLOCK_IDTCM=m
@@ -5011,24 +4919,24 @@
# Intel pinctrl drivers
CONFIG_PINCTRL_BAYTRAIL=y
-CONFIG_PINCTRL_CHERRYVIEW=m
-CONFIG_PINCTRL_LYNXPOINT=m
+CONFIG_PINCTRL_CHERRYVIEW=y
+CONFIG_PINCTRL_LYNXPOINT=y
CONFIG_PINCTRL_INTEL=y
-CONFIG_PINCTRL_ALDERLAKE=m
-CONFIG_PINCTRL_BROXTON=m
-CONFIG_PINCTRL_CANNONLAKE=m
-CONFIG_PINCTRL_CEDARFORK=m
-CONFIG_PINCTRL_DENVERTON=m
-CONFIG_PINCTRL_ELKHARTLAKE=m
-CONFIG_PINCTRL_EMMITSBURG=m
-CONFIG_PINCTRL_GEMINILAKE=m
-CONFIG_PINCTRL_ICELAKE=m
-CONFIG_PINCTRL_JASPERLAKE=m
-CONFIG_PINCTRL_LAKEFIELD=m
-CONFIG_PINCTRL_LEWISBURG=m
-CONFIG_PINCTRL_METEORLAKE=m
-CONFIG_PINCTRL_SUNRISEPOINT=m
-CONFIG_PINCTRL_TIGERLAKE=m
+CONFIG_PINCTRL_ALDERLAKE=y
+CONFIG_PINCTRL_BROXTON=y
+CONFIG_PINCTRL_CANNONLAKE=y
+CONFIG_PINCTRL_CEDARFORK=y
+CONFIG_PINCTRL_DENVERTON=y
+CONFIG_PINCTRL_ELKHARTLAKE=y
+CONFIG_PINCTRL_EMMITSBURG=y
+CONFIG_PINCTRL_GEMINILAKE=y
+CONFIG_PINCTRL_ICELAKE=y
+CONFIG_PINCTRL_JASPERLAKE=y
+CONFIG_PINCTRL_LAKEFIELD=y
+CONFIG_PINCTRL_LEWISBURG=y
+CONFIG_PINCTRL_METEORLAKE=y
+CONFIG_PINCTRL_SUNRISEPOINT=y
+CONFIG_PINCTRL_TIGERLAKE=y
# end of Intel pinctrl drivers
@@ -5095,6 +5003,7 @@
CONFIG_GPIO_ADP5520=m
CONFIG_GPIO_ARIZONA=m
CONFIG_GPIO_BD9571MWV=m
+CONFIG_GPIO_CRYSTAL_COVE=m
CONFIG_GPIO_DA9052=m
CONFIG_GPIO_DA9055=m
CONFIG_GPIO_DLN2=m
@@ -5177,7 +5086,7 @@
CONFIG_W1_SLAVE_SMEM=m
CONFIG_W1_SLAVE_DS2405=m
CONFIG_W1_SLAVE_DS2408=m
-CONFIG_W1_SLAVE_DS2408_READBACK=y
+# CONFIG_W1_SLAVE_DS2408_READBACK is not set
CONFIG_W1_SLAVE_DS2413=m
CONFIG_W1_SLAVE_DS2406=m
CONFIG_W1_SLAVE_DS2423=m
@@ -5197,7 +5106,7 @@
CONFIG_POWER_RESET=y
CONFIG_POWER_RESET_ATC260X=m
CONFIG_POWER_RESET_MT6323=y
-# CONFIG_POWER_RESET_RESTART is not set
+CONFIG_POWER_RESET_RESTART=y
CONFIG_POWER_RESET_TPS65086=y
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
@@ -5216,14 +5125,14 @@
CONFIG_BATTERY_DS2780=m
CONFIG_BATTERY_DS2781=m
CONFIG_BATTERY_DS2782=m
-CONFIG_BATTERY_SAMSUNG_SDI=y
+# CONFIG_BATTERY_SAMSUNG_SDI is not set
CONFIG_BATTERY_SBS=m
CONFIG_CHARGER_SBS=m
CONFIG_MANAGER_SBS=m
CONFIG_BATTERY_BQ27XXX=m
CONFIG_BATTERY_BQ27XXX_I2C=m
CONFIG_BATTERY_BQ27XXX_HDQ=m
-CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM=y
+# CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set
CONFIG_BATTERY_DA9030=m
CONFIG_BATTERY_DA9052=m
CONFIG_CHARGER_DA9150=m
@@ -5420,9 +5329,6 @@
CONFIG_SENSORS_OCC=m
CONFIG_SENSORS_OXP=m
CONFIG_SENSORS_PCF8591=m
-CONFIG_SENSORS_PECI_CPUTEMP=m
-CONFIG_SENSORS_PECI_DIMMTEMP=m
-CONFIG_SENSORS_PECI=m
CONFIG_PMBUS=m
CONFIG_SENSORS_PMBUS=m
CONFIG_SENSORS_ACBEL_FSG032=m
@@ -5445,7 +5351,7 @@
CONFIG_SENSORS_LM25066_REGULATOR=y
CONFIG_SENSORS_LT7182S=m
CONFIG_SENSORS_LTC2978=m
-CONFIG_SENSORS_LTC2978_REGULATOR=y
+# CONFIG_SENSORS_LTC2978_REGULATOR is not set
CONFIG_SENSORS_LTC3815=m
CONFIG_SENSORS_MAX15301=m
CONFIG_SENSORS_MAX16064=m
@@ -5527,7 +5433,7 @@
CONFIG_SENSORS_W83792D=m
CONFIG_SENSORS_W83793=m
CONFIG_SENSORS_W83795=m
-CONFIG_SENSORS_W83795_FANCTRL=y
+# CONFIG_SENSORS_W83795_FANCTRL is not set
CONFIG_SENSORS_W83L785TS=m
CONFIG_SENSORS_W83L786NG=m
CONFIG_SENSORS_W83627HF=m
@@ -5547,8 +5453,8 @@
CONFIG_SENSORS_HP_WMI=m
CONFIG_THERMAL=y
CONFIG_THERMAL_NETLINK=y
-CONFIG_THERMAL_STATISTICS=y
-CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
+# CONFIG_THERMAL_STATISTICS is not set
+CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=100
CONFIG_THERMAL_HWMON=y
CONFIG_THERMAL_ACPI=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
@@ -5563,7 +5469,7 @@
CONFIG_THERMAL_GOV_USER_SPACE=y
CONFIG_THERMAL_GOV_POWER_ALLOCATOR=y
CONFIG_DEVFREQ_THERMAL=y
-CONFIG_THERMAL_EMULATION=y
+# CONFIG_THERMAL_EMULATION is not set
# Intel thermal drivers
@@ -5596,7 +5502,7 @@
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
-# CONFIG_WATCHDOG_SYSFS is not set
+CONFIG_WATCHDOG_SYSFS=y
# CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set
@@ -5705,9 +5611,8 @@
CONFIG_BCMA_BLOCKIO=y
CONFIG_BCMA_HOST_PCI_POSSIBLE=y
CONFIG_BCMA_HOST_PCI=y
-CONFIG_BCMA_HOST_SOC=y
+# CONFIG_BCMA_HOST_SOC is not set
CONFIG_BCMA_DRIVER_PCI=y
-CONFIG_BCMA_SFLASH=y
CONFIG_BCMA_DRIVER_GMAC_CMN=y
CONFIG_BCMA_DRIVER_GPIO=y
# CONFIG_BCMA_DEBUG is not set
@@ -5752,7 +5657,10 @@
CONFIG_MFD_INTEL_QUARK_I2C_GPIO=m
CONFIG_LPC_ICH=m
CONFIG_LPC_SCH=m
+CONFIG_INTEL_SOC_PMIC=y
CONFIG_INTEL_SOC_PMIC_BXTWC=m
+CONFIG_INTEL_SOC_PMIC_CHTWC=y
+CONFIG_INTEL_SOC_PMIC_CHTDC_TI=m
CONFIG_INTEL_SOC_PMIC_MRFLD=m
CONFIG_MFD_INTEL_LPSS=m
CONFIG_MFD_INTEL_LPSS_ACPI=m
@@ -5808,9 +5716,9 @@
CONFIG_MFD_TI_LP873X=m
CONFIG_MFD_TPS6586X=y
CONFIG_MFD_TPS65910=y
-CONFIG_MFD_TPS65912=y
+CONFIG_MFD_TPS65912=m
CONFIG_MFD_TPS65912_I2C=m
-CONFIG_MFD_TPS65912_SPI=y
+CONFIG_MFD_TPS65912_SPI=m
CONFIG_MFD_TPS6594=m
CONFIG_MFD_TPS6594_I2C=m
CONFIG_MFD_TPS6594_SPI=m
@@ -5904,7 +5812,6 @@
CONFIG_REGULATOR_MC13892=m
CONFIG_REGULATOR_MP8859=m
CONFIG_REGULATOR_MT6311=m
-CONFIG_REGULATOR_MT6315=m
CONFIG_REGULATOR_MT6323=m
CONFIG_REGULATOR_MT6331=m
CONFIG_REGULATOR_MT6332=m
@@ -5922,8 +5829,6 @@
CONFIG_REGULATOR_PV88080=m
CONFIG_REGULATOR_PV88090=m
CONFIG_REGULATOR_PWM=m
-CONFIG_REGULATOR_QCOM_SPMI=m
-CONFIG_REGULATOR_QCOM_USB_VBUS=m
CONFIG_REGULATOR_RAA215300=m
CONFIG_REGULATOR_RC5T583=m
CONFIG_REGULATOR_RT4801=m
@@ -5962,8 +5867,8 @@
CONFIG_REGULATOR_WM8350=m
CONFIG_REGULATOR_WM8400=m
CONFIG_REGULATOR_WM8994=m
-CONFIG_REGULATOR_QCOM_LABIBB=m
-CONFIG_RC_CORE=m
+CONFIG_RC_CORE=y
+CONFIG_BPF_LIRC_MODE2=y
CONFIG_LIRC=y
CONFIG_RC_MAP=m
CONFIG_RC_DECODERS=y
@@ -6006,7 +5911,7 @@
# CEC support
CONFIG_MEDIA_CEC_RC=y
-CONFIG_CEC_PIN_ERROR_INJ=y
+# CONFIG_CEC_PIN_ERROR_INJ is not set
CONFIG_MEDIA_CEC_SUPPORT=y
CONFIG_CEC_CH7322=m
CONFIG_CEC_CROS_EC=m
@@ -6028,9 +5933,9 @@
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_RADIO_SUPPORT=y
-CONFIG_MEDIA_SDR_SUPPORT=y
+# CONFIG_MEDIA_SDR_SUPPORT is not set
CONFIG_MEDIA_PLATFORM_SUPPORT=y
-# CONFIG_MEDIA_TEST_SUPPORT is not set
+CONFIG_MEDIA_TEST_SUPPORT=y
# end of Media device types
CONFIG_VIDEO_DEV=m
@@ -6057,6 +5962,7 @@
# Media controller options
CONFIG_MEDIA_CONTROLLER_DVB=y
+CONFIG_MEDIA_CONTROLLER_REQUEST_API=y
# end of Media controller options
@@ -6064,7 +5970,7 @@
CONFIG_DVB_MMAP=y
CONFIG_DVB_NET=y
-CONFIG_DVB_MAX_ADAPTERS=8
+CONFIG_DVB_MAX_ADAPTERS=16
CONFIG_DVB_DYNAMIC_MINORS=y
# CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
# CONFIG_DVB_ULE_DEBUG is not set
@@ -6229,13 +6135,6 @@
CONFIG_VIDEO_EM28XX_ALSA=m
CONFIG_VIDEO_EM28XX_DVB=m
CONFIG_VIDEO_EM28XX_RC=m
-# Software defined radio USB devices
-CONFIG_USB_AIRSPY=m
-CONFIG_USB_HACKRF=m
-CONFIG_USB_MSI2500=m
CONFIG_MEDIA_PCI_SUPPORT=y
@@ -6246,14 +6145,7 @@
CONFIG_VIDEO_TW5864=m
CONFIG_VIDEO_TW68=m
CONFIG_VIDEO_TW686X=m
-CONFIG_VIDEO_ZORAN=m
-CONFIG_VIDEO_ZORAN_DC30=y
-CONFIG_VIDEO_ZORAN_ZR36060=y
-CONFIG_VIDEO_ZORAN_BUZ=y
-CONFIG_VIDEO_ZORAN_DC10=y
-CONFIG_VIDEO_ZORAN_LML33=y
-CONFIG_VIDEO_ZORAN_LML33R10=y
-CONFIG_VIDEO_ZORAN_AVS6EYES=y
+# CONFIG_VIDEO_ZORAN is not set
# Media capture/analog TV support
@@ -6261,8 +6153,7 @@
CONFIG_VIDEO_DT3155=m
CONFIG_VIDEO_IVTV=m
CONFIG_VIDEO_IVTV_ALSA=m
-CONFIG_VIDEO_FB_IVTV=m
-# CONFIG_VIDEO_FB_IVTV_FORCE_PAT is not set
+# CONFIG_VIDEO_FB_IVTV is not set
CONFIG_VIDEO_HEXIUM_GEMINI=m
CONFIG_VIDEO_HEXIUM_ORION=m
CONFIG_VIDEO_MXB=m
@@ -6272,7 +6163,6 @@
CONFIG_VIDEO_BT848=m
CONFIG_DVB_BT8XX=m
-CONFIG_VIDEO_COBALT=m
CONFIG_VIDEO_CX18=m
CONFIG_VIDEO_CX18_ALSA=m
CONFIG_VIDEO_CX23885=m
@@ -6299,7 +6189,7 @@
CONFIG_DVB_B2C2_FLEXCOP_PCI=m
# CONFIG_DVB_B2C2_FLEXCOP_PCI_DEBUG is not set
CONFIG_DVB_DDBRIDGE=m
-CONFIG_DVB_DDBRIDGE_MSIENABLE=y
+# CONFIG_DVB_DDBRIDGE_MSIENABLE is not set
CONFIG_DVB_DM1105=m
CONFIG_MANTIS_CORE=m
CONFIG_DVB_MANTIS=m
@@ -6342,7 +6232,6 @@
CONFIG_RADIO_WL128X=m
CONFIG_MEDIA_PLATFORM_DRIVERS=y
CONFIG_V4L_PLATFORM_DRIVERS=y
-CONFIG_SDR_PLATFORM_DRIVERS=y
CONFIG_DVB_PLATFORM_DRIVERS=y
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_VIDEO_MEM2MEM_DEINTERLACE=m
@@ -6450,6 +6339,17 @@
# MMC/SDIO DVB adapters
CONFIG_SMS_SDIO_DRV=m
+CONFIG_V4L_TEST_DRIVERS=y
+CONFIG_VIDEO_VIM2M=m
+CONFIG_VIDEO_VICODEC=m
+CONFIG_VIDEO_VIMC=m
+CONFIG_VIDEO_VIVID=m
+CONFIG_VIDEO_VIVID_CEC=y
+CONFIG_VIDEO_VIVID_MAX_DEVS=64
+CONFIG_VIDEO_VISL=m
+# CONFIG_VISL_DEBUGFS is not set
+CONFIG_DVB_TEST_DRIVERS=y
+CONFIG_DVB_VIDTV=m
# FireWire (IEEE 1394) Adapters
@@ -6472,6 +6372,7 @@
CONFIG_SMS_SIANO_MDTV=m
CONFIG_SMS_SIANO_RC=y
# CONFIG_SMS_SIANO_DEBUGFS is not set
+CONFIG_VIDEO_V4L2_TPG=m
CONFIG_VIDEOBUF2_CORE=m
CONFIG_VIDEOBUF2_V4L2=m
CONFIG_VIDEOBUF2_MEMOPS=m
@@ -6594,30 +6495,18 @@
CONFIG_VIDEO_WM8739=m
CONFIG_VIDEO_WM8775=m
CONFIG_VIDEO_SAA6588=m
-CONFIG_VIDEO_ADV7604=m
-CONFIG_VIDEO_ADV7842=m
-CONFIG_VIDEO_BT819=m
-CONFIG_VIDEO_BT856=m
-CONFIG_VIDEO_BT866=m
-CONFIG_VIDEO_KS0127=m
-CONFIG_VIDEO_SAA7110=m
CONFIG_VIDEO_SAA711X=m
CONFIG_VIDEO_TVP5150=m
CONFIG_VIDEO_TW2804=m
CONFIG_VIDEO_TW9903=m
CONFIG_VIDEO_TW9906=m
-CONFIG_VIDEO_VPX3220=m
# Video and audio decoders
CONFIG_VIDEO_SAA717X=m
CONFIG_VIDEO_CX25840=m
-CONFIG_VIDEO_ADV7170=m
-CONFIG_VIDEO_ADV7175=m
-CONFIG_VIDEO_ADV7511=m
CONFIG_VIDEO_SAA7127=m
-CONFIG_VIDEO_SAA7185=m
CONFIG_VIDEO_UPD64031A=m
CONFIG_VIDEO_UPD64083=m
CONFIG_VIDEO_SAA6752HS=m
@@ -6653,7 +6542,6 @@
CONFIG_MEDIA_TUNER_M88RS6000T=m
CONFIG_MEDIA_TUNER_MAX2165=m
CONFIG_MEDIA_TUNER_MC44S803=m
-CONFIG_MEDIA_TUNER_MSI001=m
CONFIG_MEDIA_TUNER_MT2060=m
CONFIG_MEDIA_TUNER_MT2063=m
CONFIG_MEDIA_TUNER_MT20XX=m
@@ -6759,7 +6647,6 @@
CONFIG_DVB_NXT6000=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
-CONFIG_DVB_RTL2832_SDR=m
CONFIG_DVB_SI2168=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_STV0367=m
@@ -6839,6 +6726,11 @@
CONFIG_DVB_CXD2099=m
CONFIG_DVB_SP2=m
+# Tools to develop new frontends
+CONFIG_DVB_DUMMY_FE=m
# end of Media ancillary drivers
@@ -6847,40 +6739,22 @@
CONFIG_APERTURE_HELPERS=y
CONFIG_VIDEO_CMDLINE=y
CONFIG_VIDEO_NOMODESET=y
-CONFIG_AUXDISPLAY=y
-CONFIG_CHARLCD=m
-CONFIG_LINEDISP=m
-CONFIG_HD44780_COMMON=m
-CONFIG_HD44780=m
-CONFIG_KS0108=m
-CONFIG_KS0108_PORT=0x378
-CONFIG_KS0108_DELAY=2
-CONFIG_CFAG12864B=m
-CONFIG_CFAG12864B_RATE=20
-CONFIG_IMG_ASCII_LCD=m
-CONFIG_HT16K33=m
-CONFIG_LCD2S=m
-CONFIG_PARPORT_PANEL=m
-CONFIG_PANEL_PARPORT=0
-CONFIG_PANEL_PROFILE=5
-# CONFIG_PANEL_CHANGE_MESSAGE is not set
-# CONFIG_CHARLCD_BL_OFF is not set
-# CONFIG_CHARLCD_BL_ON is not set
-CONFIG_CHARLCD_BL_FLASH=y
-CONFIG_PANEL=m
-CONFIG_AGP=m
+# CONFIG_AUXDISPLAY is not set
+# CONFIG_PANEL is not set
+CONFIG_AGP=y
CONFIG_AGP_AMD64=m
CONFIG_AGP_INTEL=m
CONFIG_AGP_SIS=m
CONFIG_AGP_VIA=m
CONFIG_INTEL_GTT=m
CONFIG_VGA_SWITCHEROO=y
-CONFIG_DRM=m
+CONFIG_DRM=y
CONFIG_DRM_MIPI_DBI=m
CONFIG_DRM_MIPI_DSI=y
-CONFIG_DRM_KMS_HELPER=m
+# CONFIG_DRM_DEBUG_MM is not set
+CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
-CONFIG_DRM_FBDEV_OVERALLOC=300
+CONFIG_DRM_FBDEV_OVERALLOC=100
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
CONFIG_DRM_DISPLAY_HELPER=m
CONFIG_DRM_DISPLAY_DP_HELPER=y
@@ -6895,7 +6769,7 @@
CONFIG_DRM_VRAM_HELPER=m
CONFIG_DRM_TTM_HELPER=m
CONFIG_DRM_GEM_DMA_HELPER=m
-CONFIG_DRM_GEM_SHMEM_HELPER=m
+CONFIG_DRM_GEM_SHMEM_HELPER=y
CONFIG_DRM_SUBALLOC_HELPER=m
CONFIG_DRM_SCHED=m
@@ -6936,12 +6810,14 @@
# end of Display Engine Configuration
CONFIG_HSA_AMD=y
+CONFIG_HSA_AMD_SVM=y
CONFIG_DRM_NOUVEAU=m
CONFIG_NOUVEAU_DEBUG=5
CONFIG_NOUVEAU_DEBUG_DEFAULT=3
# CONFIG_NOUVEAU_DEBUG_MMU is not set
# CONFIG_NOUVEAU_DEBUG_PUSH is not set
CONFIG_DRM_NOUVEAU_BACKLIGHT=y
+CONFIG_DRM_NOUVEAU_SVM=y
CONFIG_DRM_I915=m
CONFIG_DRM_I915_FORCE_PROBE="*"
CONFIG_DRM_I915_CAPTURE_ERROR=y
@@ -6997,7 +6873,7 @@
CONFIG_DRM_CIRRUS_QEMU=m
CONFIG_DRM_GM12U320=m
CONFIG_DRM_PANEL_MIPI_DBI=m
-# CONFIG_DRM_SIMPLEDRM is not set
+CONFIG_DRM_SIMPLEDRM=y
CONFIG_TINYDRM_HX8357D=m
CONFIG_TINYDRM_ILI9163=m
CONFIG_TINYDRM_ILI9225=m
@@ -7063,11 +6939,10 @@
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
-# CONFIG_XEN_FBDEV_FRONTEND is not set
+CONFIG_XEN_FBDEV_FRONTEND=m
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX is not set
# CONFIG_FB_HYPERV is not set
-# CONFIG_FB_SIMPLE is not set
# CONFIG_FB_SSD1307 is not set
# CONFIG_FB_SM712 is not set
CONFIG_FB_CORE=y
@@ -7088,8 +6963,7 @@
CONFIG_FB_IOMEM_HELPERS=y
CONFIG_FB_SYSMEM_HELPERS=y
CONFIG_FB_SYSMEM_HELPERS_DEFERRED=y
-CONFIG_FB_BACKLIGHT=m
-CONFIG_FB_MODE_HELPERS=y
+# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# end of Frame buffer Devices
@@ -7157,7 +7031,7 @@
# CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION is not set
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
-# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
+CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER=y
# end of Console display driver support
# CONFIG_LOGO is not set
@@ -7195,10 +7069,14 @@
# CONFIG_SND_SUPPORT_OLD_API is not set
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
-# CONFIG_SND_VERBOSE_PRINTK is not set
+CONFIG_SND_VERBOSE_PRINTK=y
CONFIG_SND_CTL_FAST_LOOKUP=y
-# CONFIG_SND_DEBUG is not set
+CONFIG_SND_DEBUG=y
+# CONFIG_SND_DEBUG_VERBOSE is not set
+# CONFIG_SND_PCM_XRUN_DEBUG is not set
CONFIG_SND_CTL_INPUT_VALIDATION=y
+# CONFIG_SND_CTL_DEBUG is not set
+# CONFIG_SND_JACK_INJECTION_DEBUG is not set
CONFIG_SND_VMASTER=y
CONFIG_SND_DMA_SGBUF=y
CONFIG_SND_CTL_LED=m
@@ -7229,7 +7107,7 @@
CONFIG_SND_MPU401=m
CONFIG_SND_PORTMAN2X4=m
CONFIG_SND_AC97_POWER_SAVE=y
-CONFIG_SND_AC97_POWER_SAVE_DEFAULT=0
+CONFIG_SND_AC97_POWER_SAVE_DEFAULT=10
CONFIG_SND_SB_COMMON=m
CONFIG_SND_PCI=y
CONFIG_SND_AD1889=m
@@ -7313,7 +7191,8 @@
CONFIG_SND_HDA_INTEL=m
CONFIG_SND_HDA_HWDEP=y
CONFIG_SND_HDA_RECONFIG=y
-# CONFIG_SND_HDA_INPUT_BEEP is not set
+CONFIG_SND_HDA_INPUT_BEEP=y
+CONFIG_SND_HDA_INPUT_BEEP_MODE=0
CONFIG_SND_HDA_PATCH_LOADER=y
CONFIG_SND_HDA_CIRRUS_SCODEC=m
CONFIG_SND_HDA_SCODEC_CS35L41=m
@@ -7338,7 +7217,7 @@
CONFIG_SND_HDA_CODEC_CMEDIA=m
CONFIG_SND_HDA_CODEC_SI3054=m
CONFIG_SND_HDA_GENERIC=m
-CONFIG_SND_HDA_POWER_SAVE_DEFAULT=0
+CONFIG_SND_HDA_POWER_SAVE_DEFAULT=10
CONFIG_SND_HDA_INTEL_HDMI_SILENT_STREAM=y
# CONFIG_SND_HDA_CTL_DEV_ID is not set
# end of HD-Audio
@@ -7352,7 +7231,7 @@
CONFIG_SND_INTEL_NHLT=y
CONFIG_SND_INTEL_DSP_CONFIG=m
CONFIG_SND_INTEL_SOUNDWIRE_ACPI=m
-CONFIG_SND_INTEL_BYT_PREFER_SOF=y
+# CONFIG_SND_INTEL_BYT_PREFER_SOF is not set
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
@@ -7423,7 +7302,7 @@
CONFIG_SND_SOC_AMD_PS=m
CONFIG_SND_SOC_AMD_PS_MACH=m
CONFIG_SND_ATMEL_SOC=m
-CONFIG_SND_BCM63XX_I2S_WHISTLER=m
+# CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
CONFIG_SND_DESIGNWARE_I2S=m
CONFIG_SND_DESIGNWARE_PCM=y
@@ -7434,19 +7313,16 @@
# Common SoC Audio options for Freescale CPUs:
-CONFIG_SND_SOC_FSL_ASRC=m
-CONFIG_SND_SOC_FSL_SAI=m
-CONFIG_SND_SOC_FSL_MQS=m
-CONFIG_SND_SOC_FSL_AUDMIX=m
-CONFIG_SND_SOC_FSL_SSI=m
-CONFIG_SND_SOC_FSL_SPDIF=m
-CONFIG_SND_SOC_FSL_ESAI=m
-CONFIG_SND_SOC_FSL_MICFIL=m
-CONFIG_SND_SOC_FSL_EASRC=m
+# CONFIG_SND_SOC_FSL_ASRC is not set
+# CONFIG_SND_SOC_FSL_SAI is not set
+# CONFIG_SND_SOC_FSL_AUDMIX is not set
+# CONFIG_SND_SOC_FSL_SSI is not set
+# CONFIG_SND_SOC_FSL_SPDIF is not set
+# CONFIG_SND_SOC_FSL_ESAI is not set
+# CONFIG_SND_SOC_FSL_MICFIL is not set
CONFIG_SND_SOC_FSL_XCVR=m
-CONFIG_SND_SOC_FSL_UTILS=m
CONFIG_SND_SOC_FSL_RPMSG=m
-CONFIG_SND_SOC_IMX_AUDMUX=m
+# CONFIG_SND_SOC_IMX_AUDMUX is not set
# end of SoC Audio for Freescale CPUs
CONFIG_SND_SOC_CHV3_I2S=m
@@ -7464,18 +7340,18 @@
CONFIG_SND_SST_ATOM_HIFI2_PLATFORM=m
CONFIG_SND_SST_ATOM_HIFI2_PLATFORM_PCI=m
CONFIG_SND_SST_ATOM_HIFI2_PLATFORM_ACPI=m
-# CONFIG_SND_SOC_INTEL_SKYLAKE is not set
+CONFIG_SND_SOC_INTEL_SKYLAKE=m
CONFIG_SND_SOC_INTEL_SKL=m
CONFIG_SND_SOC_INTEL_APL=m
CONFIG_SND_SOC_INTEL_KBL=m
CONFIG_SND_SOC_INTEL_GLK=m
-# CONFIG_SND_SOC_INTEL_CNL is not set
-# CONFIG_SND_SOC_INTEL_CFL is not set
-# CONFIG_SND_SOC_INTEL_CML_H is not set
-# CONFIG_SND_SOC_INTEL_CML_LP is not set
+CONFIG_SND_SOC_INTEL_CNL=m
+CONFIG_SND_SOC_INTEL_CFL=m
+CONFIG_SND_SOC_INTEL_CML_H=m
+CONFIG_SND_SOC_INTEL_CML_LP=m
CONFIG_SND_SOC_INTEL_SKYLAKE_FAMILY=m
CONFIG_SND_SOC_INTEL_SKYLAKE_SSP_CLK=m
-# CONFIG_SND_SOC_INTEL_SKYLAKE_HDAUDIO_CODEC is not set
+CONFIG_SND_SOC_INTEL_SKYLAKE_HDAUDIO_CODEC=y
CONFIG_SND_SOC_INTEL_SKYLAKE_COMMON=m
CONFIG_SND_SOC_ACPI_INTEL_MATCH=m
CONFIG_SND_SOC_INTEL_AVS=m
@@ -7581,11 +7457,10 @@
CONFIG_SND_SOC_SOF_INTEL_ATOM_HIFI_EP=m
CONFIG_SND_SOC_SOF_INTEL_COMMON=m
CONFIG_SND_SOC_SOF_BAYTRAIL=m
-CONFIG_SND_SOC_SOF_BROADWELL=m
+# CONFIG_SND_SOC_SOF_BROADWELL is not set
CONFIG_SND_SOC_SOF_MERRIFIELD=m
-CONFIG_SND_SOC_SOF_INTEL_SKL=m
-CONFIG_SND_SOC_SOF_SKYLAKE=m
-CONFIG_SND_SOC_SOF_KABYLAKE=m
+# CONFIG_SND_SOC_SOF_SKYLAKE is not set
+# CONFIG_SND_SOC_SOF_KABYLAKE is not set
CONFIG_SND_SOC_SOF_INTEL_APL=m
CONFIG_SND_SOC_SOF_APOLLOLAKE=m
CONFIG_SND_SOC_SOF_GEMINILAKE=m
@@ -7663,7 +7538,7 @@
CONFIG_SND_SOC_AW87390=m
CONFIG_SND_SOC_AW88399=m
CONFIG_SND_SOC_BD28623=m
-CONFIG_SND_SOC_BT_SCO=m
+# CONFIG_SND_SOC_BT_SCO is not set
CONFIG_SND_SOC_CHV3_CODEC=m
CONFIG_SND_SOC_CROS_EC_CODEC=m
CONFIG_SND_SOC_CS35L32=m
@@ -7740,7 +7615,6 @@
CONFIG_SND_SOC_MAX98390=m
CONFIG_SND_SOC_MAX98396=m
CONFIG_SND_SOC_MAX9860=m
-CONFIG_SND_SOC_MSM8916_WCD_ANALOG=m
CONFIG_SND_SOC_MSM8916_WCD_DIGITAL=m
CONFIG_SND_SOC_PCM1681=m
CONFIG_SND_SOC_PCM1789=m
@@ -8065,7 +7939,7 @@
CONFIG_ZEROPLUS_FF=y
CONFIG_HID_ZYDACRON=m
CONFIG_HID_SENSOR_HUB=m
-# CONFIG_HID_SENSOR_CUSTOM_SENSOR is not set
+CONFIG_HID_SENSOR_CUSTOM_SENSOR=m
CONFIG_HID_ALPS=m
CONFIG_HID_MCP2221=m
# end of Special HID drivers
@@ -8129,7 +8003,7 @@
# CONFIG_USB_FEW_INIT_RETRIES is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
-CONFIG_USB_OTG_PRODUCTLIST=y
+# CONFIG_USB_OTG_PRODUCTLIST is not set
CONFIG_USB_LEDS_TRIGGER_USBPORT=m
CONFIG_USB_AUTOSUSPEND_DELAY=2
CONFIG_USB_MON=m
@@ -8208,6 +8082,7 @@
CONFIG_USBIP_VHCI_HC_PORTS=8
CONFIG_USBIP_VHCI_NR_HCS=1
CONFIG_USBIP_HOST=m
+CONFIG_USBIP_VUDC=m
# CONFIG_USBIP_DEBUG is not set
@@ -8216,12 +8091,16 @@
CONFIG_USB_CDNS_SUPPORT=m
CONFIG_USB_CDNS_HOST=y
CONFIG_USB_CDNS3=m
+CONFIG_USB_CDNS3_GADGET=y
CONFIG_USB_CDNS3_HOST=y
CONFIG_USB_CDNS3_PCI_WRAP=m
CONFIG_USB_CDNSP_PCI=m
+CONFIG_USB_CDNSP_GADGET=y
CONFIG_USB_CDNSP_HOST=y
CONFIG_USB_MUSB_HDRC=m
-CONFIG_USB_MUSB_HOST=y
+# CONFIG_USB_MUSB_HOST is not set
+# CONFIG_USB_MUSB_GADGET is not set
+CONFIG_USB_MUSB_DUAL_ROLE=y
# Platform Glue Layer
@@ -8230,26 +8109,31 @@
# MUSB DMA mode
-CONFIG_MUSB_PIO_ONLY=y
+# CONFIG_MUSB_PIO_ONLY is not set
CONFIG_USB_DWC3=m
CONFIG_USB_DWC3_ULPI=y
-CONFIG_USB_DWC3_HOST=y
+# CONFIG_USB_DWC3_HOST is not set
+# CONFIG_USB_DWC3_GADGET is not set
+CONFIG_USB_DWC3_DUAL_ROLE=y
# Platform Glue Driver Support
CONFIG_USB_DWC3_PCI=m
CONFIG_USB_DWC3_HAPS=m
-CONFIG_USB_DWC2=y
-CONFIG_USB_DWC2_HOST=y
+CONFIG_USB_DWC2=m
+# CONFIG_USB_DWC2_HOST is not set
# Gadget/Dual-role mode requires USB Gadget support to be enabled
-CONFIG_USB_DWC2_PCI=y
+# CONFIG_USB_DWC2_PERIPHERAL is not set
+CONFIG_USB_DWC2_DUAL_ROLE=y
+CONFIG_USB_DWC2_PCI=m
# CONFIG_USB_DWC2_DEBUG is not set
# CONFIG_USB_DWC2_TRACK_MISSED_SOFS is not set
CONFIG_USB_CHIPIDEA=m
+CONFIG_USB_CHIPIDEA_UDC=y
CONFIG_USB_CHIPIDEA_HOST=y
CONFIG_USB_CHIPIDEA_PCI=m
CONFIG_USB_CHIPIDEA_MSM=m
@@ -8257,12 +8141,16 @@
CONFIG_USB_CHIPIDEA_GENERIC=m
CONFIG_USB_ISP1760=m
CONFIG_USB_ISP1760_HCD=y
-CONFIG_USB_ISP1760_HOST_ROLE=y
+CONFIG_USB_ISP1761_UDC=y
+# CONFIG_USB_ISP1760_HOST_ROLE is not set
+# CONFIG_USB_ISP1760_GADGET_ROLE is not set
+CONFIG_USB_ISP1760_DUAL_ROLE=y
# USB port drivers
-CONFIG_USB_SERIAL=m
+CONFIG_USB_SERIAL=y
+CONFIG_USB_SERIAL_CONSOLE=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_SIMPLE=m
CONFIG_USB_SERIAL_AIRCABLE=m
@@ -8302,7 +8190,7 @@
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SPCP8X5=m
CONFIG_USB_SERIAL_SAFE=m
-CONFIG_USB_SERIAL_SAFE_PADDED=y
+# CONFIG_USB_SERIAL_SAFE_PADDED is not set
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_SYMBOL=m
CONFIG_USB_SERIAL_TI=m
@@ -8317,7 +8205,7 @@
CONFIG_USB_SERIAL_QT2=m
CONFIG_USB_SERIAL_UPD78F0730=m
CONFIG_USB_SERIAL_XR=m
-# CONFIG_USB_SERIAL_DEBUG is not set
+CONFIG_USB_SERIAL_DEBUG=m
# USB Miscellaneous drivers
@@ -8359,14 +8247,125 @@
# USB Physical Layer drivers
CONFIG_USB_PHY=y
-CONFIG_NOP_USB_XCEIV=y
+CONFIG_NOP_USB_XCEIV=m
CONFIG_USB_GPIO_VBUS=m
CONFIG_TAHVO_USB=m
# CONFIG_TAHVO_USB_HOST_BY_DEFAULT is not set
CONFIG_USB_ISP1301=m
# end of USB Physical Layer drivers
-# CONFIG_USB_GADGET is not set
+CONFIG_USB_GADGET=m
+# CONFIG_USB_GADGET_DEBUG is not set
+# CONFIG_USB_GADGET_DEBUG_FILES is not set
+# CONFIG_USB_GADGET_DEBUG_FS is not set
+CONFIG_USB_GADGET_VBUS_DRAW=2
+CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
+CONFIG_U_SERIAL_CONSOLE=y
+# USB Peripheral Controller
+CONFIG_USB_GR_UDC=m
+CONFIG_USB_R8A66597=m
+CONFIG_USB_PXA27X=m
+CONFIG_USB_MV_UDC=m
+CONFIG_USB_MV_U3D=m
+CONFIG_USB_SNP_CORE=m
+CONFIG_USB_M66592=m
+CONFIG_USB_BDC_UDC=m
+CONFIG_USB_AMD5536UDC=m
+CONFIG_USB_NET2272=m
+# CONFIG_USB_NET2272_DMA is not set
+CONFIG_USB_NET2280=m
+CONFIG_USB_GOKU=m
+CONFIG_USB_EG20T=m
+CONFIG_USB_MAX3420_UDC=m
+CONFIG_USB_CDNS2_UDC=m
+CONFIG_USB_DUMMY_HCD=m
+# end of USB Peripheral Controller
+CONFIG_USB_LIBCOMPOSITE=m
+CONFIG_USB_F_ACM=m
+CONFIG_USB_F_SS_LB=m
+CONFIG_USB_U_SERIAL=m
+CONFIG_USB_U_ETHER=m
+CONFIG_USB_U_AUDIO=m
+CONFIG_USB_F_SERIAL=m
+CONFIG_USB_F_OBEX=m
+CONFIG_USB_F_NCM=m
+CONFIG_USB_F_ECM=m
+CONFIG_USB_F_PHONET=m
+CONFIG_USB_F_EEM=m
+CONFIG_USB_F_SUBSET=m
+CONFIG_USB_F_RNDIS=m
+CONFIG_USB_F_MASS_STORAGE=m
+CONFIG_USB_F_FS=m
+CONFIG_USB_F_UAC1=m
+CONFIG_USB_F_UAC1_LEGACY=m
+CONFIG_USB_F_UAC2=m
+CONFIG_USB_F_UVC=m
+CONFIG_USB_F_MIDI=m
+CONFIG_USB_F_MIDI2=m
+CONFIG_USB_F_HID=m
+CONFIG_USB_F_PRINTER=m
+CONFIG_USB_F_TCM=m
+CONFIG_USB_CONFIGFS=m
+CONFIG_USB_CONFIGFS_SERIAL=y
+CONFIG_USB_CONFIGFS_ACM=y
+CONFIG_USB_CONFIGFS_OBEX=y
+CONFIG_USB_CONFIGFS_NCM=y
+CONFIG_USB_CONFIGFS_ECM=y
+CONFIG_USB_CONFIGFS_ECM_SUBSET=y
+CONFIG_USB_CONFIGFS_RNDIS=y
+CONFIG_USB_CONFIGFS_EEM=y
+CONFIG_USB_CONFIGFS_PHONET=y
+CONFIG_USB_CONFIGFS_MASS_STORAGE=y
+CONFIG_USB_CONFIGFS_F_LB_SS=y
+CONFIG_USB_CONFIGFS_F_FS=y
+CONFIG_USB_CONFIGFS_F_UAC1=y
+CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y
+CONFIG_USB_CONFIGFS_F_UAC2=y
+CONFIG_USB_CONFIGFS_F_MIDI=y
+CONFIG_USB_CONFIGFS_F_MIDI2=y
+CONFIG_USB_CONFIGFS_F_HID=y
+CONFIG_USB_CONFIGFS_F_UVC=y
+CONFIG_USB_CONFIGFS_F_PRINTER=y
+CONFIG_USB_CONFIGFS_F_TCM=y
+# USB Gadget precomposed configurations
+CONFIG_USB_ZERO=m
+CONFIG_USB_AUDIO=m
+# CONFIG_GADGET_UAC1 is not set
+CONFIG_USB_ETH=m
+CONFIG_USB_ETH_RNDIS=y
+CONFIG_USB_ETH_EEM=y
+CONFIG_USB_G_NCM=m
+CONFIG_USB_GADGETFS=m
+CONFIG_USB_FUNCTIONFS=m
+CONFIG_USB_FUNCTIONFS_ETH=y
+CONFIG_USB_FUNCTIONFS_RNDIS=y
+CONFIG_USB_FUNCTIONFS_GENERIC=y
+CONFIG_USB_MASS_STORAGE=m
+CONFIG_USB_GADGET_TARGET=m
+CONFIG_USB_G_SERIAL=m
+CONFIG_USB_MIDI_GADGET=m
+CONFIG_USB_G_PRINTER=m
+CONFIG_USB_CDC_COMPOSITE=m
+CONFIG_USB_G_NOKIA=m
+CONFIG_USB_G_ACM_MS=m
+CONFIG_USB_G_MULTI=m
+CONFIG_USB_G_MULTI_RNDIS=y
+CONFIG_USB_G_MULTI_CDC=y
+CONFIG_USB_G_HID=m
+CONFIG_USB_G_DBGP=m
+# CONFIG_USB_G_DBGP_PRINTK is not set
+CONFIG_USB_G_DBGP_SERIAL=y
+CONFIG_USB_G_WEBCAM=m
+CONFIG_USB_RAW_GADGET=m
+# end of USB Gadget precomposed configurations
CONFIG_TYPEC=m
CONFIG_TYPEC_TCPM=m
CONFIG_TYPEC_TCPCI=m
@@ -8405,13 +8404,13 @@
CONFIG_TYPEC_NVIDIA_ALTMODE=m
# end of USB Type-C Alternate Mode drivers
-CONFIG_USB_ROLE_SWITCH=y
+CONFIG_USB_ROLE_SWITCH=m
CONFIG_USB_ROLES_INTEL_XHCI=m
CONFIG_MMC=m
CONFIG_MMC_BLOCK=m
CONFIG_MMC_BLOCK_MINORS=8
CONFIG_SDIO_UART=m
-# CONFIG_MMC_TEST is not set
+CONFIG_MMC_TEST=m
CONFIG_MMC_CRYPTO=y
@@ -8447,7 +8446,7 @@
CONFIG_SCSI_UFS_CRYPTO=y
CONFIG_SCSI_UFS_HWMON=y
CONFIG_SCSI_UFSHCD_PCI=m
-CONFIG_SCSI_UFS_DWC_TC_PCI=m
+# CONFIG_SCSI_UFS_DWC_TC_PCI is not set
CONFIG_SCSI_UFSHCD_PLATFORM=m
CONFIG_SCSI_UFS_CDNS_PLATFORM=m
CONFIG_MEMSTICK=m
@@ -8480,6 +8479,7 @@
CONFIG_LEDS_88PM860X=m
CONFIG_LEDS_APU=m
CONFIG_LEDS_AW200XX=m
+CONFIG_LEDS_CHT_WCOVE=m
CONFIG_LEDS_LM3530=m
CONFIG_LEDS_LM3532=m
CONFIG_LEDS_LM3533=m
@@ -8576,7 +8576,26 @@
CONFIG_LEDS_SIEMENS_SIMATIC_IPC_APOLLOLAKE=m
CONFIG_LEDS_SIEMENS_SIMATIC_IPC_F7188X=m
CONFIG_LEDS_SIEMENS_SIMATIC_IPC_ELKHARTLAKE=m
-# CONFIG_ACCESSIBILITY is not set
+CONFIG_ACCESSIBILITY=y
+CONFIG_A11Y_BRAILLE_CONSOLE=y
+# Speakup console speech
+CONFIG_SPEAKUP=m
+CONFIG_SPEAKUP_SYNTH_ACNTSA=m
+CONFIG_SPEAKUP_SYNTH_APOLLO=m
+CONFIG_SPEAKUP_SYNTH_AUDPTR=m
+CONFIG_SPEAKUP_SYNTH_BNS=m
+CONFIG_SPEAKUP_SYNTH_DECTLK=m
+CONFIG_SPEAKUP_SYNTH_DECEXT=m
+CONFIG_SPEAKUP_SYNTH_LTLK=m
+CONFIG_SPEAKUP_SYNTH_SOFT=m
+CONFIG_SPEAKUP_SYNTH_SPKOUT=m
+CONFIG_SPEAKUP_SYNTH_TXPRT=m
+CONFIG_SPEAKUP_SYNTH_DUMMY=m
+# end of Speakup console speech
CONFIG_INFINIBAND=m
CONFIG_INFINIBAND_USER_MAD=m
CONFIG_INFINIBAND_USER_ACCESS=m
@@ -8602,7 +8621,7 @@
CONFIG_INFINIBAND_QEDR=m
CONFIG_INFINIBAND_QIB=m
CONFIG_INFINIBAND_QIB_DCA=y
-# CONFIG_INFINIBAND_USNIC is not set
+CONFIG_INFINIBAND_USNIC=m
CONFIG_INFINIBAND_VMWARE_PVRDMA=m
CONFIG_INFINIBAND_RDMAVT=m
CONFIG_RDMA_RXE=m
@@ -8828,7 +8847,7 @@
# CONFIG_DMABUF_DEBUG is not set
# CONFIG_DMABUF_SELFTESTS is not set
CONFIG_DMABUF_HEAPS=y
-# CONFIG_DMABUF_SYSFS_STATS is not set
+CONFIG_DMABUF_SYSFS_STATS=y
CONFIG_DMABUF_HEAPS_SYSTEM=y
CONFIG_DMABUF_HEAPS_CMA=y
# end of DMABUF options
@@ -8870,7 +8889,7 @@
CONFIG_VFIO_MDEV=m
CONFIG_IRQ_BYPASS_MANAGER=m
CONFIG_VIRT_DRIVERS=y
-CONFIG_VMGENID=m
+CONFIG_VMGENID=y
CONFIG_VBOXGUEST=m
CONFIG_NITRO_ENCLAVES=m
CONFIG_ACRN_HSM=m
@@ -8888,11 +8907,15 @@
CONFIG_VIRTIO_VDPA=m
CONFIG_VIRTIO_PMEM=m
CONFIG_VIRTIO_BALLOON=m
+CONFIG_VIRTIO_MEM=m
CONFIG_VIRTIO_INPUT=m
CONFIG_VIRTIO_MMIO=m
CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES=y
CONFIG_VIRTIO_DMA_SHARED_BUFFER=m
CONFIG_VDPA=m
+CONFIG_VDPA_SIM=m
+CONFIG_VDPA_SIM_NET=m
+CONFIG_VDPA_SIM_BLOCK=m
CONFIG_VDPA_USER=m
CONFIG_IFCVF=m
CONFIG_MLX5_VDPA=y
@@ -8927,10 +8950,12 @@
# Xen driver support
CONFIG_XEN_BALLOON=y
+CONFIG_XEN_BALLOON_MEMORY_HOTPLUG=y
+CONFIG_XEN_MEMORY_HOTPLUG_LIMIT=512
CONFIG_XEN_SCRUB_PAGES_DEFAULT=y
-CONFIG_XEN_DEV_EVTCHN=y
+CONFIG_XEN_DEV_EVTCHN=m
CONFIG_XEN_BACKEND=y
-CONFIG_XENFS=y
+CONFIG_XENFS=m
CONFIG_XEN_COMPAT_XENFS=y
CONFIG_XEN_SYS_HYPERVISOR=y
CONFIG_XEN_XENBUS_FRONTEND=y
@@ -8944,10 +8969,10 @@
CONFIG_XEN_PVCALLS_FRONTEND=m
CONFIG_XEN_PVCALLS_BACKEND=y
CONFIG_XEN_SCSI_BACKEND=m
-CONFIG_XEN_PRIVCMD=y
+CONFIG_XEN_PRIVCMD=m
CONFIG_XEN_PRIVCMD_EVENTFD=y
CONFIG_XEN_ACPI_PROCESSOR=m
-# CONFIG_XEN_MCE_LOG is not set
+CONFIG_XEN_MCE_LOG=y
CONFIG_XEN_HAVE_PVMMU=y
CONFIG_XEN_EFI=y
CONFIG_XEN_AUTO_XLATE=y
@@ -8955,107 +8980,14 @@
CONFIG_XEN_SYMS=y
CONFIG_XEN_HAVE_VPMU=y
CONFIG_XEN_FRONT_PGDIR_SHBUF=m
+CONFIG_XEN_UNPOPULATED_ALLOC=y
CONFIG_XEN_GRANT_DMA_OPS=y
CONFIG_XEN_VIRTIO=y
# CONFIG_XEN_VIRTIO_FORCE_GRANT is not set
# end of Xen driver support
-CONFIG_GREYBUS=m
-CONFIG_GREYBUS_BEAGLEPLAY=m
-CONFIG_GREYBUS_ES2=m
-CONFIG_COMEDI=m
-# CONFIG_COMEDI_DEBUG is not set
-CONFIG_COMEDI_DEFAULT_BUF_SIZE_KB=2048
-CONFIG_COMEDI_DEFAULT_BUF_MAXSIZE_KB=20480
-CONFIG_COMEDI_MISC_DRIVERS=y
-CONFIG_COMEDI_BOND=m
-CONFIG_COMEDI_TEST=m
-CONFIG_COMEDI_PARPORT=m
-CONFIG_COMEDI_PCI_DRIVERS=m
-CONFIG_COMEDI_8255_PCI=m
-CONFIG_COMEDI_ADDI_WATCHDOG=m
-CONFIG_COMEDI_ADDI_APCI_1032=m
-CONFIG_COMEDI_ADDI_APCI_1500=m
-CONFIG_COMEDI_ADDI_APCI_1516=m
-CONFIG_COMEDI_ADDI_APCI_1564=m
-CONFIG_COMEDI_ADDI_APCI_16XX=m
-CONFIG_COMEDI_ADDI_APCI_2032=m
-CONFIG_COMEDI_ADDI_APCI_2200=m
-CONFIG_COMEDI_ADDI_APCI_3120=m
-CONFIG_COMEDI_ADDI_APCI_3501=m
-CONFIG_COMEDI_ADDI_APCI_3XXX=m
-CONFIG_COMEDI_ADL_PCI6208=m
-CONFIG_COMEDI_ADL_PCI7X3X=m
-CONFIG_COMEDI_ADL_PCI8164=m
-CONFIG_COMEDI_ADL_PCI9111=m
-CONFIG_COMEDI_ADL_PCI9118=m
-CONFIG_COMEDI_ADV_PCI1710=m
-CONFIG_COMEDI_ADV_PCI1720=m
-CONFIG_COMEDI_ADV_PCI1723=m
-CONFIG_COMEDI_ADV_PCI1724=m
-CONFIG_COMEDI_ADV_PCI1760=m
-CONFIG_COMEDI_ADV_PCI_DIO=m
-CONFIG_COMEDI_AMPLC_DIO200_PCI=m
-CONFIG_COMEDI_AMPLC_PC236_PCI=m
-CONFIG_COMEDI_AMPLC_PC263_PCI=m
-CONFIG_COMEDI_AMPLC_PCI224=m
-CONFIG_COMEDI_AMPLC_PCI230=m
-CONFIG_COMEDI_CONTEC_PCI_DIO=m
-CONFIG_COMEDI_DAS08_PCI=m
-CONFIG_COMEDI_DT3000=m
-CONFIG_COMEDI_DYNA_PCI10XX=m
-CONFIG_COMEDI_GSC_HPDI=m
-# CONFIG_COMEDI_MF6X4 is not set
-CONFIG_COMEDI_ICP_MULTI=m
-CONFIG_COMEDI_DAQBOARD2000=m
-CONFIG_COMEDI_JR3_PCI=m
-CONFIG_COMEDI_KE_COUNTER=m
-CONFIG_COMEDI_CB_PCIDAS64=m
-CONFIG_COMEDI_CB_PCIDAS=m
-CONFIG_COMEDI_CB_PCIDDA=m
-CONFIG_COMEDI_CB_PCIMDAS=m
-CONFIG_COMEDI_CB_PCIMDDA=m
-CONFIG_COMEDI_ME4000=m
-CONFIG_COMEDI_ME_DAQ=m
-CONFIG_COMEDI_NI_6527=m
-CONFIG_COMEDI_NI_65XX=m
-CONFIG_COMEDI_NI_660X=m
-CONFIG_COMEDI_NI_670X=m
-CONFIG_COMEDI_NI_LABPC_PCI=m
-CONFIG_COMEDI_NI_PCIDIO=m
-CONFIG_COMEDI_NI_PCIMIO=m
-CONFIG_COMEDI_RTD520=m
-CONFIG_COMEDI_S626=m
-CONFIG_COMEDI_MITE=m
-CONFIG_COMEDI_NI_TIOCMD=m
-CONFIG_COMEDI_PCMCIA_DRIVERS=m
-CONFIG_COMEDI_CB_DAS16_CS=m
-CONFIG_COMEDI_DAS08_CS=m
-CONFIG_COMEDI_NI_DAQ_700_CS=m
-CONFIG_COMEDI_NI_DAQ_DIO24_CS=m
-CONFIG_COMEDI_NI_LABPC_CS=m
-CONFIG_COMEDI_NI_MIO_CS=m
-CONFIG_COMEDI_QUATECH_DAQP_CS=m
-CONFIG_COMEDI_USB_DRIVERS=m
-CONFIG_COMEDI_DT9812=m
-CONFIG_COMEDI_NI_USB6501=m
-CONFIG_COMEDI_USBDUX=m
-CONFIG_COMEDI_USBDUXFAST=m
-CONFIG_COMEDI_USBDUXSIGMA=m
-CONFIG_COMEDI_VMK80XX=m
-CONFIG_COMEDI_8254=m
-CONFIG_COMEDI_8255=m
-CONFIG_COMEDI_8255_SA=m
-CONFIG_COMEDI_KCOMEDILIB=m
-CONFIG_COMEDI_AMPLC_DIO200=m
-CONFIG_COMEDI_AMPLC_PC236=m
-CONFIG_COMEDI_DAS08=m
-CONFIG_COMEDI_NI_LABPC=m
-CONFIG_COMEDI_NI_TIO=m
-CONFIG_COMEDI_NI_ROUTING=m
-CONFIG_COMEDI_TESTS=m
-CONFIG_COMEDI_TESTS_EXAMPLE=m
-CONFIG_COMEDI_TESTS_NI_ROUTES=m
+# CONFIG_GREYBUS is not set
+# CONFIG_COMEDI is not set
CONFIG_STAGING=y
CONFIG_PRISM2_USB=m
CONFIG_RTLLIB=m
@@ -9108,84 +9040,23 @@
# end of Network Analyzer, Impedance Converters
# end of IIO staging drivers
-CONFIG_FB_SM750=m
+# CONFIG_FB_SM750 is not set
CONFIG_STAGING_MEDIA=y
-CONFIG_INTEL_ATOMISP=y
-CONFIG_VIDEO_ATOMISP=m
-CONFIG_VIDEO_ATOMISP_OV2722=m
-CONFIG_VIDEO_ATOMISP_GC2235=m
-CONFIG_VIDEO_ATOMISP_MSRLIST_HELPER=m
-CONFIG_VIDEO_ATOMISP_MT9M114=m
-CONFIG_VIDEO_ATOMISP_GC0310=m
-CONFIG_VIDEO_ATOMISP_LM3554=m
+# CONFIG_INTEL_ATOMISP is not set
CONFIG_DVB_AV7110_IR=y
CONFIG_DVB_AV7110=m
CONFIG_DVB_AV7110_OSD=y
CONFIG_DVB_BUDGET_PATCH=m
CONFIG_DVB_SP8870=m
CONFIG_VIDEO_IPU3_IMGU=m
-CONFIG_STAGING_MEDIA_DEPRECATED=y
-# Atmel media platform drivers
+# CONFIG_STAGING_MEDIA_DEPRECATED is not set
CONFIG_LTE_GDM724X=m
-CONFIG_FB_TFT=m
-CONFIG_FB_TFT_AGM1264K_FL=m
-CONFIG_FB_TFT_BD663474=m
-CONFIG_FB_TFT_HX8340BN=m
-CONFIG_FB_TFT_HX8347D=m
-CONFIG_FB_TFT_HX8353D=m
-CONFIG_FB_TFT_HX8357D=m
-CONFIG_FB_TFT_ILI9163=m
-CONFIG_FB_TFT_ILI9320=m
-CONFIG_FB_TFT_ILI9325=m
-CONFIG_FB_TFT_ILI9340=m
-CONFIG_FB_TFT_ILI9341=m
-CONFIG_FB_TFT_ILI9481=m
-CONFIG_FB_TFT_ILI9486=m
-CONFIG_FB_TFT_PCD8544=m
-CONFIG_FB_TFT_RA8875=m
-CONFIG_FB_TFT_S6D02A1=m
-CONFIG_FB_TFT_S6D1121=m
-CONFIG_FB_TFT_SEPS525=m
-CONFIG_FB_TFT_SH1106=m
-CONFIG_FB_TFT_SSD1289=m
-CONFIG_FB_TFT_SSD1305=m
-CONFIG_FB_TFT_SSD1306=m
-CONFIG_FB_TFT_SSD1331=m
-CONFIG_FB_TFT_SSD1351=m
-CONFIG_FB_TFT_ST7735R=m
-CONFIG_FB_TFT_ST7789V=m
-CONFIG_FB_TFT_TINYLCD=m
-CONFIG_FB_TFT_TLS8204=m
-CONFIG_FB_TFT_UC1611=m
-CONFIG_FB_TFT_UC1701=m
-CONFIG_FB_TFT_UPD161704=m
+# CONFIG_FB_TFT is not set
CONFIG_MOST_COMPONENTS=m
CONFIG_MOST_NET=m
CONFIG_MOST_VIDEO=m
CONFIG_MOST_I2C=m
CONFIG_KS7010=m
-CONFIG_GREYBUS_AUDIO=m
-CONFIG_GREYBUS_AUDIO_APB_CODEC=m
-CONFIG_GREYBUS_BOOTROM=m
-CONFIG_GREYBUS_FIRMWARE=m
-CONFIG_GREYBUS_HID=m
-CONFIG_GREYBUS_LIGHT=m
-CONFIG_GREYBUS_LOG=m
-CONFIG_GREYBUS_LOOPBACK=m
-CONFIG_GREYBUS_POWER=m
-CONFIG_GREYBUS_RAW=m
-CONFIG_GREYBUS_VIBRATOR=m
-CONFIG_GREYBUS_BRIDGED_PHY=m
-CONFIG_GREYBUS_GPIO=m
-CONFIG_GREYBUS_I2C=m
-CONFIG_GREYBUS_PWM=m
-CONFIG_GREYBUS_SDIO=m
-CONFIG_GREYBUS_SPI=m
-CONFIG_GREYBUS_UART=m
-CONFIG_GREYBUS_USB=m
CONFIG_PI433=m
CONFIG_FIELDBUS_DEV=m
# CONFIG_VME_BUS is not set
@@ -9304,6 +9175,7 @@
CONFIG_THINKPAD_LMI=m
CONFIG_INTEL_ATOMISP2_PDX86=y
CONFIG_INTEL_ATOMISP2_LED=m
+CONFIG_INTEL_ATOMISP2_PM=m
CONFIG_INTEL_IFS=m
CONFIG_INTEL_SAR_INT1092=m
CONFIG_INTEL_SKL_INT3472=m
@@ -9336,6 +9208,8 @@
CONFIG_INTEL_INT0002_VGPIO=m
CONFIG_INTEL_OAKTRAIL=m
CONFIG_INTEL_BXTWC_PMIC_TMU=m
+CONFIG_INTEL_BYTCRC_PWRSRC=m
+CONFIG_INTEL_CHTDC_TI_PWRBTN=m
CONFIG_INTEL_CHTWC_INT33FE=m
CONFIG_INTEL_ISHTP_ECLITE=m
CONFIG_INTEL_MRFLD_PWRBTN=m
@@ -9344,7 +9218,7 @@
CONFIG_INTEL_SDSI=m
CONFIG_INTEL_SMARTCONNECT=m
CONFIG_INTEL_TPMI=m
-# CONFIG_INTEL_TURBO_MAX_3 is not set
+CONFIG_INTEL_TURBO_MAX_3=y
CONFIG_INTEL_VSEC=m
CONFIG_MSI_EC=m
CONFIG_MSI_LAPTOP=m
@@ -9402,7 +9276,7 @@
CONFIG_COMMON_CLK_PALMAS=m
CONFIG_COMMON_CLK_PWM=m
CONFIG_XILINX_VCU=m
-# CONFIG_HWSPINLOCK is not set
+CONFIG_HWSPINLOCK=y
# Clock Source drivers
@@ -9464,7 +9338,7 @@
CONFIG_RPMSG_VIRTIO=m
# end of Rpmsg drivers
-CONFIG_SOUNDWIRE=y
+CONFIG_SOUNDWIRE=m
# SoundWire Devices
@@ -9555,16 +9429,16 @@
# DEVFREQ Governors
-CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
-CONFIG_DEVFREQ_GOV_PERFORMANCE=y
-CONFIG_DEVFREQ_GOV_POWERSAVE=y
-CONFIG_DEVFREQ_GOV_USERSPACE=y
+CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=m
+CONFIG_DEVFREQ_GOV_PERFORMANCE=m
+CONFIG_DEVFREQ_GOV_POWERSAVE=m
+CONFIG_DEVFREQ_GOV_USERSPACE=m
CONFIG_DEVFREQ_GOV_PASSIVE=m
# DEVFREQ Drivers
-# CONFIG_PM_DEVFREQ_EVENT is not set
+CONFIG_PM_DEVFREQ_EVENT=y
CONFIG_EXTCON=y
@@ -9575,6 +9449,7 @@
CONFIG_EXTCON_FSA9480=m
CONFIG_EXTCON_GPIO=m
CONFIG_EXTCON_INTEL_INT3496=m
+CONFIG_EXTCON_INTEL_CHT_WC=m
CONFIG_EXTCON_INTEL_MRFLD=m
CONFIG_EXTCON_MAX14577=m
CONFIG_EXTCON_MAX3355=m
@@ -9731,10 +9606,6 @@
CONFIG_MP2629_ADC=m
CONFIG_NAU7802=m
CONFIG_PALMAS_GPADC=m
-CONFIG_QCOM_VADC_COMMON=m
-CONFIG_QCOM_SPMI_IADC=m
-CONFIG_QCOM_SPMI_VADC=m
-CONFIG_QCOM_SPMI_ADC5=m
CONFIG_RICHTEK_RTQ6056=m
CONFIG_SD_ADC_MODULATOR=m
CONFIG_TI_ADC081C=m
@@ -9895,10 +9766,7 @@
# IIO dummy driver
-CONFIG_IIO_DUMMY_EVGEN=m
-CONFIG_IIO_SIMPLE_DUMMY=m
-CONFIG_IIO_SIMPLE_DUMMY_EVENTS=y
-CONFIG_IIO_SIMPLE_DUMMY_BUFFER=y
+# CONFIG_IIO_SIMPLE_DUMMY is not set
# end of IIO dummy driver
@@ -9997,6 +9865,9 @@
CONFIG_BOSCH_BNO055=m
CONFIG_BOSCH_BNO055_SERIAL=m
CONFIG_BOSCH_BNO055_I2C=m
+CONFIG_BMI323=m
+CONFIG_BMI323_I2C=m
+CONFIG_BMI323_SPI=m
CONFIG_FXOS8700=m
CONFIG_FXOS8700_I2C=m
CONFIG_FXOS8700_SPI=m
@@ -10010,7 +9881,6 @@
CONFIG_IIO_ST_LSM6DSX=m
CONFIG_IIO_ST_LSM6DSX_I2C=m
CONFIG_IIO_ST_LSM6DSX_SPI=m
-CONFIG_IIO_ST_LSM6DSX_I3C=m
CONFIG_IIO_ST_LSM9DS0=m
CONFIG_IIO_ST_LSM9DS0_I2C=m
CONFIG_IIO_ST_LSM9DS0_SPI=m
@@ -10253,15 +10123,16 @@
CONFIG_NTB_INTEL=m
CONFIG_NTB_EPF=m
CONFIG_NTB_SWITCHTEC=m
-CONFIG_NTB_PINGPONG=m
-CONFIG_NTB_TOOL=m
-CONFIG_NTB_PERF=m
-CONFIG_NTB_MSI_TEST=m
+# CONFIG_NTB_PINGPONG is not set
+# CONFIG_NTB_TOOL is not set
+# CONFIG_NTB_PERF is not set
+# CONFIG_NTB_MSI_TEST is not set
CONFIG_NTB_TRANSPORT=m
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_DEBUG is not set
CONFIG_PWM_CLK=m
+CONFIG_PWM_CRC=y
CONFIG_PWM_CROS_EC=m
CONFIG_PWM_DWC_CORE=m
CONFIG_PWM_DWC=m
@@ -10330,12 +10201,15 @@
# CONFIG_RAS_CEC_DEBUG is not set
CONFIG_USB4=m
# CONFIG_USB4_DEBUGFS_WRITE is not set
-CONFIG_USB4_DMA_TEST=m
+# CONFIG_USB4_DMA_TEST is not set
# Android
-# CONFIG_ANDROID_BINDER_IPC is not set
+CONFIG_ANDROID_BINDER_IPC=y
+CONFIG_ANDROID_BINDERFS=y
+CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder"
+# CONFIG_ANDROID_BINDER_IPC_SELFTEST is not set
# end of Android
CONFIG_LIBNVDIMM=y
@@ -10343,8 +10217,16 @@
CONFIG_ND_CLAIM=y
CONFIG_ND_BTT=m
CONFIG_BTT=y
+CONFIG_ND_PFN=m
+CONFIG_NVDIMM_PFN=y
+CONFIG_NVDIMM_DAX=y
CONFIG_DAX=y
-# CONFIG_DEV_DAX is not set
+CONFIG_DEV_DAX=m
+CONFIG_DEV_DAX_PMEM=m
+CONFIG_DEV_DAX_HMEM=m
+CONFIG_DEV_DAX_CXL=m
+CONFIG_DEV_DAX_HMEM_DEVICES=y
+CONFIG_DEV_DAX_KMEM=m
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
@@ -10357,7 +10239,6 @@
CONFIG_NVMEM_RAVE_SP_EEPROM=m
CONFIG_NVMEM_RMEM=m
-CONFIG_NVMEM_SPMI_SDAM=m
# HW tracing support
@@ -10365,7 +10246,7 @@
CONFIG_STM=m
CONFIG_STM_PROTO_BASIC=m
CONFIG_STM_PROTO_SYS_T=m
-CONFIG_STM_DUMMY=m
+# CONFIG_STM_DUMMY is not set
CONFIG_STM_SOURCE_CONSOLE=m
CONFIG_STM_SOURCE_HEARTBEAT=m
CONFIG_STM_SOURCE_FTRACE=m
@@ -10426,8 +10307,7 @@
CONFIG_MOST_USB_HDM=m
CONFIG_MOST_CDEV=m
CONFIG_MOST_SND=m
-CONFIG_PECI=m
-CONFIG_PECI_CPU=m
+# CONFIG_PECI is not set
CONFIG_HTE=y
CONFIG_DPLL=y
# end of Device Drivers
@@ -10452,7 +10332,7 @@
CONFIG_FS_MBCACHE=m
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
-# CONFIG_REISERFS_PROC_INFO is not set
+CONFIG_REISERFS_PROC_INFO=y
CONFIG_REISERFS_FS_XATTR=y
CONFIG_REISERFS_FS_POSIX_ACL=y
CONFIG_REISERFS_FS_SECURITY=y
@@ -10460,7 +10340,7 @@
CONFIG_JFS_POSIX_ACL=y
CONFIG_JFS_SECURITY=y
# CONFIG_JFS_DEBUG is not set
-# CONFIG_JFS_STATISTICS is not set
+CONFIG_JFS_STATISTICS=y
CONFIG_XFS_FS=m
CONFIG_XFS_SUPPORT_V4=y
CONFIG_XFS_SUPPORT_ASCII_CI=y
@@ -10469,23 +10349,23 @@
CONFIG_XFS_RT=y
CONFIG_XFS_DRAIN_INTENTS=y
CONFIG_XFS_ONLINE_SCRUB=y
-CONFIG_XFS_ONLINE_SCRUB_STATS=y
+# CONFIG_XFS_ONLINE_SCRUB_STATS is not set
CONFIG_XFS_ONLINE_REPAIR=y
-CONFIG_XFS_DEBUG=y
-# CONFIG_XFS_ASSERT_FATAL is not set
+# CONFIG_XFS_WARN is not set
+# CONFIG_XFS_DEBUG is not set
CONFIG_GFS2_FS=m
CONFIG_GFS2_FS_LOCKING_DLM=y
CONFIG_OCFS2_FS=m
CONFIG_OCFS2_FS_O2CB=m
CONFIG_OCFS2_FS_USERSPACE_CLUSTER=m
-# CONFIG_OCFS2_FS_STATS is not set
-# CONFIG_OCFS2_DEBUG_MASKLOG is not set
+CONFIG_OCFS2_FS_STATS=y
+CONFIG_OCFS2_DEBUG_MASKLOG=y
# CONFIG_OCFS2_DEBUG_FS is not set
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
# CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set
# CONFIG_BTRFS_DEBUG is not set
-CONFIG_BTRFS_ASSERT=y
+# CONFIG_BTRFS_ASSERT is not set
# CONFIG_BTRFS_FS_REF_VERIFY is not set
CONFIG_NILFS2_FS=m
CONFIG_F2FS_FS=m
@@ -10502,17 +10382,19 @@
CONFIG_F2FS_FS_LZ4HC=y
CONFIG_F2FS_FS_ZSTD=y
CONFIG_F2FS_IOSTAT=y
-# CONFIG_F2FS_UNFAIR_RWSEM is not set
+CONFIG_F2FS_UNFAIR_RWSEM=y
CONFIG_BCACHEFS_FS=m
CONFIG_BCACHEFS_QUOTA=y
-CONFIG_BCACHEFS_ERASURE_CODING=y
+# CONFIG_BCACHEFS_ERASURE_CODING is not set
CONFIG_BCACHEFS_POSIX_ACL=y
-# CONFIG_BCACHEFS_DEBUG_TRANSACTIONS is not set
+CONFIG_BCACHEFS_DEBUG_TRANSACTIONS=y
# CONFIG_BCACHEFS_DEBUG is not set
# CONFIG_BCACHEFS_TESTS is not set
-# CONFIG_BCACHEFS_LOCK_TIME_STATS is not set
-CONFIG_BCACHEFS_NO_LATENCY_ACCT=y
+CONFIG_BCACHEFS_LOCK_TIME_STATS=y
+# CONFIG_BCACHEFS_NO_LATENCY_ACCT is not set
CONFIG_ZONEFS_FS=m
+CONFIG_FS_DAX=y
+CONFIG_FS_DAX_PMD=y
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
CONFIG_EXPORTFS_BLOCK_OPS=y
@@ -10538,13 +10420,13 @@
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
CONFIG_VIRTIO_FS=m
+CONFIG_FUSE_DAX=y
CONFIG_OVERLAY_FS=m
CONFIG_OVERLAY_FS_REDIRECT_DIR=y
-CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
+# CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW is not set
CONFIG_OVERLAY_FS_INDEX=y
-# CONFIG_OVERLAY_FS_NFS_EXPORT is not set
CONFIG_OVERLAY_FS_XINO_AUTO=y
-# CONFIG_OVERLAY_FS_METACOPY is not set
+CONFIG_OVERLAY_FS_METACOPY=y
# CONFIG_OVERLAY_FS_DEBUG is not set
@@ -10577,13 +10459,11 @@
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
-CONFIG_FAT_DEFAULT_IOCHARSET="utf8"
-# CONFIG_FAT_DEFAULT_UTF8 is not set
+CONFIG_FAT_DEFAULT_IOCHARSET="ascii"
+CONFIG_FAT_DEFAULT_UTF8=y
CONFIG_EXFAT_FS=m
CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8"
-CONFIG_NTFS_FS=m
-# CONFIG_NTFS_DEBUG is not set
-CONFIG_NTFS_RW=y
+# CONFIG_NTFS_FS is not set
CONFIG_NTFS3_FS=m
# CONFIG_NTFS3_64BIT_CLUSTER is not set
CONFIG_NTFS3_LZX_XPRESS=y
@@ -10595,6 +10475,8 @@
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
+CONFIG_PROC_VMCORE=y
+CONFIG_PROC_VMCORE_DEVICE_DUMP=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_PROC_CHILDREN=y
@@ -10610,7 +10492,7 @@
CONFIG_HUGETLBFS=y
CONFIG_HUGETLB_PAGE=y
CONFIG_HUGETLB_PAGE_OPTIMIZE_VMEMMAP=y
-CONFIG_HUGETLB_PAGE_OPTIMIZE_VMEMMAP_DEFAULT_ON=y
+# CONFIG_HUGETLB_PAGE_OPTIMIZE_VMEMMAP_DEFAULT_ON is not set
CONFIG_ARCH_HAS_GIGANTIC_PAGE=y
CONFIG_CONFIGFS_FS=y
CONFIG_EFIVAR_FS=y
@@ -10618,17 +10500,16 @@
CONFIG_MISC_FILESYSTEMS=y
CONFIG_ORANGEFS_FS=m
-CONFIG_ADFS_FS=m
-CONFIG_ADFS_FS_RW=y
+# CONFIG_ADFS_FS is not set
CONFIG_AFFS_FS=m
CONFIG_ECRYPT_FS=m
-CONFIG_ECRYPT_FS_MESSAGING=y
+# CONFIG_ECRYPT_FS_MESSAGING is not set
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
CONFIG_BEFS_FS=m
# CONFIG_BEFS_DEBUG is not set
-CONFIG_BFS_FS=m
-CONFIG_EFS_FS=m
+# CONFIG_BFS_FS is not set
+# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
@@ -10637,26 +10518,21 @@
CONFIG_JFFS2_FS_XATTR=y
CONFIG_JFFS2_FS_POSIX_ACL=y
CONFIG_JFFS2_FS_SECURITY=y
-CONFIG_JFFS2_COMPRESSION_OPTIONS=y
+# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
-CONFIG_JFFS2_LZO=y
CONFIG_JFFS2_RTIME=y
-CONFIG_JFFS2_RUBIN=y
-# CONFIG_JFFS2_CMODE_NONE is not set
-CONFIG_JFFS2_CMODE_PRIORITY=y
-# CONFIG_JFFS2_CMODE_SIZE is not set
-# CONFIG_JFFS2_CMODE_FAVOURLZO is not set
CONFIG_UBIFS_FS=m
-CONFIG_UBIFS_FS_ADVANCED_COMPR=y
+# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_ZSTD=y
-# CONFIG_UBIFS_ATIME_SUPPORT is not set
+CONFIG_UBIFS_ATIME_SUPPORT=y
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_SECURITY=y
CONFIG_UBIFS_FS_AUTHENTICATION=y
-CONFIG_CRAMFS=y
+CONFIG_CRAMFS=m
CONFIG_CRAMFS_BLOCKDEV=y
+CONFIG_CRAMFS_MTD=y
CONFIG_SQUASHFS=m
# CONFIG_SQUASHFS_FILE_CACHE is not set
CONFIG_SQUASHFS_FILE_DIRECT=y
@@ -10671,22 +10547,20 @@
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
CONFIG_SQUASHFS_ZSTD=y
-CONFIG_SQUASHFS_4K_DEVBLK_SIZE=y
+# CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
-CONFIG_VXFS_FS=m
+# CONFIG_VXFS_FS is not set
CONFIG_MINIX_FS=m
CONFIG_OMFS_FS=m
-CONFIG_HPFS_FS=m
-CONFIG_QNX4FS_FS=m
-CONFIG_QNX6FS_FS=m
-# CONFIG_QNX6FS_DEBUG is not set
+# CONFIG_HPFS_FS is not set
+# CONFIG_QNX4FS_FS is not set
+# CONFIG_QNX6FS_FS is not set
CONFIG_ROMFS_FS=m
-# CONFIG_ROMFS_BACKED_BY_BLOCK is not set
+CONFIG_ROMFS_BACKED_BY_BLOCK=y
# CONFIG_ROMFS_BACKED_BY_MTD is not set
-CONFIG_ROMFS_BACKED_BY_BOTH=y
+# CONFIG_ROMFS_BACKED_BY_BOTH is not set
CONFIG_ROMFS_ON_BLOCK=y
-CONFIG_ROMFS_ON_MTD=y
CONFIG_PSTORE=y
CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240
CONFIG_PSTORE_COMPRESS=y
@@ -10694,10 +10568,14 @@
# CONFIG_PSTORE_PMSG is not set
# CONFIG_PSTORE_FTRACE is not set
CONFIG_PSTORE_RAM=m
-# CONFIG_PSTORE_BLK is not set
-CONFIG_SYSV_FS=m
+CONFIG_PSTORE_ZONE=m
+CONFIG_PSTORE_BLK=m
+CONFIG_PSTORE_BLK_BLKDEV=""
+CONFIG_PSTORE_BLK_KMSG_SIZE=64
+CONFIG_PSTORE_BLK_MAX_REASON=2
+# CONFIG_SYSV_FS is not set
CONFIG_UFS_FS=m
-CONFIG_UFS_FS_WRITE=y
+# CONFIG_UFS_FS_WRITE is not set
# CONFIG_UFS_DEBUG is not set
CONFIG_EROFS_FS=m
# CONFIG_EROFS_FS_DEBUG is not set
@@ -10709,7 +10587,7 @@
CONFIG_EROFS_FS_ZIP_DEFLATE=y
CONFIG_EROFS_FS_ONDEMAND=y
CONFIG_EROFS_FS_PCPU_KTHREAD=y
-# CONFIG_EROFS_FS_PCPU_KTHREAD_HIPRI is not set
+CONFIG_EROFS_FS_PCPU_KTHREAD_HIPRI=y
CONFIG_VBOXSF_FS=m
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=m
@@ -10729,6 +10607,7 @@
CONFIG_NFS_FSCACHE=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
+CONFIG_NFS_DEBUG=y
# CONFIG_NFS_DISABLE_UDP_SUPPORT is not set
# CONFIG_NFS_V4_2_READ_PLUS is not set
CONFIG_NFSD=m
@@ -10755,7 +10634,7 @@
CONFIG_RPCSEC_GSS_KRB5_ENCTYPES_AES_SHA1=y
CONFIG_RPCSEC_GSS_KRB5_ENCTYPES_CAMELLIA=y
CONFIG_RPCSEC_GSS_KRB5_ENCTYPES_AES_SHA2=y
-# CONFIG_SUNRPC_DEBUG is not set
+CONFIG_SUNRPC_DEBUG=y
CONFIG_SUNRPC_XPRT_RDMA=m
CONFIG_CEPH_FS=m
CONFIG_CEPH_FSCACHE=y
@@ -10767,7 +10646,9 @@
CONFIG_CIFS_UPCALL=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
-# CONFIG_CIFS_DEBUG is not set
+CONFIG_CIFS_DEBUG=y
+# CONFIG_CIFS_DEBUG2 is not set
+# CONFIG_CIFS_DEBUG_DUMP_KEYS is not set
CONFIG_CIFS_DFS_UPCALL=y
CONFIG_CIFS_SWN_UPCALL=y
CONFIG_CIFS_SMB_DIRECT=y
@@ -10788,7 +10669,7 @@
CONFIG_9P_FS_SECURITY=y
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="utf8"
-CONFIG_NLS_CODEPAGE_437=m
+CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_CODEPAGE_737=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
@@ -10811,7 +10692,7 @@
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
-CONFIG_NLS_ASCII=m
+CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_3=m
@@ -10839,9 +10720,9 @@
CONFIG_NLS_UTF8=m
CONFIG_NLS_UCS2_UTILS=m
CONFIG_DLM=m
-# CONFIG_DLM_DEBUG is not set
+CONFIG_DLM_DEBUG=y
CONFIG_UNICODE=y
-CONFIG_UNICODE_NORMALIZATION_SELFTEST=m
+# CONFIG_UNICODE_NORMALIZATION_SELFTEST is not set
CONFIG_IO_WQ=y
# end of File systems
@@ -10855,7 +10736,7 @@
CONFIG_TRUSTED_KEYS_TPM=y
CONFIG_TRUSTED_KEYS_TEE=y
CONFIG_ENCRYPTED_KEYS=m
-CONFIG_USER_DECRYPTED_DATA=y
+# CONFIG_USER_DECRYPTED_DATA is not set
CONFIG_KEY_DH_OPERATIONS=y
CONFIG_KEY_NOTIFICATIONS=y
CONFIG_SECURITY_DMESG_RESTRICT=y
@@ -10865,10 +10746,10 @@
CONFIG_SECURITY_INFINIBAND=y
CONFIG_SECURITY_NETWORK_XFRM=y
CONFIG_SECURITY_PATH=y
-CONFIG_INTEL_TXT=y
+# CONFIG_INTEL_TXT is not set
CONFIG_LSM_MMAP_MIN_ADDR=65536
CONFIG_HARDENED_USERCOPY=y
-# CONFIG_FORTIFY_SOURCE is not set
+CONFIG_FORTIFY_SOURCE=y
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_SECURITY_SELINUX=y
CONFIG_SECURITY_SELINUX_BOOTPARAM=y
@@ -10885,8 +10766,8 @@
CONFIG_SECURITY_TOMOYO_MAX_ACCEPT_ENTRY=2048
CONFIG_SECURITY_TOMOYO_MAX_AUDIT_LOG=1024
# CONFIG_SECURITY_TOMOYO_OMIT_USERSPACE_LOADER is not set
-CONFIG_SECURITY_TOMOYO_POLICY_LOADER="/sbin/tomoyo-init"
-CONFIG_SECURITY_TOMOYO_ACTIVATION_TRIGGER="/sbin/init"
+CONFIG_SECURITY_TOMOYO_POLICY_LOADER="/usr/bin/tomoyo-init"
+CONFIG_SECURITY_TOMOYO_ACTIVATION_TRIGGER="/usr/lib/systemd/systemd"
# CONFIG_SECURITY_TOMOYO_INSECURE_BUILTIN_SETTING is not set
CONFIG_SECURITY_APPARMOR=y
# CONFIG_SECURITY_APPARMOR_DEBUG is not set
@@ -10895,19 +10776,34 @@
CONFIG_SECURITY_APPARMOR_HASH_DEFAULT=y
CONFIG_SECURITY_APPARMOR_EXPORT_BINARY=y
CONFIG_SECURITY_APPARMOR_PARANOID_LOAD=y
-# CONFIG_SECURITY_LOADPIN is not set
+CONFIG_SECURITY_LOADPIN=y
+CONFIG_SECURITY_LOADPIN_ENFORCE=y
CONFIG_SECURITY_YAMA=y
CONFIG_SECURITY_SAFESETID=y
-# CONFIG_SECURITY_LOCKDOWN_LSM is not set
+CONFIG_SECURITY_LOCKDOWN_LSM=y
+# CONFIG_SECURITY_LOCKDOWN_LSM_EARLY is not set
+CONFIG_LOCK_DOWN_KERNEL_FORCE_NONE=y
+# CONFIG_LOCK_DOWN_KERNEL_FORCE_INTEGRITY is not set
+# CONFIG_LOCK_DOWN_KERNEL_FORCE_CONFIDENTIALITY is not set
CONFIG_SECURITY_LANDLOCK=y
-# CONFIG_INTEGRITY is not set
+CONFIG_INTEGRITY=y
+CONFIG_INTEGRITY_SIGNATURE=y
+CONFIG_INTEGRITY_ASYMMETRIC_KEYS=y
+CONFIG_INTEGRITY_TRUSTED_KEYRING=y
+CONFIG_INTEGRITY_PLATFORM_KEYRING=y
+CONFIG_INTEGRITY_MACHINE_KEYRING=y
+# CONFIG_INTEGRITY_CA_MACHINE_KEYRING is not set
+CONFIG_LOAD_UEFI_KEYS=y
+CONFIG_INTEGRITY_AUDIT=y
+# CONFIG_IMA is not set
# CONFIG_IMA_SECURE_AND_OR_TRUSTED_BOOT is not set
+# CONFIG_EVM is not set
# CONFIG_DEFAULT_SECURITY_SELINUX is not set
# CONFIG_DEFAULT_SECURITY_SMACK is not set
# CONFIG_DEFAULT_SECURITY_TOMOYO is not set
# CONFIG_DEFAULT_SECURITY_APPARMOR is not set
CONFIG_DEFAULT_SECURITY_DAC=y
-CONFIG_LSM="lockdown,yama,bpf"
+CONFIG_LSM="landlock,lockdown,yama,integrity,bpf"
# Kernel hardening options
@@ -10919,9 +10815,9 @@
CONFIG_CC_HAS_AUTO_VAR_INIT_PATTERN=y
CONFIG_CC_HAS_AUTO_VAR_INIT_ZERO_BARE=y
CONFIG_CC_HAS_AUTO_VAR_INIT_ZERO=y
-CONFIG_INIT_STACK_NONE=y
+# CONFIG_INIT_STACK_NONE is not set
# CONFIG_INIT_STACK_ALL_PATTERN is not set
-# CONFIG_INIT_STACK_ALL_ZERO is not set
+CONFIG_INIT_STACK_ALL_ZERO=y
# CONFIG_GCC_PLUGIN_STACKLEAK is not set
CONFIG_INIT_ON_ALLOC_DEFAULT_ON=y
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
@@ -10932,7 +10828,7 @@
# Hardening of kernel data structures
-# CONFIG_LIST_HARDENED is not set
+CONFIG_LIST_HARDENED=y
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# end of Hardening of kernel data structures
@@ -10974,11 +10870,11 @@
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
-CONFIG_CRYPTO_NULL=y
-CONFIG_CRYPTO_NULL2=y
+CONFIG_CRYPTO_NULL=m
+CONFIG_CRYPTO_NULL2=m
CONFIG_CRYPTO_PCRYPT=m
CONFIG_CRYPTO_CRYPTD=m
-CONFIG_CRYPTO_AUTHENC=y
+CONFIG_CRYPTO_AUTHENC=m
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_SIMD=m
CONFIG_CRYPTO_ENGINE=m
@@ -11003,7 +10899,6 @@
CONFIG_CRYPTO_AES=y
CONFIG_CRYPTO_AES_TI=m
-CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_ARIA=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_BLOWFISH_COMMON=m
@@ -11013,12 +10908,9 @@
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_FCRYPT=m
-CONFIG_CRYPTO_KHAZAD=m
-CONFIG_CRYPTO_SEED=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_SM4=m
CONFIG_CRYPTO_SM4_GENERIC=m
-CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_TWOFISH_COMMON=m
# end of Block ciphers
@@ -11027,12 +10919,11 @@
# Length-preserving ciphers and modes
CONFIG_CRYPTO_ADIANTUM=m
-CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_CHACHA20=m
-CONFIG_CRYPTO_CBC=y
-CONFIG_CRYPTO_CFB=y
+CONFIG_CRYPTO_CBC=m
+CONFIG_CRYPTO_CFB=m
CONFIG_CRYPTO_CTR=y
-CONFIG_CRYPTO_CTS=y
+CONFIG_CRYPTO_CTS=m
CONFIG_CRYPTO_ECB=y
CONFIG_CRYPTO_HCTR2=m
CONFIG_CRYPTO_KEYWRAP=m
@@ -11040,7 +10931,7 @@
CONFIG_CRYPTO_OFB=m
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_XCTR=m
-CONFIG_CRYPTO_XTS=y
+CONFIG_CRYPTO_XTS=m
CONFIG_CRYPTO_NHPOLY1305=m
# end of Length-preserving ciphers and modes
@@ -11050,9 +10941,9 @@
CONFIG_CRYPTO_AEGIS128=m
CONFIG_CRYPTO_CHACHA20POLY1305=m
CONFIG_CRYPTO_CCM=m
-CONFIG_CRYPTO_GCM=y
-CONFIG_CRYPTO_GENIV=y
-CONFIG_CRYPTO_SEQIV=y
+CONFIG_CRYPTO_GCM=m
+CONFIG_CRYPTO_GENIV=m
+CONFIG_CRYPTO_SEQIV=m
CONFIG_CRYPTO_ECHAINIV=m
CONFIG_CRYPTO_ESSIV=m
# end of AEAD (authenticated encryption with associated data) ciphers
@@ -11062,7 +10953,7 @@
CONFIG_CRYPTO_BLAKE2B=m
CONFIG_CRYPTO_CMAC=m
-CONFIG_CRYPTO_GHASH=y
+CONFIG_CRYPTO_GHASH=m
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=y
@@ -11095,11 +10986,11 @@
# Compression
-CONFIG_CRYPTO_DEFLATE=y
-CONFIG_CRYPTO_LZO=y
-CONFIG_CRYPTO_842=y
-CONFIG_CRYPTO_LZ4=y
-CONFIG_CRYPTO_LZ4HC=y
+CONFIG_CRYPTO_DEFLATE=m
+CONFIG_CRYPTO_LZO=m
+CONFIG_CRYPTO_842=m
+CONFIG_CRYPTO_LZ4=m
+CONFIG_CRYPTO_LZ4HC=m
CONFIG_CRYPTO_ZSTD=y
# end of Compression
@@ -11128,8 +11019,8 @@
CONFIG_CRYPTO_USER_API_RNG=m
# CONFIG_CRYPTO_USER_API_RNG_CAVP is not set
CONFIG_CRYPTO_USER_API_AEAD=m
-CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y
-# CONFIG_CRYPTO_STATS is not set
+# CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE is not set
+CONFIG_CRYPTO_STATS=y
# end of Userspace interface
CONFIG_CRYPTO_HASH_INFO=y
@@ -11186,7 +11077,7 @@
CONFIG_CRYPTO_DEV_SP_CCP=y
CONFIG_CRYPTO_DEV_CCP_CRYPTO=m
CONFIG_CRYPTO_DEV_SP_PSP=y
-# CONFIG_CRYPTO_DEV_CCP_DEBUGFS is not set
+CONFIG_CRYPTO_DEV_CCP_DEBUGFS=y
CONFIG_CRYPTO_DEV_NITROX=m
CONFIG_CRYPTO_DEV_NITROX_CNN55XX=m
CONFIG_CRYPTO_DEV_QAT=m
@@ -11201,7 +11092,7 @@
CONFIG_CRYPTO_DEV_VIRTIO=m
CONFIG_CRYPTO_DEV_SAFEXCEL=m
CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m
-# CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG is not set
+CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG=y
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
@@ -11214,6 +11105,9 @@
# Certificates for signature checking
+CONFIG_MODULE_SIG_KEY="certs/signing_key.pem"
+# CONFIG_MODULE_SIG_KEY_TYPE_RSA is not set
+CONFIG_MODULE_SIG_KEY_TYPE_ECDSA=y
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
@@ -11221,7 +11115,8 @@
# CONFIG_SECONDARY_TRUSTED_KEYRING_SIGNED_BY_BUILTIN is not set
CONFIG_SYSTEM_BLACKLIST_KEYRING=y
CONFIG_SYSTEM_BLACKLIST_HASH_LIST=""
-# CONFIG_SYSTEM_REVOCATION_LIST is not set
+CONFIG_SYSTEM_REVOCATION_LIST=y
+CONFIG_SYSTEM_REVOCATION_KEYS=""
CONFIG_SYSTEM_BLACKLIST_AUTH_UPDATE=y
# end of Certificates for signature checking
@@ -11253,7 +11148,7 @@
CONFIG_CRYPTO_LIB_UTILS=y
CONFIG_CRYPTO_LIB_AES=y
CONFIG_CRYPTO_LIB_ARC4=m
-CONFIG_CRYPTO_LIB_GF128MUL=y
+CONFIG_CRYPTO_LIB_GF128MUL=m
CONFIG_CRYPTO_ARCH_HAVE_LIB_BLAKE2S=y
CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y
CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m
@@ -11290,14 +11185,14 @@
CONFIG_CRC8=m
CONFIG_XXHASH=y
# CONFIG_RANDOM32_SELFTEST is not set
-CONFIG_842_COMPRESS=y
-CONFIG_842_DECOMPRESS=y
+CONFIG_842_COMPRESS=m
+CONFIG_842_DECOMPRESS=m
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
-CONFIG_LZ4_COMPRESS=y
-CONFIG_LZ4HC_COMPRESS=y
+CONFIG_LZ4_COMPRESS=m
+CONFIG_LZ4HC_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMMON=y
CONFIG_ZSTD_COMPRESS=y
@@ -11322,7 +11217,6 @@
CONFIG_REED_SOLOMON=m
CONFIG_REED_SOLOMON_ENC8=y
CONFIG_REED_SOLOMON_DEC8=y
-CONFIG_REED_SOLOMON_DEC16=y
CONFIG_BCH=m
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
@@ -11345,9 +11239,10 @@
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_ARCH_HAS_FORCE_DMA_UNENCRYPTED=y
CONFIG_SWIOTLB=y
-CONFIG_SWIOTLB_DYNAMIC=y
+# CONFIG_SWIOTLB_DYNAMIC is not set
CONFIG_DMA_COHERENT_POOL=y
CONFIG_DMA_CMA=y
+# CONFIG_DMA_NUMA_CMA is not set
# Default contiguous memory area size:
@@ -11371,6 +11266,7 @@
CONFIG_CLZ_TAB=y
CONFIG_IRQ_POLL=y
CONFIG_MPILIB=y
+CONFIG_SIGNATURE=y
CONFIG_DIMLIB=y
CONFIG_OID_REGISTRY=y
CONFIG_UCS2_STRING=y
@@ -11378,9 +11274,20 @@
CONFIG_GENERIC_GETTIMEOFDAY=y
CONFIG_GENERIC_VDSO_TIME_NS=y
CONFIG_FONT_SUPPORT=y
-# CONFIG_FONTS is not set
-CONFIG_FONT_8x8=y
+CONFIG_FONTS=y
+# CONFIG_FONT_8x8 is not set
CONFIG_FONT_8x16=y
+# CONFIG_FONT_6x11 is not set
+# CONFIG_FONT_7x14 is not set
+# CONFIG_FONT_PEARL_8x8 is not set
+# CONFIG_FONT_ACORN_8x8 is not set
+# CONFIG_FONT_MINI_4x6 is not set
+# CONFIG_FONT_6x10 is not set
+# CONFIG_FONT_10x18 is not set
+# CONFIG_FONT_SUN8x16 is not set
+# CONFIG_FONT_SUN12x22 is not set
+CONFIG_FONT_TER16x32=y
+# CONFIG_FONT_6x8 is not set
CONFIG_SG_POOL=y
CONFIG_ARCH_HAS_PMEM_API=y
CONFIG_MEMREGION=y
@@ -11407,15 +11314,15 @@
# printk and dmesg options
-# CONFIG_PRINTK_TIME is not set
+CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
-# CONFIG_STACKTRACE_BUILD_ID is not set
-CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
+CONFIG_STACKTRACE_BUILD_ID=y
+CONFIG_CONSOLE_LOGLEVEL_DEFAULT=4
CONFIG_CONSOLE_LOGLEVEL_QUIET=1
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
-# CONFIG_BOOT_PRINTK_DELAY is not set
-# CONFIG_DYNAMIC_DEBUG is not set
-# CONFIG_DYNAMIC_DEBUG_CORE is not set
+CONFIG_BOOT_PRINTK_DELAY=y
+CONFIG_DYNAMIC_DEBUG=y
+CONFIG_DYNAMIC_DEBUG_CORE=y
CONFIG_SYMBOLIC_ERRNAME=y
CONFIG_DEBUG_BUGVERBOSE=y
# end of printk and dmesg options
@@ -11457,9 +11364,9 @@
# Generic Kernel Debugging Instruments
CONFIG_MAGIC_SYSRQ=y
-CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
+CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x0
CONFIG_MAGIC_SYSRQ_SERIAL=y
-CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE="m"
+CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE=""
CONFIG_DEBUG_FS=y
CONFIG_DEBUG_FS_ALLOW_ALL=y
# CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
@@ -11490,20 +11397,21 @@
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_TABLE_CHECK is not set
-# CONFIG_PAGE_POISONING is not set
+CONFIG_PAGE_POISONING=y
# CONFIG_DEBUG_PAGE_REF is not set
-# CONFIG_DEBUG_RODATA_TEST is not set
+CONFIG_DEBUG_RODATA_TEST=y
CONFIG_ARCH_HAS_DEBUG_WX=y
-# CONFIG_DEBUG_WX is not set
+CONFIG_DEBUG_WX=y
CONFIG_GENERIC_PTDUMP=y
+CONFIG_PTDUMP_CORE=y
# CONFIG_PTDUMP_DEBUGFS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_PER_VMA_LOCK_STATS is not set
# CONFIG_DEBUG_OBJECTS is not set
-# CONFIG_SHRINKER_DEBUG is not set
+CONFIG_SHRINKER_DEBUG=y
# CONFIG_DEBUG_STACK_USAGE is not set
-# CONFIG_SCHED_STACK_END_CHECK is not set
+CONFIG_SCHED_STACK_END_CHECK=y
CONFIG_ARCH_HAS_DEBUG_VM_PGTABLE=y
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_VM_PGTABLE is not set
@@ -11519,11 +11427,15 @@
CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
# CONFIG_KASAN is not set
CONFIG_HAVE_ARCH_KFENCE=y
-# CONFIG_KFENCE is not set
+CONFIG_KFENCE=y
+CONFIG_KFENCE_SAMPLE_INTERVAL=100
+CONFIG_KFENCE_NUM_OBJECTS=255
+CONFIG_KFENCE_DEFERRABLE=y
+CONFIG_KFENCE_STRESS_TEST_FAULTS=0
CONFIG_HAVE_ARCH_KMSAN=y
# end of Memory Debugging
-# CONFIG_DEBUG_SHIRQ is not set
+CONFIG_DEBUG_SHIRQ=y
# Debug Oops, Lockups and Hangs
@@ -11531,22 +11443,32 @@
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
-# CONFIG_SOFTLOCKUP_DETECTOR is not set
+CONFIG_LOCKUP_DETECTOR=y
+CONFIG_SOFTLOCKUP_DETECTOR=y
+# CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set
CONFIG_HAVE_HARDLOCKUP_DETECTOR_BUDDY=y
-# CONFIG_HARDLOCKUP_DETECTOR is not set
+CONFIG_HARDLOCKUP_DETECTOR=y
+# CONFIG_HARDLOCKUP_DETECTOR_PREFER_BUDDY is not set
+CONFIG_HARDLOCKUP_DETECTOR_PERF=y
+# CONFIG_HARDLOCKUP_DETECTOR_BUDDY is not set
+# CONFIG_HARDLOCKUP_DETECTOR_ARCH is not set
+CONFIG_HARDLOCKUP_DETECTOR_COUNTS_HRTIMER=y
CONFIG_HARDLOCKUP_CHECK_TIMESTAMP=y
-# CONFIG_DETECT_HUNG_TASK is not set
+# CONFIG_BOOTPARAM_HARDLOCKUP_PANIC is not set
+CONFIG_DETECT_HUNG_TASK=y
+CONFIG_DEFAULT_HUNG_TASK_TIMEOUT=120
+# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
# CONFIG_WQ_WATCHDOG is not set
-CONFIG_WQ_CPU_INTENSIVE_REPORT=y
+# CONFIG_WQ_CPU_INTENSIVE_REPORT is not set
# CONFIG_TEST_LOCKUP is not set
# end of Debug Oops, Lockups and Hangs
# Scheduler Debugging
-# CONFIG_SCHED_DEBUG is not set
+CONFIG_SCHED_DEBUG=y
CONFIG_SCHED_INFO=y
-# CONFIG_SCHEDSTATS is not set
+CONFIG_SCHEDSTATS=y
# end of Scheduler Debugging
# CONFIG_DEBUG_TIMEKEEPING is not set
@@ -11572,7 +11494,7 @@
# CONFIG_CSD_LOCK_WAIT_DEBUG is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
-CONFIG_NMI_CHECK_CPU=y
+# CONFIG_NMI_CHECK_CPU is not set
# CONFIG_DEBUG_IRQFLAGS is not set
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
@@ -11581,7 +11503,7 @@
# Debug kernel data structures
-# CONFIG_DEBUG_LIST is not set
+CONFIG_DEBUG_LIST=y
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
@@ -11596,7 +11518,7 @@
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_REF_SCALE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=60
-CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=20
+CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0
# CONFIG_RCU_CPU_STALL_CPUTIME is not set
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
@@ -11604,7 +11526,7 @@
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
-# CONFIG_LATENCYTOP is not set
+CONFIG_LATENCYTOP=y
# CONFIG_DEBUG_CGROUP_REF is not set
CONFIG_USER_STACKTRACE_SUPPORT=y
CONFIG_NOP_TRACER=y
@@ -11635,45 +11557,45 @@
CONFIG_GENERIC_TRACER=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
-# CONFIG_BOOTTIME_TRACING is not set
+CONFIG_BOOTTIME_TRACING=y
CONFIG_FUNCTION_TRACER=y
CONFIG_FUNCTION_GRAPH_TRACER=y
-# CONFIG_FUNCTION_GRAPH_RETVAL is not set
+CONFIG_FUNCTION_GRAPH_RETVAL=y
CONFIG_DYNAMIC_FTRACE=y
CONFIG_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_DYNAMIC_FTRACE_WITH_DIRECT_CALLS=y
CONFIG_DYNAMIC_FTRACE_WITH_ARGS=y
CONFIG_FPROBE=y
-# CONFIG_FUNCTION_PROFILER is not set
-# CONFIG_STACK_TRACER is not set
+CONFIG_FUNCTION_PROFILER=y
+CONFIG_STACK_TRACER=y
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_PREEMPT_TRACER is not set
-# CONFIG_SCHED_TRACER is not set
-# CONFIG_HWLAT_TRACER is not set
-# CONFIG_OSNOISE_TRACER is not set
-# CONFIG_TIMERLAT_TRACER is not set
-# CONFIG_MMIOTRACE is not set
-# CONFIG_FTRACE_SYSCALLS is not set
+CONFIG_SCHED_TRACER=y
+CONFIG_HWLAT_TRACER=y
+CONFIG_OSNOISE_TRACER=y
+CONFIG_TIMERLAT_TRACER=y
+CONFIG_MMIOTRACE=y
+CONFIG_FTRACE_SYSCALLS=y
CONFIG_TRACER_SNAPSHOT=y
# CONFIG_TRACER_SNAPSHOT_PER_CPU_SWAP is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
-# CONFIG_PROFILE_ALL_BRANCHES is not set
CONFIG_BLK_DEV_IO_TRACE=y
-# CONFIG_FPROBE_EVENTS is not set
+CONFIG_FPROBE_EVENTS=y
CONFIG_PROBE_EVENTS_BTF_ARGS=y
CONFIG_KPROBE_EVENTS=y
# CONFIG_KPROBE_EVENTS_ON_NOTRACE is not set
-# CONFIG_UPROBE_EVENTS is not set
+CONFIG_UPROBE_EVENTS=y
CONFIG_BPF_EVENTS=y
CONFIG_DYNAMIC_EVENTS=y
CONFIG_PROBE_EVENTS=y
-# CONFIG_BPF_KPROBE_OVERRIDE is not set
+CONFIG_BPF_KPROBE_OVERRIDE=y
CONFIG_FTRACE_MCOUNT_RECORD=y
CONFIG_FTRACE_MCOUNT_USE_CC=y
-# CONFIG_SYNTH_EVENTS is not set
-# CONFIG_USER_EVENTS is not set
-# CONFIG_HIST_TRIGGERS is not set
+CONFIG_TRACING_MAP=y
+CONFIG_SYNTH_EVENTS=y
+CONFIG_USER_EVENTS=y
+CONFIG_HIST_TRIGGERS=y
# CONFIG_TRACE_EVENT_INJECT is not set
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
@@ -11683,8 +11605,11 @@
# CONFIG_FTRACE_SORT_STARTUP_TEST is not set
# CONFIG_RING_BUFFER_STARTUP_TEST is not set
# CONFIG_RING_BUFFER_VALIDATE_TIME_DELTAS is not set
+# CONFIG_MMIOTRACE_TEST is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
-CONFIG_KPROBE_EVENT_GEN_TEST=m
+# CONFIG_SYNTH_EVENT_GEN_TEST is not set
+# CONFIG_KPROBE_EVENT_GEN_TEST is not set
+# CONFIG_HIST_TRIGGERS_DEBUG is not set
# CONFIG_RV is not set
# CONFIG_PROVIDE_OHCI1394_DMA_INIT is not set
# CONFIG_SAMPLES is not set
@@ -11697,19 +11622,20 @@
# x86 Debugging
+CONFIG_EARLY_PRINTK_USB=y
# CONFIG_X86_VERBOSE_BOOTUP is not set
CONFIG_EARLY_PRINTK=y
-# CONFIG_EARLY_PRINTK_DBGP is not set
-# CONFIG_EARLY_PRINTK_USB_XDBC is not set
+CONFIG_EARLY_PRINTK_DBGP=y
+CONFIG_EARLY_PRINTK_USB_XDBC=y
# CONFIG_EFI_PGT_DUMP is not set
# CONFIG_DEBUG_TLBFLUSH is not set
CONFIG_HAVE_MMIOTRACE_SUPPORT=y
-# CONFIG_X86_DECODER_SELFTEST is not set
+CONFIG_X86_DECODER_SELFTEST=y
CONFIG_IO_DELAY_0X80=y
# CONFIG_IO_DELAY_0XED is not set
# CONFIG_IO_DELAY_UDELAY is not set
# CONFIG_IO_DELAY_NONE is not set
-# CONFIG_DEBUG_BOOT_PARAMS is not set
+CONFIG_DEBUG_BOOT_PARAMS=y
# CONFIG_CPA_DEBUG is not set
# CONFIG_DEBUG_ENTRY is not set
# CONFIG_DEBUG_NMI_SELFTEST is not set
@@ -11729,9 +11655,55 @@
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
-# CONFIG_RUNTIME_TESTING_MENU is not set
+CONFIG_RUNTIME_TESTING_MENU=y
+# CONFIG_TEST_DHRY is not set
+# CONFIG_LKDTM is not set
+# CONFIG_TEST_MIN_HEAP is not set
+# CONFIG_TEST_DIV64 is not set
+# CONFIG_BACKTRACE_SELF_TEST is not set
+# CONFIG_TEST_REF_TRACKER is not set
+# CONFIG_RBTREE_TEST is not set
+# CONFIG_REED_SOLOMON_TEST is not set
+# CONFIG_INTERVAL_TREE_TEST is not set
+# CONFIG_PERCPU_TEST is not set
+# CONFIG_ATOMIC64_SELFTEST is not set
+CONFIG_ASYNC_RAID6_TEST=m
+# CONFIG_TEST_HEXDUMP is not set
+# CONFIG_STRING_SELFTEST is not set
+# CONFIG_TEST_STRING_HELPERS is not set
+# CONFIG_TEST_KSTRTOX is not set
+# CONFIG_TEST_PRINTF is not set
+# CONFIG_TEST_SCANF is not set
+# CONFIG_TEST_BITMAP is not set
+# CONFIG_TEST_UUID is not set
+# CONFIG_TEST_XARRAY is not set
+# CONFIG_TEST_MAPLE_TREE is not set
+# CONFIG_TEST_RHASHTABLE is not set
+# CONFIG_TEST_IDA is not set
+# CONFIG_TEST_PARMAN is not set
+# CONFIG_TEST_LKM is not set
+# CONFIG_TEST_BITOPS is not set
+# CONFIG_TEST_VMALLOC is not set
+# CONFIG_TEST_USER_COPY is not set
+# CONFIG_TEST_BPF is not set
+# CONFIG_TEST_BLACKHOLE_DEV is not set
+# CONFIG_FIND_BIT_BENCHMARK is not set
+# CONFIG_TEST_FIRMWARE is not set
+# CONFIG_TEST_SYSCTL is not set
+# CONFIG_TEST_UDELAY is not set
+# CONFIG_TEST_STATIC_KEYS is not set
+# CONFIG_TEST_DYNAMIC_DEBUG is not set
+# CONFIG_TEST_KMOD is not set
+# CONFIG_TEST_MEMCAT_P is not set
+# CONFIG_TEST_OBJAGG is not set
+# CONFIG_TEST_MEMINIT is not set
+# CONFIG_TEST_HMM is not set
+# CONFIG_TEST_FREE_PAGES is not set
+# CONFIG_TEST_FPU is not set
+# CONFIG_TEST_CLOCKSOURCE_WATCHDOG is not set
+# CONFIG_TEST_OBJPOOL is not set
CONFIG_ARCH_USE_MEMTEST=y
-# CONFIG_MEMTEST is not set
+CONFIG_MEMTEST=y
# CONFIG_HYPERV_TESTING is not set
# end of Kernel Testing and Coverage
I guess next thing you could do is compile manjaro kernel with liquorix config and see if that changes anything.
I’m sorry, but this is beyond my technical knowledge. How can I do that?
git clone https://gitlab.manjaro.org/packages/core/linux67.git
And replace config with lqx one and build and install that
makepkg -rsi
linux-6.7.tar.gz ... Passed
config ... FAILED
0101-ZEN_Add_sysctl_and_CONFIG_to_disallow_unprivileged_CLONE_NEWUSER.patch ... Passed
0102-drivers-firmware-skip-simpledrm-if-nvidia-drm.modese.patch ... Passed
7c13cc521f78fd261de3001dac48fd572baae671.patch ... Passed
3a88b77d3cb9f9cd8a8aee052ab479b73aeb2e80.patch ... Passed
0999-patch_realtek.patch ... Passed
v14.7-0001-HID-asus-fix-more-n-key-report-descriptors-if-.patch ... Passed
v14.7-0002-HID-asus-make-asus_kbd_init-generic-remove-rog.patch ... Passed
v14.7-0003-HID-asus-add-ROG-Ally-N-Key-ID-and-keycodes.patch ... Passed
v14.7-0004-HID-asus-add-ROG-Ally-xpad-settings.patch ... Passed
0007-mt7921e_Perform_FLR_to_recovery_the_device.patch ... Passed
ROG-ALLY-NCT6775-PLATFORM.patch ... Passed
0001-iio-imu_Add_driver_for_BMI323_IMU.patch ... Passed
0002-iio-imu-bmi323-Make-the-local-structures-static.patch ... Passed
0003-iio-imu_Add_ROG_ALLY_bmi323-support.patch ... Passed
0004-iio-imu-Load_ROG_ALLY_mount_matrix.patch ... Passed
0005-iio-imu-ASUS-ROG-ALLY-force-INT1-IRQ.patch ... Passed
0001-HID.patch ... Passed
==> ERROR: One or more files did not pass the validity check!
==> Removing installed dependencies...
Right, before compiling you need to run
updpkgsums
After compiling Manjaro kernel 6.7.0-2 with the Liquorix kernel configuration file, it now works fine, the computer always shuts down and restarts completely. Then it is clear that it is one (or several) options in the configuration file that are making it work.
The question is how to find the change (or changes) that makes this work, there are many different lines between both configuration files, it seems like looking for a needle in a haystack…
Yep. Nothing stands out to me.
You can do kinda manual bisection of files; take only half of new config (and half of old) and test. If it works remove half of half of new config (and replace with old) and test, if it doesn’t, take the other half of new config and test, etc…
But this can take me days or even weeks, considering that on my computer it takes almost 4 hours to compile the kernel…
4 hours?!
Then you might want to install modprobed-db.
Then you need run modprobed-db store and edit PKGBUILD for linux67 in the following way:
replace
msg "rewrite configuration"
yes "" | make config >/dev/null
with
yes "" | make LSMOD=$HOME/.config/modprobed.db localmodconfig >/dev/null
Then you can build a kernel only with modules that are necessary for your PC, it should significantly reduce build time.
Hey Alden20, I just wanna say thank you for sharing the XanMod and Liquorix kernel info here… I installed linux-xanmod in my Arco system and Liquorix in Manjaro. Both systems can boot and shutdown without any issues using these kernels so thanks for that… it has saved me a lot of time as I no longer need to hop to other distros to achieve stability.
In a few months I will try out the Arch & Manjaro LTS kernels again to see if this boot/shutdown issue affecting my AMD 6900HX gets rectified in future updates.
I see that the message I posted a couple of days ago has disappeared and the forum has been unavailable, I imagine they must have restored a backup…
I was just saying in my previous message that I’m glad to have saved you time, chairman67, and above all that you can continue with an Arch Linux distribution.
When I can get some time I will look into bisecting the kernel to try to find the cause of the failure since I see that the error continues to occur in the Manjaro 6.8 kernel, which will be that of Arch Linux or inherited from it, so which will also fail in Arch. I’m sorry, but right now I have a lot of work and hardly any free time.
Today I checked the current version of the upstream Arch linux-lts 6.6.18 kernel and unfortunately there is no change. The shutdown issue still persists with the latest version. It is amazing how the current Arch kernels cause this issue to modern high end AMD APUs. As far as I am aware Arch Linux (with knock-on to Arch based distros) is the only kernel that causes this problem.
It is amazing how after a month and a half with all the info you need, no one has actually went and done the work of compiling kernel with different config parameters. I’m not gonna do it for you, my system works fine. I guess it’s easier to sit and complain.
Picking up were Alden20 left off, using the info here… comparing Liquorix 6.7.6 with Arch 6.7.6 using Meld the diffs are too extensive to discern what config parameter causes the shutdown issue.
Starting from scratch I ran same initial custom kernel test as Alden20, but working with the Arch kernel. Built a test Arch 6.7.7 kernel using the Liquorix config in it’s place, and confirm the system can shutdown/reboot without issue. Kernel compiling took 30 minutes.
Next step I will try zbe’s kernel config files 50-50 bisection method suggested on 1/22 (trial & error) to narrow down to what config parameter/s is causing this issue on our AMD systems, and see if I can figure it out.
You can try grepping “AMD” and check those, but no idea if anything useful shows.
After conducting shutdown/reboot tests from 60 kernel builds, I discovered the common CONFIG that causes my system’s instability.
Testing was done across 3 different kernel config pairs. Stable Liquorix-678 vs unstable linux-678, stable Xanmod-677 vs unstable linux-677 and stable linux-lts-61.71 vs unstable linux-lts-66.21.
There are two possible solutions to fix the issue. A user based solution and/or an Arch global fix. The user solution is derived from the Liquorix kernel. They’ve included a kernel boot parameter rcupdate.rcu_expedited=1. When this parameter is added to my grub config line GRUB_CMDLINE_LINUX_DEFAULT=“” my system can run stable using the latest packaged linux-6.7.8 kernel.
The image below is Meld, comparing linux67 on the left and Liquorix67 on the right showing the kernel boot parameter that makes shutdown/reboot become stable.
The actual config that is causing the instability is.
7946 # HID-BPF support
7947 #
7948 CONFIG_HID_BPF=y
7949 # end of HID-BPF support
CONFIG_HID_BPF=y was introduced in linux-lts-66 and linux-67. When this config is removed from the compiled kernel my system becomes stable.
Xanmod-67 is a little different. HID-BPF support & CONFIG_HID_BPF=y are included, but it has ># CONFIG_FTRACE is not set< under RCU Debugging. When CONFIG_FTRACE=y & CONFIG_DYNAMIC_FTRACE=y are included my system becomes unstable.
Currently the user solution boot parameter derived from the Liquorix config is sufficient to resolve the instability issues.
My next step would be to possibly lodge a bug report to Arch’s Gitlab, and request for the possible removal of HID-BPF support & CONFIG_HID_BPF=y from the kernel’s config. This would ultimately solve our issue globally on all distros that use Arch kernels as their base.
Great work. One thing though:
Manjaro compiles its own kernels, so you have to file bug reports to manjaro’s gitlab.
that means you have rcu stalls
https://www.kernel.org/doc/html/v5.9/RCU/stallwarn.html
it may comes from eeVDF scheduler
